Staro 05.11.2013., 21:17   #511
Neo-ST
Neo-ST's Avatar
Postovi: 8,564
Nije ga nitko repairao, gađao sam ga odozgo sa tornja, svih 5 šta je prije bilo moguće.
U BF3 ti je dovoljno jednom pogodit tenk sa RPG-om od straga i disableaš ga...
Staro 06.11.2013., 10:28   #512
trpi
kupio i ja igru, pa da vidimo
http://www.buy-play.com/game/battlef...g-dlc-210.html
skinulo 293kn sa kartice
ocekivao sam key u inboxu odmah nakon uplate, ali nista evo 1h? nestrpljivost jbg a treba jos skidati 25gb
email poslije placanja:
Hello,
For the security reasons credit card payments are subject to additional verification.
Our consultants will contact you soon
To speed up the process you can send to us or upload for future orders in your Customer Panel bellowed documents:
1) a scanned photo ID with the billing address on it
2) a scanned copy of the credit card so we can verify you as the credit card holder
(You may black out all digits but the last 4 should be visable. You may also block out any ID number listed on the photo ID.)
Once we receive this, we can continue with the order process.
Please note that we respect the privacy of all of our customers and will never sell, rent, or give away any personal information. This information is used just for order validation purposes and nothing else. We apologize for any inconvenience this may cause however this is the best way for our company to fight credit card fraud
Thank you
sta ce im to placeno je paypalom
Staro 06.11.2013., 10:36   #513
jopis
gadget freak
jopis's Avatar
Lokacija: Jasenovac
Postovi: 2,224
Zato što prvi put kupuješ kod njih pa se žele osigurati da nije netko ukrao nečiji account.
U paintu zacrniš broj osobne, broj računa kartice koju imaš za paypal, fotkaš ili skeniraš i pošalješ mailom. Tako su mene tražili na gotovo svim cdkeyshopovima pri prvoj transakciji.
Staro 06.11.2013., 10:42   #514
trpi
a daj ruzan sam, jel bas moram slati sliku osobne
tnx budem uradio to
Staro 06.11.2013., 11:00   #515
mrva_zg
mrva_zg's Avatar
Datum registracije: Feb 2010
Postovi: 959
Mene nervira problem sa zvukom.
Svaki put kad svitcham u bilo kojem vozilu pogled tj zoom na oružju ili stisnem sprint nestane mi zvuk na 2 minute
Staro 06.11.2013., 11:15   #516
tpm4
tpm4's Avatar
Postovi: 330
Fix Start Origin in R&D mode • Link
Exit Origin
Create a new empty document on your desktop
Enter the following in the file:
[connection]
EnvironmentName=production
[Feature]
CdnOverride=akamai
Save the file as EACore.ini
Now start Origin. Upon start you will be asked if you want to import the file you just created on your desktop. Press Yes. This will overwrite your old config-file.
Information The EACore.ini file is deleted from your desktop as soon as you import it. If you ever want to leave R&D mode you need to go to the location where Origin is installed and delete the EACore.ini file found there.
Nakon toga mi je skidalo sa maks brzinom cjelo vrjeme.
Kupio sam i ja jucer kod njih.
Neman ja pare na kartici, iman kod sebe. Nemam volje setat do banke. Dao curi pare ona meni svoju karticu di ima para i paypal. Registrirao nju, slikao njezinu osobnu i karticu, i onda je neka zenska iz poljske zvala na mobitel da provjeri, samo se predstavila i pitala ime i prezime(english).
I dok skidas, imao sam ja jedan problem pa da znas kako rjesit ako ti se dogodi.
Nakon 10 min iz max brzine bi mi se spustila brzina skidanja na pola i nebi vise povecavala.
Pauziras, izgasis origin i rjesis ovako:
Exit Origin
[connection]
[Feature]
CdnOverride=akamai
tpm4 je offline   Reply With Quote
Staro 06.11.2013., 14:01   #517
sa20
sa20's Avatar
Postovi: 199
Sa zvukom su česti problemi. Meni posebno ona mapa gdje je brana i ona gdje je pruga. Na te dvije svako malo nestaje zvuka, što je iritantno . Al ono još gore je što i sada imam random crasheve. Stavio sam ati drivere beta verziju novu al svejedno se ruši.
