Staro 11.04.2013., 20:46   #4921
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
AMD CPU Desktop Athlon II X4 750K (3.4GHz,4MB,100W,FM2) box, Black Edition
Spire Kepler Rev.2 hladnjak 1156/775/FM1
Matična ploča Asrock FM2A75 PRO4-M
Patriot Sig. DIMM, DDR3 1333Mhz, 4GB
Sapp.HD 7850 1GB, HDMI,DVI, DP
SEAGATE/SAMSUNG HD502HJ (3.5", 500GB, 16MB, SATA II-300)
Zalman 500W GS Series Retail
Futura-It.hr 3,517.95Kn Odnesi kučište složiti ce ti besplatno
*Za sada nemas potrebe ocati, ukljuci samo turbo mode i to je to
*Ako imas jos koju kunu uzmi Sapp.HD 7850 2GB, HDMI,2xDVI, DP = 3600kn
Staro 11.04.2013., 20:49   #4922
Philips227
Datum registracije: Mar 2013
Postovi: 6
Jel mi mozes slozit jednu sa integriranom grafičkom za jedno 2000-2200 kn ,a da kasnije mogu ugraditi 7850 .
Philips227 je offline   Reply With Quote
Staro 11.04.2013., 20:57   #4923
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
zašto sada to?
Intel Core i3-3220 Soc 1155
MSI Main Board Desktop iB75
Futura-It.hr 2,289.00Kn
ili slabiji procesor ali jača integrirana grafička
Procesor AMD A8 X4 5600K
MSI Main Board Desktop AMD A75
KINGSTON ValueRAM DDR3 (4GB,1600MHz(PC3-12800)
Futura-It.hr 2,277.16Kn
Staro 11.04.2013., 22:00   #4924
ShanTech
Datum registracije: Apr 2011
Postovi: 3,784
@Philips227
Konfiguracija za igre i AutoCAD:
Ploča: MSI MSI Main Board Desktop iB75 * to je B75MA-E33
Procesor: Intel BOX Procesor Intel Core i3 3210
Memorija: KINGSTON Memory Device KINGSTON ValueRAM DDR3 SDRAM Non-ECC (4GB,1600MHz(PC3-12800),Single Rank,Unbuffered) CL11
Grafička: MSI Video Card Radeon HD 7850 GDDR5 1GB/256bit, 900MHz/4800MHz
Napajanje: Zalman 500-GS PSU, 500W
Disk: HGST HDD Desktop HGST Deskstar 7K1000.C (3.5",500GB,16MB,SATA II-300)
=3.474,01 kn + 58,90 kn eventualna dostava, dućan www.diskont24.com
Bez grafičke izađe 2.177,53 kn + 50,58 kn eventualna dostava.
Staro 12.04.2013., 02:57   #4925
Imamic23
Postovi: 18
Autor FRipper Pregled postova
A ovako nešto? Mislim radje bi uzeo i5 i slabiju grafu posto ti igre nisu prioritet...nego vertex 4 :=)
Procesor Intel Core i5 3350P
8 GB, MUSHKIN SilverLine Stiletto, 992018, DDR3 1333MHz
Sapp.HD 6670, 1GB GDDR5, HDMI, DVI, VGA
SEAGATE/SAMSUNG HDD HD502HJ (3.5", 500GB, 16MB, SATA II-300)
Kingston SSD V300, R450/W450,120GB,7mm
LG DVD-RW R+24x/-24x
NaviaTec MATX PC Case, NO PSU
Chicony Active 350W ATX PSU
Futura-It.hr 4,395.50Kn Besplatno sastavljanje i dostava
aha, ok, jos cu ove ponude pregledat i odvagat sta cu od njih, puno hvala decki, potrudili ste se maksimalno )
Imamic23 je offline   Reply With Quote
Staro 12.04.2013., 08:27   #4926
Hele
Postovi: 104
Pozdrav!
Trebao bi konfiguraciju iskljucivo za igre, do 3500kn na rate, ako mislite da cu za recimo 200kn vise dobit nesto osjetno bolje moze i to. Komp ce prakticki radit po cijele dane pa ako moze neka grafa da se jako ne grije i buci, prozracno kuciste tj. da se moze stavit koji vent. Nema klime u prostoriji pa po ljeti da ne bude komp radio ko fen pod stolom.
