Staro 23.11.2012., 15:13   #631
.Delboy
.Delboy's Avatar
Lokacija: hr
Postovi: 755
Bug je do dsl fw-a, pokreni u konzoli:
/sbin/dsl_cpe_control -f /lib/firmware/ltq-dsl-fw-b-danube.bin
Staro 23.11.2012., 23:11   #632
madone
Datum registracije: May 2012
Postovi: 11
Autor .Delboy Pregled postova
baca:
Device /dev/dsl_cpe_api open failed!
Probao i br2684ctl_2.5.2-4_lantiq.ipk, isto se ponaša- ne diže dsl.
U programs i startu ima br2684.
Očigledno ću morati pričekati neku novu verziju softa (ovo više iziskuje previše vremena).
madone je offline   Reply With Quote
Staro 24.11.2012., 00:19   #633
foo-fighter
foo-fighter's Avatar
Datum registracije: Mar 2010
Postovi: 8
Kopam vec dva dana po original fw routera, i nisam nasao password za voip.
firebug-om dodjem do voip password linije, u code upisem "text" umjesto "password" i pokaze mi postpass slova.
Kak doci do pass-a za voip.
foo-fighter je offline   Reply With Quote
Staro 24.11.2012., 00:33   #634
Postovi: 23,571
Pogledaj drugu temu o SX - u, odvrti decrypt konfiga i vidi šta si dobio.
Staro 24.11.2012., 01:39   #635
.Delboy
.Delboy's Avatar
Lokacija: hr
Postovi: 755
Autor madone Pregled postova
baca:
Probaj ovu komandu:
Code:
/sbin/dsl_cpe_control -i00_00_00_00_00_04_00_00 -n /sbin/dsl_notify.sh -f /lib/firmware/ltq-dsl-fw-b-danube.bin
Staro 24.11.2012., 16:24   #636
madone
Postovi: 11
Probaj ovu komandu:
Code:
nula bodova
root@OpenWrt:~# /sbin/dsl_cpe_control -i00_00_00_00_00_04_00_00 -n /sbin/dsl_not
DSL_CPE: using script notification file - /sbin/dsl_notify.sh
DSL_CPE: using 1st firmware file - /lib/firmware/ltq-dsl-fw-b-danube.bin
DSL_CPE: Device /dev/dsl_cpe_api opened successfully
DSL_CPE: Could not unmask event(18) for device 0 (0)!
DSL_CPE: Already initialized - ignoring '-i' option!
^CDSL_CPE: terminated
EventHandler: exit(0)
DSL_CPE: User Thread Shutdown - no responce
DSL_CPE: CLI interface of DSL CPE API terminated.
DSL_CPE: Goodbye from DSL CPE API CLI interface
Sep 8 16:00:27 OpenWrt daemon.info pppd[6069]: Plugin rp-pppoe.so loaded.
Sep 8 16:00:27 OpenWrt daemon.info pppd[6069]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.5
Sep 8 16:00:27 OpenWrt daemon.notice pppd[6069]: pppd 2.4.5 started by root, uid 0
Sep 8 16:00:42 OpenWrt daemon.warn pppd[6069]: Timeout waiting for PADO packets
Sep 8 16:00:42 OpenWrt daemon.err pppd[6069]: Unable to complete PPPoE Discovery
Sep 8 16:00:42 OpenWrt daemon.info pppd[6069]: Exit.
Staro 24.11.2012., 18:08   #637
Dac
Dac's Avatar
Lokacija: Bjelovar
Postovi: 672
Autor vr5h0 Pregled postova
Trunk image (kernel 3.3.8) s usb patchom:
http://rghost.net/41714057
ukljuceni paketi poput usb-printer, usb-storage, pptp, ddns...
ali kasnim par dana i eto nevolje... jučer je izgleda izašla nova verzija sa kernelom 3.3.8-1, novi svi paketi, ne da instalirati
Code:
Collected errors:
 * satisfy_dependencies_for: Cannot satisfy the following dependencies for mpd-full:
 *      kernel (= 3.3.8-1-60e53801fe89514f7dfb2e227ef0784b) *
 * opkg_install_cmd: Cannot install package mpd.
