Staro 03.03.2013., 18:05   #841
Facelessone
Facelessone's Avatar
Postovi: 4,205
Mar 3 16:51:16 OpenWrt daemon.notice netifd: Interface 'WAN' is now down
Mar 3 16:51:17 OpenWrt daemon.info pppd[23726]: Plugin rp-pppoe.so loaded.
Mar 3 16:51:17 OpenWrt daemon.info pppd[23726]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.5
Mar 3 16:51:17 OpenWrt daemon.notice pppd[23726]: pppd 2.4.5 started by root, uid 0
Mar 3 16:51:17 OpenWrt daemon.err pppd[23726]: Interface nas0 has MTU of 1492 -- should be at least 1500.
Mar 3 16:51:17 OpenWrt daemon.err pppd[23726]: This may cause serious connection problems.
Mar 3 16:51:32 OpenWrt daemon.warn pppd[23726]: Timeout waiting for PADO packets
Mar 3 16:51:32 OpenWrt daemon.err pppd[23726]: Unable to complete PPPoE Discovery
Mar 3 16:51:32 OpenWrt daemon.info pppd[23726]: Exit.
Mar 3 16:51:32 OpenWrt daemon.notice netifd: Interface 'WAN' is now down
Mar 3 16:51:32 OpenWrt daemon.info pppd[23789]: Plugin rp-pppoe.so loaded.
Mar 3 16:51:32 OpenWrt daemon.info pppd[23789]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.5
Mar 3 16:51:33 OpenWrt daemon.notice pppd[23789]: pppd 2.4.5 started by root, uid 0
Mar 3 16:51:33 OpenWrt daemon.err pppd[23789]: Interface nas0 has MTU of 1492 -- should be at least 1500.
Mar 3 16:51:33 OpenWrt daemon.err pppd[23789]: This may cause serious connection problems.
Mar 3 16:51:48 OpenWrt daemon.warn pppd[23789]: Timeout waiting for PADO packets
Mar 3 16:51:48 OpenWrt daemon.err pppd[23789]: Unable to complete PPPoE Discovery
Mar 3 16:51:48 OpenWrt daemon.info pppd[23789]: Exit.
Mar 3 16:51:48 OpenWrt daemon.notice netifd: Interface 'WAN' is now down
Mar 3 16:51:48 OpenWrt daemon.info pppd[23881]: Plugin rp-pppoe.so loaded.
Mar 3 16:51:48 OpenWrt daemon.info pppd[23881]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.5
Mar 3 16:51:48 OpenWrt daemon.notice pppd[23881]: pppd 2.4.5 started by root, uid 0
Mar 3 16:51:48 OpenWrt daemon.err pppd[23881]: Interface nas0 has MTU of 1492 -- should be at least 1500.
Mar 3 16:51:48 OpenWrt daemon.err pppd[23881]: This may cause serious connection problems.
Mar 3 16:52:03 OpenWrt daemon.warn pppd[23881]: Timeout waiting for PADO packets
Mar 3 16:52:03 OpenWrt daemon.err pppd[23881]: Unable to complete PPPoE Discovery
Mar 3 16:52:03 OpenWrt daemon.info pppd[23881]: Exit.
Mar 3 16:52:03 OpenWrt daemon.notice netifd: Interface 'WAN' is now down
Ako stavim MTU na 1500 ista stvar. Kod iskona u configu je postavljen na 1492. OpenWrt | OpenWrt Barrier Breaker r34578
Imam problem, naravno. DD-WRT sam brzo složio i spojio u roku 5 min, naravno, nema VOIPa pa ne dolazi u obzir. Sada je gore OpenWRT i nikako da se poveže na net.
