red drum
Datum registracije: Aug 2008
Postovi: 144
Dying Light
Ovo izgleda preodlično. http://dyinglightgame.com/site http://www.youtube.com/watch?v=J2TSCZqcjR0 Dying Light is a first-person, action survival horror game set in a vast and dangerous open world. During the day, players traverse an expansive urban environment overrun by a vicious outbreak, scavenging the world for supplies and crafting weapons to defend against the growing infected population. At night, the hunter becomes the hunted, as the infected become aggressive and more dangerous. Most frightening are the predators which only appear after sundown. Players must use everything in their power to survive until the morning’s first light. Preorder je spreman PRE-ORDER EXCLUSIVE BE THE ZOMBIE Pre-order Dying Light to receive the special Be The Zombie Game Mode! Be the Zombie is a PvP game mode and offers players the ability to stalk other players as a night hunter - a lethal predator with unique and deadly skills. Item will be packed with your game after launching.
Postovi: 16,904
O-DLI-ČNO izgleda ![]() |
Postovi: 2,251
http://dyinglightgame.com/ Dying Light + Be The Zombie DLC PRE-ORDER Steam Key http://www.g2play.net/category/5333/...der-steam-key/ Ja sam več u niskom startu ![]()
![]() RedGreenBlue |
Postovi: 5,991
Neovisno o rezoluciji 3gb vram popuni odmah, preko 12gb zauzetog vrama, 30 fps cut scene itd.. GTX 780 fps je od 35 do 70 na 1200p. Igrivo je i na visim rezolucijama al nije bas neki fps. Igra bi mogla bit ok. Izgleda ko i ostale u zadnje vrijeme.. |
Lokacija: Grobnik - Rijeka
Postovi: 3,254
Što se brinete, nakon par patcheva će ionako bolje radit, pa nemojte odmah sada igrat. Nego, kakav je gameplay? Dali je pravi otvoreni svijet, tipa kao Assassins Creed, ili slično? Kako se kvestovi obavljaju? |
Lokacija: スラボニア
Postovi: 3,061
Igra je zanimljiva,vecina kopirana iz ostalih igara,ali super ukomponirano. Vizualni prikaz je odlican,ali me muci optimizacija same igre,tj.cpu iskoristivost. Naime,do izlaska pred grad kao vecina ekipe imam 50-60 fps nekad i vise,no pred izlazak padne na 15-20 fps sto je totalno neigrivo. CPU usage je veliku vecinu vremena na 100 % na jednoj jezgri,ostale jezgre neiskoristene. GPU usage ispod 70 % ( nisam jedini,znam da je cpu bottleneck kod mene,ali ekipa sa i7 i gtx 980 prijavljuju slicne probleme ). Phenom II x4 920 3.1 ghz,8 gb ddr3 rama i r9 280x 3gb. Dolazi cpu optimization patch,do tad nesko iskemijati da dobijem barem 30 fps. http://forum.techland.pl/topic/2656-...ming-your-way/ EDIT : zapravo ovo je strahota od optimizacije,sve na LOW stavio,view distance slider minimum,Nvidia featuresi OFF i ne mogu dobiti 30 FPS. GPU usage 30 %,CPU usage jedna jezgra 60-70 %,ostale na 30-40 %,a vuce skoro 7 gb RAM-a. Jadno. Zadnje izmijenjeno od: blava. 30.01.2015. u 15:31. |
#11 | |
Postovi: 525
Otvoren je svijet,imas side questove koji ti daju ljudi(nisu neki bezvezni side questovi,malo se pomucis da ih rijesis) i naravno main quest koji rjesavas kad god zelis.Questove mozes rjesavati ili po danu ili po noci,kada po noci rjesavas misije onda dobivas vise exp ali ti je puno veci rizik da pogines ![]() |
Postovi: 3,254
Hvala vam na pojašnjenju, jedva čekam zaigrati, no pričekat ću patcheve, ima vremena. Znači, neće biti vatrenog oružja? |
music freak
Lokacija: Sibenik
Postovi: 3,316
jucer probao na laptopu (I7 2630qm,8gb rama, 5670 grafa),jos sam na pocetku u onom hotelu ili sto je vec,reza je 720p na medium i igrivo je oko 20fps vise manje dobivam..zasad igra obecava,grafika je i ovako odlicna i grad u daljini izgleda stvarno dobro.
