Staro 18.12.2012., 08:51   #1
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,533
Nvidia GeForce v310.70 WHQL Driver
GeForce GTX 680:
Up to 38% in Far Cry 3
Up to 26% in Call of Duty: Black Ops 2
Up to 16% in Battlefield 3
Up to 18% in Assassin's Creed III
Up to 9% in The Elder Scrolls V: Skyrim
Up to 6% in Medal of Honor: Warfighter
Up to 6% in StarCraft II
Up to 6% in Dragon Age II
Up to 6% in Batman: Arkham City
Up to 5% in S.T.A.L.K.E.R.: Call of Pripyat
GeForce GTX 660:
Up to 24% in Call of Duty: Black Ops 2
Up to 10% in Battlefield 3
Up to 7% in The Elder Scrolls V: Skyrim
Up to 6% in Far Cry 3
Up to 5% in Dragon Age II
Up to 5% in Assassin's Creed III
Up to 4% in Batman: Arkham City
Up to 4% in Medal of Honor: Warfighter
http://www.geforce.com/drivers/results/54625
This GeForce driver is recommended for the best experience in the blockbuster holiday games. GeForce R310 drivers add optimizations for Far Cry 3, providing up to 38% faster performance.
These drivers also include optimizations for Call of Duty: Black Ops 2 and Assassin's Creed III, providing up to 26% faster performance in Call of Duty: Black Ops 2 and up to 18% faster performance in Assassin’s Creed III, as well as smooth, shimmer-free graphics with TXAA antialiasing in both games.
GeForce GTX 680:
GeForce GTX 660:
Staro 18.12.2012., 13:15   #2
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,232
koji im je bog prvo 310.70 beta pa sad whql
Staro 18.12.2012., 16:27   #3
Core2Duo22
Mucki provokator
Core2Duo22's Avatar
Postovi: 299
A jbg treba vremena dok dobiju certifikaciju od M$-a... Tako ih lijepo možeš koristit ranije (a i imaju ispriku ako nešto shebu da su beta )
Core2Duo22 je offline   Reply With Quote
Staro 18.12.2012., 18:18   #4
dean225
DD9512
dean225's Avatar
Postovi: 1,869
Čini mi se da ovi driveri bolje griju moje grafe.. malo mi je komp topliji za ove zimske dane.
dean225 je offline   Reply With Quote
Staro 18.12.2012., 21:28   #5
windfucker
Meni se smanjio OC potencijal (opet moram tražiti iznova), roknulo par puta na samome početku partije WOT-a
Staro 18.12.2012., 22:05   #6
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,544
Autor dean225 Pregled postova
od 306 na dalje svi driveri griju 480ku dobrano , neznam koji k rade s tim driverima, prije nije prelazilo 52-3 sad i na 60 dodje
Staro 18.12.2012., 22:13   #7
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,533
Kod mene sve ok, nisam primjetio da mi se nesto vise grije o.O
Staro 19.12.2012., 00:28   #8
thubanx6
thubanx6's Avatar
Datum registracije: Aug 2011
Postovi: 533
GTX660 je dobila neloš boost u bf3
thubanx6 je offline   Reply With Quote
Staro 19.12.2012., 01:01   #9
Kreso st
Kreso st's Avatar
Lokacija: Split/Zagreb
Postovi: 148
meni grije 4 C više
Kreso st je offline   Reply With Quote
Staro 19.12.2012., 11:44   #10
thubanx6
thubanx6's Avatar
Postovi: 533
Al to je logicno, znaci da se gpu bolje iskoristava, zato smo i dobili boost u igrama.
Btw dolazi mi accelero extreme plus 2 za gtx660. Izgledat ce bolesno veliko naspram nje al ce hladit jednako bolesno dobro.
Staro 19.12.2012., 11:59   #11
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,533
Autor thubanx6 Pregled postova
Kakve su ti sad temp. i koliki ti je boost?
Staro 19.12.2012., 12:25   #12
thubanx6
thubanx6's Avatar
Postovi: 533
Sad mi je 65 battlefieldu s time sta su ventovi na 60% i relativno bucni, trnutno radi na +110% , + 150mhz / +200mhz memorija, s time sta memoriju jos testiram, nije na maksimumu cini mi se, problem je sta gpu clock moze i vise ali tdp limiter pocne ga vracat stalno i onda nema smisla. Znaci ako padnep potrosnja moc cu jos.
Tvornicki memorija nema pasivce, mislim se da li da ih stavim. Kad sam na gtx470 stavio vram pasivnce dobio sam jos 50mhz stabilno u odnosu na stock cooler.
EDIT: memorija +250mhz bez pardona...
Zadnje izmijenjeno od: thubanx6. 19.12.2012. u 13:03.
Staro 19.12.2012., 12:53   #13
Korsitim ove BETA već neko vrijeme. Sve je OK, nema nikakvih problema. Ne znam kakve sad razlike imaju ovi osim što su WHQL i da ne izbacuje onu poruku da nisu diđitalno potpisani ?
Staro 23.12.2012., 23:55   #14
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,544
Pa koji k oni rade ?! nakon sat vremena igranja grafa ode na 68 C pod accelerom ??? PA sta bi bilo da imam stock kuler ? ugasio grijanje i igrao bf3 ?? Jebali ih driveri...
Staro 24.12.2012., 00:10   #15
Autor xulos Pregled postova
Bit će da se više ne trude oko Fermija.