Code:
root@OpenWrt:~# /etc/init.d/dsl_control status
Chipset:                Ifx-Danube 1.5
Line State:             UP [0x801: showtime_tc_sync]
Data Rate:              7.192 Mb/s / 639 Kb/s
Line Attenuation:       7.8dB / 4.5dB
Noise Margin:           20.2dB / 24.1dB
Line Uptime:            20m 11s
Code:
root@OpenWrt:~# cat /etc/config/network
config interface 'loopback'
        option ifname 'lo'
        option proto 'static'
        option ipaddr '127.0.0.1'
        option netmask '255.0.0.0'
config interface 'lan'
        option type 'bridge'
        option ipaddr '192.168.1.1'
        option netmask '255.255.255.0'
        option ifname 'eth0.1'
config switch
        option name 'eth0'
        option reset '1'
        option enable_vlan '1'
config switch_vlan
        option device 'eth0'
        option vlan '1'
        option ports '4 3 2 1 5t'
config adsl-device 'adsl'
        option fwannex 'b'
        option annex 'auto'
config atm-bridge 'atm'
        option unit '0'
        option encaps 'llc'
        option payload 'bridged'
        option vci '86'
        option vpi '0'
config interface 'WAN'
        option proto 'pppoe'
        option ifname 'nas0'
        option username 'iskon_username'
        option password 'iskon_password'
        option service 'iskon.duo'
        option mtu '1492'
Log kaže:
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 03.03.2013., 21:35   #842
lepak
Datum registracije: Feb 2011
Lokacija: Doma
Postovi: 47
zadnji svn revision koji ima fajlove za sx763 je 34059 ? nakon toga ne postoji support za ovaj model u trunku openwrt-a?
lepak je offline   Reply With Quote
Staro 03.03.2013., 21:46   #843
.Delboy
.Delboy's Avatar
Lokacija: hr
Postovi: 755
Kod mene je isto tako config više manje i sve radi, nisam ništa dirao mtu:
config interface 'wan'
option username 'user'
option password 'pass'
Autor lepak Pregled postova
Da to treba još srediti wlan pa će se dodati opet support u trunk.
Staro 03.03.2013., 22:00   #844
lepak
Lokacija: Doma
Postovi: 47
zasto support nije u trunk-u openwrta?
Staro 04.03.2013., 13:37   #845
ddrasner
Postovi: 12
Koliko sam shvatio u trunku pokusavaju spojiti sve podtipove lantiq xway u jedan, odnosno da uopce nema podtipova nego sve bude xway pa je vjerojatno zato nestao.
Cini mi se da profili definiraju samo sta se ukljucuje u image, sta ostaje kao paket i sta se uopce ne builda, tako da odaberi kao profil easy50712 i dodaj razliku paketa rucno.
Iz 12.09-rc1 Image Buildera:
EASY50712:
EASY50712
Packages: kmod-usb-core kmod-usb-dwc-otg
GIGASX76X:
GIGASX76X - Gigaset SX761,SX762,SX763
Packages: kmod-usb-core kmod-usb-dwc-otg kmod-ledtrig-usbdev kmod-ath5k wpad-mini kmod-ltq-dsl-firmware-a-danube kmod-ltq-dsl-firmware-b-danube
ddrasner je offline   Reply With Quote
Staro 04.03.2013., 13:48   #846
.Delboy
.Delboy's Avatar
Lokacija: hr
Postovi: 755
Zato jer je sada lantiq target koristi http://devicetree.org/Main_Page
Staro 04.03.2013., 15:01   #847
lepak
Lokacija: Doma
Postovi: 47
buildao sam EASY50712 .. medjutim heh.. ne radi nista.. pci kontrolera nema.. znaci onboard wlan ne radi.. a nije mi ni usb radio iako ima otg driver..
problem je u tome da i neki fajlovi nisu ukljuceni i fale... kad se odabere recimo pciE onda fali pcie-lantiq.h fajl i par ostalih.. tako da.. zapravo i ne radi
ako neka ima config kernela da radi... plz share.
nemora imat ni dsl ni nista.. nek radi usb i nek radi ath5k .. ostalo mi je nebitno.. ja imam paketa unutra da mi je firmware oko 6-7 megabajta.
Staro 04.03.2013., 15:28   #848
ddrasner
Postovi: 12
Ja upravo pokusavam buildati attitude adjustment iz svn-a, traje skoro cijelu noc, neki paketi pucaju itd...
U svakom slucaju krenuo sam sa configom sa http://downloads.openwrt.org/attitud....lantiq_danube
Za trunk ce sigurno biti razlika no vjerojatno ti moze posluziti za osnovu.
