Staro 08.06.2005., 14:37   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Dobre vijesti za Amiga-nostalgičare
Zadnjih par dana je nakon dužeg zatišja nastala prava poplava
Novi AmigaSYS2:
http://amigasys.fw.hu/
Fixed Assigns errors.
- Fixed Install script.
- Fixed Sorted install script components.
- Fixed AmigaSYS install icon. (Now no New icon. Old style , default Os 3.0)
- Fixed No-startup script.
- Fixed Default font. No BIG font15 , Small Classic type font size 12.
- Fixed CD , DVD-ROMs Mounter Script now 100% work in AmigaOs 3.0 , 3.1 , and 3.9 (use right mouse button , Tools Menu/CD-ROM Mount).
- Fixed PlayCD in Os 3.9 , now work CDDA playing CD or DVD only unit 0.
- Fixed Lure Of The Temptress German version , save game fix.
- Fixed XpkMaster Prefs icon.
- Fixed 3.x def icons.
- Fixed in AmigaOS 3.9 Local bug.
- Fixed in AmigaOS 3.9 def icons.
System :
- Added Install intro YEAH!!!
- Added New AmigaSYS2.hdf 100% New format.
- Added New HDF size, AmigaSYS 1.0 , 1.5 , 1.7 default 100 MB , AmigaSYS2 200 MB.
- Added optimalized HDF (No fragmented = speed up!)
- Added Multilanguage install support (ENG , DE, HU).
- Added AmigaSYS OS 3.9 Install Scripts.
- Added AmigaSYS Theme Selector, only work in AmigaOS 3.9.
- Added 3 Theme AmigaSYS 2 Classic, Little Monster, RetroSYS, only work AmigaOS 3.9.
- Added Icon packs : GLOW , PNG Style Icons pack , only work AmigaOS 3.9.
- Added 4 stlye theme wallpaper 3.0, 3.1,3.9 RetroSYS Default old , 3.9 Classic 3, LM 1, RetroSYS 2.
- Added AmigaSYS 2.0 Classic, Little Monster , RetroSYS supported multilanguage (ENG , DE , HU) in AmigaOs 3.9.
- Added New programs configurations.
- Added About and Help options in FileMaster 3.0 AMIGASYS button.
- Added 4 new beautifull boot pictures.
- Added Visual Prefs ON only work in AmigaSYS 2 Little Monster (3.9).
- Added PowerIcons ON only work in AmigaSYS 2 Little Monster (3.9).
- Added New Scripts (UpgradeOs3.9 , Theme Selector , Themes , DVD mount, No startup , startup-sequence, etc.).
Themes :
AmigaSYS 2.0 Classic :
- 100% compatible Amiga OS 3.9.
- Default language support : ENG , DE , HU
- Glow and new style icons.
- Birdie
- 3 Style wallpaper , 800x600-1280*960.
- Default high-res pointer.
AmigaSYS 2.0 Little Monster :
- PNG Icons , and New , Glow.
- Birdie
- PowerIcons
- Visual Prefs
- 1 Stlye wallpaper , 800*600-1600*1200
- Little hand pointer.
AmigaSYS 2.0 RetroSYS :
- New icons.
- Birdie
- 2 Style wallpaper.
- AmigaSYS 1.7 stlye tunning up 2.0 !
Emulators :
- Added AmiGameBoy 0.91.
- Added Coolness 0.76.
- Added Flamingo 1.54 Plus 4 Emulator. ( Rom file need).
Library :
- Some librarys added.
Players :
- Added AmigaAMP 2.14.
- Added PlayOGG 1.3.
Games :
Revolution Software presents :
- Lure Of The Temptress Full game , English , and German JST versions. Read readme for info.
Other :
- Amidock remove WbStartup to System:Tools.
- Added WinUAE 2.01 Help file.
Novi WinUAE 1.0:
http://www.winuae.net/
Bug fixes:
- Fullscreen resolution reset if selected display mode's
height was larger than width
- Sprite emulation improvements (Battle Squadron missing high
score character and Bubba'n'Stix background mountains)
- Directory filesystem file/directory datestamp modification
if file/directory's protection flags or comment was modified
(broke in 0.9.92)
- Picasso96 RAM autoconfig area memory size error (16M or
larger was always marked as 8M)
- proper AmigaForever ROM path autodetection
- AMOS filesystem freeze (workaround only, proper fix unknown)
- Kickstart 1.2 was not autodetected (wrong CRC32)
- improved JIT direct access memory area allocation (fixes JIT
direct mode problems with some Pentium 4 or NForce 3/4 boards)
- In some cases all priority-levels were changed to "Above Normal"
- bsdsocket crash fix
- Fixed swapped audio channels
- Picasso96 compatibility problem with Directory Opus 4.12
- Random crash fixed while using external drive sounds or while
loading new configuration on the fly
- Emulation fixes (Shinobi, Double Dragon 2.., broke in 0.9.91)
New features:
- Catweasel Windows driver support, MK1/MK3/MK4 supported
(MK4 direct floppy support and Amiga mouse support coming later)
- Nero Burning ROM ASPI is automatically used if Nero is installed
(better compatibility than Adaptec ASPI)
- Arcadia (Amiga 500 based Arcade system) game support
- Disk swapper-panel improved (path edit box and history added)
- bsdsocket emulation does not ask for internet connection if
requested address is localhost
- Emulation improvements (some Digital's demos, demo Tenebra partially
fixed, 3v Demo by Cave, New Year Demo by Phoenix, game Sci-fi
graphics corruption, Battle Squadron highscores, Bubba'n'Stix
background etc...)
