#6241 |
Datum registracije: May 2005
Postovi: 1,285
I evo jos jedna, nju bi mozda trebalo i malo doratit, meni se osobne nije pretjerano svidila al ko zna mozda nekome bude odgovaralo. Sve su postavke skinute sa neta i TV su kalibrirani preko raznih uredjaja tako da postavke nisu nasumicno radjene ![]() Picture Mode - Movie Backlight - 11 Contrast - 82 Brightness - 45 Sharpness - 10 Color - 48 Tint - G47/R53 Picture Size - Screen Fit of course Advanced Settings: Dynamic Contrast - off Black Tone - off Flesh Tone - 0 Color Space - Auto (couldn't get the color space to adjust without screwing other stuff up badly, so left it alone. It's not TOO far off as you'll see in the CIE After Diagram) White Balance (2 point): R-Offset - 26 G-Offset - 25 B-Offset - 24 R-Gain - 17 G-Gain - 25 B-Gain - 18 White Balance (10 point): Interval 1 - -2 Red, 0 Green, -3 Blue Interval 2 - -1 Red, 0 Green, +4 Blue Interval 3 - 0 Red, 0 Green, -5 Blue All other intervals set to 0 for all three colors Gamma - -1 Picture Options: Color Tone - Warm2 Digital Clean View - off (preference) MPEG Noise FIlter - off (preference) Auto Motion Plus - Custom (I know most people hate this, I like its effect as long as it's set really low) Blur Reduction - 2 Judder Reduction - 1 LED Clear Motion - off |
#6242 |
Postovi: 1,285
i evo jos jedna varijanta na ovu povise kombinaciju navodno malo ispeglanija. Koliko san svatija malo je mracnija varjanta koja je pogognija za koristenje Tv-a kao monitora (ili za konzolu). naravno kome je mracno uvik moze povecat backlight. Main Menu Picture Mode: Movie Backlight: 9 Contrast: 90 Brightness: 48 Sharpness: 10 Color: 48 Tint (G/R): G49/R51 Picture Size: Screen Fit Advanced Settings Dynamic Contrast: off Black Tone: Off Flesh Tone: 0 Color Space: Custom Red - 50 Red, 0 Green, 0 Blue Green - 0 Red, 50 Green, 0 Blue Blue - 0 Red, 34 Green, 45 Blue Yellow - 50 Red, 50 Green, 0 Blue Cyan - 0 Red, 50 Green, 50 Blue Magenta - 50 Red, 0 Green, 50 Blue White Balance (2pt) R-Offset: 25 G-Offset: 25 B-Offset: 23 R-Gain: 16 G-Gain: 25 B-Gain: 17 10p White Balance: On Interval 1 - 0 Red, 0 Green, +1 Blue Interval 2 - 0 Red, 0 Green, +2 Blue Interval 3 - 0 Red, 0 Green, +1 Blue Interval 4-6 - 0 Red, 0 Green, 0 Blue Interval 7 - 0 Red, 0 Green, +2 Blue Interval 8 and 9 - 0 Red, 0 Green, 0 Blue Interval 10 - +4 Red, 0 Green, 0 Blue Gamma: -1 Picture Options Color Tone: Warm2 Digital Clean View: Off MPEG Noise Filter: Off Auto Motion Plus: Off (still experimenting with this one) |
#6243 |
Čitam, čitam ovaj prestanak proizvodnje plazme i pfff. Pol godine (za mene) prerano. Toplo se nadam da ću uspjeti za kakvih 6-12 mjeseci uzeti iduću plazmu za narednih 5 godina... http://maddukesrants.blogspot.com/20...asma-star.html Vrlo često ABL problem kod recimo scena na snijegu. Stvar ukusa. Ja preferiram "prljave bijele" u nekim uvjetima naspram "blooming bijelih" na LCD-u kod tamnih scena. Plus, klasična stvar već spomenuta. Stvar je settinga također (kod mene uvijek zatamljena prostorija pa što opet ide u korist plazme naspram LCD-a. nemam takvih problema) |
