Staro 18.11.2012., 19:57   #721
Flood
Into my head it goes
Flood's Avatar
Datum registracije: Feb 2004
Lokacija: space de luxe
Postovi: 778
Bravo Ferrari! The Seals
Staro 18.11.2012., 21:16   #722
nino
nino's Avatar
Postovi: 12,612
42. krug
Staro 18.11.2012., 21:41   #723
Blue_Fatal1ty
Blue_Fatal1ty's Avatar
Lokacija: Čazma
Postovi: 1,728
To je to prava trka!
Bravo Hamilton! Jedva čekam zadnju trku! Polažem sve nade u Alonsa!
Staro 18.11.2012., 21:43   #724
Nacki
Faktor nesreće
Nacki's Avatar
Datum registracije: Nov 2011
Lokacija: Sesvete, Zagreb
Postovi: 219
Hamilton - svaka cast i konacno da mu nesto nije krepalo.
Vettel je opet pokazao svoju placljivu stranu.
Alosno, kad se zanemari ona igrica s Massinim mjenjacem - odlicna utrka.
Massa, isto lijepa utrka.
Nisam ocekivao ovakvu utrku.
Proc: AMD Trinity Athlon 750K + Scythe Katana 3
Ploca: Asrock FM2A85X Extreme 4
RAM: 2*2gb DDR3 1333 Kingston
Grafa: Sapphire Radeon HD6850
Hard: 2*Hitachi 500gb (raid 0), 2*Hitachi 500gb (raid 1), WD blue 640gb
Optika: TSST DVD-RW
Napajanje: Seasonic ssr-650rm
Kućiste: Fractal Design Define R3
Monitor: 2*Samsung Sync Master 923NW
OS: Windows 7 Enterprise x64
Proc: Intel Pentium dual core e5800 + AC Freezer 7 pro rev. 2
Ploca: Asrock G31M-S
RAM: 2*2gb DDR2 Elpida
Grafa: Asus Radeon X1600pro
Hard: Hitachi 500gb
Optika: Benq DVD-RW
Napajanje: Fortron 400-60THN-P
Kućište: HP
Monitor: LG L1919S
Proc:Intel Pentium dual core e5800 + Scythe Shuriken
Grafa: Sapphire radeon HD4850 + Accelero S1 + Xilence 120mm
Hard: Hitachi 500gb
Optika: NEC DVD-RW + LG DVD-ROM
Napajanje: Fortron 350PNF
Kućište: Fujitsu siemens
Monitor: Samsung SyncMaster 740N
Proc: Intel Pentium 4 640 + Zerotherm
Ploca: Epox 5EGMI
RAM: 2*1gb DDR Kingmax
Grafa: Club 3D Radeon X550
Hard: Maxtor 160gb, Maxtor 80gb
Optika: LG DVD-RW
Napajanje: Seasonic ss-250sfd
Monitor: HP 1740
OS: Windows XP pro, SP3
Toshiba Satellite L300-21W
Proc: Intel Pentium dual core T3400
RAM: 2*2gb DDR2 Samsung
Grafa: Integrated Intel GMA4500M
Hard: WD blue 320gb
Optika: TSST DVD-RW
Ekran: 15.4''
Toshiba Satellice U840-10Q
Proc: Intel Core i5 3317U
RAM: 2*2gb DDR3 Samsung
Grafa: Intel HD4000
Grafa: AMD Radeon HD7550M
Hard: Hitachi 500gb
SSD: San disk 32gb
Ekran: 14''
Nacki je offline   Reply With Quote
Staro 18.11.2012., 21:47   #725
Michel
Michel's Avatar
Lokacija: Dubrovnik
Postovi: 1,287
Svaka čast Hamiltonu, a od Vettela nisam očekivao onakve ispade.
Da silly overtake hahahaahha a što ga je išo blockat onako kad je vidio da ga dobiva garant. Ma da ga je barem zakačio , i ja polažem nade sada u Alonsa i neki nevjerojatni splet okolnosti.....
Michel je offline   Reply With Quote
Staro 18.11.2012., 21:53   #726
Momir
Momir's Avatar
Postovi: 1,011
Odlicna utrka, nije ni gumbic bio los.
