DIY DILETANT
Lokacija: Čistilište
Postovi: 3,457
ATX 2.x matična na ATX 1.x napajanje
Pitam se da li bi Enermaxovo napajanje iz P4@2.8 dana radilo s ovim modernim ATX 2.0 matičnim pločama, naravno pod uvjetom da ukupni power draw ne bude veći od cca. 100 W (neki Celeron s integriranom grafikom)? Da li mi uopće treba 20 na 24 pin adapter? Hvala na odgovoru. |
Postovi: 33,916
Teoretski bi radilo i bez adaptera. Dok ne probaš, ne možeš znati. Glavno da ima 4pin EPS za procesor.
#3 | |
DIY DILETANT
Postovi: 3,457
U ovu novu kantu nebi išla diskretna grafa pa se pitam jel uopće nužno upiknut taj 4-pinac? Zadnje izmijenjeno od: kopija. 09.01.2014. u 14:23. |
Postovi: 913
radit će |
tiki
Postovi: 2,721
Ne. Na 20 pinski su dodana ta 4 pina koja osiguravaju struju pci-e portu. 4 pinski EPS (2 žute i 2 crne žice, zaseban konektor na matičnoj) osiguravaju struju procesoru. |
Datum registracije: Dec 2010
Postovi: 13
The mainboard supports ATX power supply for the power system. Before inserting the power supply connector, always make sure that all components are installed properly to ensure that no damage will be caused. PIN SIGNAL 13 +3.3V 14 -12V 15 GND 16 PS-ON# 17 GND 18 GND 19 GND 20 Res 21 +5V 22 +5V 23 +5V 24 GND PIN SIGNAL 1 +3.3V 2 +3.3V 3 GND 4 +5V 5 GND 6 +5V 7 GND 8 PWR OK 9 5VSB 10 +12V 11 +12V 12 NC Pin Definition ATX 24-Pin Power Connector: ATX1 This connector allows you to connect an SSI power supply. To connect the SSI power supply, make sure the plug of the power supply is inserted in the proper orientation and the pins are aligned. Then push down the power supply firmly into the connector. You may use the 20-pin ATX power supply or 24-pin SSI power supply as you like. If you’d like to use the ATX power supply, please plug your power supply along with pin 1 & pin 13 (refer to the image at the right hand). There is also a foolproof design on pin 11, 12, 23 & 24 to avoid wrong installation. sastavljao sam komfu s maticnom MSI k8 neo4, i neradi, sve vrti nema slike, pa me buni ovo oko napajanja kad stavim napajanje s 24 pinskom uticnicom u maticnu ono drugo 4 pinsko sto bi trebalo napajati cpu neide unutra, nece da sjedne ,, ako stavim 20 pinsko onda na tom napajanju ide to 4 pinsko za cpu (dvije zute i dvije crne), ali komp neradi,, probao sam mjenjati komponente i nista,, ispraznio bios i opet nista jednostavno komp radi al nema slike, mijenjao grafe (rade na drugom ovdje nemaju slike,, vrti hlađenje grafe),, ispirio sam utore za grafu ,, opet nista,, isto napravio s ramom i nema efekta,, pa na kraju sam pomislio da je mozda to napajanje,, al vraga probao i drugo i opet nista,, a radi na drugom kompu,, jedino me buni sto kad ga spojim na struju odmah zavrti , pospajao sam sve swicheve po manualu, rade normalno al prvo pokretanje odmah krene bez obzira sto nisam stisnuo power,, dakako najveci je problem sto nema slike na monitoru! |
Postovi: 23,484
1 - popravi gornji post, izgeda zbrčkano a i znamo kako izgleda 24-pin atx konektor 2 - vidim da si "svašta nešto" radio pa se nadaj da nisi sredio matičnu 3 - uštekaj u matičnu 20+4 pin konektor 4 - vjerojatno miješaš konektore, slično izgledaju ali im je oblik drugačiji, nisi naveo koje napajanje imaš, možda na njemu imaš EPS 8-pin umjesto starog ATX 4-pin, EPS 8-pin sasvim fino sjedne u 4-pin na mobo na način da 4 pina ostanu u zraku, dobro gledaj oblik "pin" - ova 5 - moraš dovesti napajanje na 4-pin na mobo inaće cpu neće raditi https://www.google.com/search?q=pc+c...%3B1280%3B1813 |
