Staro 21.11.2013., 11:24   #1
~Trt~
red drum
~Trt~'s Avatar
Datum registracije: Aug 2008
Postovi: 144
Dying Light
Ovo izgleda preodlično.
http://dyinglightgame.com/site
http://www.youtube.com/watch?v=J2TSCZqcjR0
Dying Light is a first-person, action survival horror game set in a vast and dangerous open world. During the day, players traverse an expansive urban environment overrun by a vicious outbreak, scavenging the world for supplies and crafting weapons to defend against the growing infected population. At night, the hunter becomes the hunted, as the infected become aggressive and more dangerous. Most frightening are the predators which only appear after sundown. Players must use everything in their power to survive until the morning’s first light.
Preorder je spreman
PRE-ORDER EXCLUSIVE BE THE ZOMBIE
Pre-order Dying Light to receive the special
Be The Zombie Game Mode! Be the Zombie is a PvP game mode and offers players the ability to stalk other players as a night hunter - a lethal predator with unique and deadly skills. Item will be packed with your game after launching.
~Trt~ je offline   Reply With Quote
Staro 21.11.2013., 13:30   #2
Postovi: 16,869
O-DLI-ČNO izgleda
Staro 21.11.2013., 14:22   #3
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
m'da, ovo uopće ne izgleda kao Dead Island.
Nimalo.
Užas.
blaa
Staro 21.11.2013., 14:23   #4
~Trt~
red drum
~Trt~'s Avatar
Postovi: 144
Autor hammer_of_thor Pregled postova
Nimalo.
Užas.
Izgleda kao DI po danu,po noći je malčice zeznuto
Staro 10.01.2015., 20:52   #5
2 die 4
2 die 4's Avatar
Postovi: 2,248
Dying Light + Be The Zombie DLC PRE-ORDER Steam Key
http://www.g2play.net/category/5333/...der-steam-key/
Ja sam več u niskom startu
RedGreenBlue
Staro 10.01.2015., 22:09   #6
alen.s
alen.s's Avatar
Postovi: 1,441
ovi iz Techlanda baš vole ovaj front-kick nogom iz Dead Island
20-ta sekunda u videu
rade istovremeno na nekoliko igara ima vec par godina a nikako nijedna napokon da izađe....
Staro 28.01.2015., 19:36   #7
alen.s
alen.s's Avatar
Postovi: 1,441
igra danas nesto malo (prolog), moj komp jest star i sve al prika ima dobar komp i njemu lega samo tako......e moj tehland.....meni neigrivo
Staro 28.01.2015., 19:53   #8
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
Neovisno o rezoluciji 3gb vram popuni odmah, preko 12gb zauzetog vrama, 30 fps cut scene itd.. GTX 780 fps je od 35 do 70 na 1200p. Igrivo je i na visim rezolucijama al nije bas neki fps. Igra bi mogla bit ok. Izgleda ko i ostale u zadnje vrijeme..
Staro 30.01.2015., 11:33   #9
Omerta
Omerta's Avatar
Lokacija: Grobnik - Rijeka
Postovi: 3,254
Što se brinete, nakon par patcheva će ionako bolje radit, pa nemojte odmah sada igrat.
Nego, kakav je gameplay? Dali je pravi otvoreni svijet, tipa kao Assassins Creed, ili slično? Kako se kvestovi obavljaju?
Staro 30.01.2015., 14:32   #10
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,059
Igra je zanimljiva,vecina kopirana iz ostalih igara,ali super ukomponirano.
Vizualni prikaz je odlican,ali me muci optimizacija same igre,tj.cpu iskoristivost.
Naime,do izlaska pred grad kao vecina ekipe imam 50-60 fps nekad i vise,no pred izlazak padne na 15-20 fps sto je totalno neigrivo.
CPU usage je veliku vecinu vremena na 100 % na jednoj jezgri,ostale jezgre neiskoristene.
GPU usage ispod 70 % ( nisam jedini,znam da je cpu bottleneck kod mene,ali ekipa sa i7 i gtx 980 prijavljuju slicne probleme ).
Phenom II x4 920 3.1 ghz,8 gb ddr3 rama i r9 280x 3gb.
Dolazi cpu optimization patch,do tad nesko iskemijati da dobijem barem 30 fps.
http://forum.techland.pl/topic/2656-...ming-your-way/
EDIT : zapravo ovo je strahota od optimizacije,sve na LOW stavio,view distance slider minimum,Nvidia featuresi OFF i ne mogu dobiti 30 FPS.
GPU usage 30 %,CPU usage jedna jezgra 60-70 %,ostale na 30-40 %,a vuce skoro 7 gb RAM-a.
Jadno.
Zadnje izmijenjeno od: blava. 30.01.2015. u 15:31.
