Staro 19.10.2013., 00:34   #361
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Autor 1v@n Pregled postova
Ma i firewall je ugašen. Probao sam sve što se moglo probati i nema pomaka.
Jesi probao ovo što na nekoliko mjesta spominju kao moguće rješenje; isključivanje svih eksternih diskova i svega što nije neophodno (za vrijeme instalacije)?
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 19.10.2013., 00:35   #362
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,123
Jesam, ali nije pomoglo. Riješio sam situaciju u međuvremenu. Imam triple boot i 4 diska u kompu. Ištekao sve osim Win8 diska i proradilo je odjednom. Ne znam kaj ga je mučilo, ali eto, šljaka sad.
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
Staro 19.10.2013., 00:38   #363
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
triple boot? I onda se čudiš!?
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 19.10.2013., 00:40   #364
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,123
Autor estugarda Pregled postova
W7, W8 i OSX
Sve radi savršeno i nikad problema dosad. Tko bi rekao da će običan OS update radit probleme.
LCD: BENQ PD3200Q
Staro 19.10.2013., 01:00   #365
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Update od 3-4GB je teško obični update...Bilo bi zanimljivo vidjeti što se sve promijenilo.
Kod mene sve fino radi. Ne vidim nikakve razlike u performansama, ali i do sad je bilo brzo. Dorade u Metrou su za pohvalu. Sad ću ga možda i malo više koristiti.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 19.10.2013., 01:12   #366
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,123
Maknuo sam Start8 misleći da je povratak starta ono povratak, for real, pa šipak
Vraća se Start8 gore opet
LCD: BENQ PD3200Q
Staro 19.10.2013., 10:09   #367
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Pa kaj će ti start? Zašto si ne namjestiš tileove za ono što bi inače čeprkao po Startu!? Sad imaš i grupe. Tileove možeš skroz smanjiti, a kad navigiraš iz Starta, tam je ionako 75% stvari koje su zapravo višak (ako ručno ne makneš), pa te samo uspori.
Uostalom, apsolutno je najbrži način pokretanja bilo čega (na desktopu) tak da jednostavno počneš pisati što hoćeš, zar ne?
Meni micanje starta nikad nije smetalo, jer sam oduvijek koristio ObjectDockove, a sad na Win8 više ne moram.
Ono što meni smeta da još uvijek nije popravljen bug sa resetiranjem kalibriranih boja. A i taj novi način skaliranja uopće nije novi. Ja i dalje ne kužim kako namjestiti DPI za zasebne monitore. Meni se i da dalje skaliraju svi...Iako nije check-ano ono "Let me choose one scalling level for all my displays".
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 26.10.2013., 12:35   #368
viper
super user
viper's Avatar
Lokacija: Houston, TX
Postovi: 1,805
Jel ovaj upgrade sa 8ice na 8.1 stalno besplatan ili ima neki određeni free period (a poslije se placa)?
viper je offline   Reply With Quote
Staro 26.10.2013., 18:19   #369
imaticx
Default
imaticx's Avatar
Lokacija: Požega
Postovi: 1,519
Stalno
Staro 28.10.2013., 21:43   #370
mmatrix
Datum registracije: Mar 2008
Postovi: 121
Može li se u sklopu reset/refresh funkcije promjeniti disk iz mbr u gpt (EFI boot)?
Origin_ID: mmatrix05
Steam_ID: mmatrix05
mmatrix je offline   Reply With Quote
Staro 09.11.2013., 20:19   #371
tutix
tutix's Avatar
Postovi: 4,069
Malo njubersko pitanje - koji su benefiti GPT u odnosu na MBR ako govorimo recimo o 120GB SSD-u i Windows 8? Prvenstveno me zanima (super) fast boot ili kako to već nazivaju u postavkama BIOS/UEFI-a?
Naime, uzeo bi možda SSD za ovaj stari laptop i sad me zanima koliko je to dobra ideja, odnosno je li bolje ići na nešto novo odmah jer ova ploča nema UEFI...