#6244 |
Lokacija: north-northwest
Postovi: 1,990
#6245 |
Ovisi do modela. |
#6246 |
Postovi: 1,809
Da bi vidio razliku moraju biti televizori jedan do drugog i prikazivat isti program. Nije to samo stvar snijega, komplet scena na lcd-u zna biti svijetlija, a samim tim i nekak dinamičnija. Dakako najveća se razlika vidi kada komplet ekran prikazuje nešto bijelo. To mi je prvi utisak za sada, treba to malo dulje promatrat da bi mogao donjeti konačan sud. Inače lcd je definitivno loš izbor za široki boravak, zbog lošeg vidljivog kuta. Šta se tiče sd signala i igara na playstation 2 konzoli pogotovo (ako se netko još igra na tome) philips crt (29pt5308) je pokazao zube i pany plasmi 42st60 i sony-u 32hx750 lcd-u. Iako su sada skoro svi naši programi u 16:9 formatu pa bi to trebala biti prednost za tanke ikrane, ipak se pokazalo da to nije dovoljno da bi bilo bolji,ili barem jednaki |
#6247 | |
Postovi: 1,990
no "čistoča" bijele se može (bar kod moje plazme) mijenjati ovisno o RGB postavkama i odsutnosti RGB gainova... kod mene je sve na "0". nisma imao potrebe prčkati po tome. meni je jedino mjerilo ti DEMO clipovi sa neta (m2ts format) - ne DVD (mpeg2) ili BD film ili TV program |
#6248 | |
To što se slažem sa tobom oko bijele (to some extent) još uvijek stoji da tebi nešto ne valja sa očima hehe |
#6249 |
Postovi: 1,809
Pa dobro ,ne vidim baš kao sokol. Također da vidim razlike nekih nijansi boja bolje od kalibratora nebi se pohvalio.Ali meni osobno i nije toliko bitno jel slika malo više vuče na topliji ili hladniji spektar,ali sam jako osjetljiv na kontrast, tj prikaz crne i bijele boje te detaljnost prikaza. Ono što primjećujem naprimjer je da crt ima bolji prikaz crne i od plasme,da su boje na crt televizoru zasećenije nego na plasmi ili lcd-u,da lcd ima bolji prikaz bijele nego crt,a lcd je za prikaz crne redovito katastrofa, bez obzira o kojem se tipu panela radi |
#6250 |
Postovi: 1,285
Da vas pitan nesto u vezi 3D-a. skinija san sa neta neki video koji je navodno 3D al svi imaju oznaku SBS sta bi znacilo side by side video. E sad mi ni jasno kako pogledat takav video u 3D-u i za sta je to manjenjeno. Znam da ima stari 3D koj je igra sa crvenom i plavom bojom, onda imamo danas popularne aktivne i pasivne. (rade na slican princip da neidemo puno u detalje) E sad ja iman aktivni 3D i koji video mogu ppgledat u 3D-u jel ima neka oznaka na koju moran pazit ili sta? |
#6251 |
Lokacija: Priko Klisa
Postovi: 852
Moraš imati 3D TV ili monitor , uključiš 3D mod , on ti preklopi te dvije slike i ti dobiše nešto kao uduplanu sliku odnosno linije po istoj a ti uzmeš naočale i gledaš (svako oko gleda svoju sliku mislim i ti onda takvom varkom dobiješ osjećaj dubine). |
#6253 |
Postovi: 852
Pogledaj pod opcijama za titlove - ili imaš li dugme na daljincu za titlove. Malo teško idu ti 3d titlovi sad ne znam jesam li sto shebao kod konvertiranja ali: - medija player od tv-a mi ih vidi ali ne prikazuje - xbmc sat box prismcube isto tako - enigma 2 box gigablue quad isto tako - popcorn a110 isto tako - vlc na laptopu ih uredno vidi i prikazuje - android tablet sa dual core procom ih vidi i prikazuje preko hdmi ali trza slika (što mi je čudno jer nisam sa drugim filmovima imao takvih problema). Sad ovo sam testirao na jednom filmu - možda je do filma odnosno može biti i do načina kako sam konvertirao titlove, trebat ću se duže pozabavit s time . |
