Staro 30.09.2013., 19:58   #1
Charmander
Ultrapiretik
Charmander's Avatar
Postovi: 903
331.40 beta
Dosli novi driveri 331.40
The new GeForce 331.40 beta driver is now available to download. An essential update for all GeForce GTX users jumping into the Battlefield 4 beta, 331.40 beta ensures maximum performance and system stability in the shooter’s eagerly anticipated pre-release test.
331.40 beta also includes a major update to our NVIDIA Control Panel Ambient Occlusion feature, which allows you to apply fidelity-enhancing, realistic shading and shadowing to games that do not natively support Ambient Occlusion. With a few simple clicks, you can greatly increase the image quality of your favorite games, and now, with 331.40 beta, the quality of the Ambient Occlusion shading will be significantly higher thanks to the introduction of HBAO+.
edit: ispravljen link za drivere. fala xulos!
Moja trgovanja: 1, 2, 3, 4, 5, 6, 7, 8
Picoin invite: bass999 // minepi.com/bass999
Zadnje izmijenjeno od: Charmander. 02.10.2013. u 09:43.
Charmander je offline   Reply With Quote
Staro 01.10.2013., 10:22   #2
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
Bumo probali tunajt kad se vratim s posla, nadam se da valjaju jer mi je lagano muka od tih nvidiinih drivera.
Staro 01.10.2013., 15:44   #3
Mrakky
Mrakky's Avatar
Datum registracije: Oct 2012
Lokacija: Velika Gorica
Postovi: 115
nisam probao i nemrem nikaj tvrdit, al isto tako u control panelu primječujem da i na prijašnjim whql drajverima ima Occlusion feature, pa mi nije jasno kaj točno time dobivam, tj. jel sad u ovoj beti to radi kak treba ili kaj?
hvala!!!
Mrakky je offline   Reply With Quote
Staro 01.10.2013., 22:07   #4
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
krivi ti je link za drivere ovo su najnoviji http://www.geforce.com/drivers/results/67378
Staro 02.10.2013., 11:57   #5
Mrakky
Mrakky's Avatar
Postovi: 115
su vidljive kakve promjene sa novim drajverom, doživljaji neki, dal bi sljedeči mogli bit i bolji?
niko nikaj ne piše, pa nije valjda da niko ne instalira više bete nakon onih fijaska koje još uvijek neki imaju, na svu sreču ja nemam, smatram da je tu dosta odgovoran i ostatak konfe.
Staro 02.10.2013., 18:31   #6
e-one
Civic (ab)user
e-one's Avatar
Lokacija: Zagreb-Dubrava
Postovi: 471
Da li i ovi novi driveri drapaju starije GTX-ice kao i 320.xx? Još uvijek sam na 310.70 jer su mi noviji izazivali artefakte prilikom igranja pa me bilo frka da mi ne ubiju grafu (pogotovo sad kad nema garancije više).
e-one je offline   Reply With Quote
Staro 02.10.2013., 19:03   #7
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,304
Autor e-one Pregled postova
stavi 314.22. oni su rock solid i preporuceni svugdje. ja njih vrtim i ni ne zelim probavat ovu ukletu seriju 320.
Staro 02.10.2013., 21:16   #8
e-one
Civic (ab)user
e-one's Avatar
Postovi: 471
Ma trebam nešto friškije radi bf4.....
Staro 02.10.2013., 21:34   #9
Volume
Datum registracije: Sep 2012
Postovi: 418
Ma stavija sam ih ja pa opet radi ajme majko. Imam gtx 660ti, 1080p, sve na low imam oko 50-60 fpsa uz ogromne frame dropove. Nikakve koristi od ove bete za bf4...
Volume je offline   Reply With Quote
Staro 02.10.2013., 22:12   #10
e-one
Civic (ab)user
e-one's Avatar
Postovi: 471
Driver je ok, nema artefakata, al baš kako kažeš, ovo je totalni raspad, treba to još puno optimizirati da bi bilo igrivo.....
Staro 03.10.2013., 18:00   #11
zagy1984
zagy1984's Avatar
Datum registracije: Jan 2012
Postovi: 105
do sada sam imao problema samo sa jednom serijom drivera,ostalo sve radi kao podmazano u sli-u
nekužim kako imate toliko problema oko drivera
zagy1984 je offline   Reply With Quote
Staro 03.10.2013., 22:05   #12
e-one
Civic (ab)user
e-one's Avatar
Postovi: 471
Nemamo, ja nikad nisam imao problema do 320.xx. Updateove sam radio valjda svakih 6mj ili više i to mi je jedan od glavnih razloga zašto imam nvidiu. Ove 320 kad sam instalirao u igrama su mi se počeli pojavljivati artefakti, navodno neki bug s throtlanjem gpu-a ili tak nešto. Prvo sam mislio da vga umire, ali sam naišao čini mi se baš na pce da se pričalo o tome i vratio sam se da 310.70 koje sam imao prije toga i sve je bilo ok ponovno. Sad sam radio update jer BF 4 ima nenormalne dropove pa čisto da probam jel kaj bolje s tim beta kao optimiziranim za bf....al nije, isti k.....treba se još bf polirat
