Staro 04.09.2013., 10:44   #31
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,741
Moguće da se ti podaci automatski generiraju pa nisu naročito točni. Vidiš da neke stvari fale. Ali ako sam dobro shvatio, razlika je u flip out LCD displayu na RX100M II i ovoj tehnologiji koja na njemu dodaje po jedan bijeli pixel. Ak sam dobro skužio, to mu diže brightness...Ili tak nešto...
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 04.09.2013., 11:20   #32
tOta
Lokacija: ...
Postovi: 685
Činjenica je da RX100 i RX100 II koji je samo poboljšani prethodnik su najbolje kompaktne kamere uz možda samo par konkurenata koji su jednako dobri ili malo kaskaju za njim, ali osobni favorit mi je već dugo vremena RX100 i Oly XZ-2.
Taj Snapsort ne uzima se za ozbiljno, RX100 II Preview
Najvažnija razlika između I i II jeste što zadnji ima hot-shoe koji omogućuje npr. korištenje trigger za opaliti flash te poboljšan senzor, ali to tek testovi trebaju pokazati.
Sami aparati su u rangu 600-750$, dok za QX100 nekih 450$.
Edit: dodata nula.
Zadnje izmijenjeno od: tOta. 04.09.2013. u 11:33.
tOta je offline   Reply With Quote
Staro 04.09.2013., 11:30   #33
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Autor tOta Pregled postova
QX10 nekih 450$.
Fali ti jedna 0, što je u ovom slučaju bitno. Dakle za QX100 su rekli da će biti $450. Ali to je vjeorjatno cijena za USA, a mi ovdje možemo očekivati dosta više. Nadam se ne duplo, kao što je kolega Mad_Duke prorekao.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 04.09.2013., 13:14   #34
Postovi: 33,941
Tu imate sve moguće tehnikalije (i cijene).
http://www.xperiablog.net/2013/09/03...-leak-in-full/
Staro 04.09.2013., 17:06   #35
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Završila prezentacija na IFA. Ništa novog. Po pitanju informacija za QX10/100 još manje nego do sada u onim leakovima. Ovaj smušeni Sony-san nije čak ni upalio "objektiv" (on je to nazvao lens-camera, ako se ne varam). Namontirao ga na futrolu na Z1, malo buljio, zbunio se i odložio na pladanj koji je Japanka brže bolje odnijela negdje iza. Poslije toga je bio sav smušen. Možda se baterija "objektiva" ispraznila dok je šarafio, pa propao plan.
Slična stvar i sa Z1. Izvadi iz džepa i vrati nazad i nešto trkelja bezveze.
Nemoguće je ne sjetiti se Jobsovih prezentacija i ne primjetiti razliku.
Bez obzira na to, sviđa mi se Sony u posljednje vrijeme. QX mi je vrlo zanimljiv, i riješio bi mi problem koji trenutno imam. Ako konačno prestanu ugrađivati sranja od (TN) matrica, možda sl. put i razmislim o Sony uređaju...
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 04.09.2013. u 17:22.
Staro 04.09.2013., 18:12   #36
Postovi: 33,941
Pogledaj fotke na mom linku. Izgleda da ti objektivi funkcioniraju neovisno o mobitelu. Koliko sam uspio skontati, izgleda da imaju vlastitu memoriju i bateriju.
Staro 04.09.2013., 18:27   #37
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Otkud si ti sad ispao?
Normalno da imaju i da funkcioniraju sami za sebe. To odavno znamo.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 04.09.2013., 19:42   #38
aski
Je suis Schumi
aski's Avatar
Postovi: 1,524
Preskupa igračka + kad dodas i cijenu mobitela.
Za mene i dalje vrijedi staro pravilo - mobitel za poruke na razne nacine, pozive multimedija i internet, a fotoaparat za slikanje, kakav god da bio dodatak za mobitele Naravno, fotic na mobitelu ponekad dobro dodje (bez ovog cevapcica), recimo kad se vracas pijan ujutro s jaranima i s bocom Jacka udjes u pekaru po burek pa se naslikavas da se kasnije imas cemu smijati.
BTW, RX100 i nije bas najjeftiniji (barem gledajuci cijene domacih lihvara), ali ali bas da je najbolji, hmm. I ima cjenovno istih fotica sa APS-C senzorima....
Di sam stao?
Staro 04.09.2013., 20:09   #39
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Zašti bi dodavao cijenu mobitela?
U tome i je poanta i prednost ovog koncepta.
Velika je šansa da već imaš android ili ios mob. Nećeš kupovati mobitel, da bi mogao kupiti objektiv. To ne bi imalo smisla. Ovime mob koji imaš pretvoriš u dobar ili odličan kompakt kad ti treba, ovisno koji objektiv odabereš. Naravno, pod uvjetom da funkcionira kako se očekuje.
