Datum registracije: Aug 2003
Lokacija: %
Postovi: 465
Low-end konfiguracija
AMD MBO: Gigabyte 7NF-RZ, nForce2, 3*DDR333, LAN, 5.1, SPDIF (378,50 kn - Ve-mil) CPU: Sempron 2400+ BOX, FSB 333MHz (475,81 kn - Diskont24) COOLER: CoolerMaster DP-6I31D (XP 3000+) (39,93 - Diskont24) Intel MBO:Abit IS7-E, i865PE, 5.1ch, LAN, SATA, FSB 800MHz, s.478 (544,89 kn - HGspot) CPU: Celeron 2400MHz, 256kB c., 533MHz, s.478, BOX (523,70 kn - Diskont24) COOLER: -box cooler- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- RAM: 2*256MB DDR 333MHz, A-Data (483,30 kn - Ve-mil) HDD: Seagate Barracuda 80GB, 7200, 2MB, ATA100 (424,92 kn - Links) GRAFICKA: Sapphire Radeon 9550, 128-bit, 128MB DDR, TV-out, DVI (478,21 kn - HGspot) CD/DVD: DVD+/-RW Pioneer DVR-MCC, DL 2.4x, DVD+/-R 8x, DVD+RW 4x, bulk (462,50 kn - Diskont24) FDD: 1.44MB, 3.5", Samsung (40,22 kn - Diskont24) KUĆIŠTE: Casetek 1016-2A B, Midi, crno (298,00 kn - Links) PSU: Fortron 350W, HQ, PFC (182,37 kn - Ve-mil) MONITOR: 17" Samsung SM795MB, 85kHz, 0.20mm (1120,00 kn - HGspot) MIŠ: Logitech S96, opticki (73,20 kn - Ve-mil) TIPKOVNICA: Logitech Value Keyboard CRO (45,14 kn - Ve-mil) ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- AMD 4502,10 kn Intel 4676,45 kn |
Postovi: 8,379
Umjesto CPU: Sempron 2400+ BOX, FSB 333MHz (475,81 kn - Diskont24) ----- CPU: AMD Sempron XP2500+, 1, 75GHz, 333MHz, 256K Sempron (450,13 kn - Diskont24) |
Lokacija: %
Postovi: 465
eh... tulipani su priča za sebe ![]() point is da je podjela na low, mid i high, što zamjenjuje cijenovne rangove i čini mi se praktičnijim. vjeruj i bit ćeš spašen ![]() ![]() |
partibrejker
Lokacija: Novi Zagreb
Postovi: 291
AMD MBO: Gigabyte 7N400S-L, sckA, nForce2, SATA, LAN (422,99 - Kvark) CPU: Sempron 2500+ (333MHz), SckA BOX (509.20 kn - Kvark) COOLER: CoolerMaster CP5-8J52F (XP 3000+) 2200rpm, 23~28dBA (40,01 - Kvark) RAM: 512mb kingmax, pc-3500,ddr 433 mhz (325,69kn - Links) HDD: Hitachi 80Gb, ATA100, 7200rpm, 2Mb cache (399,00 kn - Kvark) GRAFICKA: Gigabyte R9550, 128Mb DDR, 128 bit, DVI (449,44 kn - Kvark) CD/DVD: dvd±rw LG gsa-4163, 16x, black, dual layer, dvd ram (384,94 kn - Links) FDD:[B] 1.44MB, 3.5",crni (46,01 kn - Links) KUĆIŠTE: chieftec dg-01bd-uw, midi dragon, bez ps, office series, crno (377,76 kn - Links) PSU: Fortron 350W, HQ, PFC (190,37 kn - Ve-mil) MONITOR: 17" Samsung SM795MB, 85kHz, 0.20mm (902,00 kn - HGspot) MIŠ: Logitech S96, opticki (73,20 kn - Ve-mil) TIPKOVNICA: Logitech Value Keyboard CRO (45,14 kn - Ve-mil) UKUPNO: 4 165,75 kn P.S.Mislim da je ovo OK! (ništa puno novog - al su cijene novije) Ako je turska sila - može se cijena još spustit tako da bude "noFo računalo za ispod 4 'iljade noFaca!" ![]() ![]() |
the luda ribetna
Postovi: 3,952
to je cist ok...makar bisi ja dao vise 200 kuna zbog cl2 iliti cas 2 na supertalentu(rami) i nec przu 3520 kuler neka bude xdream 2(tih i hladan) ili falcon spire 2 ovu plocu jos nisamimao al sam imao n400l i prezadovoljan samnjome bio...i modaz si bas sad uzmem sl da vidim kak se sata ponasa ![]() kuciste je vec staro...i to je iskreno pitanje ukusa ![]() ![]() a za 333 kune mozes dobit cooler mastera centurion 5 ![]() ovo je ustvari cist dobra konfa...ako se moze negdje nabavit polovni amd xp bi ti bilo jos bolje ![]() ![]() |
partibrejker
Postovi: 291
Mislio sam da ovaj Kingmax ide na Cas2 ili...? Kućište je, slažemo se svi, stvar osobnog ukusa - pa bi se po njemu svaki kupac trebao i ravnati! ![]() |
the luda ribetna
Postovi: 3,952
niti jedan king nije deklariran na cas 2,nego na cas 2.5 pa prema 3...al ih dosta ide na 400 na 2-3-3-x meni 2 isla iz razlicite serije ![]() Gigabyte 7N400S-L, sckA, nForce2, SATA, LAN (422,99 - Kvark) Sempron 2500+ (333MHz), SckA BOX (509.20 kn - Kvark) Hitachi 80Gb, ATA100, 7200rpm, 2Mb cache (399,00 kn - Kvark) Fortron 350W, HQ, PFC (190,37 kn - Ve-mil) Super talent 400 cas 2 (500 kn - Adm trade) dvd±rw nec nd-3540, 16x, black, dual layer ± recording, bulk (links 389kn) Gigabyte R9550, 128Mb DDR, 128 bit, DVI (449,44 kn - Kvark) Cooler master centurion 5 u (333 links) 2660 kuna i ovo je isto JAKO DOBRA KONFA,mobilac umjesto 2500 semrpona i na konju si decko ![]() |
Postovi: 1
Vidim da duze nema postova, pa jel moze jedna preporuka amd low end konfiguracije (do 3000 kn, bez monitora).. Ne pratim vec duze vrijeme situaciju sa cijenama i sl. Gledao sam nesto cjenike komponenti ali toga ima previse za mene neinformiranog ![]() zahvaljujem ![]() |
Postovi: 2,458
- MBO GIGABYTE K8NS, nForce3 250, zvuk, LAN, S-ATA, s. 754 555Kn - CPU AMD Sempron 2600+ BOX, socket 754, 1600MHz, 128kb c., FSB 800MHz 531Kn - RAM PC-3200, 512MB, DDR, KINGMAX, DDR 400 MHz 398Kn -HDD 80.0 gb seagate, ncq, 8mb cache, serial ata plus 473Kn - VGA AGP SAPPHIRE ATI RADEON 9550, 128MB DDR, DVI, TV 471Kn - DVD±RW LG GSA-4163, 16x, Dual layer, DVD RAM, bulk 360Kn - Napajanje CHIEFTEC Delta GPS-350BB-101L, 350W, 12cm fan, ATX2 -Kuciste po izboru 200Kn UK=3277Kn (NAPOMENA: Danas se moze polovno kupiti vecina ovih ili boljih komponenti za manje novaca za sta je podforum trznica pravi izbor! Tako se nude DVD-i za 50Kn, DVD-RW za 200Kn, 6800LE za 800Kn...) |