Dac je offline   Reply With Quote
Staro 24.11.2012., 22:16   #638
.Delboy
.Delboy's Avatar
Lokacija: hr
Postovi: 755
nula bodova
Daj ga za sad pokreni u backgroundu dk se ne rijesi to:
/sbin/dsl_cpe_control -i00_00_00_00_00_04_00_00 -n /sbin/dsl_notify.sh -f /lib/firmware/ltq-dsl-fw-b-danube.bin &
Staro 25.11.2012., 03:02   #639
madone
Postovi: 11
Radi!!
Staro 29.11.2012., 22:02   #640
Dac
Dac's Avatar
Lokacija: Bjelovar
Postovi: 672
http://downloads.openwrt.org/attitud...lantiq/danube/
Nema USB patch, i dalje ima segmentation faultove
Staro 29.11.2012., 22:38   #641
.Delboy
.Delboy's Avatar
Lokacija: hr
Postovi: 755
Buidlati ću ja img za tu verziju, a seg. fault je jer vuče pakete iz trunk umjesto iz rc1
Staro 29.11.2012., 23:33   #642
Dac
Dac's Avatar
Lokacija: Bjelovar
Postovi: 672
Pričekat ću onda
Ali dobra je putanja
Staro 02.12.2012., 22:40   #643
smoodge
Datum registracije: Jun 2012
Lokacija: Virka
Postovi: 8
može pomoć, netko?
imao sam owrt ver. 3.2.nešt i sve je radilo ok dok danas nisam stavio rc1
http://downloads.openwrt.org/attitud...squashfs.image
sad mi više ništa ne radi, web server, neće se spojit na net, ali mogu se logirat preko puttya sa ssh protokolom..
kako da mu stavim staru verziju ili bilo šta drugo samo da proradi?
smoodge je offline   Reply With Quote
Staro 03.12.2012., 09:46   #644
Dac
Dac's Avatar
Lokacija: Bjelovar
Postovi: 672
Sad moraš instalirati, ima samo osnove. Ako radi SSH znači da si prošao ovo http://wiki.openwrt.org/doc/howto/firstlogin ? Web sučelje je luci, ne znam što ti još treba http://wiki.openwrt.org/doc/techref/opkg
Mrežne postavke koje si imao zaboravi, moraš ponovo sve konfigurirati
Staro 03.12.2012., 14:54   #645
tintin
tintin's Avatar
Lokacija: negdje
Postovi: 1,798
Imam jedan sx763...
FW je 4.3.52.11.310
Što je bolje staviti u njega openwrt ili dd-wrt.
Koje mogučnosti nudi jedan, a koje drugi?
tintin je online   Reply With Quote
Staro 04.12.2012., 00:26   #646
OMEGA SPLIT
OMEGA SPLIT's Avatar
Datum registracije: Dec 2012
Postovi: 29
Evo da pozdravim sve ovde prisutne na forumu i pošto sam ovde novi i imam također ovaj ruter siemensov gigaset sx 763 i ubacija san u njega DD-WRT soft ,i sve je ok,ali naišao san na noviju verziju Dd-a i pokušao sam ubaciti ali mi više neće nikako da fleša tj da mi ubaci niti jedan firmware....u čemu je kvaka??Nadam se da će mi netko pomoći dati koji link i pobliže pojasniti kako da to srihtam....
Unaprid se zahvaljujem na svakoj pomoći!!!
OMEGA SPLIT je offline   Reply With Quote
Staro 04.12.2012., 21:29   #647
pajoliki
Lokacija: tu
Postovi: 2
Može li se na openwrt ili dd-wrt modificirani Siemens SX763 instalirati oscam ili cccam?
pajoliki je offline   Reply With Quote
Staro 05.12.2012., 21:02   #648
smoodge
Lokacija: Virka
Postovi: 8
Autor Dac Pregled postova
nisam prošao firstlogin, password je ostao od stare verzije.. nemam pojma kak, sad nije ni bitno..
ne mogu instalirat luci jer mi je kriva adresa repozitorija..
kako da promijenim adresu repoa u opkg.conf?
