Staro 06.05.2013., 23:42   #901
acer
Whatever :)
acer's Avatar
Datum registracije: Nov 2002
Lokacija: Rijeka,Bulevard
Postovi: 1,753
Ajde daj printscreen greske, jer se jednom slicno dogadjalo pa se ispostavilo da ima novi model sa 1,2 Ghz procom tj model 4500T
GIGABYTE B450 AORUS PRO
Fractal Design Define XL R2
Chieftec A-80, CTG-750C, 750W
AMD Ryzen 5 3600
Be Quiet Dark Rock Pro 4
Asus Nvidia GTX 1060 OC Edition, 3GB
Avermedia Live Gamer HD Lite
GEIL Evo Spear AMD GASB416GB3200C16ADC, DDR4 3200MHz, kit 2x8GB
Kingston NVMe M.2, 1TB
LG BH16NS55 Bluray writer
LG GGW-H20L Bluray writer
27" Philips
Brother HL-2240
Das Keyboard 4 Professional, MX brown
Logitech mouse G402
Scanner HP Photosmart G3010
Cambridge Audio DacMagic 100
Scythe SDAR-2100 + Scythe Kro Craft Speaker SCBKS-1000
Windows 10 PRO x64
Staro 09.05.2013., 08:57   #902
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,125
@Acer:
Daj mi reci ima li ovaj 4500 WiFi HotSpot? Jednostavno nemogu vjerovati službenim podacima..... link na sluzbenu stranicu
Verifikacija poštenog trgovca #1, #2, #3, #4, #5, #6, #7, #8, #9
Staro 09.05.2013., 09:02   #903
Kruno M
Kruno M's Avatar
Lokacija: VKCI
Postovi: 1,227
Na androidu 4.1.1. ima po defaultu, a inaće uvjek možeš instalirati neku market app za hotspot.
Staro 13.05.2013., 09:12   #904
LuxZg
Postovi: 512
Bas ispred sebe imam novi 4044 model, navodno 200kn skuplji od 4040, dual core. Dizajn malo promijenjen, dodje s futrolicom i jelly bean. Bum editirao post kasnije s vise info, il postnem dolje detalje..
Intel Core 2 Duo E4400 @ 320x10 (3200MHz) w/ Scythe Ninja rev.B + 120mm fan | Gigabyte GA-P35-DS3R (Intel P35 + ICH9R) | 4x 1GB Kingmax MARS DDR2 800 CL5 | Sapphire ATi Radeon HD4890 | Seagate 7200.11 250GB+2x WD Black 640GB+Samsung F3 1TB; svi SATA/7200rpm | LG GH20NS15 SuperMulti, SATA | LG W2361V-PF 23", 1920x1080, DVI+HDMI | Aplus CS-188AF case w/ 250mm side fan | onboard 7.1, with Logitech X-540 5.1 speakers | Chieftec 450W /w 120mm fan | Windows 7 64bit Enterprise
LuxZg je offline   Reply With Quote
Staro 14.05.2013., 09:11   #905
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,125
micro first look 4322
Daklem to je to... kupio sam si smartphone
Kupio sam ga na totalni blef, nema još recenzija na netu za njega, samo par bugarskih yubito previewa.
Uglavnom izbor je pao na Multiphone 4322 DUO
Moja prva dvojba je bila veličina ekrana, 4" ili 4.3" (model sa 4.5" sam nakon kraće analize odbacio iz razmatranja. Naime postoji novi model 4055 koji ima ekran od 4" ali i bateriju od 2500mAh, za razliku od mojeg odabranog 4.3" koji ima bateriju od 1500 mAh. Uglavnom odabrao sam veći ekran, nekima će ovaj sa jačom baterijom vjeroajtno biti bolji izbor. Inače oba modela imaju običan TFT LCD, dakle nemaju IPS matricu. Inače imam Prestigiov tablet od 7" sa IPS matricom, mislim da nije tu neka prevelika razlika. Model sa 4.5" sam odbacio jer ima praktično 16:9 omjer ekrana što mi se nije svidjelo.
Sa modelom 4322 dobije se i kožni etui kojega definitivno treba razraditi, šteta što nema trakicu za izvlačenje mobitela, ali ima izbušene rupice na mjestu zvučnika tako da bi se zvonjava trebala čuti i dok je mob u etuiju. Na prijašnjim modelima su neki ljudi sami rezali rupe.
Sve podatke imate na gore priloženom linku. Ukratko, dual core, 512 Mb, nekome je važan predinstalirani JB
Ubacio sam svoju Tele2 karticu sa SMART tarifom u slot SIM1 i sve je proradilo od prve. Isprobao sam mobilni internet i gmail mi se odmah ažurirao sa mailovima. Nakon toga sam ispijajući kavu u kafići usprobao i WiFi također bez problema.