Hele je offline   Reply With Quote
Staro 12.04.2013., 09:42   #4927
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Asrock s1155 H61M-VG3 bulk
Sapphire AMD Radeon HD7770 GHZ EDITION 1G GDDR5 128-bit
DVD RW -RW RAM LG DualLay SATA
Chicony Active 80Plus 400W ATX PSU
Zalman micro tower case black
Futura-It.hr 3323Kn keš // 3692Kn kartice Besplatno sastavljanje i dostava
nacin plačanja pogledaj ovdje
Staro 12.04.2013., 15:43   #4928
ShanTech
Postovi: 3,784
@Hele
Ploča: ASRock H61M-VG3
Procesor: Intel Core i3 3210
Memorija: Memory Device KINGSTON ValueRAM DDR3 SDRAM Non-ECC (4GB,1600MHz(PC3-12800),Single Rank,Unbuffered) C
Grafička: VTX3D HD7790 1GB DDR5 X-EDITION
Kućište: Naviatec NVT-6021, Midi Tower ATX kućište
Napajanje: Fortron nap.400W, Hexa, 80+,active,12 cm
Disk: HDD Desktop TOSHIBA DT01ACA050 (3.5", 500GB, 32MB, SATA III-600)
DVD: ODD LG GH24NS90 Super-multi DVD-RW 24x SATA Black, Bulk
=3.381,15 kn keš + 3682,37 kn kartice, sastavljanje u cijeni, dućan www.centro.hr
Ako bi budžet dozvolio, uzmi kućište: Case Midi ATX Gamer Akyga AKY001BR colorFan/12cm w/o PSU
Ova oba kućišta imaju montažu gore, tako da ne bi bilo problema. Ni ne predlažem ga uz kućišta koja imaju montažu dolje.
Zadnje izmijenjeno od: ShanTech. 12.04.2013. u 16:04.
Staro 12.04.2013., 15:50   #4929
Postovi: 34,019
@shan
Pripazi s tom Hexom. Netko je rekao da ima dosta kratak 4pin EPS kabel i da nije pogodna za kućišta kod kojih je napajanje dole.
Staro 13.04.2013., 00:15   #4930
Hele
Postovi: 104
Još par pitanja.
Naime komp kupujem nećaku za firmu i danas sam ga još malo "ispikao da vidim kako diše". Sadašnji komp mu je glasan u 3pm i ja bi osobno dobio slom živaca no malca to ne smeta. Da li je bolje onda ostat na pentiumu ili kad mu već ne smeta buka i pajs u sobi ić na kakav amd?
Možda su glupa pitanja ali sam već par godina van tematike pa da ne čitam posebno teme za svaku komponentu.
Vidim da ima hrpu ventilatora ali je micro, svejedno bi trebalo dobro hladit? Pretpostavljam da se taj i3 ne grije previše?
[QUOTEASRock H61M-VG3][/QUOTE]
Vidim da ste oboje stavili istu matičnu, pogledam cijenu i skoro padnem na guzicu, istina da treba samo za igre ali kaj bude dobra matična za 300kn?
Svakako ću uzet to kućište ipak je to za pubertetliju a ima lijepi narančasti vent.
Staro 13.04.2013., 00:38   #4931
ShanTech
Postovi: 3,784
Na i3 procesoru, ventilator na cpu hladnjaku bude tiši nego što bi to bio na FM2 Athlonu. i3 je brži od Athlona 740 ili 750K, te bi ih za približavanje performansama i3-u, trebalo overklokirati, a to za sobom vuče investiciju u dodatni cpu hladnjak. Zalman micro tower case black ima montiranog jednog ventilatora na ispuhu, te još pet mjesta za montažu ventilatora. A matična je stavljena u skladu s budžetom.
Staro 13.04.2013., 14:36   #4932
Jurica99
Datum registracije: Feb 2013
Postovi: 3
Evo ljudi kupujem novi gaming PC. Htio bih konfu. za 5000-5100 kn s grafom. Radeon HD 7870.
P.S. Graficku karticu mislim Overclockati!!
Jurica99 je offline   Reply With Quote
Staro 13.04.2013., 14:43   #4933
lolofuxy
lolofuxy's Avatar
Datum registracije: Jun 2010
Postovi: 3,319
Treba ti samo kućište s komponentama ili ti treba i periferija - monitor, tip+miš, zvučnici i sl.?
