Staro 25.04.2013., 13:59   #1
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
3.6V baterija za bežični telefon - gdje kupiti?
Riknula mi je baterija (NiMH 30AAAM3BMX) u Quadro DECT 3300 bežičnom telefonu. Inače je tel OK, pa mi je blesavo bacit ga, naročito zato što ga vrlo rijetko koristim. U Quadro servisu kažu da nemaju. Mislim da je to zapravo odjeb odgovor, ali dobro.
Ovako izgleda:
U Chipoteci ima takvih baterija od 3.6V s istim konektorom, ali su fizički druge veličine (veće su) - pa ne stane.
Pogledao sam i po par dućana usput i nigdje nije bilo.
Ima tko ideju ili prijedlog?
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
Zadnje izmijenjeno od: estugarda. 25.04.2013. u 14:05.
estugarda je offline   Reply With Quote
Staro 25.04.2013., 14:03   #2
Garro
Postovi: 2,390
Ebay ili repariranje u Baterije Zagreb (firma na Zelenom valu)?
Staro 25.04.2013., 14:11   #3
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Ebay mi je trenutno jako mrzak, jer mi 3 stvari zaredom nisu stigle, pa imam 3 "eskalacije"...
Repariranje NiMh baterije? Kaj se to isplati? Koliko oni to cijene? Ne vidim cjenik na stranici...
Meni to zvuči kao da se ne ispalti, i kao da će biti jeftinije kupiti novi telefon...
U Chipoteci su 20-40kn takve baterije...
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 25.04.2013., 14:34   #4
Pepermint
Pepermint's Avatar
Postovi: 587
prije su imali takvih baterija, jel nije to dimenzija 3xAAA baterije, samo što su povezane i imaju taj konektor?
EDIT: mislim da ti je to ova
http://www.electronic-center.hr/prod...roducts_id=293
Pepermint je offline   Reply With Quote
Staro 25.04.2013., 14:55   #5
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Da. To je to!
Ali ovaj dućan je iz Osijeka!
Ima li što iz ZG?
Ali nije kao 3XAAA, jer su AAA baterije puno više. One su 42mm. I takvih baterija ima, ali ovih od 31mm nisam vidio do sada.
Hvala!
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 25.04.2013., 15:27   #6
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,299
Autor estugarda Pregled postova
Da. To je to!
Ima li što iz ZG?
Iz OS ce stici prije nego sa E-Baya pa... .
Staro 25.04.2013., 15:44   #7
Garro
Postovi: 2,390
Ne znam, da ih nazoveš na telefon 01/4875-323?
Cjenik ti je ovdje: http://baterije-zagreb.hr/baterije/?page_id=58
Uglavnom, kod njih sam reparirao Bosch bateriju za akumulatorsku bušilicu, napravili su mi to za sat vremena, dali račun i pola godine garancije, a baterija šljaka bolje nego originalna Boschova dan danas.
Staro 25.04.2013., 16:14   #8
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Imaju cjenik, ali ništa slično ovoj bateriji.
Nazvat ću ih.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 25.04.2013., 18:15   #9
Campeonato
Premuim
Campeonato's Avatar
Postovi: 1,748
Evo: link
Campeonato je offline   Reply With Quote
Staro 25.04.2013., 18:15   #10
Postovi: 23,538
Staro 25.04.2013., 20:39   #11
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Obojica ste u pravu.
Hvala!
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
