Staro 29.06.2013., 17:03   #2101
slish480
Yeeepiyaye
slish480's Avatar
Lokacija: Graz, Austria
Postovi: 294
Pozdrav trebam preporuku koji od ovih laptopa uzeti.
Samsung NP370R5E-S01HR, 15.6" 1366x768, Intel Core i3-3110M 2.4 GHz, DDR3 4096 MB, HDD SATA 750 GB, Windows 8, ATI Radeon 8750 1GB
Samsung (Novo, zapakirano, račun, garancija 12 mjeseci)
NP350E7C Intel i5-3210M 2.5Ghz/3.1Ghz, 17.3 HD+, AMD HD7670 1GB, 8GB, 750GB, DVDRW, WebCam, USB3.0, WIN8
HP Pavilion g6-1306et - novo, jamstvo 24 mjeseca
15.6'' 1366x768 LED Bright View
Intel® Core™ i5-2450M 2.5GHz (up to 3.10GHz, 3MB L2 cache)
AMD Radeon HD7450 1GB DDR3
4GB DDR3 1066MHz
750GB SATA
DVDRW
GLAN, 802.11b/g/n, Bluetooth
5in1 card reader
Web kamera 1.3Mpixel
3xUSB 2.0, HDMI, VGA, Mic, audio
FreeDOS/Windows 7 Home Premium
Garancija: 24 mjeseca
HP Pavilion g6-2211et - novo, jamstvo 24 mjeseca
Intel® Core™ i5-3210M 2.5GHz (up to 3.10GHz, 3MB L2 cache)
ATI Mobility Radeon HD7670 2GB DDR3
4GB DDR3 1066MHz
500GB SATA
DVDRW
5in1 card reader
FreeDOS/Windows 7
HP Pavilion g6-2005st - novo, jamstvo 24 mjeseca
ATI Mobility Radeon HD7670 1GB DDR3
8GB DDR3 1066MHz
500GB SATA
DVDRW
5in1 card reader
FreeDOS/WIN7
HP 4530s, B0X66EA
Intel Core i5 2450M 2,50 GHz
8192 MB
15,6" 1366x768, SATA
750 GB, Linux
AMD Radeon HD 7470M (1GB)
DVD±RW DL
10/100/1000, 802.11b/g/n, BT, HDMI 1, USB 2.0 3, USB 3.0 1, 2,51 kg
Boja metalic siva
+ torba
+ miš generički od HP-a
NP350E7C
Intel i5-3210M 2.5Ghz/3.1Ghz, 17.3 HD+, Intel HD 4000, 6GB, 500GB, DVDRW, WebCam, USB3.0, WIN8
To su sve laptopi trenutno na tržnici pa sam u nedoumici šta je najbolje, po pričama iskustvu itd.
slish480 je offline   Reply With Quote
Staro 29.06.2013., 17:15   #2102
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,309
Jel imaju uopće hr tipkovnicu?
Staro 29.06.2013., 17:27   #2103
slish480
Yeeepiyaye
slish480's Avatar
Postovi: 294
Nemam pojma, valjda imaju kad su sa tržnice tu na forumu.
Staro 29.06.2013., 17:30   #2104
Gilbert5
Agent 0
Gilbert5's Avatar
Postovi: 4,309
Trgovao sam gospodinom vec za neki punjac, super je. Ali mislim da robu izvana uvozi, pa pitaj ipak.
Staro 29.06.2013., 17:35   #2105
slish480
Yeeepiyaye
slish480's Avatar
Postovi: 294
Ok, pitat cu, nisu svi na popisu njegovi. Imas li kakvu preporuku?
Staro 29.06.2013., 18:53   #2106
Postovi: 33,918
A za što tebi treba laptop? HP bi izbjegavao - kvaliteta im je izuzetno pala (griju se, crkavaju matične, kratka garancija,...). Jednostavno ne vrijede tih para koliko koštaju.