#6255 |
Postovi: 2,717
Ovo mi se čini novi bestbuy. Samsung 55F6400 za samo 8000 kn. http://www.elipso.hr/audio__video/tv/SAMSUNG-UE55F6400/
MC |
#6257 |
Postovi: 375
Što izabrati od ova 3 tv-a ? http://www.emmezeta.hr/multimedija/t...-hd-led-mpeg4/ http://www.emmezeta.hr/multimedija/t...-hd-led-mpeg4/ http://www.emmezeta.hr/multimedija/t...-hd-led-mpeg4/ Ili ako imate neku preporuku do 3200kn |
#6259 |
Lokacija: Čakovec / AT
Postovi: 1,782
zanimljivo.... a dok je meni frend kupovao Samsung UE32F5000 u Elipsu (bila akcija, 2500 sa 5 godina garancije, na lageru pisalo 5 komada, da bi ispalo da je ostao samo jedan , a ne 5, i da je taj jedan bio izlozbeni primjerak, radio je x dana po 10 sati). reko uzmem ga ali sigurno ne po toj cijeni... zenska veli, nazalost nemremo spustit cijenu. i tako sam odustao i uzeo isti u Areni centar za iste novce i s besplatnom dostavom na vrata bilo gdje u HR. sori na OT ![]()
slow is smooth, smooth is fast... |
#6260 |
Postovi: 1,285
Pa elipso ime jeftinije TV nego Samsung poslovnica. Moj tv u Samsunga je 4900kn ( sa popuston) sa 2 god jamstva a u Elipsa 4400kn sa 5 godina jamstva. Tv nije izlozbeni primjerak nego novi. edit: samo da napomenem da mi titlovi jos uvik nerade, dok na starome LG-u rade bez ikakvog problema. (upira san i tipku na daljincu za titlove al opet nista) Zadnje izmijenjeno od: Smarty. 09.11.2013. u 23:35. |
#6261 |
Postovi: 852
Jel ovo nova (r)evolucija / poslastica na vidiku ![]() http://www.ubergizmo.com/2013/09/xia...sts-under-500/ http://multicorechina.com/xiaomi-tv-review/ |
#6263 |
Lokacija: Varazdin
Postovi: 121
#6264 |
Datum registracije: Oct 2012
Postovi: 37
domace programe znaci sd i ostalo normalno spojena plasma sa antenskim kabelom , a za 1080p mkv filmove plasma spojena sa eksternim hardom , media player od plasme cita sve zivo ,jedino treba titlove ručno namjestit ,ne cita automatski bez obzira ak se film zove ko i titl ,i onda sve radi i tilovi super ,prezadovoljan sam,za st50 mislim da je sve isto ,sam napravi update kad ti dode tv ,pozz Zadnje izmijenjeno od: devouring. 11.11.2013. u 08:15. |
#6265 |
NITKOV
Lokacija: Maksimir / Dugave
Postovi: 4,012
Kak ne čita automatski? Frend ima 42st50 i automatski čita titlove. Samo je panasonic zasro s mp4 fajlovima gdje uopće ne nalazi titlove. Al dobro, Mp42Mkvac3 konvertira to u mkv u par minuta, a s mkv fajlovima problema nema.
#6266 | |
Postovi: 37
#6268 |
Postovi: 37
#6269 |
Postovi: 698
ST50 ne čita automatski, moraju se uključit ručno, što nije problem. Problem je što ne pamti konfiguraciju encodinga pa se apsolutno svaki put treba podesiti na central european. MP4 video iz nekog razloga ne može prikazati titlove. |
#6270 | |
Postovi: 37
evo sve je receno ,a mozda to poprave sa sljedecim updateom |
