#2101 |
Yeeepiyaye
Lokacija: Graz, Austria
Postovi: 294
Pozdrav trebam preporuku koji od ovih laptopa uzeti. Samsung NP370R5E-S01HR, 15.6" 1366x768, Intel Core i3-3110M 2.4 GHz, DDR3 4096 MB, HDD SATA 750 GB, Windows 8, ATI Radeon 8750 1GB ----------------------------------------------------------------------------------- Samsung (Novo, zapakirano, račun, garancija 12 mjeseci) NP350E7C Intel i5-3210M 2.5Ghz/3.1Ghz, 17.3 HD+, AMD HD7670 1GB, 8GB, 750GB, DVDRW, WebCam, USB3.0, WIN8 -------------------------------------------------------------------------------------- HP Pavilion g6-1306et - novo, jamstvo 24 mjeseca 15.6'' 1366x768 LED Bright View Intel® Core™ i5-2450M 2.5GHz (up to 3.10GHz, 3MB L2 cache) AMD Radeon HD7450 1GB DDR3 4GB DDR3 1066MHz 750GB SATA DVDRW GLAN, 802.11b/g/n, Bluetooth 5in1 card reader Web kamera 1.3Mpixel 3xUSB 2.0, HDMI, VGA, Mic, audio FreeDOS/Windows 7 Home Premium Garancija: 24 mjeseca ----------------------------------------------------------------------------------------- HP Pavilion g6-2211et - novo, jamstvo 24 mjeseca 15.6'' 1366x768 LED Bright View Intel® Core™ i5-3210M 2.5GHz (up to 3.10GHz, 3MB L2 cache) ATI Mobility Radeon HD7670 2GB DDR3 4GB DDR3 1066MHz 500GB SATA DVDRW GLAN, 802.11b/g/n, Bluetooth 5in1 card reader Web kamera 1.3Mpixel 3xUSB 2.0, HDMI, VGA, Mic, audio FreeDOS/Windows 7 Garancija: 24 mjeseca ----------------------------------------------------------------------------------- HP Pavilion g6-2005st - novo, jamstvo 24 mjeseca 15.6'' 1366x768 LED Bright View Intel® Core™ i5-2450M 2.5GHz (up to 3.10GHz, 3MB L2 cache) ATI Mobility Radeon HD7670 1GB DDR3 8GB DDR3 1066MHz 500GB SATA DVDRW GLAN, 802.11b/g/n, Bluetooth 5in1 card reader Web kamera 1.3Mpixel 3xUSB 2.0, HDMI, VGA, Mic, audio FreeDOS/WIN7 ----------------------------------------------------------------------------------- HP 4530s, B0X66EA Intel Core i5 2450M 2,50 GHz 8192 MB 15,6" 1366x768, SATA 750 GB, Linux AMD Radeon HD 7470M (1GB) DVD±RW DL 10/100/1000, 802.11b/g/n, BT, HDMI 1, USB 2.0 3, USB 3.0 1, 2,51 kg Boja metalic siva + torba + miš generički od HP-a ----------------------------------------------------------------------------------- NP350E7C Intel i5-3210M 2.5Ghz/3.1Ghz, 17.3 HD+, Intel HD 4000, 6GB, 500GB, DVDRW, WebCam, USB3.0, WIN8 To su sve laptopi trenutno na tržnici pa sam u nedoumici šta je najbolje, po pričama iskustvu itd. |
#2106 |
Postovi: 34,042
A za što tebi treba laptop? HP bi izbjegavao - kvaliteta im je izuzetno pala (griju se, crkavaju matične, kratka garancija,...). Jednostavno ne vrijede tih para koliko koštaju.
