#4921 | |
Does youer dewg byte?
Postovi: 1,941
" Have you tried turning it off and on again ? Are you sure it is plugged in ? " ![]() |
#4922 | |
Datum registracije: Apr 2003
Lokacija: RI
Postovi: 4,911
Lorraine 40T AMX 50-100 Hit points 1,550 1,400 Weight 37.95 50.43 Engine 980 850 Speed Limit 60 51 Traverse 30 32 Armor (f/s/r) 40/40/25 90/35/30 Turret (f/s/r) 45/30/20 90/30/30 Turret Traverse 38 32 View Range 400 380 Signal Range 400 750 RoF 5.66-7.4 Average Pen- 232 Average Damage 300 Accuracy 0.36 Aim Time 2.7-3
#4923 |
Postovi: 1,941
http://wotreplays.com/site/506539#re...-t28_prototype Ok, T28p fakat ponekad može podnijeti svašta. ![]() Da mi je bio još samo jedan tenk uz T29 da izvuku ove iza zgrade, pobijedili bi. A fakat nemam pojma kaj su radili ovi na istočnom krilu osim umirali.
#4924 |
Lokacija: Slav. Brod
Postovi: 491
X:: Maus, E-100, T110E5, T57 Heavy Tank, 113, AMX50B, IS4, E-50M, Leopard 1, M48 Patton, 121, G.W. E 100, T92, Obj. 261, JagdPz E-100, WT auf E100, T110E4, T110E3, IX::IS8 VIII:: Lorr. 155 51, AC Mle 48 PREM:IS6, T34, T26E4, Pz. IV Schmalturm, T-25, Ram II, T14, Matilda BP, 105 leFH18B2, Chi-Nu Kai, T15, T2 LT, T1E6, Tetrarac, LTP, T7 Combat Car, Light MK. VIC, Type 97 Te Ke |
#4925 |
Lokacija: RI
Postovi: 4,911
Još jedan MEGA lol s Churchill III ![]() Victory! Map: Mountain Pass 29.12.2013. 16:15:47 Vehicle: Churchill III Exp: 6.378 (x2) Credits: 79.023 Battle Achievements: Top Gun, Steel Wall, Invader, Radley-Walters's Medal http://wotreplays.com/site/506661#mo...bred-churchill ![]() ![]()
![]() Zadnje izmijenjeno od: Thoroughbred B. 29.12.2013. u 16:35. |
#4928 |
Lokacija: Daruvar
Postovi: 1,743
Skoro pobjeda propadne zbog lika u T-34-85, obratite pozornost na njega, sam bog zna šta je taj radio http://wotreplays.eu/site/506976#self
#4930 |
Bajker s AMD-om na dresu
Postovi: 960
#4931 |
Datum registracije: Aug 2008
Postovi: 2,000
#4932 | |
Datum registracije: Apr 2011
Lokacija: Agram
Postovi: 603
xD btw jeste probali ovu novu mapu, hidden village... koja smijurija.. neko ima opaki asian fetish u WG-u.. prestrasno ajd da su neke schoolgirlke i to.. |
#4933 |
Postovi: 491
Da li tko ganja 6-og isusa?
#4935 |
Kupio su 122 44, zapravo skontao da me manje izađe kroz gold nego za keš na popustu u shopu, a poklopilo se da je dobra akcija za 15k golda u paketu sa tetrarch zvijerkicom (koju pikiram već oho-ho, moj fetiš spram low tiera ![]() Uglavnom, pored 3 tier8 premiuma u garaži , još jedan premium i to tier niže, nije logičan potez, onako na prvu. Ali već sam sit grinda sa Lowe-om i KV-5, te type59-kom, jednostavno ulovio sam se da radije igram tier4 non-premium vozila za grind, tako da... Uglavnom, ovaj TD-jac je pravo osvježenje. Zarada je cca 15 k niža u prosjeku, ali je fun factor opet tu... a to mi je trebalo. Btw. dogurao sam do SU 122-54, za što je ekstra bonus ovaj premium, a ni Obj.268 neće smetati malo ekstra grinda na posadi ![]() Super zadovoljan viđenim u ovih par partija... Čista preporuka. |
#4937 |
A income komparativno? Sada baš odigrao jednu u tier9, 3kill, oko 2k dmg, 48k silvera čisto (win). Jedan gold ispalio u E-50. Solidno. Jedino me arty pomete ko ništa. Al' nemo'š dobit' sve ![]() |
#4939 |
Vozi Miškoooo!!!