Nije za svakoga, ali mnogima bi bilo od velike pomoći. Ja sam među njima.
Problem je što nije 100% čisto rješenje. Moraš nositi dvije stvari. I što je puno gore od toga, moraš puniti baterije u obje stvari i paziti da se ne isprazni. Jer ako se isprazni jedna stvar više ne funkcionira cijela priča. Bilo bi puno bolje da postoji veza. Žična ili bežična (da Mad_Duke, nemoguće je), pa da se pripomogne skoro praznoj bateriji u jednom od uređaja.
I da. Preskupo je. Naročito kad se kod nas nabije jedno +50%.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 04.09.2013. u 20:15.
Staro 06.09.2013., 13:28   #40
NortonCommander
Orthodox file manager
NortonCommander's Avatar
Postovi: 422
NortonCommander je offline   Reply With Quote
Staro 06.09.2013., 13:39   #41
Mad_Duke
Može netko pojasniti ovaj movie recording?
Piše
Movie: MP4:12M (1440 x 1080, 30 fps)
1. Što mu to znači 12M?
2. ako je 1440x1080, a ne 1920x1080 zašto je sample na youtubeu u 1920x1080 @ 30P
http://www.pohrani.com/f/1Z/w7/2o6bxsyz/movie.jpg
Staro 06.09.2013., 13:47   #42
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Osobno, mislim da se radi o pogrešnoj informaciji, ali jedno vrijeme stvarno je bio taj HDV format na Sony kamerama kao ostatak snjimanja na trake, a do njega je dolazilo, ako se dobro sjećam zbog omjera pixela koji nije bio 1:1, nego 1.33, odnosno izduženi pixeli. Pa onda, iako bi se snimilo u 1440x1080, bio bi normalan aspect ratio na 16:9 FullHD. Pa i na YouTube-u.
A 12M je, Vjerojatno 12Mbps bitrate za MP4.
Ako jest istina da idu sa 1440 HDV, to je onda glupost naravno. Nema to više danas smisla kad sve živo ima mrcine od procesora.
EDIT: Kad bolje razmislim taj bitrate vjerojatno potvrđuje naše sumnje. 1920 je na WX150 i RX100 (kamerama sa kojih su ti objektivi) na 24Mbps. Tak da su se stvarno ovdje prosrasli izgleda...Valjda zbog šparanja na bateriji. Ali to je zbilja smiješno da jedan Note3 snima 4K, a ovo se nije moglo nabrijati na normalni FullHD.
A i te "službene" fotke sa njihove stranice treba uzeti sa srnom soli. To je ionak maksimalno nabrijano i peglano 100%. Kao i ono kad golf 1.9 TDI službeno troši 3,6l/100km.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 06.09.2013. u 14:16. Razlog: Hrpa tipfelera.
Staro 06.09.2013., 14:08   #43
Mad_Duke
Slažem se, ali... Jedno je mrcina od procesora koja će reproducirati. Drugo je procesor koji mora prilikom snimanja odraditi posao.
Staro 06.09.2013., 14:14   #44
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Najjači proc mora biti onaj koji video kasnije obrađuje...1440 je zapravo bilo ograničenje analogne trake, ali kasnije kad su prešli skroz na digitaliju, skužili su da su i manji resursi potrebni u "kućnoj" obradi videa. Mislim da je zato ostalo.
E sad, na nekoj šugavoj handheld kameri to zbilja ne znači puno, ali ak već imaš solidnu optiku, zašto onda gubiti na kvaliteti videa zbog tih 500px širine? Ne vjerujem da donosi takvu uštedu...
Kako god, glupost i fail.
Eto. Našli smo prvu ozbiljnu manu (uzevši u obzir što ocjenjujemo).
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 06.09.2013. u 14:21. Razlog: tipfeleri i stilske greške
Staro 07.09.2013., 09:00   #45
Postovi: 33,941
Staro 07.09.2013., 12:14   #46
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
A kako to može nekome iz Hrvatske biti zanimljivo? Pa kaj to nije vezano uz neku englesku pretplatu?
Kaže: "When you pre-order the Xperia Z1 on a pay monthly plan or use an upgrade..."
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 07.09.2013., 13:58   #47
Postovi: 33,941
Pod Monthly plan, ja sam razumio plaćanje na rate, a ne mobitel pretplatu.
Staro 07.09.2013., 14:52   #48
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Mislim da se to odnosi na pretplatu i ugovor. Ili kak to već vani ide. I vidio sam da se spominje vodafone negdje u toj akciji.
Evo:
http://www.gsmarena.com/sony_xperia_...-news-6742.php
"It is offered on a variety of plans by all major UK carriers."