#2107 |
Datum registracije: May 2012
Postovi: 24
Može li mi netko potvrditi kvalitetu baterije kod Samsunga? Vidim da negdje reklamiraju kako traje 7 sati, što je naravno pretjerivanje, ali da je i 5h opet je odlično, pogotovo u usporedbi s mnogim drugim proizvođačima. |
#2108 |
Yeeepiyaye
Postovi: 294
Ispričavam se što nisam napisao, laptop bi bio korišten za sve znači od 3d modeliranja do gledanja filmova baš sve, da i ja sam čuo da je hp-u jako pala kvaliteta postali su prepremasovni, znam za jedno iskustvo tjedan dana nakon isteka garancije riknula matična. |
#2110 |
Postovi: 260
Molim i meni savjet za laptop do 3500 kn (ili manje). Što tražim (i za koju namjenu)? - ekran sa što boljom rezolucijom (15,6 ") - što duže trajanje baterije - što manje zagrijavanje - HDMI priključak - kvaliteta izrade - da radi stabilno i brzo (vjerojatno više rama) - može free dos, a isto može i s windowsima - dobra podrška za drivere - ugrađena kamera (nije uvjet) - služit će za rad (uglavnom office) - služit će za surfanje i povremeno gledanje filma, serije itd. - neće služiti za igranje. |
#2111 |
Postovi: 34,042
Uz uvjet da 200kn više nije problem, pogledaj model NP350E7C (doljnji dio oglasa, na vrhu). Iako je overkill za tvoju namjenu, boljega nećeš naći za te pare. http://forum.pcekspert.com/showthread.php?t=248366
#2112 | |
Postovi: 260
#2113 |
Postovi: 34,042
Gdje si točno u Hrvatskoj? Ne možeš staviti neku normalnu lokaciju? Malo firmi dopušta kupovanje na daljinu i na rate.
#2114 |
Postovi: 260
#2115 |
Postovi: 34,042
Nešto u ovom stilu bi bilo ok https://www.centro.hr/detalji_proizv...55a-sx539.aspx https://www.centro.hr/detalji_proizv...59-366668.aspx Plaćanje https://www.centro.hr/Stranica.aspx?page=NacinPlacanja
#2116 |
Datum registracije: May 2009
Postovi: 87
bok, planiram uzeti laptop koji će mi zamijeniti stolno računalo. ovo na kojem trenutno radim ima 4gb rama i celerona g540 (skupa sa integriranom grafikom) i to mi je bilo sasvim dovoljno, pa sam gledao uzeti i laptop slične snage. namjena je surfanje + rad u programima težine otprilike visual studija. optički pogon mi ne treba, veličina diska mi je nebitna (recimo 160gb mi je sasvim dosta), a trajanje baterije mi je dosta bitno (volio bih moći izvući 4-6 sati normalnog rada). nisam se još stoposto odlučio za veličinu ekrana, a razmišljam između 15.6" i 13.3". pa su mi tako u oko upali ovaj samsung 350 koji se preporučuje unazad par stranica, te lenovo s400/s300 (ustvari i lenovo e3xx sa intelovim procesorom, dva frenda imaju, čini mi se, e330 i dosta su zadovoljni). kolika je razlika između s i e serije lenova? pa ako može koja preporuka s obzirom na gornje uvjete. za potrošit imam nekih 3600 kn, ali što jeftinije to bolje. windowsi ne trebaju. iz zagreba sam, dućan mi je apsolutno nebitan. hvala! Zadnje izmijenjeno od: mitja. 04.07.2013. u 17:09. |
#2117 |
Datum registracije: Aug 2008
Lokacija: karlovac
Postovi: 111
Pošto ja još nisam kupio laptop kceri a i doslo je do otkazivanje suradnje kupovanja preko frenda opet krecem iz početka samo trenutno sa smanjenim buđetom od 3-4K kn i na rate na karticu uvjet je 17" namjena gledanje filmova, net i mozda neko igranje ako ce kci biti zainteresirana trenutno nije. Bitna mi je garancija cim duza i odvojena graficka i trenutno sam nasao ovo HP Pavilion g7-2210sm, C5T24EA 1+3 godine garancije 3,8K kn. Vaše mišljenje znam da je hp li-la ali 4 godine ima garanciju. |
#2118 |
Lokacija: Kupres
Postovi: 4,085
Pretpostavljam da se radi o produljenju jamstva na ukupne 3g, a ne za dodatne 3g. Kako god, kad se radi o plaćanju na kartice, to nije loša cijena. Nešto jeftinije ipak dobiješ ovog Asusa s 2g. jamstva. Što se tiče samog branda, generaliziranje o kvaliteti je glupost. Svi se ti laptopi rade u istim kineskim tvornicama, nijednog od njih ne pravi ni HP, ni Toshiba ni nitko od velikih imena (osim Asusa), već veliki OEM proizvođači. Gotovo su jednake šanse da su dva različita modela HPa rađena u istoj tvornici, kao i da su neki HP i Lenovo rađeni u istoj tvornici. A podrška je kod svih jeftinih laptopa isto sranje, nepostojeća. |
#2119 | |
Lokacija: karlovac
Postovi: 111
#2120 |
Postovi: 34,042
Da si stavio W7, kod prvog updatea bi ti skinuo većinu potrebnih drivera, a ostatak bi lako našao na netu pomoću Hardware ID komponente.
