Staro 30.07.2013., 12:18   #1
O9g1
Bee-do Bee-do Bee-do, TUP
O9g1's Avatar
Datum registracije: Aug 2009
Postovi: 323
CM 690 III
Evo vam CM 690 loveri...
http://hexus.net/tech/news/chassis/5...0-iii-pc-case/
Skoro pa mi se počinje i sviđati ovo evoluiranje, iako sam FD fanboy. LOL
CPU: Intel i5 2500k (BX80623I52500K) cooled by Scythe Ninja3 (SCNJ-3000)
MBO: Asus P8Z68-V PRO/GEN3
RAM: 2x4GB Kingston 1600MHz, DDR3, XMP (KHX1600C9D3K2/8G)
GPU: GIGABYTE Radeon R9 290 4GB Windforce 3x (GV-R929OC-4GD)
SSD: Samsung 840 EVO 120GB (MZ-7TE120BW) - System
HDD1: WD Caviar Black 500GB (WD5001AALS) - Storage
HDD2: WD 250GB (WD2500JS-22MHB0 ) - Backup
ODD: Samsung 22/8/8/48/32x (SH-S222AB)
PSU: XFX XXX Edition P1-650X-CAG9 650W
CASE: Fractal Design Arc midi
FAN CONTROL: Scythe KAZE MASTER 5.25″ Bay Fan Controller (KM01-BK)
FAN: 2x Fractal Design Dynamic GP-14, 140 mm intake+2X Scythe S-flex 120mm (SFF21E) exhaust
OS: W10 x64
LCD:MASTER: LG 29UM57-P Ultra širok đubar, jooooj što ga volem... , SLAVE: Dell 17"
KEYBOARD: Logitech UltraX keyboard (Y-BL49)
MOUSE: Logitech G400
SOUND: Creative Sound Blaster X-Fi XtremeMusic
HEADSET: Steelseries Siberia v2
RALLYING GEAR: Logitech G25+homemade cokpit+handbrake (modani Genius MaxFighter F-16U)
IF IN DOUBT, FLAT OUT!!!
Don't touch it! It is mine! It's all miiiiineeee!!!
Lenovo Essential B580
CPU: Intel Celeron Dual Core B820 1.70GHz (2MB cache)
LCD: 15.6" HD LED 1366 x 768
GPU: Intel HD Graphics 3000
RAM: 4GB DDR3 1600MHz
HDD: 320GB SATA
ODD: DVDRW DL
PSU: Up to 4hours (Li-Ion 6 cell)
ETHERNET: Yes (Gb LAN)
COMM: Yes (802.11b/g/n)
BLUETOOTH: Yes
AUDIO IN/OUT: Yes
VGA OUT: Yes
HDMI: Yes
CASE: Lenovo
CARD READER: Yes
FINGERPRINT READER: Yes
CAMERA: Yes
OS: Windows 7 Profesional
Lenovo ThinkPad E560
CPU: Intel Core i7-6500U 2.5 GHz
LCD: 15.6 inch 16:9, 1920x1080, IPS-Panel, LED-Backlight, glossy: no
Extern LCD:Lenovo X24a, 24 inch 16:10, 1920x1200, IPS-Panel, LED-Backlight
GPU: AMD Radeon R7 M370 2 GB GDDR5
RAM: 16GB, 2 x 8 GB DDR3L-1600
HDD: 250GB SSD
ODD: DVD+/-RW
PSU: 48 Wh (6 cell)
ETHERNET: Gigabit Ethernet
COMM: 802.11ac, Bluetooth, Intel Dual Band Wireless-AC 8260 - M.2 Card
CONNECTIONS: 3 x USB 3.0, HDMI, VGA, OneLink connector, LAN, Headphone/microphone combo jack
CARD READER: 4 in 1 ( SD Card, MultiMediaCard, SDHC Card, SDXC Card )
CAMERA: Yes
OS: Windows 10 64x
Poštena, dobra i odgovorna trgovina +još jedna...
Straight roads are for fast cars, turns are for fast drivers!
O9g1 je offline   Reply With Quote
Staro 30.07.2013., 13:10   #2
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Dobar case u svakom slučaju (onaj mesh zapravo i nije toliki magnet za prašinu koliko se misli).