- Sound sample ripper
- Improved debugger
and more.. (and probably new bugs..)
I novi AmigaInABox:
http://www.amigainabox.co.uk/
Novi WinUAE v1.0 i par fixeva i novih stvari
Staro 08.06.2005., 18:27   #2
Chuby
Chuby's Avatar
Datum registracije: Feb 2004
Postovi: 1,307
downloading
Chuby je offline   Reply With Quote
Staro 08.06.2005., 18:50   #3
Zond
Rabotnik
Datum registracije: Feb 2003
Postovi: 779
Bum i ja preuzel datoteke
Zond je offline   Reply With Quote
Staro 08.06.2005., 22:44   #4
Ivan_1
Lokacija: Duga Resa
Postovi: 823
odmah mijenjam stari winuae s novim
Ivan_1 je offline   Reply With Quote
Staro 08.06.2005., 23:47   #5
Jelc
Super Moderators
Postovi: 17,485
Trebali bi tu na softu napraviti jedan podforum za emulaciju i slične stvari
Ja još nisam isprobao ovo novo, imam još staru verziju SYS-a, budem sutra.
Staro 08.06.2005., 23:50   #6
Zond
Rabotnik
Postovi: 779
Jedna zamolba za vas nostalgicare. Kako nikada nisam ni vidio Amigu uzivo a kamoli kliketao, dajte malo opisite kako je bilo raditi na Amigi, kaj ste radili, kakvi su bili programi i sve to - ako nije problem da u ovim zadnjim potpitanjima povucete neku paralelu sa PC-em kako bi se dobila kakva osnova za usporedjivanje.
Staro 09.06.2005., 01:08   #7
Jelc
Super Moderators
Postovi: 17,485
To se ne da napisati u par rečenica
Staro 09.06.2005., 01:10   #8
Zond
Rabotnik
Postovi: 779
Dobro.. moze i u par katrena sa pripadajucim screenshotovima
C'mon .. pomogni ljudima koji nisu imali srece posjedovati prijateljicu
Staro 09.06.2005., 01:31   #9
Jelc
Super Moderators
Postovi: 17,485
Možeš si tu pogledati neke sljikice pod screenshots
A za malo duže objašnjenje pričekaj dok Visagea ne ulovi napad scribomanije
Staro 09.06.2005., 03:36   #10
Visage
8-bit Gen.
Visage's Avatar
Lokacija: Giethoorn - ZG
Postovi: 3,158
Zamisli stroj koji je 10 godina ispred vremena (u nekima stvarima daleko ispred) na prelasku sa 8-bit-a na prve 16-bit strojeve.
Stroj koji ima nekoliko grafickih chip-ova, (svaki sa zenskim imenom) 4 kanalni stereo sound, a pod jednim krovom prava "mala" graficka radna stanica i super synth sampler.
Animacije koje danas ljudi kad vide, ne shvacaju jesu li iz buducnosti ili super proslosti.
Dok su mnogi mislili da je Mac prvi imao pravi multitasking = Krivo!
Amiga ga je imala u punoj funkcionalnosti, dok je PC sricao po > One task-u
Zamisli viruse koji (vecina benigni) su se multi medijski
izvrsavali na odusevljenje vlasnika (naravno, ne bas
stalno, sigurno ne Gadafi)
Upalim masinu...... poruka..... > Something Wonderful has
just happened. Your Computer Is In Love <
Hall 9000, poznato?
Naj ekonomicnija masina ikad sto se tice iskoristavanja
memorije. Citavi animirani filmovi su mogli strati na jednu ili
dvije diskete, uzgred receno 2DD diskete
Graficki programi od kojih je doslovno pokradeno sve i svasta
sto se danas naziva inovacijom. Stroj koji je mogao raditi
video obradu sa malom "kutijom" koju si mogao kupiti tada
za cca.500DEM (Genlock) i imati ono sto se nadziralo od
10.000 na vise $ na mega SF masinama.
Programi su bili toliko kreativni i efikasni da je to fantazija.
Nakon 8-bit masina, neke od naj lucidnijih ideja za igre i meni najdrazih Avantura (kod Amige arkadnih Avantura)
Radile su se mape, danima dogovaralo kako zavrsiti jednu
za drugom
Evo nasao sam iz vlastite arhive par slicica jedne od meni najdrazih igara -> Defender Of The Crown <-
Za ostale cu vulgaris baciti linkove, gledaj i divi se :
http://img300.echo.cx/img300/153/0011or.jpg
http://img300.echo.cx/img300/5894/0029io.jpg
http://img300.echo.cx/img300/8657/0c8lm.jpg
http://img300.echo.cx/img300/1928/0d0po.jpg
http://img300.echo.cx/img300/5237/0e9ou.jpg
http://img300.echo.cx/img300/2733/0f7hx.jpg
http://img300.echo.cx/img300/4443/0h2ug.jpg
http://img300.echo.cx/img300/5967/12ar.jpg
http://img300.echo.cx/img300/3438/1a1gt.jpg
http://img300.echo.cx/img300/8324/28lw.jpg
http://img300.echo.cx/img300/6465/2d0pg.jpg
http://img15.echo.cx/img15/1331/2d2il.jpg
http://img15.echo.cx/img15/3918/2e3dd.jpg
http://img15.echo.cx/img15/6306/2f8bz.jpg
http://img15.echo.cx/img15/4285/2f8df.jpg
http://img15.echo.cx/img15/1406/88md.jpg
http://img15.echo.cx/img15/3376/8a1ww.jpg
http://img15.echo.cx/img15/3230/8b6jp.jpg
Kad bi 16-bit-ni jahaci apokalipse zajahali ka smaku svijeta
i kad bi ih prevodio naj opakiji jahac Jelc, koji bi bio tamanitelj
svih masina
Dao bi mu i Mac i PC....tesko bi dao 8-bitnike....no, ovo : mu nikad ne bi dao
Nakon Amige, osim igre LBA (1,2) nikad vise nisam mogao nista zaigrati na PC-u.