#2121 |
Lokacija: karlovac
Postovi: 111
E jbg sada neka radi koji dan na win 8 pa cu staviti win7. Je da su brži subjektivno ali su komplicirani u ... Hvala još jednom na preporuci da ne zeznem se sa HP |
#2123 |
Agent 0
Lokacija: Kutina - ZG
Postovi: 4,312
Zato što je loša kvaliteta izrade kao i na vecini njihovih jeftinih prijenosnika Zato što procesor nije quad core, vec dual core sa ajmoreci hyperthreadingom. Ram je nebitan u prici, grafička nije nešto presnažna. http://www.links.hr/?naziv=prijenosn...kl=014.620.049 IMHO, Bolji proc, bolja grafika, viša kvaliteta, bolji proizvod. |
#2125 |
Postovi: 24
Čini li se meni ili je trenutno ponuda u našim trgovinama stvarno značajno pala? Mislim na solidne laptope za umjerenu cijenu, posebno Samsung i Lenovo koji su ovdje često spominjani kao best buy. |
#2126 |
Lokacija: Kupres
Postovi: 4,085
Možda je trenutno takvo stanje, povoljni modeli su rasprodani, a uvoznik obično ne dobavlja nove količine istog laptopa, pa je ponuda takva kakva je. Sigurno će se uskoro pojaviti neki novi best buy model, samo treba ubosti u pravo vrijeme. |
#2127 |
Postovi: 24
Hvala na informaciji, nisam znao da se ne naručuju nove zalihe, pogotovo modela koji se dobro prodaju. Ah sad neću prežaliti što nisam na vrijeme uzeo 350e5x-s01hr, taman je imao sve što mi treba. |
#2128 |
Datum registracije: Feb 2013
Postovi: 17
Evo ga SAMSUNG NP350E5X-S01HR opet u Hrvatskoj:http://www.nabava.net/trazilica.php?...NP350E5X-S01HR Najbolje bi bilo uzeti ga ovdje:http://futura-it.hr/proizvod.aspx?productId=0490909 |
#2129 |
Datum registracije: Feb 2004
Postovi: 302
Neki komentari za ovaj laptop? http://www.centro.hr/detalji_proizvo...m-d1p03ea.aspx Ja sam očito retardiran pa nisam uspio iskopati neki review. Vidim da coconut kritizira HP-ove laptope i kvalitetu izrade; odnosi li se to i na ovu seriju Pavilion G6? Koje su uopće konkretne zamjerke, zašto bi Samsung/Lenovo/Asus bio bolji izbor?
KAJ |
#2130 |
Lokacija: Kupres
Postovi: 4,085
Očita zamjerka je kratko jamstvo i ne baš najjeftinije produljenje, cca 300kn na 2g. Druga je to što za novije HPove modele imaš samo drivere za Win8. Kvaliteta izrade je korektna, cijeli je od glossy plastike što nije baš zahvalno za održavanje. Nerijetke su primjedbe i na pregrijavanje tog modela (to nećeš naći u rewievima jer se nijedan laptop ne pregrijava nov, ali kad se malo prašine nakupi...). Osobno ga ne bih uzeo isključivo zbog jamstva, a kad nadodamo produljenje na cijenu, onda bih te novce radije dao za ovog Asusa, iako ima manje diska i RAMa. http://www.nabava.net/trazilica.php?tp=0&q=K55VJ-SX019D |