Staro 04.03.2013., 15:48   #849
shkolarac
Datum registracije: Mar 2013
Lokacija: Zagreb-Đurđevac
Postovi: 5
Pozrav, novi sam tu na forumu, ali se trudim ne postavljati suvišna pitanja..
uglavnom, stavio sam gore openwrt sa prve stranice, sve radi oke, al svejedno imam problema oko postavki
znači, na iskonu sam (DUO.CARNet) i imam njihov ruter (Enkom) te sad sx 673, te bi htio wirelles mrežu da ne moram raditi pppoe konekciju sa svakog spojenog uređaja, to jest samo da se spojim na siemens i da sam na webu (to mi znatno olakšava stvari, jer ovak moram ili na androidima imati pppoe aplikacije, al onda moraju biti rutani itditd)
pokušao sam napraviti wan prema configa od par postova prije, samo tamo nije bilo u igri pppoe vec static.. i dok sam napravio taj wan ,dok sam pokušavao pingati, davalo je odaziv, ali sam od svih tih postavka ocito negdi ** jer vise ne sljaka..kud dalje?
i da stavio sam na static route ip i gataway od iskonovog rutera.. jel moram još kaj mjenjat il? ak bi neko bio dobar, pa mi dao config od networka kako bi to radilo bio bih mu zahvalan do neba
shkolarac je offline   Reply With Quote
Staro 04.03.2013., 16:02   #850
lepak
Lokacija: Doma
Postovi: 47
Autor ddrasner Pregled postova
ma ja sam popizdio s tim.. radi na gcc kompajleru obicnom.. sa binutils 2.22.1 ili tako nesto.. sa ukljucenim --mips32 i pizdarijma u advanced building ili kako se zove.. dosta paketa puca, srecom za mene nijedan bitan..
taj config je prekrcan gluparijama.. najbolje ti je od pocetka pocet.. `make menuconfig` -- izaberes uredjaj.. izadjes i sejvas .. i onda make defconfig.. i onda se vratis u menuconfig ili kernel_config .. mada kernel nesto pretjerano netreba dirati osim iskljuciti tamo di puca.. dsl puca recimo i sranja...
ja sam izludio s tim.. pa sam vratio na ovaj revision koji radi i sad se zajebavam.. moram prakticki slozit kompletan nod... ath5k + carl9170 + rt2800usb .. php/ moj custom portal za wifi + routing + dodatni alati za routing i moj firewall iptables+hrpa dodataka.
prvo sam mislio napravit nesto tek jednostavno.. dva tri wlan-a i bridgat sa lan-om .. medjutim mogu bridgat AP mode ali STA mode da se kaci na iduci nod -- to ne mogu ... a iskljucene su mi opcije da radim SNAT ili slicno jer moram pass-at broadcast dalje. uh.
trenutno mi je fw 6.1mb ... bez routinga.... mislim se uopce stavljat ospf ili bgp jer to cica ram i cpu...
Staro 04.03.2013., 19:23   #851
golf2gtd
Lokacija: Bjelovar
Postovi: 12
ako tko uspije molio bih da uploada stabilnu ili noviju verziju openwrt-a,svaka koju stavim ima neku grešku,il neradi USB ili se ruši ili nešto treče :/
golf2gtd je offline   Reply With Quote
Staro 04.03.2013., 20:57   #852
lepak
Lokacija: Doma
Postovi: 47
Staro 04.03.2013., 21:55   #853
subixonfire
Datum registracije: Jan 2013
Postovi: 34
Autor shkolarac Pregled postova
Ako sam te dobro skuzio, ti bi na enkoma u bridge modu spoijo sx-a i da onda on odradjuje sav posao?
Ja to tako imam rijeseno, ovo je moj network config.
Code:
	option ifname 'lo'
config switch
	option name 'eth0'
	option reset '1'
config switch_vlan
	option vlan '1'
	option vid '1'
	option ports '2 3 4 5t'
config switch_vlan
	option vlan '2'
	option vid '2'
	option ports '1 5t'
	option _orig_ifname 'eth0.2'
	option _orig_bridge 'false'
	option ifname 'eth0.2'
	option username 'tvoj username'
	option password 'tvoj pass'
subixonfire je offline   Reply With Quote
Staro 04.03.2013., 22:40   #854
.Delboy
.Delboy's Avatar
Lokacija: hr
Postovi: 755
Fali config za sx, ostalo je sve tamo, biti će ovih dana nadam se rješeno.