Ovdje ih mozes sve pregledati i potrositi barem jedan zivot da bi to stigao
Staro 09.06.2005., 09:31   #11
Zond
Rabotnik
Postovi: 779
Izvrsno Visage, puno hvala! Placam pice po izboru ako nas zivot ikad nanese na isto mjesto! Molio bih i ostale kad uhvate malo vremena da napisu nesto o zadanoj temi. Shvatite to kao zadacnicu iz Hrvatskog
Sad sam vidio igre, no jeli se itko bavio audio/video/grafickom obradom - na netu sam citao o ogromnoj kvaliteti takvih programa (Picasso recimo). Je li istina da je 3D Studio Max portan sa Amige na PC?
U biti mozete i pisati sa temom "Moja prva Amiga"
Sad kada covjek procita sve te cinjenice, ne moze se ne pomisliti i zapitati, kako je Amiga izgubila tu magiju. Tko je bio krivac? Sve vise mocniji PC, ili lose vodstvo Amige koje je "losim" poslovnim postupcima Amigu gurnula na marginu "osobnog racunalstva"
Razmisljao sam netko vrijeme postaviti topic "Retromanija" koji bi se bavio old-timerima u kompjuterskoj industriji. Razlog tome (osim Amige) su razne price o starim kompjuterima od covjeka koji mi je par puta servisirao ves-masinu. (inace covjek podsjeca na g.Raka - glavno da kroz uredjaj tece struja, za sve ostalo bu se on pobrinuo) Po njegovima ispovjestima, dosta se bavio kompjuterima krajem 80ih i pocetkom 90ih - te o tim vremenima prica sa velikom nostalgijom. Međuostalim, spomenuo je kako je u Jugi bilo dobrih kompjuterskih casopisa (Galaksija?? Moj Mikro?? - molim eventualne ispravke) i postojala je jaka scena kompjuterskih entuzijasta. Postoji li danas, kriticna masa zainteresiranih, koji bi takav topic odrzavali neko vrijeme na zivotu. Jer ne bih htio da po meni tako zanimljiva tema, nakon par poruka dozivi binarni arest i odluta u bespuca povijesne zbiljnosti
Ako dobijemo zakljucak da sve sto valja je iz proslosti, uzivajmo u trenutnom stanju... jer tko zna sto nam nosi buducnosti
Staro 09.06.2005., 12:03   #12
Ivan_1
Lokacija: Duga Resa
Postovi: 823
napisite i koje ste igre igrali i koje su vam bile najdraže....
Staro 09.06.2005., 12:10   #13
Zond
Rabotnik
Postovi: 779
Kao poticaj Veteranima i s ciljem upoznavanja mladjih populacija s Amigom prenijet cu izvrstan tekst o Amigi koji je bio objavljen u nultom broju elektronickog casopisa " @lter Format - IT časopis o računalima, programiranju i alternativnim tehnologijama .. Broj 0, 06/2004"
Evo napokon se i to dogodilo! I Amiga je pronašla svoje mjesto u jednom elektroničkom informatičkom časopisu! U prvom broju, a ujedno i prvom članku posvećenom kraljici kućnih računala Amigi, želimo vam prikazati kompletnu povijest tog nikad neprežaljenog računala koji se i dan danas pokušava izboriti za svoje mjesto u sada već velikom Informatičkom svijetu! Naime, vjerujem da se dosta ljudi barem jednom zapitalo kako je nekad tako jaka kompanija kao što je bila Amiga (Commodore) mogla tako brzo propasti ili točnije tvrtka koje je imala najprodavanije računalo 80' godina jednostavno je zaboravljena i danas skoro da se i ne spominje! Evo kao što je već bila riječ na početku teksta u slijedećim rečenicama vam želimo pobliže predočiti Amigu od njenog nastanka pa sve do današnjih dana! Nadamo se da čete uživati u tekstu te će vam neke stvari u vezi Amige biti puno jasnije! Pa krenimo!
