Neradnik
Lokacija: Slav.Brod
Postovi: 1,268
Philips 42 PFL
Evo imam doticnog par dana no ponekad podivlja, upalim ga ima slike ima tona al nece da prebacuje..nemogu ga ugasiti na daljinskom niti rucno na njemu. Jedino gasenje je istekak ga iz struje i ponovo upaliti. Primjetio sam da se to ponekad zna desiti kad prenoci. Dali je netko imao takvih problema. I jos nesta vidim da lampica na tv blica kad prckam po daljinskom znaci nije do baterija. http://www.ve-mil.hr/opis.aspx?prika...&Sifra=4020288 I da omg nisam upute nikakve dobio s njim a nikako da odem do vemulja ![]() |
Agent 0
Lokacija: Kutina - ZG
Postovi: 4,311
Skini novi softver na službenoj stranici, sejvaš na stick, stick ubodeš u TV i čekaš. Kada se ugasi i upali, postupak nadogradnje softvera je završen i problema više imati nećeš. A to što nisi dobio upute, to je tvoja krivica. Trebao si provjeriti da li je sve na mjestu. |
Registered Abuser
Lokacija: Velika Gorica \ ZG
Postovi: 747
službeni odgovor filipsa kad sam ja to rješavao With regards to your query we can advise that you upgrade software with the latest corrected version 000.064.072.000 from 2009-01-16, which is available on our website If the above action does not help, you may try resolving the problem by changing the country selection in the TV menu to ‘CZECH REPUBLIC’ and then perform the auto installation again. In this case you need to take the following steps follow these steps to change the country setting and reinstall the channels: 1. Reset the TV by unplugging it from the power outlet for 30 seconds. 2. Turn on the TV. 3. Press the 'MENU' button on the remote control to access the main menu. 4. Select TV MENU and press the cursor right to access the submenu. 5. Select INSTALLATION and press the cursor right to access the installation menu. 6. If the Child lock is activated, the screen will prompt you to enter your pin code. If you have forgotten your pin code, refer to the FAQ (I have forgotten my 4-digit access code. How can I reset it?). 7. Press the cursor down to select CHANNEL INSTALLATION and press the cursor right to access the channel installation menu. 8. Select AUTOMATIC INSTALLATION and press the cursor right to START NOW. 9. Press the 'OK' button to access the country menu. 10. Press the cursor up/down to select CZECH REPUBLIC and press the green button to confirm. 11. Press the green button to start the installation. 12. Once the installation is completed, press the red button to return to the channel installation menu. 13. Press the 'MENU' to exit the menu. BEZ BRIGE , DALJE OD UPDATE FIRMWARE-a NEBUŠ IŠAO ;-) |
Neradnik
Lokacija: Slav.Brod
Postovi: 1,268
Eto mene opet s problemom doticnog tva. U zadnje vrijeme tvu treba minuta da se upali. Ugasim upalim i onda dodje slika. Neki dan i danas upalim ima zvuka nema slike WTF? Gasio sam i palio par puta ista stvar i nakon peti put dodje slika. Skinio sam novi soft. pa cu ga sad probat upgrejdat pa javim sutra navecer sta ce biti. I da to se desava samo kad ugasim tv u noci npr 2h ujutro i nepalim ga do sutra navecer do 20h . Inace kad upalim i ugasim sve sljaka ok. |
Neradnik
Lokacija: Slav.Brod
Postovi: 1,268
Ljudovi evo maloprije mi nesta puklo u tvu, culo se kao ona mala petardica i nestalo slike. Isti problem kao i sto sam ovdje pisao samo sto sad nikako slika nedolazi. Ima tona slike nema koliko god put palio gasio. |
Postovi: 2,390
Imao sam isti problem sa starim LG LCD-om, tri mjeseca se nije htio isprve upaliti dok jedan dan nije samo crknuo. U servisu su mu promijenili napajanje i od tada sve radi normalno. Ceh je bio oko 600 kuna. |
#9 | |
Neradnik
Lokacija: Slav.Brod
Postovi: 1,268
Postovi: 23,535
Ako misliš na element R302 koji izgleda sumljivo, vjerojatno se radi o otporniku a ne kondenzatoru. Rijetko otpornici crknu "sami od sebe", prije kao posljedica kvara nekog drugog elementa. Kako imaš problema sa tim primjerkom od samog početka preporučam da nabaviš full service manual / schemu i detaljno prekontroliraj modul napajanja za početak. Ako nisi doma sa elektronikom onda nosi u dobar servis. |
Datum registracije: Apr 2011
Lokacija: Usa
Postovi: 628
Očito da je dotični otpornik skuren. Da si ranije interveniso (zamjena elektrolita u mrežnom dijelu) to ti se ne bi desilo. Inače ja isto imam led32 Elit, skoro nikad ne pali od prve čak nekad iz 4-5 puta. Ima još preko god.garanciu pa ne diram ništa. Drugi put prije servisa četkica i usisač (kompresor) ![]() |
Postovi: 23,535
begi - nosi na servis / garanciju ako se ne pali otprve. U garanciji ti to trebaju popraviti mukte a poslje ćeš morati dati nofčeke. |
#16 | |
Neradnik
Lokacija: Slav.Brod
Postovi: 1,268
#17 |
Postovi: 481
Da ne otvaram novu temu, zanima me ako netko zna neki dobar servis u Zagrebu. Imam Samsung 37" ali razbijeni ekran :P, pa me zanima za kolko bi se mogao popravit. Ovdje u Samoboru nema poštenog servisa. Odma da kažem da me ne zanima nova telka i to ne dolazi u obzir, tako da nemorate pisat odi u dućan i kupi novu na rate ![]() |
#18 |
Postovi: 23,535
Preskup sport, eventualno da nađeš isti ekran polovno (vidi kod na njemu kad rastaviš), na ebay - u. |
#19 |
Postovi: 481
e kad bi našao isti takav koji je u banani a ekran dobar ![]() budem ga raskapao koji drugi dan, sad mi se neda. |
#20 |
Neradnik
Lokacija: Slav.Brod
Postovi: 1,268
tv rijesen, 300 kunica. Ja zadovoljan ![]() |