Staro 29.06.2013., 18:59   #2107
smaug
smaug's Avatar
Datum registracije: May 2012
Postovi: 24
Može li mi netko potvrditi kvalitetu baterije kod Samsunga? Vidim da negdje reklamiraju kako traje 7 sati, što je naravno pretjerivanje, ali da je i 5h opet je odlično, pogotovo u usporedbi s mnogim drugim proizvođačima.
smaug je offline   Reply With Quote
Staro 29.06.2013., 21:03   #2108
slish480
Yeeepiyaye
slish480's Avatar
Postovi: 294
Autor coconut Pregled postova
Ispričavam se što nisam napisao, laptop bi bio korišten za sve znači od 3d modeliranja do gledanja filmova baš sve, da i ja sam čuo da je hp-u jako pala kvaliteta postali su prepremasovni, znam za jedno iskustvo tjedan dana nakon isteka garancije riknula matična.
Staro 30.06.2013., 07:17   #2109
Postovi: 33,918
Uzmi nekog od tih Samsunga koje si naveo sa i5 procom.
Staro 01.07.2013., 14:20   #2110
fico007
Postovi: 260
Molim i meni savjet za laptop do 3500 kn (ili manje).
Što tražim (i za koju namjenu)?
- ekran sa što boljom rezolucijom (15,6 ")
- što duže trajanje baterije
- što manje zagrijavanje
- HDMI priključak
- kvaliteta izrade
- da radi stabilno i brzo (vjerojatno više rama)
- može free dos, a isto može i s windowsima
- dobra podrška za drivere
- ugrađena kamera (nije uvjet)
- služit će za rad (uglavnom office)
- služit će za surfanje i povremeno gledanje filma, serije itd.
- neće služiti za igranje.
fico007 je offline   Reply With Quote
Staro 01.07.2013., 14:25   #2111
Postovi: 33,918
Uz uvjet da 200kn više nije problem, pogledaj model NP350E7C (doljnji dio oglasa, na vrhu). Iako je overkill za tvoju namjenu, boljega nećeš naći za te pare.
http://forum.pcekspert.com/showthread.php?t=248366
Staro 01.07.2013., 15:18   #2112
fico007
Postovi: 260
Model izgleda odlično, ali je problem kako platiti. Mislio sam uzeti na rate (ako mogu, jer zašto keširati tu lovu ako se može uzeti na rate - maestro kartica -erste banke - bez kamata). Na žalost firma koja nudi ovaj laptop nema mogučnost kupovanja na rate kod erste banke (možda sam to trebao navesti u prvom postu).
Staro 01.07.2013., 15:30   #2113
Postovi: 33,918
Gdje si točno u Hrvatskoj? Ne možeš staviti neku normalnu lokaciju? Malo firmi dopušta kupovanje na daljinu i na rate.
Staro 01.07.2013., 15:41   #2114
fico007
Postovi: 260
Koprivnica, ali nije nikakav problem otići do Zagreba.
Staro 01.07.2013., 19:19   #2115
Postovi: 33,918
Staro 03.07.2013., 23:11   #2116
mitja
mitja's Avatar
Datum registracije: May 2009
Postovi: 86
bok,
planiram uzeti laptop koji će mi zamijeniti stolno računalo. ovo na kojem trenutno radim ima 4gb rama i celerona g540 (skupa sa integriranom grafikom) i to mi je bilo sasvim dovoljno, pa sam gledao uzeti i laptop slične snage.
namjena je surfanje + rad u programima težine otprilike visual studija. optički pogon mi ne treba, veličina diska mi je nebitna (recimo 160gb mi je sasvim dosta), a trajanje baterije mi je dosta bitno (volio bih moći izvući 4-6 sati normalnog rada).
nisam se još stoposto odlučio za veličinu ekrana, a razmišljam između 15.6" i 13.3". pa su mi tako u oko upali ovaj samsung 350 koji se preporučuje unazad par stranica, te lenovo s400/s300 (ustvari i lenovo e3xx sa intelovim procesorom, dva frenda imaju, čini mi se, e330 i dosta su zadovoljni). kolika je razlika između s i e serije lenova?
pa ako može koja preporuka s obzirom na gornje uvjete. za potrošit imam nekih 3600 kn, ali što jeftinije to bolje. windowsi ne trebaju. iz zagreba sam, dućan mi je apsolutno nebitan.
hvala!