1982
Tri zubara iz Floride koja su htjela uložiti u industriju kompjuterskih igara osnovala su tvrtku Hi-Toro. Uložili su 7 miliona dolara u razvoj novog stroja koji je predvodio Jay Miner, dizajner Atarija 2600. Hi Toro je ubrzo promijenio ime u Amiga Inc. zbog toga što je već postojala tvrtka sličnog imena, japanski proizvođač kosilica Toro. Radno ime kompjutera na kojem su radili bilo je Lorraine , po ženi predsjednika tvrtke. Kako ne bi privlačili pozornost na sebe počeli su praviti dodatke za druge platforme. Tu spadaju Amiga Power-Stick - mali joystick, te Amiga Joyboard - vrlo neobičan kontroler kojim se upravlja stajanjem ili sjedenjem na plastičnoj ploči pomicanjem tijela. Amigini programeri napravili su igru za Joyboard imena . Cilj igre bio je što duže sjediti na Joyboardu bez pomicanja. Amigin razvojni tim tvrdi da kada sve pođe po zlu (osobito prilikom konstantnog rušenja prototipa) najbolji način za opuštanje je igranje Zen Meditationa. Tako je nastala ideja za poruku 'Guru Meditation Error' prilikom rušenja sistema prvih Amiga.
Joyboard
1983
Amerikom su se širile glasine o razvoju novog super-kompjutera. Zbog sve većeg financijskog pritiska i krize tržišta igara Amiga tim je odlučio da Lorraine neće biti samo igrača konzola već pravi kućni kompjuter. Dizajnirali su posebne čipove: Agnus (generator Adresa), Daphne, kasnije preimenovan u Denise (grafički čip) i Portia, kasnije nazvan Paula (portovi i zvuk). Jay i njegov tim radili su na hardveru, dok su Dale Luck i njegova grupa radili na OS-u preko softverske simulacije. budući da nisu imali pravu Amigu, morali su emulirati još nepostojeći kompjuter. Hardveraši bi dolazili Daleu i informirali ga koji registri čemu služe i gdje se nalaze i on bi podesio svoj stroj da to emulira.
Lorraine
Staro 09.06.2005., 12:16   #14
Zond
Rabotnik
Postovi: 779
1984
Projekt je poprilično premašio planirani budžet i Amiga tim je upao u financijske poteškoće. Da bi spasili Lorraine morali su pronaći ulagača. 4 siječnja na Consumer Electronic Show-u u Chicagu Lorrain je predstavljena nekolicini potencijalnih ulagača. Pošto posebni čipovi još nisu bili gotovi predstavljeni prototip bio je glomazna hrpa čipova i žica. Tijekom showa RJ Mical i Dale Luck napisali su famozni 'Boing' demo u kojem se kuglica sa crveno-bijelom šahovnicom odbija od rubova ekrana. Kasnije će ta kuglica, tzv. 'Boing Ball' postati Amigin simbol. Iako su mnoge tvrtke kao Sony, Apple, Philips, HP i dr, bile zainteresirane za Amigin hardver, ali nitko, osim Atarija nije dao ozbiljnu ponudu. Atari je posudio Amigi 500,000 dolara na mjesec dana, a kada je bilo očito da dug neće moči vratiti ponudio je da je kupi za 98 centi po dionici. Nisu pristali na tako nisku cijenu i tražili su novog ulagača. Tri dana prije isteka Atarijevog roka Amiga pregovara s Commodoreom koji je kupuje za 4.25 dolara po dionici. Commodore plača sve dugove i ulaže 27 miliona dolara u razvoj novog kompjutera. Amiga je spašena.
1985
Amiga je u lipnju ponovno prezentirana, ali ovaj put dovršena. Ljudi koji su vidjeli novu Amigu nisu mogli vjerovati da običan kompjuter može proizvesti takvu grafiku. Mislili su da se radi o nekoj šali.
23. srpnja u Lincoln centru u New Yorku prva Amiga je službeno predstavljena javnosti Amiga 1000. U listopadu se već isporučivala prvim kupcima. Cijena je bila 1,500 funti, što je bilo duplo jeftinije nego PC s EGA grafikom. Ubrzo je počeo izlaziti i prvi Amiga časopis 'Amiga World'. Kodiran je i 'Juggler' demo, žongler koji žonglira s prozirnim kuglicama u 3D svijetu.
Amiga 1000
1986
Počeo je rad na novom modelu Amige. Nova Amiga razvijala se nezavisno u dva Commodoreova razvojna laboratorija, u Las Gatosu (SAD) i Braunshweigu (Njemačka). Commodore je htio da nova Amiga bude kompatibilna s IBM PC-ima, pa su oba laboratorija radila na softverskim i hardverskim emulatorima. Ubrzo je laboratorij u Las Gatosu zatvoren i njihov dizajn odbačen, te je nastavljen rad na onom iz Braunshweiga. Većina originalog Amiga tima je otpuštena. Iste je godine izašla igra 'Defender of the Crown' koja je izgledala stvarno impresivno i zbog nje su se prodale tisuće Amiga.
1987
Commodore je izdao Amigu 2000, koja je naslijedila Amigu 1000. Imala je malo veće kućište i puno veću mogućnost proširenja (5 Zorro II slotova i video slot). Cijena u Velikoj Britaniji bila je 3200 funti. Kasnije je izašla Amiga 500 koja je bila kompaktna verzija Amige 2000 - cijeli kompjuter uključujući tipkovnicu i 3.5'' FD bio je u zajedničkom plastičnom kućištu (kao Commodore 64 ranije) i imala samo jedan slot za proširenja. Cijena joj je bila oko 360 funti. Bio je to najpopularniji model Amige.
