Staro 24.11.2013., 21:40   #1
warlock25
warlock25's Avatar
Postovi: 2,327
Seasonic S 12 500w
Imam navedeno napajanje i trebao bi promijenit vent na njemu jer je prozujo nakon 5 god.imam 4 noctue u kucistu spojene na potenciometar koje su necujne
da li je ac f12 pwm dobar za napajanje da ga provucem na potenciometar?
Staro 24.11.2013., 22:00   #2
Dottore
Dottore's Avatar
Postovi: 7,627
Pa možeš promjeniti vent, bitno da nađeš iste specifikacije.
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 24.11.2013., 22:17   #3
boy005
boy005's Avatar
Postovi: 598
Nije ti pametno spajati vent od napajanja na potenciometar!
boy005 je offline   Reply With Quote
Staro 25.11.2013., 00:06   #4
Postovi: 23,505
Ako se radi o Seasonic S12-II 500W po ovom testu > http://www.bit-tech.net/hardware/psu...-ii-500w-psu/1
"Talking about the fan; Seasonic uses an ADDA AD1212MB-A71GL which is rated at 3.96W, 2,050RPM, 80.5CFM at 38dBA when pushed to full speed. In reality though, Seasonic runs it at a fraction of this speed because 38dBA is considerably noisy. It's actually almost identical to what Corsair uses, however Corsair preferred to go for a slightly more powerful ball bearing AD1212HB model, which is rated to 4.44W, 2,200RPM and 85.2CFM at 39.1dBA instead."
Dakle:
- također mislim da nije pametno spajati vent od napajanja na potenciometar
- neodgovara ti pwm nego "obična" verzija
- napajanje ima regulaciju rpm po temperaturi / opterećenju
- nabavi vent koji ima što sličnije karakteristike (navedeno gore) i što veći MTBF (MTTF)
Evo preporuke:
http://www.scythe-eu.com/en/products...rand-flex.html
treba ti SM1225GF12H (2000 rpm) verzija:
http://www.portio.hr/index.php?page=artikl&id=050908348
http://www.links.hr/?naziv=ventilato...kl=050.908.348
Pazi kako je bio "okrenut" origigi vent (smjer puhanja) pa tako stavi i novi.
Obzirom da origigi vent ima samo dvije žice (crvena i crna), kod novog možeš treću žicu (žuta) izvući vani i spojiti na "rpm pin" neiskorištenog fan priključka na mobo.
Na taj način možeš pratiti rpm venta.
Staro 25.11.2013., 10:46   #5
warlock25
warlock25's Avatar
Postovi: 2,327
Je to je to napajanje.znaci uzet taj scythe i spojit ga di i ovaj.problem je kaj neznam kak da spojim zutu zicu kad nemam konektor za nju.crnu i crvenu mi je jasno.skinut origigi konektor od adde i unutra puknut pinove od scythe-a ali kak trecu zicu od scythea spojit.kaj da ju direktno na plocu spojim ili?
Zadnje izmijenjeno od: warlock25. 25.11.2013. u 10:55.
Staro 25.11.2013., 11:27   #6
ShanTech
Datum registracije: Apr 2011
Postovi: 3,784
Jesi probao kapnuti malo (kap) finog mašinskog ulja u ventilator te staviti malo litijeve ili grafitne masti?
Staro 25.11.2013., 11:59   #7
alengrosevic
alengrosevic's Avatar
Postovi: 3,775
Autor warlock25 Pregled postova
treću niti ne trebaš na ništa spajati. Samo je izoliraj i osiguraj da se ne saplete u lopatice. i to je to
alengrosevic je online   Reply With Quote
Staro 25.11.2013., 14:22   #8
Postovi: 23,505
Ta "zamjena" pinova ti vjerojatno neće upaliti jer vjerojatno nisu isti,
najlakše da ocvikaš (samo crvenu i crnu), oguliš cca 6 -10 mm, "zafrkneš", izoliraš izolir trakom svaki spoj zasebno.
Kod sklapanja pazi kako je sve skupa bilo da žice ne upadnu u ventilator.
Za treću (žutu) samo je izvuci van napajanja gdje izlaze ostale žice, kad rastaviš shvatit ćeš da je to lako napraviti jer se otvara taman gdje prolaze žice,
ako si napravio kako gore piše zapravo je ostala na 3-pin konektoru.
Možeš ostaviti tako ili samo konektor (tako sa jednom žutom) uštekaš na mobo na PWR_FAN header poviše ATX 24-pin i sve automatski sjeda na svoje mjesto.
Programi koji "čitaju" brzinu ventilatora će ti tako prikazati rpm venta.
Jedino još provjeriš (ako već nije) da je u Bios - u > PC Health > POWER FAN Fail Warning = Disabled.
Ako nisi na "ti" sa svim ovim, zamoli netkog tko je i pokaži mu ovu temu.
Staro 25.11.2013., 16:13   #9
warlock25
warlock25's Avatar
Postovi: 2,327
Mislio sam da skinem 2 pinski konektor sa starog venta i izvadim crvenu i crnu zicu sa flex-a i puknem u dvopinski konektor sa starog venta.zutu bi onda ostavio u 3 pinskom flexu i izvuko van na power fan na maticnoj.
U napajanje mi fizicki ne stane 3 pin konektor jer ima plastiku ogradenu sa svih strana konektora
kaj nisu iste debljine zice 2 pinskog i 3 pinskog konektora?
jer ako jesu onda mogu napravit ovo gore sto sam napisao ak se ne varam
Staro 25.11.2013., 16:53   #10
Postovi: 23,505
Sve zavisi kakvi su pinovi u pojedinom konektoru, ako ti uspije samo seljenje iz jednog u drugo i da ima dobar spoj = bingo
Nije štos u žicama nego u obliku, dužini, kako se uglavi pojedini pin u onoj plastici.
Staro 26.11.2013., 21:13   #11
Nybelung
Ako ti je na napajanju standardni 2pin konektor ne trebaju ti nikakva diy rješenja, imaš adaptere posvuda. Ja sam uzimao s ebaya i iz Chipoteke, 5-10kn dođu.