Ukoliko imaš monitor koja ti je rezolucija? Plačaš u kešu ili na kartice?
lolofuxy je offline   Reply With Quote
Staro 13.04.2013., 19:39   #4934
Jurica99
Postovi: 3
Placam kesom. Treba mi samo kuciste. Imam full hd 3d tv kao monitor i imam jedan Samsung 1680x1054 kao sekundarni monitor koji ce sluziti za surfanje neta dok gamemam.
Staro 13.04.2013., 20:10   #4935
ShanTech
Postovi: 3,784
Ploča: MSI B75MA-E33, Socket : 1155, microATX, Intel® B75, 2xDDR3
Procesor: Intel Core i5-3350P 3.1GHz (Max Turbo FQ 3.3 GHz) ,6MB
Memorija: DDR3 8GB (1x8GB) Kingston, Value, 1600MHz, CL11, KVR16N11/8
Grafička: MSI HD 7870 2GB GDDR5 256bit, R7870-2GD5T/OC, 28nm,dual fan
Kućište: Spire Sonex 6010, kućište ATX/micro ATX
Napajanje: Zalman 500-GS PSU, 500W, ATX12V V2.3, dual rail +12V
Disk: HDD Seagate 1TB, Serial ATA III, 7200 rpm, ST1000DM003
DVD: DVD upisivač LG GH24NS, DVD±RW, 24x DVD±R ,8x DL , 40x CD-R
=5.134,99 kn, sastavljanje i dostava u cijeni, dućan www.adm.hr
Zadnje izmijenjeno od: ShanTech. 13.04.2013. u 20:45.
Staro 13.04.2013., 23:52   #4936
Hele
Postovi: 104
Da li se isplati uložit još npr. 100kn u matičnu? Pa da ima barem USB 3.0. Normalno ne mislim davat više love samo zbog USB, nego jel na još čemu profitira?
Staro 14.04.2013., 09:50   #4937
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Uzmi onda ovu: MSI B75MA-E33
Autor Jurica99 Pregled postova
MSI B75MA-E33
Sapphire AMD Radeon HD7870 GHZ EDITION 2G GDDR5 PCI-E
HDD Desktop TOSHIBA DT01ACA100 (3.5", 1TB, 32MB, SATA III-600)
Zalman T1/T2 micro tower case black
Futura-It.hr 5,067.13Kn Besplatno sastavljanje i dostava
*Kuciste uzmi koje ti se svidja, preporuka za Zalman T1/T2 jer su kvalitetni
*Grafičku nema potrebe odma ocati, jer je dosta jaka, kada ti bude trebalo,onda ocas
Staro 14.04.2013., 16:30   #4938
lolofuxy
lolofuxy's Avatar
Postovi: 3,319
@Jurica99
Ako želiš bolju matičnu onda si ovako napravi konfiguraciju:
i5 3350P
AS ROCK B75 PRO3
2X PATRIOT 4GB 1333 MHZ (8GB)
WD BLUE 1TB
MSI HD 7870 2GB OC
LG DVD-RW SATA
ZALMAN GS 500W
MS LOGIC
Ukupno: 5164 kn besplatno slaganje i dostava - Futura it
Zadnje izmijenjeno od: lolofuxy. 14.04.2013. u 20:59.
Staro 15.04.2013., 02:09   #4939
Overclock_freak
Datum registracije: Dec 2012
Lokacija: Rijeka-Zagreb
Postovi: 1,207
Imate kakvu preporuku grafe i napajanje do cca 1300kn može novo i polovno
Inače ostatak konfe je
AMD FX 8350, 990FXA UD7, 8GB Ripjaws CL7, ST1000DM003,
Staro 15.04.2013., 08:56   #4940
Toorop
Mother Russia
Toorop's Avatar
Postovi: 326
Autor Overclock_freak Pregled postova
Corsair CX430M
XFX HD7770 + igre
1,263.28kn Futura.it
Zadnje izmijenjeno od: Toorop. 15.04.2013. u 11:09.
Toorop je offline   Reply With Quote
Staro 15.04.2013., 09:57   #4941
ShanTech
Postovi: 3,784
Novi CX600 se može kupiti za 459 kn u dućanu. klik
Moja preporuka je:
Sapphire 7770 1GB DDR5 + Zalman 500W=1.234,90 kn
Može i CX430M, mada će skoro svi modulatni kablovi biti iskorišteni.