Nemam pojma što dalje napraviti, samo znam da nema ništa iritantnije kad usred mape sve pukne i još mi ne snimi u cloud ništa . Kad pogledam koju sam mapu zadnju igrao prikaže mi mapu prije one iz koje me izbacilo
Al baš za samu igru (kad mogu igrati normalno) nemam nekih velikih prigovora osim netcoda, koji je strašan. U bat 3 mi se dešavalo da me netko ubije a ja to skužim 3 sekunde nakon što sam pobjegao u zaklon . Sad su nadmašili sami sebe, sad odem u zaklon pa prođe još duže vremena i onda mi tek piše da sam mrtav
Al valjda budu to sve riješili s update-ima.
sa20 je offline   Reply With Quote
Staro 06.11.2013., 14:34   #518
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,515
nisam baš pratio, možda je već napisano..kakav je SP? isplati li se odigrati? jel ima akcije ili gledaš filmske scene i stišćeš space što brže i slično?
Staro 06.11.2013., 14:50   #519
Ati freak
aka Striko
Ati freak's Avatar
Lokacija: Krapina - Zagreb
Postovi: 1,756
Kad svi djele dojmove da i ja kažem pokoji dojam o BF4 i usporedba sa BF3 koji je skoro isti ( mehanika igre ) .
MBT tenkovi :
BF4 opca katastrofa..... Mogu ja gađati po gusjenicama do prekosutra al 3-4 od 10 dobi mobility hit, katastrofa , onaj High explosive shell ima pad toliko velik da bi rađe izašao iz tenka i rukom mu bacio taj projektil.
U BF3 imam ~10 000 Killova sa MBT tenkovima i tamo je 3x bolji dojam tenka nego tu, iako su ga uništili sa oslabljivanjem, ali je i dalje bolji nego tu.
Attack helli:
U BF4 je to Hide helli prije nego attack, sa tim jedino sad možeš napadati pokojeg šepavog snipera ili supporta. TV raketa nije one shoot kill na ništa od vozila, cak ni na bird.
Snaga vozila je takva da ne budem prost , kad protivnički jet samo preleti pored helija padne health za 15% , a ako se ovaj odluci zapucati, bolje da se sam ubijem jer nema teoretske šanse da se obranim od njega ili njih jer obično nevolja ne dolazi sama pa još neki mali Poljak "wlaciyslaw awww XD XD" češka ljevo jajčeko i loka sa Stingerom , e onda heli pocne zujati, zavijati , mijaukati , imam osjecaj da ce elisa otpasti sa helija i da su cigici pokrali svu limariju s helija.
Probao sam protumjere flares i ECM, ma bacio ja to prije locka ,poslje locka, nakon ispaljivanja nema to nikakvog utjecaja , bacim i malog crnca da lovi rakete niti to ne pali . Katastrofa .
Ubilo mi volju za "Attack helijem " .
Još samo fali da i protivničke zgrade počnu lokati i to je to.
U bf3 je helli imao barem šansu sakriti se , al tu ne. No way, barem ne na vecini mapa.
Attack brod :
E to je vec pjesma koja jedina od vozila vrijedi prakticki na BF4.
Močan , brz i okretan . Uz posadu od jednog vozača + 2 gunnera to je močan stroj.
Generalno oduševljen .
Scout helli :
Pre okretan kad se gađa pješadija i manevrira među zgradama a kad se treba na visini boriti onda je ko fixiran. O oružjima na njem necu jer ih nisam baš otkljucao.
RHIB Boat ( običan gumenjak ):
Ok je ima malo više smisla nego na BF3.
to je to od vozila.
Oružja:
Igram sad samo sa inžinjercem i sve AT oružja sam otkljucao i koristio.
MBT LAW:
Point and shoot. Smece.
SRAW : Očajna imitacija AT-4 iz BC2 , kakvo je to wire guided oružje koje kad lik baci u tenku ili bil cem drugom smoke da se raketa odbije od smoke-a....... A damage ima ravan tome da bi rađe došo do tenka i šutao ga nogom.
Mine nisam oprabao.
Ako se nađem sam sa tenkom i 7 SRAW raketa rađe cu baciti bombu sam sebi pod noge.
Kad sam vec kod bombi to su fascinante stvarčice. Mamicu im , kad god ju meni netko baci nema teoretske da pobjegnem igdje jer cim padne pred mene explodira , nema iznimaka.
Mape, ima par dobrih, ostale ce se brzo zaboraviti.
Staro 06.11.2013., 15:21   #520
Neo-ST
Neo-ST's Avatar
Postovi: 8,564
Znači ipak nisam lud...