Moj primjerak iz prve serije nažalost nema rupu za instalalaciju coolera/backplatea bez vađenja matične i nije iznutra crno ka ni stražnja strana.
Ali kvaliteta izrade, veličina/prostranost, ostale funkcije/dodaci i sam izgled mi je bilo dovoljno za kupovinu (jeftino i polovno).
Pomelo mi sig -.-
Staro 30.07.2013., 17:50   #3
ECHO
Lokacija: CROATIA-Vukovar
Postovi: 2,354
Izgleda "supika" baš me zanima cijena pošto i sam gledam neku "kantu" da zamijenim i umirovim staru kantu
Staro 01.08.2013., 14:46   #4
Postovi: 33,932
Sviđa mi se. Pogotovo onaj front 'ventić' od 200mm - trenutni 140mm mi se čini preslab. Čini mi se da su ponovili grešku iz 690 II - X-dock na vrhu je napravljen tako da kontakti hard idu prema prednjici kućišta. Puno bolje bi bilo da je napravljeno kako kod Obsidiana - kontakti prema zadnjici kućišta. Meni je dosta nezgodno jer mi je kućište u rupi u stolu i onda ga moram dosta izvući van da bi mogao ubosti hard u X-dock.
Staro 01.08.2013., 21:37   #5
His Airness
His Airness's Avatar
Datum registracije: Aug 2012
Postovi: 144
nekako mi ružno ovo zaobljenje gornje prednje strane
ali ok, izgled kućišta mi još i najmanje bitan
His Airness je offline   Reply With Quote
Staro 20.09.2013., 09:02   #6
vex
vex's Avatar
Datum registracije: Aug 2003
Lokacija: sl. brod
Postovi: 1,320
za vodeno dušu dalo ...
2 x 240 će ohladiti sve , a može se i 2 x 120 još dodati ako baš baš treba
čista petica
http://www.overclock3d.net/reviews/c...0_iii_review/1
Staro 17.02.2014., 22:50   #7
medo
#erase startup-config
medo's Avatar
Postovi: 3,679
Postao sam vlasnik CM690 III kučišta prošli tjedan. Kučište sam ostavio stock, samo sam dodao jedan 200mm vent na vrh kučišta CoolerMaster Megaflow 200 s plavim ledicama jer je to jedini i zadnji 200mm koji su imali u Linksu.
Gledam temperature i ne vjerujem... Grafa i procesor su praktički na istoj temperaturi skoro kao da sam ih stavio na stol bez kučišta. Sapphire Radeon 7970 Dual-X koja je cijelo vrijeme na full opterećenju stalno je ispod 60 stupnjeva @75% vent (tiha je). Procesor je na 63 stupnja, a VRM-ovi od proca na 39 stupnjeva. Ovo je nakon pola sata OCCTa koji je zakucao CPU i GPU na ~100%.
Tri 2TB harda su jedan ispod drugoga jer je grafa predugačka pa sam morao ostaviti uvučen kavez za diskove. Sva tri WD Greena su 31-33 stupnja.
Moje kučište je došlo bez gumenih obruba na cable managementu kao i sve prve serije. Da je HDD kavez centimetar bliže lijevoj strani da SATA kabeli nisu toliko savinuti bilo bi skoro savršeno. I ovaj glossy sliding tray je magnet za otiske prstiju i ogrebotine.
Staro 25.02.2014., 13:48   #8
win32
win32's Avatar
Datum registracije: Apr 2008
Postovi: 1,517
Imam CM 690 II i mrzim ga.
Kuciste je kupljeno "silom prilike" i na njega sam presao s Corsair 800D, Cosmosa i sl. big tower kucista te ga stvarno mrzim.
Eto, ima nas koji ga imamo i koji ga organski ne podnosimo.
Osobno bi ga rado prodao, ali mi se ne gnjavi sa slanjem, postom itd. no da je netko blizu mene, rado bi ga se rijesio.
Za vodeno nikako nije, imam u njemu H50 pa sve izgleda skuceno i natrpano (mozda je to samo moj feeling posto godinama nisam imao midi kucste).
"In the beginning there was 0. And then there was 1. A mind-bending meditation on the transcendent power of digital computation."
Pošteni trgovac: 1, 2, 3, 4, 5...
win32 je offline   Reply With Quote