Staro 05.12.2012., 22:53   #649
.Delboy
.Delboy's Avatar
Lokacija: hr
Postovi: 755
Staro 05.12.2012., 23:42   #650
tintin
tintin's Avatar
Lokacija: negdje
Postovi: 1,798
1. Prvo je potrebno skinuti modificirani secondary_boot.img i onda otići u firmware upgrade sekciju i ubaciti ga kao i svaki drugi firmware.
Code:
Secondary_boot.img - link za download OVDJE
Nakon šta ste ubacili novi secondary, ruter će se rebootat i više neće biti moguće bootat originalni fw. (vidi napomenu 1)
2. Ukoliko već nije, namjestite si ip adresu mrežnog interfacea na:
Code:
ip: 192.168.1.16
subnet mask: 255.255.255.0
default gateway: 192.168.1.1
dns server: 192.168.1.1
(ove postavke su ujedino i defaultne postavke za mrezu u openwrt-u i dd-wrt-u)
3. Nakon šta se router rebootao, pošto jos nema openwrt ili dd-wrt firmwarea u ruteru automatski će se upaliti web server od novo ubaćenog secondary bootloadera na ip adresi 192.168.1.1
4. Uđite u web server i odaberite koji img želite flashnut (vidi niže) i sad saćekajte par minuta dok se router ne reboota.
Nakon reboota treba nekih cca 30 sekundi da se izboota i onda bi se trebalo moći pristupiti openwrt ili dd-wrt web configu na ip adresi 192.168.1.1
Openwrt Firmware-ovi:
(kako namjestiti annex procitaj u napomeni 2)
Annex A i B - osnovni img:
Code:
Download OVDJE
Ovaj dio iznad sam napravio i ruter se normalno boota.
Moram li napraviti ovo ispod ili ne?
Openwrt Firmware za ubacivanje novog secondary ukoliko je netko već ubacio onaj stari koji boota sa krivog mjesta u flashu:
Code:
Download OVDJE
Nakon šta se boota openwrt, skinite program WinSCP i zatim se spojite na router sa scp protokolom, prebacite u /tmp folder rutera secondary_boot.img sa gornjeg linka i izvrsite komandu:
Code:
mtd write /tmp/secondary_boot.img secondary_boot
i nakon restarta vrijedi tutorial tocka 2 nadalje.
Nakon što namjestim Annex što (i gdje) trebam napraviti da proradi wlan i da se mogu spojiti na net?
Staro 06.12.2012., 00:47   #651
alengrosevic
alengrosevic's Avatar
Postovi: 3,781
ima li novi DD-WRT s kojim radi wireless na novijim uređajima? vidim da je openwrt izašao s funkcionalnim wirelessom, no nisam vidio nigdje za DD-WRT.
Thnx!
EDIT: @Friday: noviji uređaji imaju problema s WLAN-om, ima vec opisan taj problem na temi, potrazi malo. Zato je i gore postavljen link sa Open-WRT-om koji podržava te novije uređaje.
Zadnje izmijenjeno od: alengrosevic. 08.12.2012. u 00:57.
alengrosevic je online   Reply With Quote
Staro 07.12.2012., 10:10   #652
Friday
Proktolog
Lokacija: Dublin
Postovi: 287
Kakvi su to problemi sa WLAN-om? Ja imam 2 uređaja sa dvije različite verzije ddwrt-a (najstarija i najnovija) i radi mi perfektno na oba...
Freak Show Inc.
Friday je offline   Reply With Quote
Staro 07.12.2012., 19:53   #653
sljaka
Postovi: 2
Autor sljaka Pregled postova
SX 763 fleshan sa Openwrt firmware-om za voip iz prvog posta. Sve uredno radi.