Momir je offline   Reply With Quote
Staro 18.11.2012., 21:54   #727
draksa
Postovi: 333
Alonso ima realno sanse u Brazilu samo ako se dogodi utrka tipa Kine, tj da padne kisa
A ovo za mjenjac, mogu radit sta oce. Vidli smo Kimija na startu danas nije imo sanse pored ovih na drugoj strani, Alonsu trebaju bodovi tako da je to po meni opravdano. Nitko nije ocekivo od Masse u utrci da napravi puno
draksa je offline   Reply With Quote
Staro 18.11.2012., 22:25   #728
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,268
Odlicna utrka a staza je cini se demantirala sve skeptike i dezurne pljuvace koji su pricali da ce biti dosadna . Cini se kao da su ameri uspjeli asfaltirait sa nekim "staklenim" asfaltom pa se klize ko sam vrag .
Lewis je online   Reply With Quote
Staro 18.11.2012., 22:30   #729
Burko
Osobni opis - pitaj me
Burko's Avatar
Postovi: 2,317
meni je iskreno bila dosta dosadna utrka . bila je ok, ali nista extra, bilo je dva-tri bas prava poteza, ostalo je DRS radio...... plus sto se vidjelo gdje je mclarenu blokada, ono, fali jos ~10km/h od ostatka.........
ovo sto se mjenjaca tice, jebiga. prolilo se ocito i ovako sline, iako razumijem druga brku. manje-vise kada je i bila greska hamiltona (a boze moj, koliko je imao bliskih susreta prosle sezone), suti. NHF, ali je istina. ovo sranje (sto jebiga jest, nimalo sportski potez, ali ocito nema posljedica), govnari, pljucanje itd. iskreno, mene ne tangira uopce, jer ponavljam - cist' sumnjam da ce alonso osvojiti prvenstvo. onih dva-tri sudara sto je imao ce mu uzeti titulu, i ok. hamilton opet dobra utrka (kao i prosla, sto sam rekao da mi je zao sto mu je riknuo bolid), jedino mi je malo lotus podbacio. i nemam pojma sta je sa sauberom, kobayashi prvenstveno........ nevazno.
veselim se brazilu. tamo tek ce biti svacega. prosla utrka mi je bila gro puta bolje od ove danas, mislim da ce i brazil biti bolji. jedina svjetla tocka (meni, kao navijacu ferrarija) je massa koji je itekako proradio posljednjih par utrka, ipak ce mozda biti nesto od njega. ispada malo cudno, ali je odmah tu iza alonsa, tako da ocito nije bilo do nicega nego do vozaca.
Staro 18.11.2012., 22:34   #730
draksa
Postovi: 333
Što je padala kiša u Kini ove godine??? ja bi rekao da nije.
Sry pomjeso sam Kinu i Maleziju
Staro 19.11.2012., 23:50   #731
Burko
Burko's Avatar
Postovi: 2,317
ma kakvi, jos prije tri-cetiri utrke sam rekao da ode alonsu prvenstvno. nema, RB je proradio kako je klao i prosle sezone, hamilton je realno jedini koji moze konkurirati, jer su se mclaren i RB stvarno popravili nakon one mjesecne stane za vrijeme godisnjih. dok je ferrari ostao isti, lotus pao, mercedes isto tako........
sto se utrke tice, moj dojam je bio takav. mozda sam se krivo izrazio, mozda sam trebao reci "bilo je kud i kamo zanimljivijih i bogatijih utrka ove sezone", eto. ja moram, ja znam to, biti posebna kobasa .
Staro 20.11.2012., 18:59   #732
Nacki
Faktor nesreće
Nacki's Avatar
Postovi: 219
Je li ikad u Brazilu bila normalna utrka?
svaki put nekaj ludo i nezaboravno
e sad, velika je lutrija tko ce biti prvak iz vise razloga
1. RB-ova nepouzdanost
2. Kisa
3. kvale i start
4. kako ce se tko ustat na koju nogu (tu mislim na sve vozace na gridu, pa tako i na jadnog Karthikeyana)
Ja kao Ferrarijevac se ne nadam naslovu jos od Alonsovog sudara s Kimijem u Suzuki, tog trena je naslov izgubljen. Alonso moze do naslova samo ako nekaj Vettelu krepa ili se isti razleti negdje na stazi.
