Zaključane teme
Staro 20.09.2013., 01:30   #631
dean225
DD9512
dean225's Avatar
Postovi: 1,869
Čak sam toliko blesav da sada kada odem u njemačku kupim sony, sebi ostavim sat a sonya prodam.
dean225 je offline
Staro 20.09.2013., 07:09   #632
Autor dean225 Pregled postova
Čuj, 650 eura ti je 5000 kn. Ne znam ko bi ti dao tolike pare za mob. Ok, vjerojatno im netko... samo je pitanje tko
Brko je offline
Staro 27.09.2013., 10:27   #633
viper
super user
viper's Avatar
Lokacija: Houston, TX
Postovi: 1,805
Izgleda da je ekran na Z1 ipak losiji od Z ultra
Xperia Z1 display goes up against the Xperia Z Ultra
viper je offline
Staro 27.09.2013., 11:21   #634
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,741
Znači ipak još uvijek guraju TN-ce u mobitele!?
Pa se onda čude ko pura dreku, kad stignu prodajni rezultati.
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline
Staro 27.09.2013., 12:01   #635
Snowrider
Snowrider's Avatar
Lokacija: Lika
Postovi: 864
Ja neznam što je problem s tim ekranom na Xperiji...... Osobno mi je na Xperiji Z ekran WOW. Prvo sam imao anti-finger screen protector koji je bio malo mutan. Kad sam metnuo novi screen protector , ekran izgleda super...
Snowrider je offline
Staro 27.09.2013., 12:06   #636
Master_Hrc
Master_Hrc's Avatar
Lokacija: Bec
Postovi: 1,182
Imao sam xperiu Z u ruci od frenda....i stvarno sam ostao paf kako mob rula.....definitvno nakon 3 godine desire hd sljedeci mob mi je ako cu imati love dotični.....fala bogu pa se nisam previše obazirao na pljuvanja po ekranu....koja su očito čista propaganda
Master_Hrc je offline
Staro 27.09.2013., 12:19   #637
Snowrider
Snowrider's Avatar
Lokacija: Lika
Postovi: 864
Nećeš pogriješit sigurno...a pljuvanje po ekranu je samo zato što se mobu ne može naći nikakva greška pa ajmo pljuvat po ekranu.
Staro 27.09.2013., 12:22   #638
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Pa kakva propaganda? Lijepo se na fotkama vidi usporedba displaya koji ima konzistentne boje po otklonu kuta gledanja i z1 koji deformira boje. Možda to nekome i ne smeta, ali danas i najjeftiniji kinezi imaju ips display sa 178 stupnjeva vidljivosti bez ovakvih deformacija. Činjenica je da iz nekog razloga sony još uvijek gura tn...ili možda neku drugu tehnologiju koja ima probleme sa kutevima...
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 27.09.2013., 12:46   #639
Master_Hrc
Master_Hrc's Avatar
Lokacija: Bec
Postovi: 1,182
je u pravu si...ovih 178 stupnjeva je dosta kritično.....da je 177 jos bi covjek i presao bez toga....uglavnom neznam čemu tupljenje jednog te istog....fino kupiš onda najjeftinijeg kineza i problem riješen...
Staro 27.09.2013., 12:54   #640
Jaoooo, evo opet... gurui i šamani koji VIDE...
Brko je offline
Staro 27.09.2013., 12:59   #641
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
A što mogu kad to vidim i kad mi smeta? Vjerojatno je profi deformacija.
Izgleda da se to ovdje ne smije reći. OK!
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 27.09.2013., 13:49   #642
Autor estugarda Pregled postova
Nije stvar jel se smije ili ne smije reći... poanta je da smo to odavno apsolvirali. Da, ekran nije state of the art. A mene samo zanima, koliko još puta treba to ponoviti??? Jel vidiš mene kako svaka 2 tjedna u Samsung temi pljujem po Amoledu ili u HTC temi kako pljujem po IPS-u?
Jednostavno - dosadno je to i bogu i vragu više sa tim ekranima, a pola pljuvača nije ni vidjelo Xperiju Z uživo ili držalo u ruci dulje od 2 minute. Samo to.
Brko je offline
Staro 27.09.2013., 13:52   #643
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
OK, OK. U pravu si. Mea culpa.
Reagirao sam zato jer me iznenadilo. Mislio sam da su se od Ultra Z konačno opametili.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 27.09.2013., 14:20   #644
Sony očito ima svoju neku politiku i neke svoje razloge koji su svima nama čudni. Možda bi mobitel sa IPS ekranom bio skuplji ili manje otporan. To samo oni znaju zašto... Ekrani su Sharpovi ili JDC-ovi, a oboje japanske firme. Možda je i lokalpatriotizam u igri
Brko je offline
Staro 27.09.2013., 14:33   #645
gin.tonic
gin.tonic's Avatar
Postovi: 2,434
Autor Daky007 Pregled postova
Opet ovisi koliko platiš mobitel, da ga kupiš za 1500kn preko pretplate npr. onda ćeš zanemariti lošiji ekran/kuteve gledanja, ali ako ideš kupovati mobitel za 3500kn npr. onda će ti sigurno biti faktor kakav ekran ima...
