Staro 27.06.2013., 12:53   #301
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
eo citam sad forums i novi driveri isti k ko i stari... meni se skidao bf3 ponovno zbog friske reinstalacije winsa pa probam veceras. Evo samo neki postovi sa geforce foruma
"So nvidia, are you telling us we waiting ALL THIS TIME for this driver.
Only for it to be as broken as the last one?
I'm really starting to lose faith in nvidia and am seriously considering selling my 6series for the equivalent ATI. It is beyond a joke now."
odmah post ispod
"I still have issues with my GTX 770 Gigabyte 2 go.
The game crash came back to windows, no error message but "nvlddmkm failed to respond" in windows report event.
I have this problem with every driver i could install 320.08 320.18 320.49.
Nvidia please fix this "
i jos cijele 24 stranice sranja... budem vidio veceras
https://forums.geforce.com/default/t...sed-6-25-13-/1
24 stranice o driveru , nisam nasao 4 pozitivna posta
s tim da nisu samo 7xx seriju smrdali nego sve , usotalom tko ima vremena ima gore temu sa sluzbenog foruma pa da ne ispadne da pricam gluposti
Staro 27.06.2013., 13:00   #302
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Ne vjerujem da pricas gluposti ali me zanima koji k se desava jer sam ja apsulutno bez najmanjeg problema osim one glupe poruke change to basic colors ili sl. u Metrou.
Ti korisis Firefox? Ja ne jos od prije dve godine kad sam zadnji put imal probleme s Nvidijom i Firefoxom sa rusenjem drivera.
Zadnje izmijenjeno od: MAGARAC. 27.06.2013. u 13:12.
MAGARAC je online   Reply With Quote
Staro 27.06.2013., 13:05   #303
musso
Unregistered User
musso's Avatar
Datum registracije: Jun 2002
Lokacija: Beč
Postovi: 722
Autor MAGARAC Pregled postova
Stavi bf3 na ultra a u driverima nemoj mijenjati nista pa igraj jedno pola sata u komadu pa onda reci ako ce ti se pojavljivati problemi. Meni je znalo nakon 5 min vec. Stvar je u antialiasingu nesto. Sada imam u driverima pod global ukljuceno FXAA - ON i onaj post processing na HIGH stavljeno a MSAA iskljuceno i onda mogu igrati sat vremena u komadu desi mi se stvarno rijetko.
Ali ako sve default ostavim 5-10min artefakti nemogući.
musso je offline   Reply With Quote
Staro 27.06.2013., 13:24   #304
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
Ne koristim firefox jako dugo, na chromu sam.
Staro 27.06.2013., 18:01   #305
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Pa dobro, nije to tak ni strašno kako bi moglo biti strašno
Nije uopće strašno, osim što su ventovi gotovo konstantno na povećanim vrijednostima
Postoji još jedna promjena koja, čini mi se, nije bila prisutna sa starijim driverima - napon na čipu je sada konstantan (1.175V), dok je prije znao padati na manje vrijednosti tijekom 3D okoline.
Znači sada je, od početka pa do kraja uvijek isti, što je možebitni uzrok veće brzine ventova.
Primjetio sam da su i taktovi sa novim driverima konstantno na Boost vrijednostima prilikom gejmanja. Praktički nema padanja MHz ni u jednom trenutku.
Staro 27.06.2013., 20:40   #306
Toorop
Mother Russia
Toorop's Avatar
Datum registracije: Mar 2013
Postovi: 326
Stigle su 780-tke u HR. GTX 780
Toorop je offline   Reply With Quote
Staro 27.06.2013., 22:26   #307
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,826
Stigla 760, 2200kn.
Staro 27.06.2013., 22:43   #308
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
http://forum.pcekspert.com/showthrea...67#post2421767
Dobro je kaj ej to Asus pa bi mogle bit i jeftinije..
http://www.techpowerup.com/reviews/A..._II_OC/32.html
Nije bas na nekom DC2 nivou ak se mene pita.
Staro 27.06.2013., 22:47   #309
zvonac
zvonac's Avatar
Postovi: 5,826
Onda mogu ocekivat oko 1800-1900kn... MSI Tf, GB Wf itd..
Staro 27.06.2013., 22:50   #310
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Mozda. Cekaj MSI. Oni nisu previse stedili na hladnjaku i PCBu i sigruno ce bit povoljna kod nas u odn. na ostale. Ref. modele Gainward, Palit i sl. izbjegavaj. TF sa MSIja sa svojim velikim ventovima je odlican hladnjak i na 760 ce bi zakon.