Da li ima gorilla glass? Neznam.
Punjač daje "samo" 550mA pa punjenje od nule po proizvođaču može potrajati i 3.5h. Imam doma neki Belkin od 700mA pa možda budem koristio njega za brže punjenje.
Malo me razočarala kamera od 8 Mpix. Nadao sam se da će snimati video 720p ali čini mi se da nije tako. Na najboljim postavkama snimak je 4:3
Chrome browser mi na ovom androidu ne radi. Jednostavno se sruši. Skype, viber,FB, Gmail.... rade bez problema.
Jutros sam ga iskopčao sa punjača pa ću sada vidjeti koliko će trajati baterija sa normalnim korištenjem.
Eto....
Staro 15.05.2013., 12:04   #906
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,125
Uobičajena priča...
Malo mobilnog interneta, malo WiFija, još malo kombinacije oba dva prilikom uspješnog korištenja hotspota za surfanje tabletom, malo razgovora...
Baterija navečer došla na 23%. Dakle svakodnevno punjenje, ali to sam i znao da će se desiti. Ništa, ako bude moguće nabaviti zamjensku jaču bateriju, to će biti slijedeći korak.
Inače dojmovi nakon prvog dana korištenja su vrlo dobri.
Staro 15.05.2013., 13:23   #907
tskarda
tskarda's Avatar
Postovi: 1,125
Čitam Pogija, pa reko i ja ću napraviti osvrt, možda nekome pomogne.
Znači Prestigio 4500 1.2 GHz
Uz ostale mobitele koje sam imao (wildfire, desire, galaxy mini, iphone 4, xperia u... znači niti jedan high end u ovo novije doba) ovo mi je najbrži mobitel. U biti to mi je i jedini razlog zašto sam mijenjao mobitele. Svi nakon nekog vremena i uz par aplikacija postanu tromi i užasno je raditi na njima (ili je samo užasno raditi na njima - iphone).
Prestigio nakon mjesec dana korištenja je i dalje brz, uz standardne aplikacije koje koristim (Aptoide, call recorder, clockq, compass, evernote, fing, keep, kvizoman , lite led, rba na dlanu, sms backup+, sudoku, viber, skype).
Imam osjećaj da je na drugim mobitelima stiskanje po rubu ekrana, kada se drži jednom rukom bilo nekako zaštićeno, tj. da ne prihvaća ako dlanom stisnem rub ekrana, Prestigio toga nema, pa često stišćem rub ekrana i malo je iritantno.
Najveća zamjerka mobitelu je baterija. Katastrofalna baterija. (1850mAh
Ujutro ga skinem s punjača oko 8 i rijetko koji dan izdrži do 10 navečer. Dnevno imam cca 80 razgovora koji su kratki, mobitel je uvijek na wirelessu ili ako sam izvan ureda onda je mobilni internet uključen. (dvije sim kartice su unutra)
Uredno svake večeri dobijem poruku Over Current Protection, Your battery is over current - protection, please remove battery! pa ga ne držim blizu kreveta.
Hotspot koristim jedino ako mi je punjač uz mene.
No i dalje ću ga koristiti jer za taj novac se ne može kupiti bolji mobitel od ovoga.
Staro 15.05.2013., 14:38   #908
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Može tko kresnuti kakvu sliku dok je vani lijepo vrijeme i slično ? Sa modela 4500 ? A i nisam dobio informaciju koliko MB ima interno za instalirati aplikacije. Jel oko 500MB točan podatak ?
Staro 15.05.2013., 15:19   #909
ukiy
ukiy's Avatar
Datum registracije: Apr 2008
Lokacija: ST
Postovi: 398
Da, 500MB za aplikacije je tocan podatak.
Trenutno nemam slika u mob., ali ima par recenzija po netu sa testom kamere pa mozes baciti oko tamo, npr.
ukiy je offline   Reply With Quote
Staro 15.05.2013., 16:53   #910
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,125
@tskarda & acer:
Pitanje, jesi isprobao GPS?
Instalirao sam si par aplikacija za GPS, ono samo da isprobam da li radi da mi očita položaj. Međutim, nikako nemogu dobiti geo poziciju iako nađe i do 6-7 satelita ali signal im je nekako slab (ako sam skuzio kako aplikacija radi) u žutom je području.
Inače testirao sam ga i tako da pokupi točno vrijeme sa GPS satelita i to mi radi, ali pozicija nikako.
KAda upališ GPS, da li ti onaj kružić u gornjoj traci blinka dok ne nađe satelite i kad ih nađe onda kružić više ne blinka nego je upaljen (bijelo) ?
Prvi problem na kojeg sam naišao, sa ovim mobom
Staro 15.05.2013., 17:04   #911
tskarda
tskarda's Avatar
Postovi: 1,125
Evo lokalpatriotizma!