Staro 06.11.2013., 15:23   #521
Bishop
Postovi: 470
Primjetio sam dosta hejta po uvrjezenim stranicama tipa pcgamer, ign i gamespot koje obicno hvale i bf i cod fransizu, pa zar je EA usfalilo love za marketing??
Of course he's dead, you can see his brain
Bishop je offline   Reply With Quote
Staro 06.11.2013., 15:45   #522
sinke.ZG
sinke.ZG's Avatar
Postovi: 733
meni skoro nakon svake igre komp restarta...al sto je cudno nikad za vrijeme igre nego igra zavrsi i cekam novu mapu kad ono restart....tak da mislim da nije dok kompa....ima ko ovakav slucaj windowsi 8.1 oni najeftiniji
edit:sad sam za vrijeme izmedju dve mape napravio alt/tab i naravno opet reset al mi je sad javio neki "bad pool caller"
Zadnje izmijenjeno od: sinke.ZG. 06.11.2013. u 16:09.
sinke.ZG je offline   Reply With Quote
Staro 06.11.2013., 20:52   #523
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,515
Autor Bishop Pregled postova
Ne CoD je več odavno copy paste smeče to svi stariji od 18 g. znaju,a BF 4 je nedovršena/izbagana igra izbačena na brzinu da se prestigne rok kad CoD izlazi,jasno je da su krenuli CoD stopama ipak je to EA $$ im je najbitniji ,ja osobno kune više nedam za BF,puno više sam očekiva možda nisam u pravu ili me jednostavno to bezglavo napucavanje ne zanima više./a i ipak je ovo samo moje mišljenje/
Tajl3r je online   Reply With Quote
Staro 06.11.2013., 21:07   #524
Postovi: 17,138
Može brzi odgovor od nekoga da ne scrollam previše...
Igrao sam bf3 sp na high postavkama, neke čak i ultra, na ovoj konfi u potpisu...
Kako ću vrtiti bf4?
Staro 06.11.2013., 21:19   #525
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Bolje nego bf3.
Staro 06.11.2013., 21:37   #526
Hellhound
Hellhound's Avatar
Datum registracije: Dec 2010
Lokacija: IRL
Postovi: 264
Moje tipicno vrijeme s BF4:
1. izgleda mi refresh servera ne radi(jel jos kome to?), pa moram kliktat na druge stvari pa nazad....
2. Udem u igru...stuttera
3. Crasha
4. Crasha pri loadanju mape
I tako u 4/5 igre ubacite jedan od 2.-4.
Srecom nemam exp boostova(niti bi ih koristio) al tek sam lvl 3, bio bi 10+ da ne crasha sigurno.
Ccc...sve dobre igre 2+ kdr, 10kbodova....trolololo...nema.
Hellhound je offline   Reply With Quote
Staro 06.11.2013., 21:54   #527
RaWeN
RaWeN's Avatar
Datum registracije: Aug 2009
Postovi: 637
Vi ste mazohisti.
RaWeN je offline   Reply With Quote
Staro 06.11.2013., 23:45   #528
sa20
sa20's Avatar
Postovi: 199
Autor Hellhound Pregled postova
3. Crasha
Hehehe aj nisam jedini . Tak je i meni, od 5 partije 1 ili 2 najviše mi prođu bez crasha.
Danas sam bio prvi put commander, tek sam uspio do lvl 10 doći napokon. Čak sam uspio sa raketama puno ljudi ubiti, točno su mi se naredavali na jednom mjestu nekoliko puta. Užitak kad pukneš raketu a ono pol ekrana se popuni sa killovima
Staro 07.11.2013., 00:03   #529
trpi
usao, odigrao malo sa jetom i chopperom - ocjena 2. zvuk posebno ocajan, ostalo da ne komentiram, jedino grafika valja i igra na istim postavkama bolje radi od trojke.
ako mi se ne svidi u roku tjedan dana ide na trznicu a ja se vracam firestormu caspianu khargu viperu hornetu <3
Staro 07.11.2013., 00:08   #530
Dottore
Dottore's Avatar
Postovi: 7,701
Autor mrva_zg Pregled postova
Zvučna preko matične? Realtek?