Zadnje izmijenjeno od: mitja. 04.07.2013. u 16:09.
mitja je offline   Reply With Quote
Staro 04.07.2013., 20:09   #2117
ivan_karlovac
ivan_karlovac's Avatar
Datum registracije: Aug 2008
Lokacija: karlovac
Postovi: 111
Pošto ja još nisam kupio laptop kceri a i doslo je do otkazivanje suradnje kupovanja preko frenda opet krecem iz početka samo trenutno sa smanjenim buđetom od 3-4K kn i na rate na karticu uvjet je 17" namjena gledanje filmova, net i mozda neko igranje ako ce kci biti zainteresirana trenutno nije. Bitna mi je garancija cim duza i odvojena graficka i trenutno sam nasao ovo HP Pavilion g7-2210sm, C5T24EA 1+3 godine garancije 3,8K kn. Vaše mišljenje znam da je hp li-la ali 4 godine ima garanciju.
ivan_karlovac je offline   Reply With Quote
Staro 04.07.2013., 23:07   #2118
redscro
redscro's Avatar
Lokacija: Kupres
Postovi: 4,085
Pretpostavljam da se radi o produljenju jamstva na ukupne 3g, a ne za dodatne 3g. Kako god, kad se radi o plaćanju na kartice, to nije loša cijena. Nešto jeftinije ipak dobiješ ovog Asusa s 2g. jamstva.
Što se tiče samog branda, generaliziranje o kvaliteti je glupost. Svi se ti laptopi rade u istim kineskim tvornicama, nijednog od njih ne pravi ni HP, ni Toshiba ni nitko od velikih imena (osim Asusa), već veliki OEM proizvođači. Gotovo su jednake šanse da su dva različita modela HPa rađena u istoj tvornici, kao i da su neki HP i Lenovo rađeni u istoj tvornici. A podrška je kod svih jeftinih laptopa isto sranje, nepostojeća.
Staro 06.07.2013., 09:09   #2119
ivan_karlovac
Lokacija: karlovac
Postovi: 111
Autor redscro Pregled postova
Samo da javim na kraju sam ipak kupio asusa tvoj i coconutov stav je prevladao mojoj "privlacnosti" hp-u sve je u redu malo je samo zeznuto sta gore idu samo win 8 jer nema drivera za 7 a nije mi se dalo pola dana pretrazivati koje su komponente u njemu. Jedini minus za links je da nemaju produzetak garancije za asus u ponudi tj. Ono sta sam ja mislio da je produljenje se odnosi samo na mali 10 incni tako da cu za mjesec dana ici u potragu za produzetkom jamstva.
Staro 06.07.2013., 09:21   #2120
Postovi: 33,918
Da si stavio W7, kod prvog updatea bi ti skinuo većinu potrebnih drivera, a ostatak bi lako našao na netu pomoću Hardware ID komponente.
Staro 06.07.2013., 12:15   #2121
ivan_karlovac
Lokacija: karlovac
Postovi: 111
E jbg sada neka radi koji dan na win 8 pa cu staviti win7. Je da su brži subjektivno ali su komplicirani u ... Hvala još jednom na preporuci da ne zeznem se sa HP
Staro 13.07.2013., 14:17   #2122
henri_007
Postovi: 484
Ljudi možete mi nešto reći o ovom laptopu
LINK
Meni to malo jeftino izgleda za takav harver. Di je caka? Zašto je tako jeftino?
henri_007 je offline   Reply With Quote
Staro 13.07.2013., 14:37   #2123
Gilbert5
Agent 0
Gilbert5's Avatar
Postovi: 4,309
Zato što je loša kvaliteta izrade kao i na vecini njihovih jeftinih prijenosnika
Zato što procesor nije quad core, vec dual core sa ajmoreci hyperthreadingom.
