Staro 02.08.2013., 11:50   #1
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,025
ATI Catalyst 13.8 Beta
Za vlasnike Crossfire rješenja:
Link na changelog
Feature Highlights of The AMD Catalyst 13.8 Beta Driver for Windows:
Support for AMD CrossFire™ Frame Pacing
Frame Pacing ensures that frames rendered across multiple GPUs in a CrossFire configuration will be displayed at an even and regular pace.
Enabled through the AMD Catalyst Control Center; Globally or on a per application basis.
Frame Pacing is enabled by default.
Supported for DirectX 10 and DirectX 11 applications, and resolutions up to and including 2560x1600 (single display).
OpenGL 4.3 support – full support for the OpenGL 4.3 feature set
Performance improvements found in AMD Catalyst 13.8 Beta for Windows:
Metro: Last Light – improves performance up to 7% on the AMD Radeon™ HD 7000 Series
OpenGL support for User Profiles and Catalyst Application Profiles:
Users can now create per application 3D setting profiles for OpenGL applications.
OpenGL applications are now supported through Catalyst Application Profile updates (for single GPU and AMD CrossFire configurations).
AMD Enduro Technology enhancement - Catalyst Control Center will now show which applications are active on the Performance GPU, and the Power-Saving GPU
Resolved issues:
Resolved crash when enabling AMD CrossFireX™ on some AMD 970 platforms
Improved stability for AMD Radeon HD 7790
Resolved intermittent mouse cursor corruption when rapidly moving the cursor across window borders
Download
Download - Mobility
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 05.08.2013., 02:44   #2
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,190
Preduhitrio si me za pola sata, baš sam i ja htio temu otvorit čudilo me da nitko nije još.
Instalirao sam drivere i malo provrtio igre kod kojih sam primjećivao microstuttering ponajviše - Hitman Absolution i Tomb Raider. I čini mi se da se stanje lijepo popravilo i kod dobrih starih 5850
Apsolutne pohvale AMD-u kako se suočio s problemima i krenuo u pravom smjeru njihova rješavanja, makar i nakon toliko vremena.
EDIT:
Sad odvrtih i Sleeping Dogs benchmark koji je serija onako letećih kardova određenih scena i oduševio sam se! Apsolutno fluidno! Taman sam razmišljao o umirovljenju ove dvije 5850 i prelazak na 7950, ali ovaj driver me baš ugodno iznenadio i odgovorio
Zadnje izmijenjeno od: Sam Fischer. 05.08.2013. u 02:56.
Staro 05.08.2013., 15:27   #3
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,025
Tko zna jel bi ovo radilo na hibridnom Crossfireu ili mora biti čisti Crossfire...
Dok ulovim cajta stavljam na lap pa testiram
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 05.08.2013., 20:41   #4
MAGARAC
MAGARAC's Avatar
Postovi: 5,983
Staro 05.08.2013., 23:12   #5
ZOX
ZOX's Avatar
Lokacija: Koprivnica
Postovi: 297
Ne znam dal neko ima isti problem, ali Google Earth sa 13.8 DX akceleracijom ne radi (na najnovijoj verziji i onoj iz 2011).
Ostalo sve 5.
ZOX je offline   Reply With Quote
Staro 19.08.2013., 09:11   #6
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,164
Evo ja sam slučajno naletio na još jedan problem s ovom betom - Crysis 2 Maximum Edition ima sprčkane teksture sa HD7770 kad se object detail postavi na Ultra. Ne znam da li je netko s drugim grafičkim čipom naletio na isti problem. S druge strane, na 13.4 WHQL nema takvih problema.
Staro 20.08.2013., 16:01   #7
alengrosevic
alengrosevic's Avatar
Postovi: 3,775
jesi li probao verziju 2 ovog drivera?
http://www.guru3d.com/files_details/..._download.html
alengrosevic je online   Reply With Quote