Nove amige imale su Amiga OS 1.2 i novi grafički čipset, EHB, koji je omogućavao prikaz 64 boje na ekranu. U Norveškoj je osnovana tvrtka Scala.
Amiga 500
Amiga 2000
1988
Prodaja Amiga sve više raste. Amiga počinje preuzimati Atarijevo tržište sa sve većim brojem igara koje su bile puno bolje nego za Atari ST . Atari tuži Commodore tvrdeći kako su oni uložili u razvoj Amige i gubi parnicu.
1989
Izašao je Batman paket, najpopularniji Amiga paket koji se prodao u stotinama tisuća primjeraka. Dogodile su se neke male promjene u čipsetu: Agnus je postao Fat Agnus i kasnije Fatter Agnus i mogao je kontrolirati 1 MB chip RAM-a.
1990
24. travnja predstavljena je Amiga 3000, Commodoreov prvi potpuno 32-bitni kompjuter. Imala je Motorolin 68030 procesor, novi ECS čipset, Zorro III slotove, SCSI kontroler i flicker fixer koji je omogućavao lako spajanje na PC monitor. Uz nju je dolazio i novi Kickstart 2.0, koji je izgledao puno bolje nego 1.3.
U lipnju izlazi CDTV, jedna od najskupljih Commodoreovih pogrešaka. Bila je to ustvari Amiga 500 s 1 MB chip RAM-a i CD ROM-om.
U kolovozu izlazi Amiga 500+. Bila je to Amiga 500 sa ECS čipsetom i Kickstartom 2. Iako je bila u prodaji samo nekoliko mjeseci bila je bolja od svoje nasljednice, Amige 600.
U studenom izlazi NewTekov Video Toaster, što je izazvalo revoluciju u video industriji. Od kad je izašao, zaslužan je za grafiku u filmovima i serijama kao što su Babylon 5, Seaquest DSV, Star Trek Next Generation, Star Trek DS9, Quantum Leap, Robocop, Alladin, pa čak i Jurassic Park (jednim dijelom).
Amiga 3000
1991
CDTV je otkazan. Izašla je Amiga 3000T, verzija u tower kućištu. Širi se tržište konzola što narušava Amiginu dominaciju na području kućnih kompjutera.
1992
U travnju izlazi Amiga 600, još jedan Commodoreov promašaj. Poboljšanja u odnosu na Amigu 500+ bila su ugrađeni IDE kontroler, PCMCIA, te RF i kompozitni izlazi, a veliki nedostatak bio je manjak numeričke tipkovnice. U rujnu je predstavljen novi grafički čipset - AA (Advanced Amiga), kasnije preimenovan u AGA (Advanced Graphics Architecture). Mogao je prikazati 256 boja na ekranu i čak 262,144 boje u HAM modu iz palete od 16.7 milijuna boja. Predstavljen je i Amiga OS 3.0 koji je imao CrossDOS (za kompatibilnost sa PC zapisima), datatype-ove, lokalizaciju, standardni installer, poboljšanja u file sistemu i dr.
U prosincu izlazi prva AGA Amiga, Amiga 4000. Imala je 68040 procesor, 2 MB chip memorije proširive sa standardnim SIMM modulima kao FAST ram, IDE kontroler, te Zorro III slotove kao Amiga 3000.
Za Božić izlazi jeftina verzija AGA Amige, Amiga 1200. Bila je u plastičnome kućištu poput Amige 500. Imala je IDE kontroler, PCMCIA slot i 32-bitni slot za proširenje. Kao i Amiga 4000 dolazila je s novim OS-om 3.0. Amiga 1200 postala je jedan od najuspješnijih modela Amige.
Amiga 3000T
Staro 09.06.2005., 12:25   #15
Zond
Rabotnik
Postovi: 779
1993
U rujnu izlazi zadnji Commodore-ov kompjuter, CD32. Bila je to prva 32-bitna igrača konzola s CD ROM-om, a bazirana je na Amigi 1200. Imala je Full Motion Video (FMV) način rada koji nije baš podržan od programera igara. CD32 nije uspio spasiti Commodore od gubitaka.
CD32
1994
Commodore je bio u ogromnim financijskim problemima. Iako su se Amige prodavale kao to nije bilo važno jer su im dugovi bili preveliki. Amige su se proizvodile sve do travnja. Commodore je razvijao novi AAA čipset koji je trebao moći prikazati rezolucije do 1280x1024 u milijonima boja i 16-bitni zvuk CD kvalitete, ali taj čipset nikad nije ugledao svjetlo dana. Tijekom zadnjih dana Commodore-ova postojanja otpuštene su tisuće zaposlenika i zatvorene su mnoge tvornice i razvojni centri. Konačno je 29 travnja 1994 u 16:10 Commodore potpisao likvidaciju. PC je preuzeo Amiginu poziciju kao kućno računalo. 20. lipnja preminuo je Jay Miner, otac Amige. Bila je to tužna godina za Amigu.