Trebao bi složiti VoIP preko bilo WAN bilo LAN porta, ali svi pokušaji da to napravim bili su uzaludni.
Kako složiti VoIP i/ili ostale postavke da radi preko WAN ili LAN porta (svejedno), a ne preko DSL porta?
SX763 je preko WAN porta spojen na lokalnu mrežu koja ima spoj na Metronetovu optiku i preko nje spoj na Internet i VPN sa drugom mrežom u drugom gradu. VoIP centrala postavljena je u drugoj mreži, ali je zbog VPN moguće pristupiti kao lokalnoj centrali, a moguć je i pristup internetom.
SX763 je ostao od T-coma i trebao bi biti iskorišten da se mogu DECT telefoni spojiti na VoIP.
Ima li netko ideju kako to izvesti?
Sve ostalo, lan, wi-fi ... nije uopće bitno, ako radi odlično, ako ne ni ne treba.
Ima li itko ideju kako ovo riješiti?
sljaka je offline   Reply With Quote
Staro 08.12.2012., 10:59   #654
tintin
tintin's Avatar
Lokacija: negdje
Postovi: 1,798
Stavio sam na ruter DD-WRT...
Jel se može preko njega raditi torrent, neki server...
Uglavnom, nemam pojma što takav ruter sad sve može.
Staro 09.12.2012., 00:37   #655
vr5h0
Lokacija: os
Postovi: 39
Evo vam zadnji revision OpenWrt-a(r34578):
http://vrsho.com/openwrt/sx763/openw...squashfs.image
Napravljen i repository da mozete instalirat sve pakete: http://vrsho.com/openwrt/sx763/packages
Nakon flashanja bi morao bit ovaj moj repo u /etc/opkg.conf no ako nije, stavite. Nadam se da sam kompajlo sve kernel module.
EDIT: zaboravio ubacit gspca video support u pakete, bit ce uskoro.
Zadnje izmijenjeno od: vr5h0. 09.12.2012. u 00:58.
vr5h0 je offline   Reply With Quote
Staro 09.12.2012., 12:13   #656
Friday
Proktolog
Lokacija: Dublin
Postovi: 287
Jel netko uspio upogoniti transmission bez problema? Pričalo se da nešto ne radi baš najbolje...
Freak Show Inc.
Staro 09.12.2012., 13:54   #657
Dac
Dac's Avatar
Lokacija: Bjelovar
Postovi: 672
@vr5h0 - :top:
Ali nešto ne valja:
Code:
root@OpenWrt:~# opkg install kmod-usb-ohci
Installing kmod-usb-ohci (3.3.8-1) to root...
Downloading http://vrsho.com/openwrt/sx763/packages/kmod-usb-ohci_3.3.8-1_lantiq.ipk.
Collected errors:
 * opkg_install_pkg: Package kmod-usb-ohci md5sum mismatch. Either the opkg or the package index are corrupt. Try 'opkg update'.
 * opkg_install_cmd: Cannot install package kmod-usb-ohci
opkg update napravi normalno.
Tebi nije ništa javljao?
Staro 09.12.2012., 18:58   #658
vr5h0
Lokacija: os
Postovi: 39
@vr5h0 - :top:
Ali nešto ne valja:
Code:
Collected errors:
Ma ubacivao sam sad zadnje gspca module i u medjuvremenu je izasao novi kernel pa sam sjebo package-index.
Al evo, sređeno. Samo ponovno skini firmware i flashaj ruter. Reci ako nesto nece radit.
Staro 09.12.2012., 19:12   #659
smoodge
Lokacija: Virka
Postovi: 8
Autor smoodge Pregled postova
uspio sam ga spojit na inet preko drugog routera, instalirao luci, postavio sve šta treba i neće se ulogirat.. adsl je syncan, annex a je postavljen..
šta još treba postavit i dali treba još nešto instalirat od paketa?
Staro 09.12.2012., 19:13   #660
smoodge
Lokacija: Virka
Postovi: 8
šta si sve stavio od modula i paketa?