Staro 30.01.2015., 16:15   #11
Albert Wesker
Albert Wesker's Avatar
Postovi: 525
Autor Omerta Pregled postova
Otvoren je svijet,imas side questove koji ti daju ljudi(nisu neki bezvezni side questovi,malo se pomucis da ih rijesis) i naravno main quest koji rjesavas kad god zelis.Questove mozes rjesavati ili po danu ili po noci,kada po noci rjesavas misije onda dobivas vise exp ali ti je puno veci rizik da pogines Igri fali neki range weapon tipa samostrel ili luk i strijela jer bacanje surikena/nozica je bezazleno.Borba ti je hand to hand i nema bas opcije da ubijes protivnika izdaleka tako da se uzdas u sjekirice,cekice,raznorazne macete itd...
Albert Wesker je offline   Reply With Quote
Staro 30.01.2015., 20:00   #12
Omerta
Omerta's Avatar
Postovi: 3,254
Hvala vam na pojašnjenju, jedva čekam zaigrati, no pričekat ću patcheve, ima vremena.
Znači, neće biti vatrenog oružja?
Staro 31.01.2015., 14:15   #13
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,315
jucer probao na laptopu (I7 2630qm,8gb rama, 5670 grafa),jos sam na pocetku u onom hotelu ili sto je vec,reza je 720p na medium i igrivo je oko 20fps vise manje dobivam..zasad igra obecava,grafika je i ovako odlicna i grad u daljini izgleda stvarno dobro.
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD)
Staro 31.01.2015., 15:24   #14
alen.s
alen.s's Avatar
Postovi: 1,441
eto šta su nam developeri i izdavači napravili...20 fps-a "igrivo", prije 5 ili 10 godina ovo mislim niko nebi izjavija a danas je "igrivo"....to su valjda one "cinematic" fore sa 30 fps-a sa konzola...
meni osobno ni 60 fps-a u brzom šuteru poput counter strike ne izgleda dovoljno fluidno...današnji developeri su jeb*** ljenčine i nista drugo...najlakše je reć;don't play on wooden pc! Imaju li svi love za novi hardver svako 6 mjeseci ? Min sys req se zadnjih par mjeseci toliko promjenija da imam osjećaj da sam prespava jedno 5 godina...ili nas samo trolaju a na trziste se izbaci polu-zavrsena igra??
Zadnjih nekoliko igara san proba igrat na najnižim mogućim postavkama i sa svim efektima pogašenima...cod nešto (ovi zadnji, neznam mu ime), the forest, dying light...jednostavno je nemoguce dobit 50-60 sličica na najnizem setingsu a igre poput bf3 idu ko avion na med-high (do 100 fpsa zavisno o situaciji)...ko je tu lud??
Staro 31.01.2015., 15:41   #15
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,059
Ne mozes usporedivati BF3 sa Dying Light nikako,drugi engineovi a i bome graficki prikaz.
Evo dva grafikona da se dobije dojam koliko je igra zahtjevna ( a i *ebeno neoptimizirano smece ).
Staro 31.01.2015., 15:53   #16
alen.s
alen.s's Avatar
Postovi: 1,441
isti Chrome enđin iz Dead Island sa novim zmuljanim šaderima...ebene ljenčine
Staro 31.01.2015., 16:09   #17
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
Izgleda dosta bolje od Dead Islanda al i ide puno losije. Debeli je potpis Nvidije, vidi se po rezultatima i svemu.
Staro 31.01.2015., 18:07   #18
Omerta
Omerta's Avatar
Postovi: 3,254
Jeste probali stavit update?
Frendu se poboljšao fps i to dosta.
Staro 31.01.2015., 19:32   #19
Albert Wesker
Postovi: 525
Nema vatrenog oruzja ali imam jednu misiju gdje nekom liku moram donijeti neki pistolj tako da moze pobjeci iz grada sa obitelji tako da najvjerojatnije necu moci koristiti taj pistolj
Upravo sam isprobao update i osjeti se malo na performansama,dobio sam negdje 5 frejmova sigurno.
Staro 31.01.2015., 19:49   #20
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,059
Autor Albert Wesker Pregled postova
Ima vatrenog oruzja,dobijes ga tj.pokupis nakon jedne misije,g3 type rifle samo je beskorisno,navuce ti zombija samo tako pucnjava
Staro 31.01.2015., 22:15   #21
Albert Wesker
Postovi: 525
Onda bolje da ga i nema Ovaj patch je pridonio dosta perfomansi ove igre,ionako mi je CPU malo slab za ovu igru (i3) a oni zajebu tako da igra koristi jednu jezgru...
EDIT: naposlijetku se moze kupiti vatreno oruzje,jest da kosta masno i da nema bas municije ali eto ima i ta opcija
Zadnje izmijenjeno od: Albert Wesker. 01.02.2015. u 00:34.
Staro 01.02.2015., 00:55   #22
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,059
Evo nakon desetak sati gameplaya da podijelim utiske.
Pored *srane optimizacije i konzolitisa i gdje koje texture pop-up,generalno nemam zamjerke,igra me drzi "budnim" i najbitnije zabavna je i ne postaje monotona i dosadna kao tipa Far Cry 4.
Parkour je odlicno izveden,animacije su predivne,na veliku vecinu zgrada se moze popeti i lootati te uci unutra,vremenski efekti su odlicno izvedeni,teksture su podosta visoke rezolucije kao i opcenito vegetacija,cista petica.