1995
20 travnja končano je održana aukcija. Zainteresirani za Amigu bili su Commodore UK, IBM, Dell, Escom, CEI i Samsung. Na aukciji su se pojavili samo Escom i Dell. Escom je pobjedio i kupio Commodore za 12 miliona dolara. Escom je razdvojio Commodore od Amiga branda. Osnovao je Amiga Technologies kojim su upravljali poznata Amiga imena uključujući Jonathana Andersona. Escom je licencirao Amiga tehnologiju VISCorp-u. Ponovno je pokrenuta proizvodnja Amige 1200 i 4000T. Nova A4000 je dolazila sa 68060 procesorom i za nju je bilo dizajnirano novo tower kućište. Escom je potpisao sporazum sa Scalom i sa svakom novom Amigom dobila se Scala MM300.
1996
Escom predstavlja novi proizvod Amiga Surfer Pack. U njemu se dobila Amiga 1200 sa ugrađenim hard diskom od 260 MB, 2 MB RAM-a, 14,4kbps modem i softverski paket za internet (AmIRC, AmFTP, AS225 Release 2, MUI 3.2, Mindwalker Web browser i Voodoo Multimedia Mailer).
Predstavljen je i Walker, nešto kao A1200 sa 68030 ili 68040 procesorom, utorom za FPU, PCI slotom, 4x CD-ROMom, tower kućištem (koje je dizajnom podsjećalo na suvremeni usisavač, i daleko ljepše i modernije od najljepših Macintosh-a) i Amiga OS 3.2.
U travnju VISCorp najavljuje kupnju Amige od Escoma, ali pošto je nikad nije kupio u srpnju iste godine Escom je bankrotirao.
Amiga 1200 Escom
1997
Gateway 2000 (tada samo , jedan od najvećih proizvođača PC-a kupio je Amiga Technologies u ožujku i promijenio joj je ime u Amiga International (i kasnije u Amiga Incorporated), te je osnovao novu podružnicu koja je radila na razvoju novih proizvoda. Predsjednik Amiga Internationala je ostao Petro Tyschtschenko.
Ostatak godine nije bilo značajnijih događaja. Gateway 2000 i Amiga International licencirali su Amiga tehnologiju i OS nekolicini drugih firmi i otvoreno je nekoliko Amiga user grupa.
1998
Godinu dana nakon kupnje Gateway 2000 objavljuje svoje planove za Amigu. Amiga International mijenja ime u Amiga Incorporated i otvara novi web sajt na http://www.amiga.com. Objavljeno je da će Amiga Inc. raditi samo na novom OS-u za Amigu, a razvoj hardvera će prepustiti drugim zainteresiranim tvrtkama. Objavljeno je također da budućnost Amige leži u kombiniranim 68k+PPC rješenjima. Takvo rješenje već je postojalo u obliku PowerUP kartica tvrtke Phase 5. Pretpostavljalo se da će kasnije izaći Amiga klonovi zasnovani na PowerPC procesorima. Na veliku žalost Amige klonovi se nisu pojavili ali najgora stvar je bila ta sto su PowerPC procesori bili slabo podržani od strane aplikacija !! A kako su se stvari odvijali dalje??To ćete saznati u nastavku ovog teksta kad planiramo opisati novu doba Amige, točnije doba od pojave prvih PPC,PCI kartica pa sve do danas kad već imamo I novu Amigu u kojoj "kuca " već dobro poznati procesor G3, G4, G5.
Amiga 4000T
Staro 09.06.2005., 13:43   #16
Zond
Rabotnik
Postovi: 779
Staro 09.06.2005., 15:12   #17
Jelc
Super Moderators
Postovi: 17,485
Koliko me pamćenje skuži-Maxx je dolazio na sedam disketa
Ja još uvijek imam svoj stari hard sa Amige-WD850MB, spojim ga na piceka nakon deset godina i samo veselo zarošta i radi bez beda
Čisto da ti kane suza pod oko kad začuješ taj zvuk
Staro 09.06.2005., 23:55   #18
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,158
Inace na slijedecem linku mozete preuzeti 3 primjerka casopisa Total Amiga!
Mani se toga Zond
Zivot mi je dovoljno kompliciran da me sad tu navlacis na nostalgiju.
Danas je konzumentsko vrijeme, nema mjesta kreaciji vec pukom egzistencijalno potrosackom drustvu koje guta samo povrsinu i robuje kultu tijela. Zato i sve izgleda sterilno.
Amiga je kap u moru, sto je sve postojalo i zavrsilo pocetkom 90-tih. Vec sam davno donio odluku sa prijateljem preko bare napisati naj kompletniju knjigu ikad o dosezima tehnologije u svim sferama A/V/Comp, razlozima zasto, i koliko je sve sto danas samo ekstrakt juhe u vrecici naspram dekadama prije, posebno 80-tima. Dekada u kojoj je tehnologija dosegla zenit iod tada se samo kompilira. Za deset ili vise godina, tesko je reci kada
Najbolja medicina za tebe je da si kupis jednu Amigu u Plavom (po mogucnosti 2000 sa dva flopaca) ili jos bolje daj oglas da je kupujes....mala cijena za veselje koje te ceka na tom putu.
Staro 10.06.2005., 00:20   #19
Zond
Rabotnik
Postovi: 779
Neznam, skidam sa neta Computer Chronicles, Amiga ofkors, pa bumo vidjeli rekli bi slijepci.