Staro 09.11.2013., 21:13   #372
santos
santos's Avatar
Lokacija: Čakovec / AT
Postovi: 1,782
mislis na suspend?
meni na asus ultrabooku dizanje iz suspenda traje oko 4 sekunde (pentium 987 1,5 Ghz dual core, 4 gige rama, 500 gb disk)
ako uzmemo u obzir da jedan asus zenbook za 1000+ eura (i7, 8 giga rama, SSD disk) ima dizanje iz suspenda 2 sekunde... meni je to zanemarivo.
slow is smooth, smooth is fast...
santos je offline   Reply With Quote
Staro 15.11.2013., 16:40   #373
gin.tonic
gin.tonic's Avatar
Postovi: 2,438
Upgrade na Windows 8.1 nema problema?
Pitam jer mi nudi a ne želim neke probleme
gin.tonic je offline   Reply With Quote
Staro 15.11.2013., 17:52   #374
D.O.M.I.
D.O.M.I.'s Avatar
Datum registracije: Jul 2009
Postovi: 279
Neki dan odradio, prošlo bez i najmanjeg problema, skine se, instalira i pičiš.
D.O.M.I. je offline   Reply With Quote
Staro 26.12.2013., 21:37   #375
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Da li je netko imao windows automatic repair problem.
Zapravo kao neka beskonacna petlja, i sad ne mogu nikako u windowse osim da napravim nanovo instal..
Probal sam sa onom komandom u cmd ali nikako da mi se recovery promjeni u off, znaci pise mi da je komanda uspjesno izvdsena ali nis se ne mijenja...
Moze pomoc? 3 dana igram igrice i nis, a danas sam se primil pisanja seminara i evo pi7darije...
danc00 je offline   Reply With Quote
Staro 09.02.2014., 23:13   #376
dean225
DD9512
dean225's Avatar
Postovi: 1,869
ja imam problem sa critical process died i ne nalazim rijesenja na netu..
Ustvari ništa mi od riješenja ne pomaže!! Znači nova instalacija win 8.1 Pro, čista instalacija.. Komp radi uredno sve do prvog restarta a onda critical process i skoro ga je nemoguće više upaliti. U eventima mi pokazuje kernel power grešku.
O čemu bi se moglo raditi?
Molim moderatora da mi premjesti post, promašio sam podforum (u Windows 8.1)
EDIT:Rijeseno. Problem je bio u Avastu!
Zadnje izmijenjeno od: dean225. 12.02.2014. u 16:32.
dean225 je offline   Reply With Quote
Staro 28.03.2014., 21:13   #377
zele
zele's Avatar
Lokacija: split
Postovi: 51
Autor danc00 Pregled postova
eto i taj problem je na osmici naucna fanstatika za rijesiti...na sedmici je to bilo jednostavno..
zele je offline   Reply With Quote
Staro 29.03.2014., 22:17   #378
Poggiali
Rocker
Poggiali's Avatar
Lokacija: Zagorje
Postovi: 2,030
imam pitanjce... da li mi na laptop lakse stavit win 8 preko diska ili usb?
Konfa: Intel Core 2 Duo E 6400, 2.72GHz || Asus P5B Deluxe || 8800 EVGA GTS 320 mb || Super Talent 2x1 gb 800MHz CL5 || Seagate Barracuda 7200.10 320 GB 16 mb || Samsung Spinpoint F1 750 GB 32mb || Seasonic S 12 430W || A+ X-Blade || Logitech Z 5500 || CL X-Fi Xtreme Game || Logitech G500 || Logitech UltraX Flat Desktop || Canon Pixma iP4300 || Samsung ML-2510 || Toshiba Regza 32XV733G
Poggiali je offline   Reply With Quote
Staro 29.03.2014., 22:20   #379
Postovi: 8,223
Usb, ako ništa drugo, zato što si gotov doslovno u 5 minuta s instalacijom windowsa.
Staro 29.03.2014., 22:48   #380
Poggiali
Rocker
Poggiali's Avatar
Lokacija: Zagorje
Postovi: 2,030
Jel moze neki proces u kratkim crtama ili ak ima neki linkic, a da je provjeren ?
