#721 |
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
meni je ipak bio problem u ud monitoru, zajebo mi je par resulta... zato ga sad koristim samo kad mjenjam cache slotove (kad mi je jedan poso gotov prebacim na drugi)... Slanje resultata ostavljam gridu....
#722 |
matroxfanatic
Lokacija: Zagreb, na zapadu
Postovi: 2,444
grid.org official communication 7/22/2005: http://forum.grid.org/phpBB/viewtopic.php?t=17442 "We would like to thank all of our members for their continued patience over the last couple of days while our servers have been offline for maintenance. At this point, our grid servers should now be operational and distributing workunits again. Unfortunately, there are some complications that all members will want to be aware of: - If your UD Agent displays a login prompt and asks you to enter your password again, please select the checkbox indicating that you are an existing user, and then re-enter your old password. (If you have forgotten your password, you can try the password-recovery facility at https://www.grid.org/services/login/recover_login.htm, or worst case re-create a new user account.) Once you do this procedure, your Agent should download a new workunit and begin working again. - The "Total Points" and "Total CPU Time" values displayed by the UD Agent may be temporarily desynchronized (slightly lower) than the values displayed on the Member Web pages at https://www.grid.org/services/. We will be working to resynchronize these values, and we expect all point and cpu time totals to be properly reflected as soon as possible. Thanks again for your continued support!"
Holly: "Appreciate what vou've got, because basically, I'm fantastic!"
#724 |
Datum registracije: May 2005
Lokacija: Ankum
Postovi: 161
lool nekuzim, posaljem obradjeno i za uzvrat dobim k...... i jos mi oduzme 1 bod, niti vrijeme rada proc ne pribroji... : finger : ode 96 sati u vjetar...: finger : |
#725 |
Lokacija: Agram
Postovi: 2,983
ne znam ja .. ja sam uredno odaslal i primio nove pakete i uknjižio nove tisućice jedino me tražio da se ponovo ulogiram i to je bilo sve od neuobičajenog ... meni sve 5. Možda taj UD manager malo prca ... mislim ja sam bahato 0-24 on line dok je Fleta pa ne koristim to pa nemam niti dobri niti loših iskustava ...
#726 |
Lokacija: Agram
Postovi: 2,983
hm ... prvo čitaj a onda s*ri ... uglavnom imam oko 500 sati propalog rada ... 3 paketa nisu donjela ništa ... dva od 150 sati na dal AMDu i jedan sa jednog PIII-S ... a niš ... i ovak bi procevi zujali u prazno ovako su zujali korisno 2 godine i neš tako da tih 20 dana CPU vremena su kap u moru ...
#730 | |
Magister Mundi sum!
Datum registracije: Jun 2003
Lokacija: Zagorje
Postovi: 2,335
#731 |
AutoCad & Allplan expert
Postovi: 2,159
moral sam se re registrirat, napravil sam to sa starim imenom passeordom i pocel je obradjivat novi paket... ALI imam 0 bodova, 0 vremena, 0 paketa????? nis mi ni jasno.... sam ja sad to pocel iz pocetka s novim istim imenom koje sam i imal??? jer na listi jos uvjek pise da sam umirovljen.... sve u quratz.. ![]() edit: cini mi ce da mi je novi nick Vogler?????
none |
#737 | |
Kompjuterov frend
Postovi: 326
Bolje je šutjeti i pustiti da te smatraju budalom, nego progovoriti i otkloniti svaku sumnju. A. Lincoln |
#740 |
bycod
Lokacija: Zagreb / Dubrava
Postovi: 6,699
JA sam se umirovio nakon sto je poceo grid srati previse,...... I da onaj ud agent nevalja kurcu popusio sam 5 rezultata.... ili ti oko 60sati . Tako da mi se neda razmisljati o tome vise dao sam 24k bodova dosta im.
#741 |
Kompjuterov frend
Postovi: 326
Ljudi jeste mogli jučer i jel možete danas posla rezultate meni uporno neče
#742 |
matroxfanatic
Postovi: 2,444
grid.org official communication 8/05/2005 (re: Team Stats): "Dear members, We forgot to mention that we continue to work diligently at repairing the Team Stats figures. The problem appears to be related to a corrupted table, which just so happens to host the team statistics; the data is ok - it's just the table that seems to be problematic. To fix, we are going through a process of 1) exporting all team stats data from the corrupted table, 2) recreating a new team stats table, 3) importing team stats data back into new table. The explanation above sounds rather simplistic, but it's very intensive due to the enormity of the data contained in this table. Just the exercise of moving the data around via the export/import is very time consuming - so we beg for your continued patience. Thank you very much. Kindest regards, grid.org team" grid.org official communication 8/05/2005: "Dear members, Thanks for being so patient. Below is a current update on grid.org: A new LigandFit Pancreatic Cancer job is still pending new data from our European partner. In the meantime, the grid.org team will be performing some LigandFit post-processing script improvements on our LigandFit grid infrastructure in order to prepare for the new Cancer project data soon to arrive from our European partner. As a result, the old LigandFit Cancer job that is currently running will be suspended briefly in order for our team to make the necessary preparations offline. The Rosetta Human Proteome Folding batches of jobs on grid.org continue to run well, and results are being post-processed nicely. Thanks for contributing your compute time. Kindest Regards, grid.org team"
#743 |
Džabe si krečio!