Visage, nemoj se opirati, prepusti se nostalgiji. Zivot ne pruza load&save, nema drugog cina - live and let die . Naravno, prije toga cemo zanemariti cinjenicu da ja sa 21om godinom nemam kaj vama starijima govoriti kak treba zivjeti
Ovo o knjizi me jako zanima. Ali jaako i to mislim bez ikakvog ulagivanja i slicnog. Je li pisanje u tijeku ili se tek planira.
Ima frend neku Amigu, bum ga pitao kaj tocno ima. Pa cemo to isprobati. Citajuci one casopise, gledajuci te ekspanzijske kartice, nazalost priznajem da je Amiga danas skup sport ako ju se zeli drzati u kakvom al-pari stanju sa modernijim PC-ima. Ali za nostalgiju, nam to ne treba
Bas slusam Depeche Mode i kad pogledam ovu raspravu, nekako mi ovaj refren totalno upada u razmisljanja
And I thank you for bringing me here
For showing me home
For singing these tears
Finally I’ve found that I belong here
Staro 10.06.2005., 01:41   #20
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,158
Originally posted by Zond Visage, nemoj se opirati, prepusti se nostalgiji. Zivot ne pruza load&save, nema drugog cina - live and let die . Naravno, prije toga cemo zanemariti cinjenicu da ja sa 21om godinom nemam kaj vama starijima govoriti kak treba zivjeti Ovo o knjizi me jako zanima. Ali jaako i to mislim bez ikakvog ulagivanja i slicnog. Je li pisanje u tijeku ili se tek planira.
Hehehe, danas mi je bas dan pun filozofskih rasprava pa da i ovu zadnju sumiram u zadnjem postu danas (sutra?)
Knjiga se pise na kapaljku, ali oblikuje se u glavi svako malo.
Amiga , kao i svaka nostalgija se prozivljava u okruzenju vremena nastanka. Nemas zasto ciniti ju "recentnom" Nikakvi ti "akceleratori" ne trebaju za uvid u ljepotu Amige.
Trebas jednu Amigu, programe, igre i to je sve.
Na 68030 i 68040 ionako ne bi mogao (kompatibilnost) vrtiti puno stvari, A4000 bi te natjerala na plac po tom pitanju.
Jedna A500 (1MB) ili 2000 (ako imas srece i nije ti zao malo dublje posegnuti u djep)
Da bi uskladio retro sferu sa Amigom i slusao Martin Gore-ovu super grupu, moras se spustiti barem do "101 Live"
albuma Inace Martin je bio veliki ljubitelj 8-bit masina i kad je Vince (danasnji Erasure) napustio grupu Martin je lansirao DM kako danas zvuce. Do tada je radio kao sluzbenik u banci i napikavao prve Roland Jupitere (synth)
Sto se tice zadnje stvari "load&save" zivota.... (dolazimo na filozofiju)... tu se dolazi na protutezu danasnje javne tajne koncepta reinkarnacije.
Dovedes li najvece eksperte egzatnih znanosti pred zid organicenja lineatnosti inkubatora znanosti (fiksno/krutog)
Prisiljeni su sve discipline gurati na rubne sfere (parapsihologija i kult mita)
I najstariji skolastici od naj starijih vremena zapravo vjeruju u reinkarnaciju (literatura to potvrdjuje) ali je nemogu priznati svome stadu zbog problema interpretacije. Pa tako se ona izgovara hrabro samo na medju Vedistima i Budistima.
Zato ju linearno prezentiraju u kotacu percepcije naseg fisnog shvacanja svjesti. Dok cak i sam nauka (ironicno) odobrava paralenost. Zato jer se sve dogadja u jednoj točci ili jednom valu.
Ne jedan za drugim, vec svi u jednom - (životi)
No nas um ako nema pocetak i kraj, nije u stanju to svesti na racionalni zakljucak = linearnost.
Zato bi se "Imam jedan zvot", "Zivim jedan zivot", "Samo se jednom zivi" ili "Load & Save" cak i u najstarija paganska vremena
smatrao bogohuljenjem, mada bi rani monoteizam to volio negirati.
Tu dolazimo do fenomena odgovornosti. Kulture koje otvoreno govore o reinkarnaciji puno su odgovornija drustva (gledano kroz proslost do danas) buduci da se ravnaju po zakonu akcije i reakcije. I tu nestaje "Load & Save"
Mano Matra Jagata = Cijeli svijet je samo kreacija uma.
Drugi pasus (USA/Washington) >>> !!! <<<
Dovoljno za veceras....
PS: Zahvaljujem se svojoj novoj 3 dana staroj IBM klikuši sto mi omogucava da rusim vlastite rekorde u brzini tipkanja, cca, barem brzo kao najdraza sekretarica Henry Forda
>>>> PCE kante 2012 <<
>>>>>>>>> PCE & ostalo <<<<<
>>>>>>> Što sam Slušao? <<<<<<
>>>>> Gimnastika za Okulare & LCD Addendum<<<<
>>>>> P o s t ... M j e s e c a <<<<
______________________________
Zadnje izmijenjeno od: Visage. 10.06.2005. u 01:59.
