Staro 16.10.2013., 20:37   #1
_saiko
system kaiser
Postovi: 194
MicroUSB kabeli
Gdje na netu nabaviti jeftine ali kvalitetne USB-MicroUSB (2.0) kabele?
Nabavio sam za sichu nekoliko takvih preko ebaya (kinez) pa je toliko losa kvaliteta da niti mobitel ne moze puniti.
Ako netko ima ideju a da shipping nije višestruko veći od same robe preporučam se.
<FLEET>
MBO: Gigabyte GA-X58A-UD7 (rev. 2.0)
CPU: Intel Core i7-950 @ 3.2 GHz
Chipset: Intel X58
RAM: 6 x 4 GB DDR3-1600 (PC3-12800)
VGA: HD4850
HDD(OS): OCZ Vertex3 120GB
HDD(local storage): WD WD2002FAEX 2TB, 2x Seagate 500GB (RAID0@IRST/ICH10R)
ODD: Optiarc (?)
PSU: Silverstone SST-ST60F-P Corsair VX450
Display: Samsung Syncmaster 930BF @ 1280 x 1024
Display2: Panasonic TC-P55VT60 @ 1920x1080
Other: eSata dock
OS: Windows 7 Ultimate x64
Input:
Logitech MX1000 + Logitech UltraX cordless
Model: HP Z420
CPU: Intel Xeon E5-1650 6x core @ 3.2 GHz
Chipset: Intel Sandy Bridge-E
RAM: 4 x 16 GB DDR3-1600 (PC3-12800)
VGA: Nvidia
HDD(OS): Seagate ST500DM002 500GB
HDD(local storage): 2x WD WD5000AAKX (RAID1@C600 SAS/SATA ctrl)
Display: 2x HP LA2205wg 22" @ 1680 x 1050
OS: Windows 7 Enterprise x64
Model: HP Elitebook 8570
CPU: Intel i5 3360M
Chipset: Intel Ivy Bridge
RAM: 2 x 8 GB DDR3-800 (PC3-12800)
VGA: Intel HD4000
HDD: Samsung SSD 850Pro 512GB
ODD: DVD+/-RW
Display: 15.4" (1366 x 768)
Other: Fingerprint reader
Input:
Logitech V500 cordless
MBO: GA-P35-DS3P (rev. 2.0)
CPU: Intel C2Q Q6600 @ 2.4 GHz
RAM: 4 x 2 GB DDR2-800 @ 533 MHz
VGA: ATI Rage 3D @ PCI
HDD(OS): Seagate ST380815AS 80GB / Seagate ST3500418AS 500GB
HDD(storage01): 2x WD RE WD4000FYYZ 4TB (RAID10,f2@mdadm)
HDD(storage02): WDC WD20EARX-00P 2TB
HDD(storage_cctv): Seagate ST3250824AS 250GB
ODD: NEC DVD-RW ND-4551A
PSU: Corsair GS800
Display: -
LAN: Intel 82571EB @2x1Gbps LACP
Controllers: RS232 Oxford Semiconductor Ltd OXuPCI952
OS: Linux x64 (Ubuntu 14.04 LTS)
MBO: HP ProLiant DL120 G7
CPU: Intel Xeon E3-1220 @ 4x 3.10GHz
Chipset: Intel i875P-ICH5
RAM: 4 x 4096 MB DDR3-667 (PC3-10600)
HDD1: 2x MB2000EBUCF HUA723020ALA640 2TB 7200RPM (RAID1@P410)
Display: -
LAN: 82574L @ 1000Mbps FD
OS: Linux x86_64 (Ubuntu 14.04 LTS)
MBO: ASRock 4Core1333-FullHD
CPU: Intel Core 2 Duo E84000 @ 3.0 GHz
Chipset: ATI RS600+SB600
RAM: 1 x 512 MB DDR2-800
VGA: -
HDD: Seagate 500GB
ODD: DVD-RW
PSU: Corsair VX450(?)
Display: Panasonic TH-50PY800
LAN: @1Gbps FD
OS: Windows 8.1 Pro x64
Input:
Logitech Cordless DiNovo Edge
MBO: Intel D201GLY2 (ITX)
CPU: Intel Celeron 220 @ 1.2GHz
Chipset: SiS662
RAM: 1 x 512 MB DDR2-533
VGA: Intel
HDD: Sandisk 1GB CF @ CF2IDE
ODD: -
PSU: miniITX type(?)
Display: -
LAN1-Uplink: @1000Mbps FD
LAN2: @100Mbps FD
OS: Mikrotik OS 6.28
Model: Mikrotik RB2011UAS-2HnD
</FLEET>
cat.7 - where crosstalk is not an issue anymore.
_saiko je offline   Reply With Quote
Staro 16.10.2013., 20:45   #2
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,051
Mislim da ti je problem u punjaču prije nego u kabelu. Imam ih valjda 10 s ebaya po 0.99$, oćeš okrugli, plosnati, od 5 cm, 20 cm, zeleni, plavi ili crni. Svi rade savršeno.
Provjeri kabel na poštenom punjaču.
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 16.10.2013., 22:41   #3
_saiko
system kaiser
Postovi: 194
Nije problem u punjacu sigurno.
Problem je najizrazeniji kada spojim mob sa (bilo kojim) PC-em. Uopce ga ni ne prepoznaje a kamoli puni.