Postovi: 1,441
eto šta su nam developeri i izdavači napravili...20 fps-a "igrivo", prije 5 ili 10 godina ovo mislim niko nebi izjavija a danas je "igrivo"....to su valjda one "cinematic" fore sa 30 fps-a sa konzola... meni osobno ni 60 fps-a u brzom šuteru poput counter strike ne izgleda dovoljno fluidno...današnji developeri su jeb*** ljenčine i nista drugo...najlakše je reć;don't play on wooden pc! Imaju li svi love za novi hardver svako 6 mjeseci ? Min sys req se zadnjih par mjeseci toliko promjenija da imam osjećaj da sam prespava jedno 5 godina...ili nas samo trolaju a na trziste se izbaci polu-zavrsena igra?? Zadnjih nekoliko igara san proba igrat na najnižim mogućim postavkama i sa svim efektima pogašenima...cod nešto (ovi zadnji, neznam mu ime), the forest, dying light...jednostavno je nemoguce dobit 50-60 sličica na najnizem setingsu a igre poput bf3 idu ko avion na med-high (do 100 fpsa zavisno o situaciji)...ko je tu lud?? |
#19 | |
Postovi: 525
![]() Upravo sam isprobao update i osjeti se malo na performansama,dobio sam negdje 5 frejmova sigurno. |
#20 | |
Lokacija: スラボニア
Postovi: 3,061
#21 |
Postovi: 525
Onda bolje da ga i nema ![]() EDIT: naposlijetku se moze kupiti vatreno oruzje,jest da kosta masno i da nema bas municije ali eto ima i ta opcija ![]() Zadnje izmijenjeno od: Albert Wesker. 01.02.2015. u 00:34. |
#22 |
Lokacija: スラボニア
Postovi: 3,061
Evo nakon desetak sati gameplaya da podijelim utiske. Pored *srane optimizacije i konzolitisa i gdje koje texture pop-up,generalno nemam zamjerke,igra me drzi "budnim" i najbitnije zabavna je i ne postaje monotona i dosadna kao tipa Far Cry 4. Parkour je odlicno izveden,animacije su predivne,na veliku vecinu zgrada se moze popeti i lootati te uci unutra,vremenski efekti su odlicno izvedeni,teksture su podosta visoke rezolucije kao i opcenito vegetacija,cista petica. Al protivnika,e to me iznenadilo posto nema settinga za podesavanje tezine.Neprijatelji su dosta pametni,izbjegavaju napade,flankaju kad ih je vise,koriste oruzje i dosta precizno,skrivaju se i bjeze te ih je problem ubiti,srecom to rjesavaju molotovljev koktel i petarde kad ih zombiji flankaju ![]() Sto se tice zombija,ovi najprimitivniji su glupi jer eto zombiji su,ovi penjaci su dosta inteligentni i agresivni,svuda te prate i kad ih je vise problem je ubiti i cesto zavrsim sa end game. E,sada meni najdrazi dio igre,noc i gameplay po noci.Mrak i tisina,nigdje nikoga,Volatiles ( agresivna vrsta zombija koji izlaze nocu ) patroliraju i tu se heroji prepoznaju. Zombiji postaju jos agresivniji,problem se snaci,za cas se stvore njih 3-4 i nema tog oruzja koje te spasi. XP je poduplan nocu,ali i vjerojatnost da se pogine i tu se gube survive pointsi. Definitivno meni najdraze time of day za igrati i skoro pa horror atmosfera,savjet pripremite firecrackersa,flares i medkitova. Prica je zanimljiva koliko god moze biti uz more slicnih igara i filmova,ima zapleta i zanimljivih likova i nije eto tu samo da bude radi reda. Inventory je ajmo reci dosta dobro izveden,ima se dosta toga za craftati i kombinirati pa se definitivno isplati lootati. Soundtrack je odlicno pogoden za atmosferu i definitivno stvara trnce dok se igra po noci,a sami zvukovi zombija su ajmo reci izvedeni tako da se izludi i utjera strah u kosti i da se bude svakog trena na oprezu. Eto ukratko malo da napisem,zasluzila je igra barem,koliko mi se svida da igram na 20-25 fps sta reci vise. ![]() Ajmo heroji,igra li tko jos po noci,izdrzite do jutra uz konstantno trcanje i izbjegavanje ? |
#23 |
Postovi: 525
Oni brzi i agilni koji dolaze kada zacuju eksploziju je puno lakse ubiti kada imas Focus perk i dovoljna su 4 udarca da ih ubijes. Ja igram malo vise po danu nego po noci a i igranje po noci nije bas nesto pretjerano tesko,previse sam igrao Metal Gear Solid da bi me tako lako prokuzili Volatilesi(igram bez lampe po noci) ![]() |
#24 | |
Postovi: 14
#26 |
RPG player
Postovi: 1,574
eh, baš lijepo napišem dojmove o igri jer sam je danas završio, pošaljem odogovor i više nisam logiran te je sve što sam napisao nestalo ![]() skraćena verzija: igra je dobra
I hate to see you leave, but I love to watch you go |
#28 |
Lokacija: スラボニア
Postovi: 3,061
I meni je cudno,ja evo skoro nabrao 20-tak sati gameplaya i tek na 15 %. Dobro,rjesavam side-questove,ganjam airdropove i slicno pa se ne obazirem toliko na main story. Ne brini,ako ces sidequestove rjesavati,airdropove rjesavati po noci i suljati se,ja mislim da cu izvuci 30-40 h gameplaya iz igre ![]() |
#29 |
Postovi: 525
I ja imam oko 20-tak sati,obavljam side misije i trenutno sam na 22% igre ![]() ![]() EDIT: Ovi su stvarno bili uporni u namjeri da me ugrizu ![]() https://fbcdn-sphotos-e-a.akamaihd.n...09395282_o.jpg Zadnje izmijenjeno od: Albert Wesker. 01.02.2015. u 23:14. |
#30 |
Džabe si krečio!
Postovi: 5,190
Hm, spustio sam očekivanja zbog ovih postova o neoptimiziranosti, ali ovo što sam ja dosada vidio je izvrsno. Maltene lock na 60fps. Doduše, tek sam na počeku, Rahim me uči parkouru ![]() Ne znam, možda je ovaj patch popravio stvari... |