Staro 29.03.2014., 23:33   #381
Postovi: 8,223
Za što, instalaciju il stavljanje na stick?
Ako je instalacija, stvarno nemaš što, par klikova Next i to je to. Eventualno te može bunit postavljanje računa jer trebaš kao imati windows online acc, al nemoraš. Samo dole odabereš opciju za offline. Nesjećam se sad točno, davno sam instalirao.
Staro 29.03.2014., 23:47   #382
Poggiali
Rocker
Poggiali's Avatar
Lokacija: Zagorje
Postovi: 2,030
Ma prebacivbanje na stik mi je veci problem, imam neki rufus tool, pa ne znam princip, ja znaci na postojecim windowsima pripremim stick, i onda kod bootanja na laptopu namjestim da je usb first boot device ?
Staro 29.03.2014., 23:49   #383
Postovi: 8,223
Da, tako ti je najlakše
Staro 30.03.2014., 09:10   #384
Charmander
Ultrapiretik
Charmander's Avatar
Postovi: 903
koristi rade windows download tool. nema postelavanja, samo odaberes iso i stavis "begin copying". nista lakse.
Moja trgovanja: 1, 2, 3, 4, 5, 6, 7, 8
Picoin invite: bass999 // minepi.com/bass999
Charmander je offline   Reply With Quote
Staro 31.03.2014., 16:43   #385
Postovi: 8,464
Nažalost, Windows USB Tool ima tendenciju baciti missing bootsect error, pa Rufus ipak predstavlja bolje, brže i bezbolnije rješenje.
Staro 31.03.2014., 16:50   #386
Guls
Guls's Avatar
Lokacija: Sveta Nedelja
Postovi: 2,938
Meni se upravo jučer po prvi put to desilo... ali ovaj alat je ok.
Intel i7 9700F
32GB Hyper-X DDR4-2666
2TB 970Pro PCIe NVMe M.2
Windows 11 Professional
Periferija
2 x 27" Dell P2723D
Corsair SP2500 2.1
Logitech MK270
17,3 FHD IPS 144Hz
AMD Ryzen 7 5800H
16GB DDR4-3200 RAM
1TB PCIe NVMe SSD
Sony Playstation 5
Staro 06.04.2014., 21:36   #387
santos
santos's Avatar
Postovi: 1,782
pitanje: kak uci u bios u windows 8?
radi se o asus laptopu x201e
dok restartam lap direktno windowse dize, asusov logo ni pola sekunde nije gore, probao stiskat f1, f2, nista...
pitam jer kad probam instalirat asus winflash dobijem ovo:
probao ovo:
http://rog.asus.com/forum/showthread...stall-WinFlash
al i dalje ne mogu ni prismrdit biosu. ideje?
takodjer, kak obrisat sve ove podatke koje glupe windows 8 aplikacije navuku? (prognoza, windows store i te gluposti)
EDIT: uspio apdejtat bios , trebalo je ATKACPI drivere instalirat da ga prepozna kao asus, onda ide s winflashom.
Zadnje izmijenjeno od: santos. 06.04.2014. u 21:52.
Staro 26.04.2014., 20:31   #388
spawn
spawn's Avatar
Postovi: 8,459
Windows 8
Mali problemčić. Laptop asus x550c s predinstaliranim windows 8 64bit. Malo poceo stekati pa probao napraviti restore s particije i javlja mi: Pogon na kojem je instaliran windows je zalljucan. Otkljucajte pogon. Naravno prije toga pita password kojeg normalno ubacim. Password je 100% točan jer kad upisem pogrešan odmah javi da password nije točan. U bioeu provjereno sve,nema nikakvog locka ili passworda. Ima netko ideju?
Staro 26.04.2014., 21:35   #389
preX
Postovi: 15
Imam sličnih problema. Poslao sam mail podršci pa ćemo vidjeti.
preX je offline   Reply With Quote
Staro 27.04.2014., 20:37   #390
Baja 001
Baja 001's Avatar
Postovi: 7,504
Zasto ne OEM ISO i sve ubijes? Kljuc ce radit...