Staro 24.12.2012., 00:15   #16
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,544
Ma nek se teraju u k i oni i driveri. Bitno da se serucka oko ATIja i drivera, a ovi su uzas.
Staro 24.12.2012., 00:20   #17
pa vrati zadnje koji su ti bili normalni.
Staro 24.12.2012., 00:30   #18
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,544
Pa normalno da sam vratio. samo kazem za ostalu ekipu nek pripaze.
Staro 31.12.2012., 18:27   #19
poker
poker's Avatar
Lokacija: osijek
Postovi: 225
je tak nešto su opasno sjebali u ovim driverima moja 560 gs s stock kulerom kad je pričepim s furmarkom burnintest temp ode do 97C a vent na100% u idleu mi je temp 2-3 stupnja viša.grafa nije ockana ,vidjet ću u igrama da li ima nekog pomaka ako nema natrag na 306.97
poker je offline   Reply With Quote
Staro 31.12.2012., 22:00   #20
dean225
DD9512
dean225's Avatar
Postovi: 1,869
Kog uopće briga za temp grafe? Pa bar da hoće riknut pa da zamjenim za noviju generaciju. tako je bilo i prije kada se prešlo sa Gtx 2xx na 4xx pa je brzo riknulo jako puno 2xx zbog pregrijavanja. Ništ novo..
Staro 01.01.2013., 20:43   #21
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Je, meni je moja 560 Ti počela bacat plavi ekran...ubrzo sam ručno ventove na grafi jer vidim da se pregrijava...
Staro 01.01.2013., 21:48   #22
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,818
/cut/
One koji nemaju više grafičku karticu pokrivenu jamstvom? One koji nemaju vremena/mogućnosti gnjaviti se sa zamjenom u garantnom roku?
Ja sam za zamjenu svoje 560Ti kojoj je počeo cviliti ventilator čekao 3 tjedna dok se nije pojavila 660OC koja joj je bila određena kao zamjena. Nije da sam nezadovoljan zamjenom samo je trebalo preživjeti 3 tjedna bez poštene grafe...
Staro 02.01.2013., 13:17   #23
poker
poker's Avatar
Lokacija: osijek
Postovi: 225
vratio se na 306,97 drivere jer ovi nisu normalni koliko griju gtx560 u WOT ide temp do 70-75 što je malo puno previše za ovaj tip igre(s driverima 306,97 ide do 60-63 max).
vide se neki pomaci u igrama ali nisu vrijedni spomena i nesnosne buke od venta grafe
Staro 02.01.2013., 17:22   #24
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,544
Ja sam lijepo rekao da kure grafu ko popizdili, pa kad meni s accelerom 480ka dodje na 68 c , a prije je bilo 55.
Staro 02.01.2013., 18:25   #25
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,714
E da znaš da bome jesi. Svaka ti dala.
Staro 02.01.2013., 22:12   #26
RePlaY
RePlaY's Avatar
Datum registracije: Mar 2009
Lokacija: Kaštela
Postovi: 93
Dali se razlikuju išta ovi oficijalni od onih beta drivera da ne skidam bezveze?
RePlaY je offline   Reply With Quote
Staro 02.01.2013., 22:36   #27
Sinac
Sinac's Avatar
Postovi: 2,818
Autor RePlaY Pregled postova
Da li se razlikuju išta ovi oficijalni od onih beta drivera da ne skidam bez veze?
Neki se gotovo i ne razlikuju s napomenom da su u oficijalnim ispravljeni svi eventualni bugovi koji postoje u beta drajverima. Moja preporuka je da se ipak stave zadnji oficijalni makar već 5-6 verzija beta drajvera radi bez ikakvih problema.
Staro 02.01.2013., 22:37   #28
windfucker
Autor poker Pregled postova
Ovi driveri rade nevjerovatno dobro sa WOT-om na mome laptopu, ne znam jesu li WG-ovci šta patchirali u međuvremenu, no dok se na 660ti pomak gotovo i ne zamjeti, na 525m, ali i 560ti, te 460-tki (imam WOT na svim konfama ) pomaka itekako ima.
Čini mi se što je grafa nazivno slabija da je pomak veći, ova iz laptopa je prije išla max. na 40-45fps, sada poteže i do 70-80fps sa istim postavkama- nisam mogao vjerovati koliko igra lakše radi, pa to je skoro duplo za max.fps (avg ipak nešto manje, no opet- razlika je "nebo-zemlja").
Ali, istina je- grafa na laptopu potegne sada do70-75C, prije je bilo max.65C što sam ja zapamtio, i utilizacija GPU-a je prilično konstantnija (nema toliko oscilacija u grafu Afterburnera kao prije).
Ma, odlično!
OT: 660ti niti sa novim driverima ne dostiže 7950 u ovome naslovu.
Staro 03.01.2013., 02:40   #29
poker
poker's Avatar
Lokacija: osijek
Postovi: 225
ako misliš na pomake tipa malo blješti više serem im se u čarapu i njihove nove drivere- s mojom 560gs ima nešto pomaka u fps-ima u WOT ali nije nešto pretjerano moje skromno mišljenje da radi pomaka fps s 60 na 75 se ne isplati stavljati ove drivere jer ima da popizdiš od buke venta na grafi.
Zadnje izmijenjeno od: poker. 03.01.2013. u 02:41. Razlog: dodatak
Staro 03.01.2013., 02:41   #30
poker
poker's Avatar
Lokacija: osijek
Postovi: 225
XULOS hvala bio si 100% u pravu ne vrijede ovi driveri niš