Ram je nebitan u prici, grafička nije nešto presnažna.
http://www.links.hr/?naziv=prijenosn...kl=014.620.049
IMHO,
Bolji proc, bolja grafika, viša kvaliteta, bolji proizvod.
Staro 14.07.2013., 08:26   #2124
Postovi: 33,918
12Gb rama u Aceru? Čemu?
Staro 14.07.2013., 17:25   #2125
smaug
smaug's Avatar
Postovi: 24
Čini li se meni ili je trenutno ponuda u našim trgovinama stvarno značajno pala?
Mislim na solidne laptope za umjerenu cijenu, posebno Samsung i Lenovo koji su ovdje često spominjani kao best buy.
Staro 14.07.2013., 20:10   #2126
redscro
redscro's Avatar
Lokacija: Kupres
Postovi: 4,085
Možda je trenutno takvo stanje, povoljni modeli su rasprodani, a uvoznik obično ne dobavlja nove količine istog laptopa, pa je ponuda takva kakva je. Sigurno će se uskoro pojaviti neki novi best buy model, samo treba ubosti u pravo vrijeme.
Staro 14.07.2013., 21:17   #2127
smaug
smaug's Avatar
Postovi: 24
Hvala na informaciji, nisam znao da se ne naručuju nove zalihe, pogotovo modela koji se dobro prodaju.
Ah sad neću prežaliti što nisam na vrijeme uzeo 350e5x-s01hr, taman je imao sve što mi treba.
Staro 19.07.2013., 22:51   #2128
Raccoony
Datum registracije: Feb 2013
Postovi: 17
Evo ga SAMSUNG NP350E5X-S01HR opet u Hrvatskoj:http://www.nabava.net/trazilica.php?...NP350E5X-S01HR
Najbolje bi bilo uzeti ga ovdje:http://futura-it.hr/proizvod.aspx?productId=0490909
Raccoony je offline   Reply With Quote
Staro 20.07.2013., 11:15   #2129
Domi
Domi's Avatar
Datum registracije: Feb 2004
Postovi: 302
Neki komentari za ovaj laptop?
http://www.centro.hr/detalji_proizvo...m-d1p03ea.aspx
Ja sam očito retardiran pa nisam uspio iskopati neki review.
Vidim da coconut kritizira HP-ove laptope i kvalitetu izrade; odnosi li se to i na ovu seriju Pavilion G6? Koje su uopće konkretne zamjerke, zašto bi Samsung/Lenovo/Asus bio bolji izbor?
KAJ
Domi je offline   Reply With Quote
Staro 20.07.2013., 12:41   #2130
redscro
redscro's Avatar
Lokacija: Kupres
Postovi: 4,085
Očita zamjerka je kratko jamstvo i ne baš najjeftinije produljenje, cca 300kn na 2g. Druga je to što za novije HPove modele imaš samo drivere za Win8. Kvaliteta izrade je korektna, cijeli je od glossy plastike što nije baš zahvalno za održavanje. Nerijetke su primjedbe i na pregrijavanje tog modela (to nećeš naći u rewievima jer se nijedan laptop ne pregrijava nov, ali kad se malo prašine nakupi...).
Osobno ga ne bih uzeo isključivo zbog jamstva, a kad nadodamo produljenje na cijenu, onda bih te novce radije dao za ovog Asusa, iako ima manje diska i RAMa.
http://www.nabava.net/trazilica.php?tp=0&q=K55VJ-SX019D