Imam neki filing da Ferrari prati prokletstvo otkad je otjero Kimija. A sad kad sam se dotaknul Kimija, biti ce vesela iduca sezona na trzistu vozaca, upraznit ce se mnoga mjesta, a neki mozda dobiju izgon ili mozda sami odu i prije kraja sezone.
Optika: TSST DVD-RW
Hard: Hitachi 500gb
Optika: Benq DVD-RW
Kućište: HP
Monitor: LG L1919S
Hard: Hitachi 500gb
Ploca: Epox 5EGMI
Optika: LG DVD-RW
Monitor: HP 1740
Hard: WD blue 320gb
Optika: TSST DVD-RW
Ekran: 15.4''
Grafa: Intel HD4000
Hard: Hitachi 500gb
SSD: San disk 32gb
Ekran: 14''
Staro 20.11.2012., 21:00   #733
aski
Je suis Schumi
aski's Avatar
Postovi: 1,524
Red Bull ce tj. Renault u Brazilu koristiti druge, pouzdanije alternatore, tako da nista od kvara. Kise nece biti, pogledaj weather forecast, to je manje vise tocno.
Kvale i start - slazem se. Vettel prvi, Webber drugi, Alonso valjda 5-6-7...
Alonso ce mozda u utrci dogurati do prva tri koliko mu i treba u slucaju da Vettel utrku zavrsi prije kockaste zastave, u sto cisto sumnjam.
Di sam stao?
Staro 20.11.2012., 22:49   #734
Burko
Burko's Avatar
Postovi: 2,317
u prvom zavoju massa nabije gas do kraja i slucajno pobere vettela.......... brijem da bi bio do 65-e godine zivota vozac ferrarija .
brko, ja jesam navijac ferrarija, ali kako sam rekao nekoliko puta - realist. zato se volim uvuci u polukonflikt recimo sa tobom, kada gledas strikno protiv nekoga, a zazmiris malo na proslost. meni ne smeta, ali volim napomenuti, jer gledam najcesce sa svih strana.
zato sam i napisao da se uopce ne nadam naslovu. da si me pitao prije godisnjih odmora bi ti rekao da je 95% njegov naslov, ovako mu nebi dao niti 10%. ne kvare se bolidi kao prije 10 godina (i to mi je cak iskreno i zao, generalno), ganjaju se kroz sve utrke i nema problematike. ovo sto je webberu bilo, sasvim nevazno...... stvarno bi vettel morao imati peh da mu krepa zadnju utrku nesto, prije ce se to dogoditi na talijanskom auto-proizvodima.
Staro 21.11.2012., 18:16   #735
Nacki
Faktor nesreće
Nacki's Avatar
Postovi: 219
Autor Burko Pregled postova
ovogodisnji Ferrari poluproizvod je prokleto pouzdana masina. Mislim da imaju 1 promjenu mjenjaca - i to je ovaj Massin mjenjac koji zapravo i nije zamjenjen
Ne sjecam se nekog kvara ove godine osim onog u Monzi u kvalama.
Dok se RB nije iskazal ni na jednom polju pouzdanosti, osim ciste brzine. Krepalavalo im je svasta, uglavnom KERS i alternatori. A da ne spominjam da na ovu utrku u Brazilu Ferrari (Alonso) dolazi s mozda cak novim motorima!, a RB ce se morat zadovoljit nekim starim par utrka. Nije da su motori nepouzdani i da nemogu odvozit vise od 2 utrke, ali mogao bi biti problem.
Optika: TSST DVD-RW
Hard: Hitachi 500gb
Optika: Benq DVD-RW
Kućište: HP
Monitor: LG L1919S
Hard: Hitachi 500gb
Ploca: Epox 5EGMI
Optika: LG DVD-RW
Monitor: HP 1740
Hard: WD blue 320gb
Optika: TSST DVD-RW
Ekran: 15.4''
Grafa: Intel HD4000
Hard: Hitachi 500gb
SSD: San disk 32gb
Ekran: 14''
Staro 23.11.2012., 18:43   #736
kian
kian's Avatar
Datum registracije: Oct 2001
Lokacija: Velika Gorica
Postovi: 600
Zadnje izmijenjeno od: kian. 23.11.2012. u 18:50.