Originalni kabel nikakvih problema.
<FLEET>
Chipset: Intel X58
VGA: HD4850
ODD: Optiarc (?)
Other: eSata dock
Input:
Model: HP Z420
VGA: Nvidia
CPU: Intel i5 3360M
VGA: Intel HD4000
ODD: DVD+/-RW
Input:
PSU: Corsair GS800
Display: -
Display: -
VGA: -
HDD: Seagate 500GB
ODD: DVD-RW
LAN: @1Gbps FD
Input:
Chipset: SiS662
VGA: Intel
ODD: -
Display: -
LAN2: @100Mbps FD
</FLEET>
Staro 16.10.2013., 22:52   #4
spawn
spawn's Avatar
Postovi: 8,368
U pravu si. Ebay kablovi su u 90% slucajeva smece. Ja sam ih dosad bacio bar 30 komada. Svaki put kupujem sve bolji ali opet bude smece. Dok originali koje dobijes uz mob rade besprijekorno,pogotovo nokia. Imam nokijin usb kabel na kojeg se spojilo bar 500 telefona ,sto fleshanje,sto unlock,backup ,prijenos podataka i jos radi. Tako i samsung i htc.
Staro 16.10.2013., 23:08   #5
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,051
Očito onda imam sreće
Evo linkova na dvojicu od kojih sam uzimao
1
2
LCD: BENQ PD3200Q
Staro 17.10.2013., 02:00   #6
SilentException
SilentException's Avatar
Lokacija: RI-KR
Postovi: 789
Ti kineski eBay kablovi su jako loši. Može se naletiti na dobar primjerak ali niti jedan mi nije izdržao dugo, obično su to unutra vodovi debeli 1 atom i naravno da se jako brzo unište...
Najbolji micro USB kabel do sad mi je onaj kojeg sam dobio sa Nexus 4. Baš je ono win u svim kategorijama, jako fleksibilan, kvalitetan konektor a kroz njega leti i 2 ampera, naravno i data isto radi Morat ću još bar 2 uzeti sa Play Storea dok ih još ima hehe.
Evo jedan dosta kvalitetan kojeg sam nedavno uzeo, poštarina isto nije bila paprena koliko se sjećam:
http://www.portablepowersupplies.co....cro-usb-cable/
Sve 5, fast charge radi odlično, malo duži micro USB konektor (obično nije problem), ali je kabel dosta "tvrd". Pazi, ovo je samo charge kabel ali imaju u ponudi i "normalan"
Još dva kvalitetnija kabela sam uzeo sa Farnella:
http://si.farnell.com/jsp/search/pro...sp?SKU=2085464
http://si.farnell.com/jsp/search/pro...sp?SKU=2115733
| Dell XPS m1530 Red | 15,4'' UltraSharp WSXGA+ (1680x1050) | Intel Core2Duo T7500 2.2GHz 4MB | 3GB RAM (1x2GB + 1x1GB) | nVidia GeForce 8600M GT 256MB DDR3 | Seagate 200GB 7200RPM | Slot Loading Dual-Layer DVD+/-RW | 6-cell (2.5 sati) & 9-cell (4.5 sati) batteries | Media Remote Control IR | Intel 4965AGN Wireless (2.4GHz & 5GHz Radio), Bluetooth, Fingerprint Reader, 8in1 Card Reader, 2 MegaPixel WebCam, LAN, HDMI 1080p connector, 3xUSB, Firewire, S-Video, VGA, ExpressCard slot | Windows Vista Home Premium | Logitech VX Nano Cordless Mouse | Logitech Alto Cordless Notebook Stand & Keyboard | Logitech AudioHub Notebook Speakers |
| TBA |
| Silverstone GD01B-MXR | Corsair HX620 620W Modular PSU | ASUS P5W DH Deluxe | Intel Core2Duo E6600 2.4GHz (3.0GHz) | nVidia GeForce 8800GTX 768MB DDR3 | AverMedia AverTV Hybrid Duo PCI-E | Creative Labs X-Fi Elite Pro | 200GB Seagate Barracuda 7200.8 7200RPM | BenQ DW1650 | Scythe Ninja Mini & Sharkoon Silent Eagle 92mm | 2x Sharkoon Silent Eagle 80mm | Case separated in two termal zones (CPU, HDD, DVDRW, TV Card & PSU, GPU, Sound Card) | AZiO BTD603-132 USB 2.0 Bluetooth Adapter | Logitech MX Revolution Cordless Laser Mouse | Logitech diNovo Edge Keyboard |
| D-Link DNS-323 A1 v1.05 fun_plug-ed + many mods | 2 x 320GB Seagate Barracuda 7200.10 7200RPM RAID0 | Cat6 Gigabit Network | 9k Jumbo Frames | Average (WRITE): 19,32 MB/sec | Average (READ): 28,60 MB/sec |
| D-Link DNS-323 B1 v1.05 fun_plug-ed + many mods | 2 x 1TB Samsung HD103UJ F1 7200RPM | Cat6 Gigabit Network | 9k Jumbo Frames | Average (WRITE): XX,XX MB/sec | Average (READ): XX,XX MB/sec |
| TBA (work in progress ) |
SilentException je offline   Reply With Quote