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 07.09.2013. u 14:57.
Staro 07.09.2013., 16:09   #49
Postovi: 33,941
Hebiga
Staro 27.09.2013., 14:54   #50
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Stigli QX10 i QX100 u Svijet Medija.
1580 za QX10 još nekako. relativno blizu najavljenih $250, ali 3450kn za QX100...uh...
Kako su to formirali, da mi je znati...!?
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 27.09.2013., 15:14   #51
NortonCommander
Postovi: 422
Ako se ne varam, cijena za QX100 je ~500 dolara vani (u Kanadi je 550 dolara). Plus PDV, došlo bi čak i više nego što je u Svijetu Medija. Jbg, ipak je riječ o senzoru sa RX100 II.
Staro 27.09.2013., 15:26   #52
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
A rekli su da će biti $450...prema tome sam mjerio. Nemam pojma koliko je vani sad...
Može biti RX100ii senzor, ali to je cijena entry level-dslra sa nekim kitom. Dakle previše.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 27.09.2013., 15:29   #53
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
dupli post...pardon...može brisanje.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 27.09.2013., 16:07   #54
NortonCommander
Postovi: 422
Da, cijena jest kao npr. za Nikon D3100, ali opet, ja DSLR rijetko kada nosim sa sobom, samo kad znam da će mi trebati. A dosta puta sam požalio što ga nisam imao.
Definitivno vidim dosta publike za ovu stvar, u prvom redu novinari i sl. kojima je bitno i da mogu slikati kvalitetne fotografije i poslati ih što prije u redakciju.
Staro 27.09.2013., 17:03   #55
gin.tonic
gin.tonic's Avatar
Postovi: 2,434
Rastavili su QX100 i možete vidjeti šta je unutra
http://www.youtube.com/watch?feature..._dAtKofw#t=168
Majke ti koliko katova
gin.tonic je offline   Reply With Quote
Staro 28.09.2013., 12:36   #56
rodney
only fool, not a horse
rodney's Avatar
Datum registracije: Apr 2008
Lokacija: near zgb
Postovi: 1,280
Autor NortonCommander Pregled postova
... u prvom redu novinari i sl. kojima je bitno i da mogu slikati kvalitetne fotografije i poslati ih što prije u redakciju.
Po meni oni će zadnji na svijetu kupit ovako nešto, jer ako živi od toga,
žrtvovat ce neku lovicu, isto tako zna kad ide na posao da mu treba fotoaparat.
Da ne ulazimo dalje u to da ti često treba i pošteni blic,
rezervna baterija, i druge "sitnice".. Osim ako radi u 24 sata, onda je i ovo
overkill, ta ionako ima kamera na iphonu...
"I intend to live forever. So far, so good."
job security - example
rodney je offline   Reply With Quote
Staro 28.09.2013., 13:35   #57
NortonCommander
Postovi: 422
Nisam mislio da ce mu biti praktično radi kvalitete fotke nego radi brzine slanja fotke koju je slikao u redakciju, ali dobro, danas se može i sa dslra slat slika direktno na smartphone.
Al da, blic definitivno nedostaje u cijeloj priči, skroz sam zaboravio na taj "detalj".
Staro 28.09.2013., 14:38   #58
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,065
Čekaj sad da Sony izbaci i džepni flash za Android
Maknu hotshoe, ručne kontrole i ekran, ugrade Li-ion bateriju i WiFi za spajanje sa smartphoneom pa blicaj miki
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
Staro 28.09.2013., 15:58   #59
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Pa ak imaš mobitel, uglavnom imaš i blic; kakav takav...bar nešto. Nije to ovdje problem. Naročito na qx100 čiji bi senzor trebao dobro okidat i u mraku. Kad sam prvi put čuo za ovo i otvorio temu, bio sam 100% uvjeren da ću prvog dana dostupnosti skočit po qx100. Čak sam i lovu odvojio. Ali nisam dovoljno razmišljao o prenosivosti i praktičnosti. Tak da sam se polako ohladio...Naročito kad sam vidio puno višu cijene od najave...Bojim se da će to kod mene stvarno završit ko i dslr uglavnom; u ladici. A fotke i dalje s moba, jer mi se ni ovo, kao ni dslr neće dati vući za sobom...mislim da sam od qx100 odustao...možda još razmislim o qx10 ako bude dobar review i prihvatljivi sampleovi...i manji je ipak dosta.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 28.09.2013. u 16:16.
Staro 28.09.2013., 16:03   #60
Mad_Duke
Pa zato ja hvalim veće senzore sa brzom širokutnom lećom bez zooma na mobitelu. Može se napraviti malo više bulky (kao pureview 808), ali opet furaš sigurno sa sobom.
