Staro 19.11.2013., 18:32   #1
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,507
Nvidia GeForce v331.82 WHQL Driver
New in GeForce R331 Drivers
Performance Boost – Increases performance by up to 50% for GeForce 400/500/600/700 series GPUs in several PC games vs. GeForce 327.23 WHQL-certified drivers. Results will vary depending on your GPU and system configuration. Here is one example of measured gains:
GeForce GTX 770/780/TITAN/780Ti:
Up to 50% in Metro: Last Light
Up to 26% in Crysis 3
Up to 18% in Battlefield 4
SLI Technology
Assassins Creed IV: Black Flag – updated profile
Path of Exile – added profile
Natural Selection – updated profile
3D Vision
Assassins Creed IV: Black Flag – "Good"
Gaming Technology
Enables GeForce ShadowPlay™ technology
Call of Duty: Ghosts – added TXAA support (disabled FXAA)
SHIELD
Enables NVIDIA GameStream™ technology
http://www.geforce.co.uk/drivers/results/70214
Staro 20.11.2013., 01:50   #2
MAGARAC
MAGARAC's Avatar
Postovi: 5,993
Probal sam malo BF4 i ide bolje 5-10 fps prosjecno u odnosu na driver prije.
Staro 20.11.2013., 09:51   #3
Delpiero
Delpiero's Avatar
Datum registracije: Aug 2008
Lokacija: Split, Croatia
Postovi: 380
Meni također na bf4 ima cca 5-10 fps više , iako sam samo na 1 mapi obratio pozornost na to
Delpiero je offline   Reply With Quote
Staro 20.11.2013., 13:02   #4
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,170
Impresivni postotci povećanja performansi...
Je li netko gledao kakve su temperature s novim driverima? Da ne bude kao u prošlosti, da porast performansi prati i porast temperature u loadu....
Staro 20.11.2013., 13:21   #5
Delpiero
Delpiero's Avatar
Postovi: 380
Autor JC Denton Pregled postova
Nisam, iskreno, instalirao sam nove drivere i samo kratko pogledao kako radi.. pa morao izići vani, tako da nemam pojma o ostalim stvarima..
Staro 21.11.2013., 16:41   #6
Thund3rman
Thund3rman's Avatar
Datum registracije: Dec 2010
Postovi: 104
Meni se stanje pogorsalo sa ovim driverima. Imam gtx 680 i u igri BF4 padovi fps su katastrofa. Vratio sam se na prijasnje drivere i opet sve ok...
Thund3rman je offline   Reply With Quote
Staro 04.12.2013., 22:52   #7
OuttaControl
OuttaControl's Avatar
Lokacija: Dalmacija
Postovi: 5,921
Za starije serije (9600 GT) katastrofa, kad sam instalira nakon par min se pocme mis zamrzavat par sec i onda se cili komp zamrzne, nece niti u safemode da udje, mora sam sa hirenom brisat fileove ručno...
OuttaControl je online   Reply With Quote
Staro 12.12.2013., 03:22   #8
flyer1
flyer1's Avatar
Lokacija: home
Postovi: 572
Autor MAGARAC Pregled postova
Autor Thund3rman Pregled postova
hmm...čudnovate 'fluktuacije' i to na top modelima...s 560 za obične smrtnike izgleda bolje da ostanem na 314.22
meni je 8800 donedavno bila u kompu i sasvim normalno radila s nekim pradavnim 197.xx driverima...dobro da novi uopće i rade sa stari(ji)m karticama.
flyer1 je offline   Reply With Quote
Staro 13.12.2013., 21:07   #9
vedranzeman
Lokacija: Kloštar Podravski
Postovi: 1,019
Potvrđujem ono što su prije mene napisali, definitivno nisu za starije serije grafičkih.
Prije par minuta su mi na 560 Ti bacili "Display driver stopped responding..." i to dva puta u razmaku 6 sekundi.
U vrijeme dok sam pisao ovdje, našao sam post gdje nVidia priznaje da su već jedno vrijeme izgubili kompas s driverima za 4xx i 5xx seriju.
Znači povratak na 314.22, iako dolazim u napast da stavim legendarne 320.18 , da riješim grafu dok je još u garanciji.
vedranzeman je offline   Reply With Quote
Staro 13.12.2013., 21:21   #10
Nick7
Lokacija: Velika Gorica
Postovi: 1,533
Instaliraj 331.93, jer su u njemu rijesili (napokon) problem s Fermi karticama (barem za vecinu ljudi).
Staro 15.12.2013., 20:27   #11
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Ja instalirao na svjes W7 331.28 i nakon restarta monitor ide u sleep mod kada bi se trebao prikazati Welcome screen. Obrisem te drivere, stavim neku verziju malo stariju, isto, pa jos par verzija unazad, isto. Onda probam 275.33 sa njim malo bolje, ali i dalje ne radi, naime, monitro par puta ode u sleep i vrati se nazad i onda se komp restartuje. Probao sam i 314.22, ni sa njima ne radi... Sad skidam 301.xx da i sa njima probam. POLUDICU!!!
Kartica je GTX560. Ako ima neko doticnu karticu neka napise na kojim je drajverima trenutno da ne moram do jutra probavati jednu po jednu verziju...
Staro 16.12.2013., 00:38   #12
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
neces napraviti nista reinstalacijom. ostali su ti fajlovi od najzadnjih drivera koji ce ako ih maknes driver sweeperom sjebat winse. Dakle reinstall win i onda 314.22 ili 310
Staro 16.12.2013., 01:36   #13
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Naravno da sam sve micao driver sweeperom, windowsu nije bilo nista. Nakon brisanja sve se normalno upali i dobijem sliku, dok ne instaliram novu verziju drivera. Onda sve ipet iz početka. Na kraju se sve samo od sebe sredilo, magično, nakon što sam par puta prebacio monitor sa jednog DVI konektora na drugi i nazad par puta...