Staro 04.03.2013., 22:45   #855
lepak
Lokacija: Doma
Postovi: 47
aj javi plz kad bude.. bas me zanima.
usput:
kako se makne, ubije ili drugacije ukloni ovaj netifd ili slicne gluparije koje prekopiraju moje postavke u konfigu na svaki reboot.. ovo stvarno dize zivce.. izmjenim uhttpd config da ukljucuje php a on se vrati na staro na svaki reboot pa moram pisat skripte da prekopiraju konfig i restartaju daemon..
Staro 04.03.2013., 23:56   #856
shkolarac
Postovi: 5
@subixonfire hvalaa, al još nisam upogonio ruter na net.. ono jednom sam uspio pingat iz luci-a (nisam backupo taj config) i to je bilo to...
config sam unio prek lucia backupa, prek klikanja opcija, prek ssh-a.. probao sam u onom osnovnom img, i u onom sekundarnom iz prvog posta.. al stvarno više neznam gdi je greška, al imam par pitanja:
1. koji na kraju openwrt img da koristim? sad mislim probat još s ovim iz par postova prije openwrt-lantiq-danube-GIGASX76X-squashfs.image, jel možda to ključ?
2. jedno malo banalno al i to mi je tek sad (nakon cjelog dana ubijanja) palo na pamet : dok stavim u vlanu port 1 recimo ko eth0.2, gdi da uštekam kabel ?! samo sam se igrao s lan portovima, jel to oke?? tek mi poslje palo na pamet da su tu i "line" i "adsl" portovi
3. da li se u wifi -u moraju mjenjat kakve postavke il ga je dovoljno samo uključit?! nije mi bilo opcije da tamo stavim wan, nego samo lan, a to mi nije bilo baš bistro pošto se prek wana trebam spojit prek pppoe?
oprostite ak gnjavim, možda je već bilo negdi odg, al sam već tolko puta prešao cijelu temu da mi se lagano vrti...unaprijed, i da nisam pohvalio zalaganje i temu članova u globalu, stvarno se puno znanja razmjenjuje.. čini mi se puuuno više neg na wikiu od openwrta
Staro 05.03.2013., 00:42   #857
subixonfire
Postovi: 34
Probas ovako:
- preko winscp-a se spojis na sx-a (protokol:scp , user: root, password: #sta god si postavio u luci)
- u "/etc/config" imas sve config fajlove, sa nekim malo pametnijim text editorom (npr notepad++) uredis network config da bude kao ovaj moj(samo sa tvojim user i pass), i restart dali kroz luci ili na botun svejedno.
- kabel iz enkoma(nebitno koj ulaz na enkomu) spojis u sx-a na ulaz na kojem pise lan4 / wan (na nekim verzijama sx-a nepise to wan).
- Wifi postavke netrebas dirati osim sto mozes iz luci dodati zastitu po zelji...
Zadnje izmijenjeno od: subixonfire. 05.03.2013. u 00:50.
Staro 05.03.2013., 00:57   #858
shkolarac
Postovi: 5
Autor subixonfire Pregled postova
Probas ovako:
Hvala ti na pomoći, mislim da je fora bila ipak u imageu, jer kad sam stavil onaj "najnoviji" od pred par postova, i složio postavke (radil sam ih ručno, preko lucia), reboot i sve je proradilo .
to jest, spojen je, sad sam pingao i ping mi se odaziva, znači wan je povezan.. evo sad idem uključit wifi, pa reboot pa valjda bude i sve skupa proradilo, samo sam htio pričekat potvrdu da ne treba niš drugo mijenjat... mislim da se budem još javljal oko nekih drugih problema, al to koji drugi dan hvala još jednom
Staro 06.03.2013., 03:59   #859
lepak
Lokacija: Doma
Postovi: 47
e hvala onome sta je updejtao slike na wiki-u openwrt-a.. moje su bile stvarno trash .. slikane prastarim mobitelom.. (nikon mi je u kvaru) btw postoji jos jedan pin, njega sam otkrio tako da sam na drugom uredjaju uspio sa trash lemilicom odlemit nesto na drugoj strani ploce i pin nije vise spajao..
mislim da je ovaj ili neki u blizini sad neznam daleko sam na laptopu..
http://oi50.tinypic.com/57hip.jpg
poz.