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 07.11.2013., 00:33   #531
slavonac90
slavonac90's Avatar
Postovi: 1,530
3. Crasha
de mi reci molim te kak ti šljaka igra? vidim da su nam tu negdje konfiguracije otprilike pa da znam jel mi se isplati kupovat ili da bolje uzmem premium za BF 3
slavonac90 je offline   Reply With Quote
Staro 07.11.2013., 01:53   #532
simpleplan
Datum registracije: Jun 2013
Postovi: 286
Skoro sam je kupio na g2playu, hvala Bogu sto sam usao u ovu temu
simpleplan je offline   Reply With Quote
Staro 07.11.2013., 02:04   #533
dean225
DD9512
dean225's Avatar
Postovi: 1,869
@Hellhound
Nije do igre već do kompa. Imaš par kritičnih nedostataka
1. Igra sama pojede više od 4gb rama koliko ti imaš, treba ti bar 8
2. Imaš slabašnu ati grafu koja ima problema s driverima + mišljenja sam kako je 1gb rama na grafi puno premalo za ovu igru.
I cpu ti je slabašan ali ovo gore su kritični problemi..
dean225 je offline   Reply With Quote
Staro 07.11.2013., 11:48   #534
pdx
pdx's Avatar
Datum registracije: Dec 2009
Lokacija: krk
Postovi: 515
Meni je igra super, igram hard-core par metaka i mrtav tako je s svim vozilima, uglavnom funkcionira odlično :d
pdx je offline   Reply With Quote
Staro 07.11.2013., 13:37   #535
mrva_zg
mrva_zg's Avatar
Postovi: 959
Autor Dottore Pregled postova
Jap
Isto mi se nije dešavalo u bf3 iako se ekipa žalila
Staro 07.11.2013., 13:52   #536
trpi
za ekipu koja je igrala bf3 od pocetka, jel i trojka bila ovako grbava i nebalansirana u pocetku kao sad 4?
kakve promjene mozemo ocekivati u buducnosti, ne mislim na crash fixeve i stabilnost vec samu igru, balansiranje (smanjivanje moci anti aira, povecavanje moci helikoptera i stealth jetova, nerfanje okretnog radijusa SU-50 etc..), poboljsanje zvuka? ili samo sitnice?
ne zelim da me netko uvjerava kako je ipak dobra i balansirana igra te kako se samo treba priviknuti, nego kolika je sansa da ce raditi drasticne promjene (jel uopce moguce to kroz patcheve), jer ovo sad mi se nista ne svidja.
Zadnje izmijenjeno od: trpi. 07.11.2013. u 13:58.
Staro 07.11.2013., 14:04   #537
jopis
gadget freak
jopis's Avatar
Lokacija: Jasenovac
Postovi: 2,224
Autor trpi Pregled postova
Bf3 je bio zbuggan i pun glitcheva daleko gore i daleko više kad je izišao.
To što možemo očekivati u budućnosti zna samo ea. Balansiranja i nerfanja ovise o whineanju širokih igračkih masa, pošto uvijek najglasniji i najuporniji redovno whineaju po službenom forumu, pa se nauštrb takvih mrda po igri svako malo, jer uvijek je nekome nešto preslabo, ili op -.-
MobileAA u bf4 nije prejak, pogotovo ruski, (pričam o strojnici), samo mu malo treba smanjit range lockanja, al ne previše, jer onda će biti beskoristan za tv-from-deployment ekipu.
Stealth jetovi su sasvim ok kad se unlockaju do kraja, njihova namjena je air2air borba, i to rade kako treba.
Neće tebe nitko uvjeravati kako je dobra igra, ako ti ne paše, ima masu drugih igara, odi i igraj, ja tu ne vidim nikakav problem. Čemu igrati nešto što ti se ne sviđa, pogotovo ako si odigrao 'čak' 5h igre i zaključio to sve
Staro 07.11.2013., 14:21   #538
Neo-ST
Neo-ST's Avatar
Postovi: 8,564
Igra bi trebala biti više-manje balansirana nakon 30-ak patcheva i zadnjeg DLC-a.
Najbolje ti je počekat pa vidit
Staro 07.11.2013., 14:56   #539
Postovi: 17,138
Autor dean225 Pregled postova
@Hellhound
Glupost.
Ako je tako, zašto svi kažu da bf4 radi bolje od bf3?
Ja sam s svojom konfom (koja je slabija od hell-ove) igrao bf3 na ultra.
6850 nije slabašna grafa neko je čisti mid-range, a proc je čisto solidan. I više nego solidan po meni.
Staro 07.11.2013., 15:10   #540
mrva_zg
mrva_zg's Avatar
Postovi: 959
Bitna stavka u tome svemu kaj si reko je rezolucija na kojoj igraš
