Staro 31.08.2013., 23:03   #1
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Sony "objektivi" za Android
http://blog.gsmarena.com/new-images-...-respectively/
Prilično zanimljiv koncept. Dakle objektiv sa senzorom. U prinicipu očito cijela kamera ugrađena u objektiv, koja se kao dodatna oprema "zakači" na Android mobitele.
Da, mora se nositi u džepu i nije ultra elegantno rješenje, ali zapravo zvuči zanimljivo. Ovisno o kvaliteti, cijeni i robusnosti veze, moglo bi biti zanimljivo.
Očito se spaja na wifi/bt/nfc sa mobom. Nejasno mi je ima li bateriju? Možda se puni/napaja bežično? Pretpostavljam da se onda sve kontrole vrše na mobu u nekoj aplikaciji...
Hm...
Nije to tak bedasta ideja...
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
Zadnje izmijenjeno od: estugarda. 31.08.2013. u 23:09.
estugarda je offline   Reply With Quote
Staro 31.08.2013., 23:24   #2
aski
Je suis Schumi
aski's Avatar
Postovi: 1,524
Cim pise Carl Zeiss, ne moze biti lose.
Samo, kakve onda ovo ima veze s mobitelom, ako je sve odvojeni sustav?
Di sam stao?
Staro 31.08.2013., 23:33   #3
Mad_Duke
Exactly. Neko spajanje na konektor od mobitela pa da dotični, odnosno app sve kontrolira bi bilo puno jeftinije rješenje. Ovako, kad je cijeli sustav praktički neovisan bezveze ne iskorištavaš hardware od moba.
Također, bilo bi fora kad bi radio bez moba isto kako npr dela gopro hero3.
Staro 31.08.2013., 23:33   #4
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
nikakve, dfp glupost, 250 dolara za tu pizdariju ? neka hvala.
Staro 01.09.2013., 00:04   #5
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,130
Autor aski Pregled postova
Može, ne brini
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
Staro 01.09.2013., 00:29   #6
rodriguez
rodriguez's Avatar
Postovi: 2,065
Objasni.
Staro 01.09.2013., 00:46   #7
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Mislim da ste malo prebrzi s odjebima. Nije da bih se ja kladio u ovu tehnologiju uz toliko nepoznanica. Ali mislim da kao ideja ima potencijala. Zašto!?
1. Ide na bilo koji Android, pa ako hoćeš dobar cameraphone, ne moraš se ograničiti na jedan od 2-3 modela, ili drugi OS (recimo ekstremno skupa Lumia 1020).
2. Kad ti ne treba optika, ne vučeš je za sobom i nemaš zbog nje 2 ili 3 puta veći/teži mob. (kao Galaxy Camera)
3. Ako je optika dovoljno dobra, a ne trebaš profi/art rezultat, može ti zamijeniti dosta opreme. (recimo u mojem slučaju entry level dslr, torbu).
4. Ukoliko bi app na mobu bio dovoljno dobar, i konekcija robusna, možda se objektiv može koristiti s punom kontrolom? Dakle, onako kako se mogu koristiti kvalitetni kompakti; s ručnim postavkama. I tome se još možda može dodati i ono što već Android ima; manipulacija fotki, cloud, share...
5. Teoretski, ako već imamo android mob, a većina ima, dodamo još $250 i dobijemo (možda) kompakt više klase koji sigurno inače košta duplo više.
Sve to ovisi o stvarnoj funkcionalnosti (i kvaliteti) o kojoj još ništa ne znamo, ali ja mislim da ima potencijala kao ideja...
I da. Negdje sam vidio da funkcionira kao kamera i bez mobitela...link...Dakle očito ima i bateriju...
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 01.09.2013. u 10:30. Razlog: tipfeler
Staro 01.09.2013., 01:12   #8
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,130
Objasni.
Eto, osobni primjer. Razočaran sam kamerom na 820 koja nosi Carl Zeiss na sebi.
Nijedna od starijih Carl Zeiss Nokia nije bila ništa bolja od konkurencije, ali je bila skuplja. U to vrijeme sam imao SonyEricssone sličnih performansi na papiru, što se kamere tiče. Svaki (W800, K550, C905) je imao bolje fotke od CZ Nokia.
Kod objektiva, Sony ima 3 grupe objektiva, G, CZ i onu za obične smrtnike.
Osim obične, G seriju nekako i kužim, ali mi CZ nikad nije bila jasna.
Boluju od svih bolesti kao i ostali objektivi, a ako i nude veću kvalitetu fotografije, onda to rade za 2-3% korisnika koji to mogu iskoristiti uz 2-3x veću cijenu.
Meni je danas CZ isto što i Swarowski. Nema proizvoda na kojem se neće moć nać jedan od ta dva logotipa.
Vjerojatno će biti dobri ti portabl objektivi, ali hoće li biti jednako dobri kao kompakt za tu ili (sigurno) još nižu cijenu? Sumnjam
Fora igračka, ali svaka čast onome kod koga ne završi na dnu ladice nakon par mjeseci igranja.