Staro 10.06.2005., 02:19   #21
Jelc
Super Moderators
Postovi: 17,485
Bivši Yazoo
Staro 10.06.2005., 12:16   #22
Chuby
Chuby's Avatar
Postovi: 1,307
sad ste me zbedirali, bas sam se prisjetio kako su se nekad stvari radile, s koliko entuzijazama i inovacija, pravih inovacija a ne ovih danasnjih milimetarskih pomaka i to u prazno
Amiga je imala nesto sto ju je pretvaralo u racunalo s osobnoscu, tad ni patchevi nisu postojali jer se sav posao obavio PRIJE izdavanja softwarea
i onda propast commodorea i zaustavljanje razvoja amige i ona sramotna vijest da ce se hardware (i neki soft) od amige koristit u kucanskim aparatima za par godina.
gledam svog piceka i znam da nikad nece bit stroj kao amiga, bez obzira koliko love utukao u njega
BTW one ekspanzijske kartice i cuda iz novijeg doba za Amigu su mi gnjusne........
Staro 10.06.2005., 12:30   #23
Zond
Rabotnik
Postovi: 779
Thumbs up
Na dobrom smo putu, ajmo Veterani, olaksajte dusu, dr. Stefan Frank je ovdje
Zar je moguce da su samo 3 Amigasa na forumu? Mislim da sam i neke druge nadimke nasao u nekim retro raspravama na forumu, ukljucite se decki na casisu razgovora sa ostalim nostalgicarima
Uh, Visage, ovo za jogu i reinkarnaciju .. treba to lagano probaviti
Nego kaj se tice knjige, ako nije problem jer bi se mogao staviti kakav sample chapter kao nekakv teaser ?
Staro 10.06.2005., 12:42   #24
Jelc
Super Moderators
Postovi: 17,485
Ja imam doma 1200HD, uključim je tu i tamo
Ali zato ima finih emulatora koje možete koristiti na piceku, ja sam si stavio na USB stick AmigaSYS, programe i igre...tak da samo spremim u đžep i bilo gdje mogu haklat.
Staro 10.06.2005., 12:46   #25
Zond
Rabotnik
Postovi: 779
Problem kod emulatora su oni Kickstart romovi, khm
Postoji li nacin Jelc, da se sadrzaj tog USB-a prebaci u neki ISO i podjeli dalje?
Staro 10.06.2005., 13:09   #26
Jelc
Super Moderators
Postovi: 17,485
Orginal ROM-ovi moraju biti legalni, tjst. tvoje vlasništvo.
Isto kao i WB OS.
Trebalo bi pogledati da li je možda postao "slobodan" kakav ROM starije revizije ili WB...
Staro 10.06.2005., 14:34   #27
Ivan_1
Lokacija: Duga Resa
Postovi: 823
ja imam neke kick-ove, to me sve malo zbunjuje, imam 1.3, 1.4, 3.0. ovaj 3.0 koristim jer je bolja slika u igrama, noviji je predpostavljam. jel ja sad moram loadat sve te kickove ili samo jedan? imam i nekakav workbench 3.1 pa sam s njime formatirao virtualni amiga hdd, i pokusao sam instalirati i nekakav OS. fora je to, kad vidim tu jednostavnost sucelja i slicnost sa windozima.....ah...
Staro 10.06.2005., 21:41   #28
Jelc
Super Moderators
Postovi: 17,485
Kad delaš emulaciju može se dogoditi da neka igra ili prog zahtijeva drugi ROM.
Tamo gdje ti je npr u WINUAE folder sa ROM-ovima potrpaš sve i koristiš po potrebi
Staro 19.06.2005., 17:13   #29
Jelc
Super Moderators
Postovi: 17,485
Mali update za AMIGA SYS2:
- QuarkTex is a Warp3D & StormMESA to OpenGL wrapper for WinUAE. Version 0.51 is out !
Install : Add agl.library , and warp3d.library System:Libs dir (overwrite old files) , alib/QuarkTex.alib copy your winuae folder.
http://quarktex.kontechs.de/
A sprema se i novi AMIGA SYS 3
http://www.freeweb.hu/amigasys/asys3003l.jpg
Baš sam neki dan zabrijao do sitea sa AMIGA demo mjuzom, guštao cijelu večer i razmišljao kako se na ondašnjim kompovima pravila puno bolja i orginalnija mjuza nego danas
A neću ni govoriti koliko oku ugodnije izgleda slika napravljena na AMIGI nego danas ove na piceku...
Da li je to stvar AMIGA formata, manjih mogućnosti i shodno tome veće kreativnosti, ili jednostavno toga da sam odrastao u doba kad je "multimedija" podrazumijevala čitanje stripova, slušanje tranzića i skidanje softa koji se emitirao preko lokalne radio-stanice-vrag bi ga znao.
Znam jedino to da se i dan-danas znam zablejati u ručni rad amigaša i razmišljati kako je ta slika jednostavno bolja, ljepša, toplija oku...ni blizu "umjetnicima" koji danas rade na piceku (čast izuzetcima).
Sa nijansama i kombinacijama istih se na Amigi znalo čuda raditi
Imam negdie na starom hardu mrak slike, sve su "crno/bijele" ali tako napravljene da možeš samo blejati u nju...satima
Staro 19.06.2005., 23:57   #30
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,158
Prvo sretnem neki dan bivsu koji nisam vidio ohoho.
Jucer dobijem lopatu egzota spotova iz 80-ih.
Sad me ti jos zelis navlaciti sa Amigama Jelc.
Mani to jer je nepodnosljivo funkcionirati kad ti je glava puna nostalgije ;(
Uzas, sretna nesreca...nostalgija
