Staro 25.03.2013., 15:16   #1
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,226
Nvidia GeForce v314.22 WHQL Driver
http://www.geforce.co.uk/drivers/results/59671
Release Summary
This is the GeForce Game Ready driver for BioShock Infinite, delivering up to 41% faster performance.
Instantly apply optimal game settings for BioShock Infinite with GeForce Experience.
New in GeForce 314.22 Drivers
Performance Boost – Increases performance for GeForce 400/500/600 series GPUs in several PC games vs. GeForce 314.07 WHQL-certified drivers. Results will vary depending on your GPU and system configuration. Here are a few examples:
GeForce GTX 680:
Up to 41% faster in BioShock Infinite
Up to 60% faster in Tomb Raider
Up to 23% faster in Sniper Elite V2
Up to 13% faster in Sleeping Dogs
GeForce GTX 680 SLI:
Up to 21% faster in Sniper Elite V2
Up to 14% faster in Sleeping Dogs
Up to 10% faster in StarCraft II
Up to 15% faster in Civilization V
NVIDIA SLI Technology – Adds or updates the following SLI profiles (since GeForce 314.14 drivers):
Sniper Elite: Nazi Zombie Army – Added DX11 SLI profile
Dungeons and Dragons: Neverwinter – Added DX9 SLI profile
BioShock Infinite – Added AO profile
NVIDIA 3D Vision – Adds the following profiles (since GeForce 314.14 drivers):
MUD - rated Good
Brutal Legend - rated Good
Tomb Raider - updated rating to Good
NVIDIA CUDA
Includes support for applications built using CUDA 5 or earlier version of the CUDA Toolkit. More information at http://developer.nvidia.com/cuda-toolkit
Additional Details
Installs PhysX System Software 9.12.1031.
Installs HD Audio v1.3.23.1
Supports OpenGL 4.3 for GeForce 400-series and later GPUs.
Supports DisplayPort 1.2 for GeForce GTX 600 series GPUs.
Supports multiple languages and APIs for GPU computing: CUDA C, CUDA C++, CUDA Fortran, OpenCL, DirectCompute, and Microsoft C++ AMP.
Supports single GPU and NVIDIA SLI technology on DirectX 9, DirectX 10, DirectX 11, and OpenGL, including 3-way SLI, Quad SLI, and SLI support on SLI-certified Intel and AMD motherboards.
Release notes - http://uk.download.nvidia.com/Window...ease-notes.pdf
Staro 25.03.2013., 20:34   #2
frankycro
frankycro's Avatar
Postovi: 65
Danas ujutro mi stigla GTX680 Gainward-ica, referentna, i skinem driver, naravno u to vrijeme je još bio 314.07 WHQL zadnji, stavim i sve ok koliko sam stigao testirat i odigrat, a onda je došao na red TombRaider i bu crash igre i drivera i pomislim bem ti sunce a onda vidim da i drugi imaju taj problem s igrom.
Sad slučajno skužim da je u toku dana izašao 314.22 WHQL pa čemo sad vidit kak ide.
frankycro je offline   Reply With Quote
Staro 26.03.2013., 15:58   #3
poker
poker's Avatar
Lokacija: osijek
Postovi: 225
ajmo ljudovi vaša iskustva jel više grije (gtx560) i jesu li porasli FPS i da li je stabilan driver ?
poker je offline   Reply With Quote
Staro 26.03.2013., 19:34   #4
Mrakky
Mrakky's Avatar
Datum registracije: Oct 2012
Lokacija: Velika Gorica
Postovi: 115
napravljen update, na prijašnjim drajverima sam morao skalirat profil za The Secret World, a sad sve klizi bez skaliranje, kasnije budem probao duže igrat pa javim, nadam se da su složili to kak treba jer dve msi gtx660 oc TF da nemreju tu igru terat na ful su gluposti, stvar je u drajverima i podosta u igrici, nije baš optimizirana, sve u svemu ok, kasnije javim kak se ponašaju temperature.
Mrakky je offline   Reply With Quote
Staro 27.03.2013., 00:28   #5
frankycro
frankycro's Avatar
Postovi: 65
Evo da se i ja još jednom priključim, s ovim driverom i updateom za TombRaider nema ispadanja, također igram i Crysis 3 i sve radi ko podmazano, isprobao sam još jedino heaven benchmark 4.0 i 3dmark vantage i nema rušenja drivera a niti micro stuttering-a. Ganjam to u HD-u sa 3D vision.
Staro 27.03.2013., 09:26   #6
Mrakky
Mrakky's Avatar
Postovi: 115
kod mene temperature iste na boljim postavkama, uglavnom jako dobro odrađeno
Staro 27.03.2013., 23:38   #7
poker
poker's Avatar
Lokacija: osijek
Postovi: 225
hvala na info o novom driveru
Staro 28.03.2013., 11:35   #8
Stavio na GTX 660 Ti. Nikakve razlike od prethodnih, samo nešto je brži odziv kad uključujem TV signal preko Control Panela.
Staro 06.04.2013., 19:35   #9
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,128
jeste primjetili mozda, dali ima sta u ovome:
"I have something to be of a slight issue with 314.22, at least for me... I have been experiencing slightly higher DPC latency.
Also for those who are experiencing stuttering in games, if you have EVGA Precision or MSI Afterburner (or any other OC programs)... please disable and uninstall them before updating to 314.22.