LCD: BENQ PD3200Q
Staro 01.09.2013., 02:02   #9
Mad_Duke
Autor 1v@n Pregled postova
Može, ne brini
Isto tako možeš imati najbolju ženu na planeti, ali ako je slikaš sa Gameboy kamerom kako će ispasti?
Autor estugarda Pregled postova
-cut-.
Teoretski. Jedini razlog zašto bi neki kompakt istih perfomanski bio skuplji je radi ekrana pošto očito sve iznutrice imaš i u jednom i u drugom. Plus kaj firme koje se bave fotićima sigurno mogu sniziti cijenu dosta s obzirom na količinu koju izbacuju van.
Staro 01.09.2013., 08:42   #10
Postovi: 34,052
Staro 01.09.2013., 22:13   #11
Mejzlik
tha pilot
Mejzlik's Avatar
Postovi: 649
Osobno ovo mi se svidja, ako ce raditi koliko toliko dobre fotke...
Zadnjih mjesec dana imam N8, ponajvise radi kamere, jer mi se ne tegli fotic svuda, a Nokijin senzoric moze super fotke napraviti u usporedbi sa vecinom daleko skupljih Androida...
Usto, ako bi taj objektiv imao svoju bateriju i xenon flash, uz zadovoljavajuce slike, bio bi zanimljiv aparatic, no 250$ mi je previsoka cijena...
Mejzlik je offline   Reply With Quote
Staro 02.09.2013., 10:33   #12
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Da. To je ključno. Ako neće raditi fotke na razini onih koje okida kompakt s istim objektivom, onda nema smisla. Ako hoće, onda $250 i nije tako puno, ako se uzme u obzir da je kompakt s istim objektivom $400. Nema neke logike da bi fotke bile slabije, s obzirom da ovo praktički ima ugrađeno sve ključno što ima i kompakt s kojim dijeli optiku i senzor. Zapravo sve osim LCD-a i vjerojatno viewfindera. Možda čak ima i viewfinder iza, na ovoj strani koja se ne vidi na fotkama...
Definitivno ima svoju bateriju, kad se vidi indikator baterije. Pitanje je samo koliko veliku. Sigurno ne kao ona u kompaktu. Ali bilo bi zgodno da se recimo puni bežično s moba, kad će se vjerojatno ionako postavljat na stražnju stranu nekako. Još bi bolje bilo da kao dodatnu opciju ima mogućnost spajanja na mob putem kabela za prijenos podataka i punjenje...
Pitanje je ima li flash. Nešto ima što izlazi iz tijela objektiva. Možda flash koji iskače, ili hot-shoe za eksterni flash?
I pitanje je još načina spajanja na mob. Meni ovak na prvu izgleda kao da ima neke kukice, dakle vjeorjatno će trebati i nekakav adapter, odnosno vjerojatno futrolu za mob na koju se montira. Možda ta futrola zapravo ima bateriju i handgrip!?
Ima to puno potencijala, ako se napravi kako treba.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 02.09.2013. u 11:08.
Staro 03.09.2013., 18:03   #13
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Novi detalji!
Ukratko:
Sad je montaža jasnija. Za Xperiu će biti case (bez baterije i gripa je malo idiotski IMHO), a za Androide ova "hvataljka" sa magnetom. Ni riječi o bežičnom punjenju, spajanju kabelom ili slično. Već vidim da će biti problem s baterijom.
Može se fotkati i bez mobitela, ali nisu niš spomenuli za viewfinder i nema fotke stražnje strane objektiva. Sutra na predstavljavanju valjda više...
Xperia:
Ostali:
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 03.09.2013. u 18:09.
Staro 03.09.2013., 18:11   #14
Mad_Duke
Bežićno punjenje prekriži odmah. Nemoguće.
Staro 03.09.2013., 18:19   #15
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Zašto? Ako magnetsko zračenje može prenositi el. energiju u jednom smjeru, zašto ne i u drugom, pod uvjetom da su odašiljači u oba smjera...
Mislim...ne znam zapravo. Ne razumijem se naročito u to i znanje na tom polju mi je ono, srednjoškolsko u najboljem slučaju. Samo mi se čini logično.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 03.09.2013. u 18:24.
Staro 03.09.2013., 18:31   #16
Mad_Duke
Pa pogledaj si koji su gubici u prijenosu energije na taj način. Onda zamisli da ti to cucla bateriju iz mobitela. Zašto bi netko to htio tako riješiti pitaj boga. Bolje da stave onda AAA baterije umjesto toga. Onda manjak standarda bla bla bla bla.
Staro 03.09.2013., 18:42   #17
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Ali ne mora cuclati stalno. Nego kad okidaš fotku...Uglavnom, kužim te...i slažem se. Teško da ćemo to vidjeti u ovom slučaju...
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 03.09.2013., 18:47   #18
Mad_Duke
Ne teško nego NEMA ŠANSE!
Staro 03.09.2013., 22:22   #19
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 03.09.2013., 23:55   #20
tOta
Lokacija: ...