Edit: Ako bi našao polovnu 7850 za normalnu cijenu...sve iznad 1000 kn je previše za 7850 1GB, garanciju mora imati ofc.
Zadnje izmijenjeno od: ShanTech. 15.04.2013. u 10:20.
Staro 15.04.2013., 10:12   #4942
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Malo mi glupo metati 7770 na takav proc
Ja bi nasao polovnu 7850,a ima ih po cc 1000-1100kn te napajanje uzeo neki cx430,gp4 460 itd il neki polovan seasonic 430 nadju se za 200kn
Ili čak neka gtx 460 1gb, sa garom cc 800kn
Zadnje izmijenjeno od: FRipper. 15.04.2013. u 10:48.
Staro 15.04.2013., 11:12   #4943
Toorop
Mother Russia
Toorop's Avatar
Postovi: 326
A neznam ja sam mu stavio 7770 zbog dvije igre koje dobije :P ali ako nađe polovnu 7850 samo neka uzima
Staro 15.04.2013., 19:01   #4944
PR3DA70R
PR3DA70R's Avatar
Lokacija: Yautja Prime
Postovi: 1,227
Može neka preporuka CPU, MBO, RAM, GPU i PSU za malo gaminga (pretežito MMO) i multimediju do 3,500kn. AMD ili Intel. Hvala.
Staro 15.04.2013., 19:19   #4945
lolofuxy
lolofuxy's Avatar
Postovi: 3,319
Staro 16.04.2013., 10:21   #4946
ShanTech
Postovi: 3,784
@PR3DA70R
Ploča: MSI H77MA-G43
Grafička: Sapphire HD 7770, 1GB GDDR5 128bit, 28nm, DVI + HDMI + 2xDP, PCI
=3.497,98 Kn, dostava u cijeni, dućan www.adm.hr
Edit: Ako možeš izdvojiti 3.641,98 kn, zamijeni ploču i grafičku s:
Sapphire Sapphire HD 7790, 1GB GDDR5 128bit
Zadnje izmijenjeno od: ShanTech. 16.04.2013. u 13:48.
Staro 16.04.2013., 13:25   #4947
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
vise manje identicna konfiguracija a 2 posta, zanimljivo
da ne znam bolje rekao bi da jednog placa futura, drugog adm
Msi x79a GD65
Intel i7 3930k @ 4.7 1.4V
4x 4GB Kingston 1866 9-11-9
Gigabyte gtx 460 1gb
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Coolermaster Stacker 831
HP LP2065 / LG IPS231P
Windows 7 Enterprise
Trenutno nepostojeci
Staro 16.04.2013., 13:35   #4948
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Sve bi bilo ok da su postali u isto vrijeme...ovako kao i inače glupo, ali ne vrijedi pričati...
Staro 16.04.2013., 13:54   #4949
MiroGavran
Datum registracije: Feb 2011
Postovi: 190
Autor PR3DA70R Pregled postova
ADM
1 x Asrock FM2 FM2A75 PRO4 - AMD A75 Hudson D3, ATX, Dual Channel
1 x Procesor AMD Trinity A10-Series X4 5800K 3.80GHz 4cores, FM2 (integriran AMD Radeon HD 7660D GPU)
1 x DDR3 8GB (1x8GB) Kingston, HyperX Blue, 1600MHz, CL10
1 x Napajanje CORSAIR 430W, CX Series 80+ Bronze, EPS12V v2.3, 80+
2.330,99Kn
Zadnje izmijenjeno od: MiroGavran. 16.04.2013. u 14:25.
MiroGavran je offline   Reply With Quote
Staro 17.04.2013., 12:44   #4950
Efient
Datum registracije: Aug 2012
Postovi: 35
Molio bi ako mozete sastaviti kompjuter do 3500 kn s printerom ali da su jeftine boje od printera i s monitorom, placa se kesom i kompjuter bi sluzio za igrice i za gledanje filmova i kladionica,da je besplatna dostava za Osijek. Hvala! Printer nije jako hitan mozete ga i izbaciti pa da naknadno kupim.
Zadnje izmijenjeno od: Efient. 17.04.2013. u 13:07.
Efient je offline   Reply With Quote