I have no idea why, but for the most part... this seems to have alleviate the stuttering issue that most are complaining about in BF3."
Staro 06.04.2013., 20:19   #10
ante2
ante2's Avatar
Postovi: 1,313
Meni se komp srusio kad sam upalio MSI afterburner, i to bez upozorenja tj plavog ekrana samo bam crni ekran i ponovno paljenje a sam afterburner kasni sa prikazom brzine venta, tj ovi driveri i programi za nadzor grafe se ocito ne vole.
MSI Z77 MPower
Intel i5 3570K @4,2GHz, NOCTUA NH-U12S
Gigabyte GTX 1070
DDR3 16GB (4x4GB) 1600Hz Corsair Vengeance
Carbide Series Air 540, Corsair RM750i
CREATIVE LABS X-Fi Titanium-Kingston HyperX Cloud
DELL U2515H
Synology DS413
ante2 je offline   Reply With Quote
Staro 09.04.2013., 19:11   #11
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,818
Sve radi super za razliku od prethodne verzije koja mi je rušila igre i Windows 8. I temperature su nekih 5-6°C više nego kod 306 verzije, defaultne koje je došla s Windowsima 8.
Staro 10.04.2013., 00:33   #12
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
Zadnji afterburner radi sranja. Probo sam i sa starijim driverima i ista stvar. Meni je u igrama, na uz desni rub ekrana traka puna kao artifakata(mozda latencije). Cim iskljucim Afterburner nestane. Tj. problem je u RTSu 5.0.0.. Kad ga nemam instaliranog, ne rade ni neke monitoring opcije u AB ali nema nikakvih problema ali ni previse koristi od ABa.
Skuzio sam. U Stat. Serveru treba stavit opciju frambuffer i enable frame color off i onda nema te crte a ostalo radi. Kod mene nema problema izmedu AB i tog drivera na kraju iako sam mislio da ima.
Driver ko driver mi se cini ok. FC3 letikao i jos par igri kaj znam zaigrat. BF3 ne igram.
Zadnje izmijenjeno od: MAGARAC. 15.04.2013. u 23:45.
Staro 15.04.2013., 21:14   #13
gsxr750k9
Datum registracije: Apr 2011
Lokacija: Agram
Postovi: 603
Ja sma probal driver.
Sve ok al mi se WOT sruisl par puta pa sam se vratil na 306.97 jer s uti preporuceni od strane WOT ekipe..kao svi ovi noviji imaju neki bug pa ruse to desktop igru.
Inace je ok driver sve smooth.
gsxr750k9 je offline   Reply With Quote
Staro 17.04.2013., 19:24   #14
poker
poker's Avatar
Lokacija: osijek
Postovi: 225
Autor gsxr750k9 Pregled postova
moguće da nisi napravio clean instal drivera meni na gtx560 s ovim novim driverima radi savršeno
Staro 09.06.2013., 22:01   #15
geronimo_2
geronimo_2's Avatar
Postovi: 4,128
moze potvrda, ako je netko probao/zna.
jel ovaj driver radi sa GTX770 il treba ic bas na 320.xx?
nekak bih volio pricekat do stavljanja 320.xx serije jer vidim da se sve vise zale, a i spominje se dosta crkavanje grafi.
We all must hang together, or surly we will hang separately.
Staro 10.06.2013., 10:25   #16
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,543
mora ic 320. Snimi one koje dobis s cdom.
Staro 13.06.2013., 19:09   #17
Probao malo igrati Metro sa ovim driverima koji ga kakti ne podržavaju. Sve ok, tu i tamo možda koji FPS manje u odnosu na 320 drivere. Ali barem neće zaroštiljat grafu
Staro 04.09.2013., 17:57   #18
Thermaltake
1
Thermaltake's Avatar
Postovi: 3,553
Dal se nekom dešava da odjednom mu u power options monitor se postavi na 20min da se ugasi, svaki put ga stavim na never i on mi se sam od sebe vrati na 20min.
Staro 04.09.2013., 18:22   #19
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,226
to nema veze sa nvidiom ni drajverima, to je na windows 7 od početka
Staro 04.09.2013., 18:45   #20
Thermaltake
1
Postovi: 3,553
Prije mi se nikad to nije dešavalo na 8800gts, a ove iste win imam već 2 godine.
Staro 04.09.2013., 18:46   #21
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,226
meni se događa otkad imam win7, ali rijetko, u prosjeku jednom u 6 mjeseci
Staro 04.09.2013., 18:54   #22
Thermaltake
1
Postovi: 3,553
hmm...čudno.
EDIT:
Našo sam razlog HD Tune to napravi, je da nema veze sa power saving-om, al evo otkrio sam znači ako ga pokreneš i startaš scan nekog drive-a stavit će ti 20min da se ugasi monitor.
Zadnje izmijenjeno od: Thermaltake. 04.09.2013. u 19:00.
Staro 04.09.2013., 19:03   #23
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,226
ja nemam hd tune a to se dešava
Staro 04.09.2013., 19:05   #24
Thermaltake
1
Postovi: 3,553
Možda još koji program istu stvar radi ne znam, al evo ja sam sad isprobao i hd tune mi je stavio 20min monitor da se ugasi ne znam zašto to radi valjda neki bug.