Postovi: 685
OK, CZ Sonar - ako je u rangu onoga sa RX100, imamo bolju stvar nego PureView na 808/1020.
EDIT: Čini se da jeste i to senzor sa RX100 mk2, držim fige da ovo bude dobro kao spomenuti high end kompakt, napokon alternativa za PV Nokije.
tOta je offline   Reply With Quote
Staro 04.09.2013., 03:50   #21
Mad_Duke
Ova lens mount back maska je savršena stvar skupa sa wireless prikazom slike kad ti je u ruci. Još vidjet battery life i to je to. (i cijenu kad zapravo dodje kod nas u Europi) :P
Ali, dolazim do sljedećeg pitanja :P Ako već postoji šansa za back maska lens mount, sljedeća stepenica koja bi bila cool su izmjenjivi objektivi :P (pretjerujem)
Autor tOta Pregled postova
PureView se ne može uspoređivati sa ovime.
Staro 04.09.2013., 08:58   #22
tOta
Lokacija: ...
Postovi: 685
Mah, znam, ali ujedno onda ovo postaje uistinu najbolje rješenje za fotografiju na mobilnim telefonima, mislim u manjem paketu nego sam RX100 imaš isti taj i to po jeftinijoj (?) cijeni uz mogućnost da držiš u jednoj ruci viewfinder, a u drugoj sam objektiv/aparat/nazoviGaKakoHoćeš.
Staro 04.09.2013., 09:16   #23
Mad_Duke
A ne bih se složio! Integrirani dobar senzor etc. na mobitel je opet džepna verzija. Ovo koliko god da je cool, neću imati sa sobom dok sam na pjena partiju u nekom klubu u nekom gradu. (karikiram)
Staro 04.09.2013., 10:36   #24
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Pa već su dva objektiva, ne!? Dakle izmjenjivo je. Barem bi bilo logično.
Čudno je što veći i skuplji objektiv ima manji zoom. Pretpostavljam da ima zaro veći i bolji senzor (osim što ima više mp). Možda i veću bateriju?
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 04.09.2013., 10:42   #25
chief_wolfinjo
kao na t68 kamera vrlo zanimljivo
Staro 04.09.2013., 10:55   #26
Mad_Duke
Pa koliko sam skužio svaki objektiv ima senzor u sebi i bateriju. Ja govorim o fiksnom senzoru
znači three step.
- Mount (bio back maska ili onaj "magnetski"),
- Dio sa senzorom
- Leća
Kao nekakve mirrorless alternativa. Velim, bacam ideje samo, ovo se sigurno neće dogoditi.
A što se tiče zooma. Koga briga za zoom, pa vidi razlike u optici
QX10 - f/3.3-5.9 optics - sporo gofno
SmartShot QX100 - f/1.8-4.9 optics - jako brzo
razlika u megapiskelima je blah, nevažna. Više me zanima razlika u samom senzoru kakva je. sa 1.8 će se u svakom slučaju jako lijepe noćne moći okidati ako senzor neće imati puno šuma. Ima netko review sa fotića takvog senzora? Nisam stigao sve pogledati.
Staro 04.09.2013., 11:08   #27
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Jasno je da je ovo bolja optika i senzor, ali postavlja se pitanje; zašto tolika razlika u veličini po dužini!? A naročito što ovaj manji sa 10X ima vjerojatno više "hoda". Možda je i baterija veća u QX100?
Sony RX100 DPreview
BTW kod nas 5k+!
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 04.09.2013. u 11:42.
Staro 04.09.2013., 11:10   #28
Mad_Duke
Pa kod nas će koštati ovaj bolji objektiv oko 4-5.000 kuna najvj
Pa to što je brža optika ne znači da je jedan dio brži Drugačiji je to dizajn. Ne znam detalje.
Staro 04.09.2013., 11:19   #29
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
$450 je pisalo...Pa neće valjda biti baš 2x skuplje?
Iako, i to je moguće kad se pogledaju cijene NEX objektiva kod nas...
Ali 5k za RX100. To je ludo.
Inače, ima i RX100M II za 5.7k.
Razlike. (Malo je OT, ali ima veze s QX100 objektivom, pa može biti zanimljivo)
To je već rang dobrog APS-C DSLR-a.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 04.09.2013. u 11:36.
Staro 04.09.2013., 11:36   #30
Mad_Duke
To je problem koji se ne može izbjeći sa "high end" malim senzorima, a čisto je form factor prilike. Da bi strpao neki 4/3 ili APS-C senzor na identičan uređaj (a nije da ne možeš) automatski bi dobio i puno širu/veću optiku potrebnu i to više ne bi bio toliko prenosivi "mali objektivčić" nego čist dobar bulky dodatak.
A ovo mi nije jasno
http://snapsort.com/compare/Sony-Cyb...SC-RX100/specs
Isti senzor, sve isto, optika ista, a ovaj noviji i skuplji je teži, manji burst rate, manje video format podržava i još neke stvari. Strange.