Lokacija: Svuda okolo / EU
Postovi: 1,404
Ja evo vozam cijeli dan Ferdinanda, istrazio zadnji top na njemu, al je zabavan za igrati, strasan TD, samo sto me nece danas, 27 partija, 27 poraza, sve s Ferdom, ali nema veze, jako se zabavljam, sto je je. Neznam na koju foru se slazu MM ali nema mi logike nikakve, evo samo zadnji video: link - ovi tenkovi u mom timu na koju foru su tamo dospijeli, nebih znao, i sljepac vidi na prvu da protivnicki tim ima jace tenkove, sto god napravio danas gubim partije. |
#4940 |
Meni w/l oko 30% danas i jučer kombinirano, ista shema, isti tenkovi kao i prethodna dva dana gdje sam bio oko 60%. Baš gledam, i svi idemo u istome valu. Od kada koristim xvm, pratim, doslovno u zadnja dva dana tri puta u timu sa više od 50% po xvm. Sreća nisam igrao previše. No, nema veze, iskoristio sam specijal da se dignem na dva modela po tier više, u dva dana meni dosta ![]() Btw. svaka im čast na specijalima ove godine, nemamo se što žaliti, sve smo dobili (osim inteligentnijeg MM-a, al' dobro, stara vijest...). |
#4941 |
Vozi Miškoooo!!!
Postovi: 1,404
Je, specijal je savrsen ove godine, nisam ni mislio WoT pokretati ali me privuklo, narocito jucer x2 cijeli dan, nebih Ferdinanda nikad full istrazio da toga nije bilo. Ja sam morao maknuti xvm, framrate mi s njim dropa do neigrivosti, bez njega mi sve na 70-80 slicica (minimum detalji, komp iz Moj komp). A i WoT poceo imati server bussy ovih par dana, sad samo treba da ih blizzard kupi ![]() |
#4942 |
Postovi: 1,941
http://wotreplays.com/site/509174#st...23-g_w_tiger_p Ovdje je arty odradio veliki dio posla. ![]() Ovoliko o goldu u WoTu. Naravno, ovo nisu njubare, već zeleni igrači koje boli dupe. Dobiju hrpu golda u klanskima, i municija im više nije problem. Danas više stvarno nije problem imati dobru statistiku, pogotovo ak igraš u platoonu i svi koriste samo gold. ![]()
" Have you tried turning it off and on again ? Are you sure it is plugged in ? " ![]() Zadnje izmijenjeno od: m4dm4n. 30.12.2013. u 20:58. |
#4943 |
(uzeo i E-25, impulzivac, psmtr ![]() Prva partija 54k u plusu ![]() Sada imam par za rotaciju ![]() I, ne, ne žalim, bio sam jako dobar čitavu godinu, i zaslužio sam oba ![]() (valjda) ![]() |
#4944 |
Postovi: 491
Ja sam rijesio 4 nacije (zNjemci, ameri, britanci, rusi) Taj grind is 6 uopce nije problem, krenio sam igrati 20og, 2 sata svaki dan (preskocio sam dva dana) i laganini se nakupilo, kad je krenila misija mislio sam no way hose... onda se jos tri dana premisljao. Ugl jos malo i biti ce jos jedan tier 8 prem. u garazi na racun WG-a
#4945 |
Lokacija: Daruvar
Postovi: 1,743
zavrsio sam, ha sam paralelno svaki dan duplo sve nacije imo sam po 3 tenka iz svake nacije osim japanaca i kineza. dobio sam 10030 golda i mjesto maloprije jer imam is6, htio sam do 8.1 to rijesit da uzmem 6 mjeseci premiuma na popustu, izgleda da budem moro jos dodat ja na 59-16 isto sam golde imam
#4946 | |
![]() .... Partija druga sa "nabildanim Alectom": ![]() 100k silvera u dvije partije...ludo ![]() edit: treća ![]() ![]() Neću više ![]() Zadnje izmijenjeno od: windfucker. 30.12.2013. u 23:03. |
#4947 |
Postovi: 1,941
http://wotreplays.com/site/509617#ko...m4dm4n123-l_we Koliko smo gubili, ali smo se baš fino uspjeli izvući. Oni koji su preživjeli su izvrsno komunicirali, spottali, snajpali, relocirali se. Ma ono, prava ekipica koju bi svatko poželio. ![]()
#4949 |
Postovi: 1,941
Ziher te 10 T7 combat carova i ovih free britanaca okružilo i gađalo onim kikirikijima. ![]()