Slikano upravo sada, sunce sja.
http://pluvia.hr/2013-05-15%2015.55.23.jpg
http://pluvia.hr/2013-05-15%2015.55.26.jpg
Nije mi se ugasio GPS u 2 min koliko sam stajao vani, moram kad ulovim vremena probati pa javim.
Staro 15.05.2013., 17:28   #912
acer
Whatever :)
acer's Avatar
Postovi: 1,753
Meni GPS radi ko zmaj. Satelite pronadje jako brzo, recimo Navitel za 20-tak sekundi nadje.
Ne znam sto te tocno zanima.
Jesi probao ovo?
FASTER GPS FIX:
-Go to "Location services" in "Settings"
-Enable "GPS EPO assistance"
-Click "EPO settings" and then click "Download" (Internet connection is needed!)
-Go back and enable "A-GPS"
-Click "A-GPS Settings" and select "GOOGLE" profile
Inace svima bih preporucio da instaliraju Mobileuncle MTK tools, ima hrpu opcija za tweak.
https://play.google.com/store/apps/d...euncle.toolbox
AMD Ryzen 5 3600
27" Philips
Brother HL-2240
Logitech mouse G402
Windows 10 PRO x64
Staro 15.05.2013., 19:15   #913
RAUL
Lokacija: Worldwide
Postovi: 2,553
A-GPS trosi data promet.Da poslje ne bude da novci nestaju sa racuna ukoliko nije aktiviran neki data paket.
Staro 16.05.2013., 09:01   #914
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,125
Autor RAUL Pregled postova
Sve OK. To je jasno.
Staro 17.05.2013., 03:26   #915
trolljegeren
Datum registracije: Dec 2012
Postovi: 15
imam jedan problem..znaci internet (podatkovni paketi) sve je normalno radilo do prije neki dan..probao sam upaliti podatkoven podatke i pise VIP HR i uredno stisnem i dugo se pali i kada se upali nema vise one ikone iznad signala da je 3G spojen i da radi..jednostavno nece..sto da radim?hvala
trolljegeren je offline   Reply With Quote
Staro 18.05.2013., 01:00   #916
Prijateljski
ex manki1
Prijateljski's Avatar
Datum registracije: Aug 2008
Lokacija: Zwickau
Postovi: 604
Jel ima tko model 4505?
Kakvi su dojmovi? Imao sam model 5000 i jedina mana mu je bila dimenzija. Ovaj mi se čini taman.
Prijateljski je offline   Reply With Quote
Staro 21.05.2013., 21:47   #917
bad_ri
bad_ri's Avatar
Postovi: 87
imam jedno pitanje za znalce - kako stati na kraj aplikaciji koja se sama pali nakon što je ugasim? radi se o viber-u.... kad ga hoću ugasiti, idem normalno na "more options -> exit", aplikacija se ugasi, stoji ugašena neko vrijeme, a onda se nakon nekog proizvoljnog vremena sama pali. nemojte pitati zašto želim da bude ugašena (kao što pitaju druge na drugim forumima), jednostavno želim biti izvan vibera, dok mi druge aplikacije koriste net. znam da ima fora za sakriti online status i druge cake, ali baš želim da aplikacija ostane "ubijena". hvala!
bad_ri je offline   Reply With Quote
Staro 21.05.2013., 22:39   #918
Omerta
Omerta's Avatar
Lokacija: Grobnik - Rijeka
Postovi: 3,254
Ako netko želi rootat PAP 5000 DUO, na XDA su upute.
Pripazite jer ovo nije za "T" verziju.
link
Staro 21.05.2013., 23:39   #919
dstojic
Datum registracije: Aug 2011
Postovi: 45
Autor bad_ri Pregled postova
Isprobaj aplikaciju Greenify. Mob ti treba biti rootan. Meni radi perfektno.
dstojic je offline   Reply With Quote
Staro 22.05.2013., 09:22   #920
antonio3012
Datum registracije: May 2013
Postovi: 1
Pozdrav svima
Kupio sam 4322 i tek se igram s njim. Nisam jos stavio kartice, previse podataka na starom tel itd. Osim njegovih aplikacija skinuo tek jednu. E sad, sinoc mi se rusi internet preglednik 5 puta u 5 min. Pise gore u kutu sitnim slovima low memory. Nakon toga se samod sebe restarta i onda radi super. Sve aplikacije su bile pogasene ali sam u pregledniku imao 6-7 tab-ova otvorenih. E sad da li mi netko moze reci jel to normalno ili je neka greska u tel?! Jer kao sto sam napisao nema nista na njemu osim jedne youtube app. Strah me sta ce biti poslje! Pa ako netko moze pomoci. Hvala
antonio3012 je offline   Reply With Quote
Staro 22.05.2013., 11:25   #921
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,125
Autor antonio3012 Pregled postova
Pozdrav svima
Već je netko spomenuo da otvaranje puno tabova u brovseru uzima puno rama a ovaj mob ima samo 512Mb, tj. nema gigu. Vjerojatno je to uzrok.