Postovi: 5,191
Ma ja više ne znam. Sad sam došo s mora i upalio komp, grid se restarto, izbacio me iz tima, imam 0 bodova, i iskreno uopće mi se neda sa tim opet zajebavat. Pitaj boga kaj oni rade sa tim svime... |
#744 | |
matroxfanatic
Postovi: 2,444
Istina je da si bas poceo kada je grid.org imao poprilicne probleme (i jos sredjuju dio njih), ali i to ce se srediti. Budi malo uporniji, ponovno registriraj svog klijenta, i vrti ga makar kao screensaver. I sam sam odustajao u dva navrata od svega ovoga, tako da imam barem dvije rupe od 3 i vise mjeseci neaktivnosti, ali ipak sam odlucio i dalje sudjelovati u svemu ovome. Tako sam sada na 30-tak dana o 6 godina doniranog procesorskog vremena.
#745 |
Datum registracije: Feb 2004
Postovi: 1,309
stvar je u tome sto cijeli projekt ocito ide u khm....... stalni kvarovi hardwarea nemogucnost updatea i tako mjesec dana ili vise....... bas me zanima sto se dogodilo s svim rezultatima koje smo vec obradili ako nemogu dignut obicnu tablicu s clanovima i updejtat jednom u par dana tamo se ocito nista ne radi, iz kojeg razloga neznam ali za mjesec dana se nisu pomakli s mjesta navodno zbog kvara hardwrea i recoverija podataka, da imaju 10 zaposlenih vec bi to 15 puta napravili |
#746 |
matroxfanatic
Postovi: 2,444
@ Chuby: vidi se da nikada nisi radio sa serverima. Meni se cini da nisu imali kvalitetan backup, jer njih ne muci HW problem (to, uostalom, niti nije problem), vec to da su imali graske u bazi koje su se vremenom multiplicirale, a kako ih ne mogu ispraviti/eliminirati, morali su vratjati backup. I tek su im tada krenuli problemi, jer, ako malo bacimo pogled na zadnja 3-4 mjeseca, problemi su bili sve veci i veci, a kulminiralo je prije dva-tri tjedna, kada se sve raspalo do kraja. Kako nisu imali potpuni (ili uopce ispravni) backup, izgleda da su morali odredjene djelove baze kreirati iz nule (od tuda ono da smo morali nanovo registrirati svoje grid.org klijente). Od tada rade na tome da im statistike prorade, a usred svega toga im je dosao novi paket zadataka za Cancer Research. I iza cijelog grid.org projekta stoji odredjena grupica (ili grupa, ili grupetina,...) ljudi, a oni (kao i mi) su od krvi i mesa, i ne mogu rijesavati probleme brze nego jedan po jedan.
#747 |
Postovi: 4,193
Tek sam sad zavirio u ovu temu na pc ekspertovom forumu...i vidio da se radi o nečemu zanimljivom i korisnom, a neda mi se čitat 70-tak stranica pa vas molim da mi opišete to u 1-2 posta....please |
#748 |
Lokacija: Agram
Postovi: 2,983
baze podataka su osjetljiva stvar i to će ti reći svaki i najmanji knjigovodstveni servis i u bana republici ili ti ovdje. Sav hardware je totalno nebitan u poslu, podaci su ono šo važi i vrijedi, tako je svakoj firmi i korporaciji ... ako se ne sjećate 1st National Bank of USA (mislim da je ona) je nedavno IZGUBILA !!! podatke o 1.000.000 tekućih računa i još nisu sve sanirali do kraja (prošlo već mislim i mjesec dana) a ako oni nemaju ljdskih resursa nema niko, para valjda imaju pa jesu ili nisu banka A ovi isto to rade za nekoliko milijuna korisnika samo ne za pare već za bodove ...
#749 |
Postovi: 4,193
malo sam čitao...izgleda zanimljivo, ako se koristi u dobrotvorne svrhe naravno....nebih htio davati procesorsku snagu u neki weapon of mass destruction nikako. Je radi taj grid.org uopće?:confused: dali da malo mučim svog (pra) starog celerona pomaganjem za dobrotvorne svrhe? je registration free? |
#750 |
Lokacija: Agram
Postovi: 2,983
je registracija je free, da naravno da ga treba tlačiti Meni radi sve bez greške ...