Staro 06.03.2013., 16:43   #860
cloaked
Postovi: 19
Autor .Delboy Pregled postova
Mislim da još treba pokrenuti ovo u konzoli, jer nešto sa skriptama ne valja koje pokreću dsl fw:
annex a:
/sbin/dsl_cpe_control -i00_00_00_00_00_04_00_00 -n /sbin/dsl_notify.sh -f /lib/firmware/ltq-dsl-fw-a-danube.bin &
annex b:
/sbin/dsl_cpe_control -i00_00_00_00_00_04_00_00 -n /sbin/dsl_notify.sh -f /lib/firmware/ltq-dsl-fw-b-danube.bin &
izbaci mi slijedece kad probam i opet ne radi
Code:
-ash: DSL_CPE:: not found
root@OpenWrt:~# /sbin/dsl_cpe_control -i00_00_00_00_00_04_00_00 -n /sbin/dsl_not
root@OpenWrt:~# DSL_CPE: using script notification file - /sbin/dsl_notify.sh
DSL_CPE: using 1st firmware file - /lib/firmware/ltq-dsl-fw-a-danube.bin
DSL_CPE: Device /dev/dsl_cpe_api open failed!
[1]+  Done                       /sbin/dsl_cpe_control -i00_00_00_00_00_04_00_00 -n /sbin/dsl_notify.sh -f /lib/firmware/ltq-dsl-fw-a-danube.bin
root@OpenWrt:~#
Code:
Sep  8 16:56:24 OpenWrt daemon.notice netifd: Interface 'wan' is now down
Sep  8 16:56:24 OpenWrt daemon.info pppd[9243]: Plugin rp-pppoe.so loaded.
Sep  8 16:56:24 OpenWrt daemon.info pppd[9243]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.5
Sep  8 16:56:24 OpenWrt daemon.notice pppd[9243]: pppd 2.4.5 started by root, uid 0
Sep  8 16:56:24 OpenWrt daemon.err pppd[9243]: Interface nas0 has MTU of 1492 -- should be at least 1500.
Sep  8 16:56:24 OpenWrt daemon.err pppd[9243]: This may cause serious connection problems.
Sep  8 16:56:24 OpenWrt daemon.err pppd[9243]: error sending pppoe packet: Network is down
Sep  8 16:56:24 OpenWrt daemon.err pppd[9243]: error receiving pppoe packet: Network is down
Sep  8 16:56:29 OpenWrt daemon.err pppd[9243]: error sending pppoe packet: Network is down
cloaked je offline   Reply With Quote
Staro 06.03.2013., 22:46   #861
.Delboy
.Delboy's Avatar
Lokacija: hr
Postovi: 755
Autor cloaked Pregled postova
Ajde probaj izvršiti:
/etc/init.d/dsl_control disable
rebootaj i onad izvrši onu liniju od prije
Staro 07.03.2013., 14:16   #862
cloaked
Postovi: 19
Code:
root@OpenWrt:~#
root@OpenWrt:~# root@OpenWrt:~# /sbin/dsl_cpe_control -i00_00_00_00_00_04_00_00
-n /sbin/dsl_not
-ash: root@OpenWrt:~#: not found
root@OpenWrt:~# ify.sh -f /lib/firmware/ltq-dsl-fw-a-danube.bin &
root@OpenWrt:~# root@OpenWrt:~# DSL_CPE: using script notification file - /sbin/
dsl-ash: ify.sh: not found
_notify.sh
[1]+  Done(127)                  ify.sh -f /lib/firmware/ltq-dsl-fw-a-danube.bin
Staro 08.03.2013., 19:08   #863
Dac
Dac's Avatar
Lokacija: Bjelovar
Postovi: 672
Prodao SX763, obećao kupcu vratiti T-com softver međuota ne ide mi. Jel netko to uspio?