BTW koliko ti rtaje baterija sa takvim korištenjem bez kartica?
Ako budeš instalirao Skype javi se malo u tred Android aplikacije
Staro 22.05.2013., 22:00   #922
domy_os
domy_os's Avatar
Postovi: 18,894
Autor Vuco Pregled postova
Kamera je bezveze, previše kompresira slike i u mračnijim uvjetima ponekad ima problema s blurom. To se donekle riješi continuos shotom čime u sekundi napravi nekoliko slika pa filtriraš najbolju.
Što se tiče memorije, stvari stoje ovako:
internal storage za aplikacije > 504 MB
internal memory card (oznaka sdcard1) > 1,89 GB
Samo za info, externa SD kartica nosi oznaku sdcard0.
To je jedna od većih stvari koja me smetala na ovom mobitelu pa sam odmah tražio način za reparticioniranje pa stvari nakon toga izgledaju ovako:
internal storage > promijenjeno u 1,97 GB
internal memory card > promijenjeno u 566 MB
Dodatno sam uzeo Samsungovu SD Class 10 karticu od 32 GB pa samo za info kakve su joj performanse:
Uglavnom, s mobitelom sam jako zadovoljan, pogotovo zato jer sam ga platio debelo ispod 2000 kn.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 22.05.2013., 22:04   #923
Kruno M
Kruno M's Avatar
Lokacija: VKCI
Postovi: 1,227
Autor domy_os Pregled postova
Kako si napravio ovo? Te da li se aplikacije ostau ili se sve friško mora instalirati?
Staro 22.05.2013., 22:28   #924
domy_os
domy_os's Avatar
Postovi: 18,894
Ukratko:
- prerequisite: mobitel mora biti rootan i instaliran CWM recovery
- nisam odgovoran za moguću štetu
1. napravi nandroid backup u CWM
2. skini i instaliraj APK iz priloga
3. odaberi željenu količinu memorije za aplikacije (nemoj preko 2 GB jer ćeš izgubiti internu SD karticu pa bi moglo biti problema)
4. na pop-upu stisni desnu tipku
5. odaberi reset u recovery i opet desnu tipku
U recoveryu obavezno formatiraj data, cache i dalvik cache, reinstaliraj ROM i vrati backup. Ako si koristio custom ROM, onda prvo instaliraj stock ROM pa na njega custom ROM i na kraju vrati backup.
Ako imaš noviji PAP4500TDUO, ni slučajno nemoj koristiti metodu sa MTK6577_Data_Repartition.zip fileom jer on je samo za stariji model s 1 GHz CPU i ICS-om. Ja sam brzinski čitao, predvidio tu zamku i greškom instalirao. Normalno, "ubio" sam mobitel pa onda par sati tražio kako ga vratiti iz mrtvih. Uspio sam môdom kojeg sam sâm napravio jer na netu nisam našao rješenje.
Zadnje izmijenjeno od: domy_os. 07.01.2020. u 00:29.
Staro 22.05.2013., 22:56   #925
Kruno M
Kruno M's Avatar
Lokacija: VKCI
Postovi: 1,227
OK, hvala. Ništa od toga jer imam T model. Vidjet ću možda negdje dalje ima šta pametno.
Staro 22.05.2013., 23:04   #926
domy_os
domy_os's Avatar
Postovi: 18,894
Imam i ja, očito si me krivo shvatio...
Mt657xRepartition-HK-Phone-Rom-Edit-em-English.zip MTK6577_Data_Repartition.zip
Ovo što sam ti napisao po točkama radi bez problema na T modelu.
Staro 23.05.2013., 03:36   #927
LuxZg
Postovi: 512
Novi mali update za pap 4040, geo location fixed, sms search fixed. Sad mi je iskocio, samo 1.5mb, al nemrem ga odmah stavit jer imam custom CWM i root i sl.. Ak ko proba nek javi da li je brzi gps fix!!
Staro 23.05.2013., 07:23   #928
Kruno M
Kruno M's Avatar
Lokacija: VKCI
Postovi: 1,227
Aaaa. danas-sutra probam. Hvala na ovome.
Staro 23.05.2013., 17:30   #929
tborzic
Lokacija: 21000 Split, Hrvatska
Postovi: 144
Pozdrav,
prelistao sam stranice ali nisam našao informaciju gdje kupiti nekakav gel case za 4500?
Hvala
tborzic je offline   Reply With Quote
Staro 24.05.2013., 14:35   #930
qutip
Lokacija: Zaprešić
Postovi: 164
Imam MP 4505.
Interesira me dali je moguće isključiti onu fade in animaciju u izborniku i kako?
qutip je offline   Reply With Quote