Nije mi jasno zasto su na 770 TF toliko spustili brzinu venta i dopustili da se grafa toliko grije. Samo par % vise i sve je jos uvijek necujeno i skoro 10c bolje. To su naprvili na Lightning pa valjda zato nisu sa ovom, treba opravdat razliku u cijeni i za one kaj ne klokaju tolko. 760 gaming nema taj problemcic.
http://www.techpowerup.com/reviews/M...Gaming/31.html
Zadnje izmijenjeno od: MAGARAC. 27.06.2013. u 22:58.
Staro 27.06.2013., 22:55   #311
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,306
he he, ako bude stvarno 1800-1900 MSIjka mozda ja stvarno preskocim 770tku (i ako ne nadem 670tku povoljno).
sta mislite jel mi dost 760tka za sljedecih godinu-dve dana rokat na 1080p ?
samo sta nebi onda stvarno 670tke trebale drasticno past polovne pa cak i nove ? bar isto tako oko 1800kn.
We all must hang together, or surly we will hang separately.
Staro 27.06.2013., 22:55   #312
syss
syss's Avatar
Postovi: 10,805
ma taj asus je počeo žešće saksat... najskuplji, najmanje se kloka, a ni taj kuler više nije neka fantazija (ref. na 770 roundup kaj sam gledao neki dan).
Staro 27.06.2013., 23:22   #313
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Gdje se rusi BF3, artifakti i ostalo? Ima specificna mapa ili svugdje. Ja sam sad odigral 10tak min i radi bez beda, 100njak fps na Ultra..
DC2 vani kosta 10$ vise od preporucene cijene, isto kao i MSI. Te visoke cijene su samo kod nas.
Bitrate je jako skresan da bude sto manje, upload u banani ali se dovoljno vidi da nema niceg cudnog. Jebeno me zanima zasto nekima sve radi super a drugima je sve u k.
http://www.youtube.com/watch?v=DvsIi...ature=youtu.be
http://www.youtube.com/watch?v=ZkZwn...ature=youtu.be
Malo zanimljivosti, BF3 na GTX 580 Light. Extreme u 2011 i sad na gtx 770. Nikad ta igra nebu imala stabilan FPS za one kaj se zale da im padne sa 120 na 75. Prevelike su razlike izmedu zahtjevnih i manje zahtjevnih sekvenci.
Frames, Time (ms), Min, Max, Avg
17219, 215437, 45, 136, 79.926
2011-10-25 21:46:59 - bf3
Frames: 15509 - Time: 300000ms - Avg: 51.697 - Min: 33 - Max: 81
Zadnje izmijenjeno od: MAGARAC. 28.06.2013. u 00:33.
Staro 27.06.2013., 23:27   #314
nino
nino's Avatar
Postovi: 12,613
Meni sutra stizu 2 Gigabytice 760 oc, pa se nadam ako ne odu uskoro da cu moci isprobati koju.
Staro 27.06.2013., 23:33   #315
Toorop
Mother Russia
Toorop's Avatar
Postovi: 326
Well, 760 ce biti pristojna zamjena za 8600GT iako mozda piknem 770
Staro 27.06.2013., 23:35   #316
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Autor syss Pregled postova
Ma za bacit u smeće, fuj Asus, pljuc pljuc ... ne bi ga uzeo ni za kunu, pljuc
Malo su promijenili dimenzije, sa triple-slot na dual-slot, pa je vjerojatno zbog toga slabije hlađenje ...
The Secret ...
Staro 27.06.2013., 23:37   #317
syss
syss's Avatar
Postovi: 10,805
ma sve divno i krasno, ali ja na to gledam kao set-and-forget hardver, a out of the box ga ždere ono palit.
Staro 27.06.2013., 23:45   #318
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Ima istine u tome, znam po svojim Asusovim garfama u zadnje dve, tri god. Mada je to cesto nikakva razlika. S druge strane im memorija ide puno bolje nego na svemu ostalome, gtx 670/680 s lakocom prelaze 7000, cak i 7400 dok ostale jedva predu 6500. 580 isto divlja s memorijim.
Staro 27.06.2013., 23:45   #319
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
S obzirom na komentare u ovoj i stranim temama, biti će sve, samo ne set-and-forget
Koliko se ljudi žali da im ni na stocku grafe ne rade kako treba, bio bih oprezan sa izjavama o OC potencijalu pojedinih kartica
The Secret ...
Staro 27.06.2013., 23:50   #320
syss
syss's Avatar
Postovi: 10,805
ma dobro sada to na stranu... hoću reći da mi ne treba neki bijesni pcb, voltage izvodi, lemilica i slične stvari, pričam čisto o hardveraju.
pod uvjetom da normalno radi jel
Staro 27.06.2013., 23:50   #321
geronimo_2
geronimo_2's Avatar
Postovi: 4,306
Autor dh41400 Pregled postova
Staro 28.06.2013., 00:08   #322
Kako ocati nekaj kaj je već debelo pretjerano ocano?