Prva naredba nakon ubacivanja secondary_boot.img preko WinSCP kaže:
Code:
root@OpenWrt:~# mtd write /tmp/secondary_boot.img secondary
Could not open mtd device: secondary
Can't open device for writing!
root@OpenWrt:~# dd if=/tmp/secondary_boot.img of=/dev/mtdblock2
126+1 records in
126+1 records out
Nakon toga gasim. Ugašen FW i AV, tftpd32 sve kako treba, IP 192.168.2.16, palim router ali jok. Digne se u klasični FailsafeUI i to je to.
Dac je offline   Reply With Quote
Staro 08.03.2013., 20:29   #864
lepak
Lokacija: Doma
Postovi: 47
sta ti tu nije jasno.. to je uspilo.. al to je samo bootloader.. da njega nema nebi imao ni failsafe gui
Staro 08.03.2013., 20:35   #865
Dac
Dac's Avatar
Lokacija: Bjelovar
Postovi: 672
Koliko sam shvatio umjesto toga bi trebao povući runtime.img sa tftpd32, nakon slijedećeg restarta trebao bi ponovo biti T-com orđinale kako je i bio prije kemijanja
Staro 08.03.2013., 20:41   #866
lepak
Lokacija: Doma
Postovi: 47
a neam ti pojma, valjda ce se netko javit tko zna.. vjerovatno mos iz openwrt-a flashat original na neki nacin
Staro 08.03.2013., 21:24   #867
alcem
Datum registracije: Jun 2010
Lokacija: selo veselo
Postovi: 133
Procitao cijelu temu (huh, trebalo je izdrzati ) ali nigdje ne nalazim jel i jedan od ova dva wrta podrzava Repeater Bridge za SX763?
Dakle, imam primarni ruter koji se kaci na net i sluzi kao AP, a trebao bih na njega spojiti flashani SX763 na nacin da:
a) primarni ruter i SX budu povezani preko wirelessa na istom subnetu
b) da mogu spojiti uredjaje na SX zicno (konzola, NAS i 2 kompa)
c) da na SX mogu spojiti i wireless klijente (mobitel recimo i laptop)
d) da uredjaji spojeni na SX bilo preko zice ili wireless mogu na net i da dobijaju ip adresu od DHCPa s glavnog rutera.
e) da je veza primarnog i SXa zasticena minimalno WPA enkripcijom buduci imam okolo nadobudne susjede koji vole krekati WEP.
f) eventualno da se moze koristiti Super G izmedju rutera (najvise radi NASa, primarni ruter podrzava Super G).
Malo sam googlao i ispada da mi za ovo treba Repeater Bridge pa da ne flasham ako to nije podrzano...
Unaprijed zahvaljujem.
Zadnje izmijenjeno od: alcem. 08.03.2013. u 21:50.
alcem je offline   Reply With Quote
Staro 08.03.2013., 22:29   #868
subixonfire
Postovi: 34
oscam
Evo oscam za sx-a testirano sa openwrt-om...
Staro 09.03.2013., 01:24   #869
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,120
Pozdrav,
Stavio sam danas dd wrt jer mi router treba kao repeater. Nakon lagane yebade oko toga proradilo mi je sve i ja sretan - ne trebam pljunut lovu za universal repeater
E sad, nakon cirka 12 sati rada skužio sam da mi svako malo veza "zatilta" kao da se dogodi nekakav timeout. Zanimljivo je što kod downloadanja nema tog timeouta.
Sam web config je responzivan i nema tih problema. Speedtest pokazuje ok brzinu i ok ping samo eto - dok surfam svako malo neka stranica zatilta. Cache je očišćen, isprobao na Chromeu i IE10 tako da sam siguran da je u routeru problem.
Any help?
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 09.03.2013., 01:56   #870
.Delboy
.Delboy's Avatar
Lokacija: hr
Postovi: 755
Autor Dac Pregled postova
Stavi gore ovaj fw, i onda ponovi postupke, samo ako ti neće sa prvom komandom nemoj izvršavati onu drugu:
http://sx76x-openwrt-danube.googleco...allparts.image