Al protivnika,e to me iznenadilo posto nema settinga za podesavanje tezine.Neprijatelji su dosta pametni,izbjegavaju napade,flankaju kad ih je vise,koriste oruzje i dosta precizno,skrivaju se i bjeze te ih je problem ubiti,srecom to rjesavaju molotovljev koktel i petarde kad ih zombiji flankaju
Sto se tice zombija,ovi najprimitivniji su glupi jer eto zombiji su,ovi penjaci su dosta inteligentni i agresivni,svuda te prate i kad ih je vise problem je ubiti i cesto zavrsim sa end game.
E,sada meni najdrazi dio igre,noc i gameplay po noci.Mrak i tisina,nigdje nikoga,Volatiles ( agresivna vrsta zombija koji izlaze nocu ) patroliraju i tu se heroji prepoznaju.
Zombiji postaju jos agresivniji,problem se snaci,za cas se stvore njih 3-4 i nema tog oruzja koje te spasi.
XP je poduplan nocu,ali i vjerojatnost da se pogine i tu se gube survive pointsi.
Definitivno meni najdraze time of day za igrati i skoro pa horror atmosfera,savjet pripremite firecrackersa,flares i medkitova.
Prica je zanimljiva koliko god moze biti uz more slicnih igara i filmova,ima zapleta i zanimljivih likova i nije eto tu samo da bude radi reda.
Inventory je ajmo reci dosta dobro izveden,ima se dosta toga za craftati i kombinirati pa se definitivno isplati lootati.
Soundtrack je odlicno pogoden za atmosferu i definitivno stvara trnce dok se igra po noci,a sami zvukovi zombija su ajmo reci izvedeni tako da se izludi i utjera strah u kosti i da se bude svakog trena na oprezu.
Eto ukratko malo da napisem,zasluzila je igra barem,koliko mi se svida da igram na 20-25 fps sta reci vise.
Ajmo heroji,igra li tko jos po noci,izdrzite do jutra uz konstantno trcanje i izbjegavanje ?
Staro 01.02.2015., 01:43   #23
Albert Wesker
Postovi: 525
Oni brzi i agilni koji dolaze kada zacuju eksploziju je puno lakse ubiti kada imas Focus perk i dovoljna su 4 udarca da ih ubijes.
Ja igram malo vise po danu nego po noci a i igranje po noci nije bas nesto pretjerano tesko,previse sam igrao Metal Gear Solid da bi me tako lako prokuzili Volatilesi(igram bez lampe po noci) Vecinom se drzi high grounda i nemas nekih problema.
Staro 01.02.2015., 06:39   #24
mileni007
Postovi: 14
Autor blava Pregled postova
isto tako u gotovo svakom policijskom kombiju tzv. marici nadjes ili pistolj ili police rifle ako ih nemas u inventory, uglavnom isplati se ici otvarati ih (very hard lock ) jer se nađe dobrih oruđa ili oružja
mileni007 je offline   Reply With Quote
Staro 01.02.2015., 13:53   #25
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,859
ok je igra,zanimljiva,naravno uvjek problema s oni skakanjem tj na početku one lampe upalit za noć,uvjek dole padnem.
Staro 01.02.2015., 20:22   #26
Big Guy
RPG player
Postovi: 1,574
eh, baš lijepo napišem dojmove o igri jer sam je danas završio, pošaljem odogovor i više nisam logiran te je sve što sam napisao nestalo
skraćena verzija: igra je dobra
I hate to see you leave, but I love to watch you go
Big Guy je offline   Reply With Quote
Staro 01.02.2015., 22:05   #27
Omerta
Omerta's Avatar
Postovi: 3,254
Pa kako tako brzo završavate te igre? Vi letite kroz njih ili?
Staro 01.02.2015., 22:43   #28
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,059
I meni je cudno,ja evo skoro nabrao 20-tak sati gameplaya i tek na 15 %.
Dobro,rjesavam side-questove,ganjam airdropove i slicno pa se ne obazirem toliko na main story.
Ne brini,ako ces sidequestove rjesavati,airdropove rjesavati po noci i suljati se,ja mislim da cu izvuci 30-40 h gameplaya iz igre
Staro 01.02.2015., 23:09   #29
Albert Wesker
Postovi: 525
I ja imam oko 20-tak sati,obavljam side misije i trenutno sam na 22% igre Bas sam maloprije nasao dvocijevku u "marici" Trenutno sam combat lvl 12,agility lvl 10(blizu sam 11) a survivor na 12.
EDIT:
Ovi su stvarno bili uporni u namjeri da me ugrizu
https://fbcdn-sphotos-e-a.akamaihd.n...09395282_o.jpg
Zadnje izmijenjeno od: Albert Wesker. 01.02.2015. u 23:14.
Staro 02.02.2015., 00:35   #30
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,190
Hm, spustio sam očekivanja zbog ovih postova o neoptimiziranosti, ali ovo što sam ja dosada vidio je izvrsno. Maltene lock na 60fps. Doduše, tek sam na počeku, Rahim me uči parkouru
Ne znam, možda je ovaj patch popravio stvari...