Tako da to 'pljuvanje' ima smisla.
gin.tonic je offline
Staro 27.09.2013., 14:39   #646
Autor gin.tonic Pregled postova
Istina, ali i onda isto tako si u dilemi jel oćeš mobitel od aluminija, plexiglasa ili reciklirane plastike od jogurt-čašica. Pa netko u tom slučaju i zažmiri na ekran i uzme nešto za što misli da je ljepše,bolje,kvalitetnije dizajnirano
Brko je offline
Staro 27.09.2013., 14:49   #647
tonisostaric
Datum registracije: Feb 2011
Postovi: 288
Ja sam baš gledao testove i upravo ta plastika iz čašica je otpornija od tvojeg stakla. Isto tako mi je amoled sa živim bojama daleko bolji od ispranog sonijevog ekrana i tmurnog sivila kojeg vidim dovoljno svakog dana u gradu. Isto tako mi touchwiz daleko ugodniji od sonijevog launchera i da dalje ne nabrajam.
Ti ko da sam svojeg konja hvališ, a moj main phone niti je samsung niti sony niti htc, toliko o tome.
tonisostaric je offline
Staro 27.09.2013., 14:51   #648
Autor tonisostaric Pregled postova
Tebe smo majstore čekali. Svaki put se lijepo upecaš još dvoje-troje i svi ste opet tu...
Brko je offline
Staro 27.09.2013., 14:52   #649
gin.tonic
gin.tonic's Avatar
Postovi: 2,434
Sad ovisi da li mobitel misliš imati u kurtonu
Materijal dolazi do izražaja ako nije u kurtonu.
Staro 27.09.2013., 14:52   #650
Master_Hrc
Master_Hrc's Avatar
Lokacija: Bec
Postovi: 1,182
Ja sam baš gledao testove i upravo ta plastika iz čašica je otpornija od tvojeg stakla....
Buduci da si ja razmisljam o kupnji xperie daj mi molim te link na te testove......fuckas staklo na mobu ako je ta plastika iz čašica otpornija....
Staro 27.09.2013., 14:58   #651
Nebi znao. ne koristim kurton
nakeljio sam kaljeno staklo na prednju i stražnju površinu moba
Brko je offline
Staro 27.09.2013., 15:05   #652
tonisostaric
Postovi: 288
Evo npr Note 2, ekran nakon 3 pada kao nov, samo rub oštečen, a kod nas ti zamjena novog ruba u servisu dođe 230kn
https://www.youtube.com/watch?v=mA0r7tc6V5s
Xperia Z
https://www.youtube.com/watch?v=00WsPnOHh6I
Nakon drugog pada ekran mrtav.
Toliko o tome koliko plastika ne valja.
Staro 27.09.2013., 15:16   #653
Master_Hrc
Master_Hrc's Avatar
Lokacija: Bec
Postovi: 1,182
ček malo nakon drugog pada sa metra visine na beton pukne staklo i to znači da mob ne valja
Vjerojatno sam onda ja čudan skupa sa poimanjem čvrstoće....
Staro 27.09.2013., 15:20   #654
tonisostaric
Postovi: 288
Poanta je da staklo nije izdržljivo kao plastika. A pazi koje je i jeftinije za zamjeniti?
Staro 27.09.2013., 15:31   #655
timmy
timmy's Avatar
Lokacija: N/A
Postovi: 1,242
timmy je offline
Staro 27.09.2013., 15:31   #656
Kuiš, isti je test, ista visina, isti kut udarca, sve je isto u oba testa. Kak ne vidiš to
Brko je offline
Staro 27.09.2013., 18:59   #657
warlock25
warlock25's Avatar
Postovi: 2,327
evo spojio mob na pc companion i ponudio mi update firmwera na 10.3.1.A.2.67
koji je to firmware?
sony xperia z unbranded bootloader unlock:yes
Zadnje izmijenjeno od: warlock25. 27.09.2013. u 20:00.
warlock25 je offline
Staro 27.09.2013., 20:01   #658
Autor warlock25 Pregled postova
To je zadnji update koji je izašao, pred 2-3 dana. Slobodno ga updateaš, same pohvale na njegov račun na XDA forumu.
Brko je offline
Staro 27.09.2013., 21:04   #659
warlock25
warlock25's Avatar
Postovi: 2,327
Evo vec je i rootan.to je valda zadnji prije 4.3
Staro 27.09.2013., 22:47   #660
To svaki puta se misli
Brko je offline
Zaključane teme
