Staro 19.11.2002., 00:24   #1
Aba
Aba's Avatar
Datum registracije: Nov 2002
Postovi: 10
Question Cach u Win XP-u?
Kako odrediti cach pod winXP
Aba
Aba je offline   Reply With Quote
Staro 19.11.2002., 09:49   #2
gpremec
matroxfanatic
gpremec's Avatar
Lokacija: Zagreb, na zapadu
Postovi: 2,444
Cash sto?
Swap file?
Internet cash files?
Preciznije malo
Holly: "Appreciate what vou've got, because basically, I'm fantastic!"
my UD stats
gpremec je offline   Reply With Quote
Staro 19.11.2002., 10:00   #3
Aba
Aba's Avatar
Postovi: 10
cache memorija
cache memoriju u odnosu na radnu računala.(vcache) Minimalna i maximalna?!
Aba
Staro 19.11.2002., 10:29   #4
greg SE
greg SE's Avatar
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
eto, i ovdje si postavio jako precizno pitanje.......
i sad ja izmisljam jer koristim winme
Staro 19.11.2002., 10:55   #5
Studano
Studano's Avatar
Datum registracije: May 2002
Postovi: 75
Re: cache memorija
Vjerovatno te zanima kako podesiti swap memoriju iliti virtualnu memoriju da bude veca ili manja....
to radis u WINME i ranijim verzijama u virtual memory settings by right clicking on 'my computer', selecting the performance tab, click 'virtual memory'. is it set for windows to manage it, or is windows running on a set ammount of virtual memory?
eto tako si namjesti koliko zelis virtualne memorije...
Take the path that is your own...INDIVIDUALITY.
Studano je offline   Reply With Quote
Staro 19.11.2002., 11:02   #6
Studano
Studano's Avatar
Postovi: 75
A ako te zanima kako i sta to radi odi na
http://www.howstuffworks.com/question684.htm
mozda ti pomogne ...
A ako ti treba za XP probaj...
Go to control panel,system,advanced,setting(performance),advanced,change(virtual),set
ili
What are your virtual memory settings? To find them, go to Start > Settings > Control Panel > System > Advanced > Performance > Settings > Advanced > Change. There are at least a couple of possibilities: (a) If the setting is "No paging file", you can change this to either "System managed size" or "Custom size". Most people on the various fora suggest changing to Custom and specifying a fixed amount (both maximum and minimum the same value) of 1.5 times amount of ram. I don't believe that XP is as bad about eating your system alive by constantly changing the sizes as earlier windows systems, so changing to System managed might not be all that bad. (b) If the setting is already for System managed virtual memory, you may need to defragment your HDD or put your virtual memory on a larger disk. (c) If the display shows that the specified maximum is in use, increase the maximum.
Staro 19.11.2002., 18:28   #7
Aba
Aba's Avatar
Postovi: 10
Exclamation sysedit
Ljudi šta to nikada niste radili na Wim 98 recimo
Start ,run ,sysedit, i u sistem.ini fajlu pod vcache upisati min VIRTUALNOG cacha i max.
Samo je pod XP malo drugačije pa pitam ,a ako niste to ni prije radili onda ništa , u svakom slučaju hvala na trudu
Aba
Staro 19.11.2002., 19:13   #8
RAK
Feldwebel
RAK's Avatar
Datum registracije: Feb 2002
Lokacija: bolnica
Postovi: 3,739
Tako ne jer je postojao daleko brži i lakši način.
Pod XP-ima ti treba biti onoliko koliko ti XP preoruče. Samo još toliko dodaj na drugi disk i super.
Staro 20.11.2002., 09:44   #9
gpremec
matroxfanatic
gpremec's Avatar
Postovi: 2,444
Ah, dobra stara vremena Windowsa NT 4.0...
Evo, bas sam jucer detaljno provijerio Antivirus server u firmi: Win 4.0 Server, 64MB, radi neprestano vec 4 mjeseca (tada su bili radovi u server sali), ima 300+700MB swap fajla, a on je od tada maksimalono u jednom trenutku koristio cak 25MB. Di ces bolje.
my UD stats
Staro 20.11.2002., 11:26   #10
Raven_1
Night shift
Raven_1's Avatar
Datum registracije: Jul 2002
Postovi: 884
Originally posted by gpremec
Evo, bas sam jucer detaljno provijerio Antivirus server u firmi: Win 4.0 Server, 64MB, radi neprestano vec 4 mjeseca (tada su bili radovi u server sali), ima 300+700MB swap fajla, a on je od tada maksimalno u jednom trenutku koristio cak 25MB. Di ces bolje.
Server na memorijskoj dijeti
Proc: AMD X2 3800+ cooled by TT BigTyphoon
Matična: ABIT AN8 SLI
RAM: 2x512MB OCZ Platinum EL rev2 PC3200
Grafička: SAPPHIRE ATI RADEON HD3450 256MB
HDD: WD 40GB i Samsung 160GB @ 7200
RW:DVD-ROM Pioneer DVD-106
PSU: 420W Xilence RedWing
"NOBODY expects the Spanish Inquisition! Our chief weapon is surprise...surprise and fear...fear and surprise.... Our two weapons are fear and surprise...and ruthless efficiency.... Our *three* weapons are fear, surprise, and ruthless efficiency...and an almost fanatical devotion to the Pope.... Our *four*...no... *Amongst* our weapons.... Amongst our weaponry...are such elements as fear, surprise.... I'll come in again."
--uoɥʇʎd ʎʇuoɯ--
Raven_1 je offline   Reply With Quote
Staro 20.11.2002., 12:06   #11
gpremec
matroxfanatic
gpremec's Avatar
Postovi: 2,444
Ne samo to, vec i manji memorijski zahtjevi NT 4.0 naspram XPa. Da ne kazem da i bolje koristi svoj RAM.
my UD stats
Staro 20.11.2002., 15:08   #12
greg SE
greg SE's Avatar
Lokacija: Vinkovci
Postovi: 5,231
Re: sysedit
inace windowsi imaju i daleko jednostavniji nacin na koji ti kao strucnjak nekim cudom ocito nisi naiso
Staro 21.11.2002., 10:30   #13
gpremec
matroxfanatic
gpremec's Avatar
Postovi: 2,444
Re: Re: sysedit
Mozda mu je bilo prejednostavno.
my UD stats
Staro 21.11.2002., 11:24   #14
greg SE
greg SE's Avatar
Lokacija: Vinkovci
Postovi: 5,231
Re: Re: Re: sysedit
ma da, sta je zivot bez izazova