Staro 28.06.2013., 00:54   #323
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Za klokanje su 780 i Titan ali zna se u cemu je problem. Te grafe su "out of box" na jako niskim mhz a staju na prakticki istim mhz ko 770 i ostale gf104. 863mhz na skoro 1200 ak neko ima dobru, mnogo je to. GTX 770 ima mozda 10% u rezervi, gtx 670 ima 20%, 680 mrvicu manje itd. OD gtx 660ti na dalje do 770 je sve apsulutno isti drek za 1080p. Dal ide sa 60,70 ili 80 na kraju ispadne isto. Malo je igri gdje dodatne perf. na 770 u odn na 660ti mogu znaci i neke bitno vise postavke. Sad igram CoH 2 i nema sansi da 770 vrti SSAA i na kraju ce se igra igrat na istim postavkama kao i na 660ti, isto kao i Metro, FC3 i mnoge druge..
Ni jedna od tih grafi nema dovoljno masti na opravda vise od 2gb memorije, ukljucujuci i Radeonke, preslabe su za te postavke gdje treba toliko vrama i ta prica je isto bezveze i taj problem nece nikad doc do izrazaja, kad vec meljem da i to napisem.
Zadnje izmijenjeno od: MAGARAC. 28.06.2013. u 01:00.
Staro 28.06.2013., 00:55   #324
Za klokanje su 780 i Titan ali zna se u cemu je problem. Te grafe su "out of box" na jako niskim mhz a staju na prkticki istim mhz ko 770 i ostale gf104. 863mhz na skoro 1200 ak neko ima dobru, mnogo je to. GTX 770 ima mozda 10% u rezervi, gtx 670 ima 20%, 680 mrvicu manje itd. OD gtx 660ti na dalje do 780 je sve apsulutno isti drek za 1080p. Dal ide sa 60,70 ili 80 na kraju ispadne isto. Malo je igri gdje dodatne perf. na 770 u odn na 660ti mogu znaci i neke bitno vise postavke. Sad igram CoH 2 i nema sansi da 770 vrti SSAA i na kraju ce se igra igrat na istim postavkama kao i na 660ti, isto kao i Metro, FC3 i mnoge druge..
G92 story all over again.
Staro 28.06.2013., 01:10   #325
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Nebi ja imal nist protiv da je Kepler ko G92. Prvu 8800gt, EVGA sam kupio u AMD, starom i imala je perf. kao vise nego duplo skuplja 8800gtx. Za 2000kn kaos. Igre su isto bile x puta bolje nego sad. Kerpler nije ni blizu tak revolucionaran i njemu rebranding ne oprastam. Meni je 8800gts 512 najbolja grafa svih vremena, mojih. 8800gt su bile malo prevruce inace bi njih stavio.
Staro 28.06.2013., 01:12   #326
syss
syss's Avatar
Postovi: 10,805
bitno da ti nisi znao di je bivši adm... čuj mene amd... ovaj adm
Staro 28.06.2013., 01:17   #327
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Da to mi je mana. Znal sam ja gdje je bio i HG srot.
Litrenka od Pramena, Litrenka od zuje nakon vecere i sad cuclam mali Becks pa je razumljivo..
Staro 28.06.2013., 08:09   #328
Imao sam 8800GT vrlo brzo nakon izlaska. Ali predugo je ta priča trajala. 9000 serija, pa onda još i GTS-ice iz 200 serije. Vrlo brzo je postao nemoćan.
Što znači da ćemo sada ovaj čip vidjeti i u 800 seriji do nekog broja, recimo 850
Staro 28.06.2013., 10:34   #329
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
Probah nove drivere i za sad je "ok". Ovo ok kazem s dozom opreza jer iako sve radi nema bsodova, driver stop respondinga inostalih pizdarija, bf3 ima gadne dropove znaci sa 120 fpsa padne i ispod 60 na caspianu, sve ultra 4x msaa i iskkjucen hbao. Probam sutra preksutra metro 2-3 h pa cu vidjeti. Ovo je sve na friskoj instalaciji winsa tako da su ovo prvi driveri snimljeni.
Staro 28.06.2013., 11:22   #330
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Titan na Swordbraker ima prosjek od 90fps tak da ne znam kak ocekujes 120 od 770, pogotovo na toj mapi kaj je jedna od najzahtjevnijih. Stani se ispod hellfirea kad rokne i imat ces drop i ispod 40 ali to je ve normalna stvar u toj igri, zloglasni particle effects kaj to rade vec godinama na svim garfama i u puno igri.. Ukljuci vsync ili probaj adaptive vsync i to se nebu toliko osjetilo. 120fps ne treba u toj igri osim ak imas 120 mhz monitor.
Zadnje izmijenjeno od: MAGARAC. 28.06.2013. u 11:37.