Staro 24.11.2012., 09:00   #737
The_Void
Postovi: 108
Coca cola potpisala sponzorski ugovor sa lotusom, mogli bi biti extra dobri sljedece sezone s tim financijskim boostom. Ne mogu docekati nedjelju i utrku, nadam se da ce biti kise (ne vjerujem bas weath forcastu grijesili su par puta ove sezone najavljivali kisu 100% pa nista od nje, sad na sluzbenoj f1 stranici stoji da ce biti kisa) i onda je sve moguce. Navijam za ferrari i alonsa tako da bih volio da on osvoji ali nece mi biti strasno zao i ako vettel pobijedi, obojica su zasluzili ovo prvenstvo. Mada mislim da je karma na alonsovoj strani nakon zadnje utrke prosle sezone
Hamilton je strasan vozac al mi je opet njegova odluka da predje u mercedes sto nasi ljudi kazu s konja na magarca. Jest ga malo mclaren zezao ove sezone ali je i on njih prosle, kad se pricalo o prelasku mislio sam nema sanse da ode ipak njega mclaren financira od kako je bio mali, britanska ekipa koja se stalno bori za naslov itd itd. Ne znam je li presudio novac (nekako sumnjam) ili mu je mercedes obecao status prvog vozaca i da ce citav tim njega stavljat na prvom mjestu -jedino sto mu mclaren nije nudio
Sudeci po free practiceu kvalifikacije mislim da ce zavrsiti kao i proslu utrku, mozda alonso popravi malo startno mjesto. Masa se konacno digao u formi pravi ista vremena kao alonso, izgleda da ga je novi ugovor opustio pa se fokusirao na voznju
Zadnje izmijenjeno od: The_Void. 24.11.2012. u 09:05.
The_Void je offline   Reply With Quote
Staro 24.11.2012., 18:20   #738
alen.s
alen.s's Avatar
Postovi: 1,441
ontopic ; grožan opet sudar ?
offtopic ; ko je plavuša u ferarijevom boxu ?
Staro 24.11.2012., 20:26   #739
Momir
Momir's Avatar
Postovi: 1,011
Masa opet zapiso velikog alonsa.
Mclarenovci naprijed, ajmo za kraj po dvostruku pobjedu
Nisam gledao kvalifikacije, pa iskreno neznam sta se izdogadjalo
Staro 24.11.2012., 22:00   #740
Nacki
Faktor nesreće
Nacki's Avatar
Postovi: 219
Massa ili ima brzi auto ili je opet isao u autoskolu
i mene zanima tko je plavusa, mozda Alonsova nova ljubav
evo, barem ovaj put mislim da Grosjean nije kriv
Maldonado kaznjen, Alonso skocio na 7. mjesto - da im ne gori mjesto u poretku konstruktora mislim da bi Massa mozda opet pobral novi mjenjac
Nekak mi se cini da bu sutra dobra utrka, ali bumo vidili
Optika: TSST DVD-RW
Hard: Hitachi 500gb
Optika: Benq DVD-RW
Kućište: HP
Monitor: LG L1919S
Hard: Hitachi 500gb
Ploca: Epox 5EGMI
Optika: LG DVD-RW
Monitor: HP 1740
Hard: WD blue 320gb
Optika: TSST DVD-RW
Ekran: 15.4''
Grafa: Intel HD4000
Hard: Hitachi 500gb
SSD: San disk 32gb
Ekran: 14''
Staro 25.11.2012., 17:04   #741
nino
nino's Avatar
Postovi: 12,612
Fetl
Alonso
Staro 25.11.2012., 17:04   #742
Burko
Burko's Avatar
Postovi: 2,317
ima Boga.........
Staro 25.11.2012., 17:04   #743
ShanTech
Datum registracije: Apr 2011
Postovi: 3,784
TOOOOOOOOO!!!!
Staro 25.11.2012., 17:10   #744
nino
nino's Avatar
Postovi: 12,612
To Massa!!
Kisa pocinje
Staro 25.11.2012., 17:16   #745
Burko
Burko's Avatar
Postovi: 2,317
sve mi se nekako cini da treba vettel jos neko sranje da izgubi prvenstvo, eto njega skoro iza kolone iza masse.......... ajmo kisa, ovo ce biti trka za pamcenje .
Staro 25.11.2012., 17:27   #746
Postovi: 8,212
Hahaha, kako će Vettel dobit kaznu za obilaženje pod žutom Koji kreten
Staro 25.11.2012., 17:31   #747
Nacki
Faktor nesreće
Nacki's Avatar
Postovi: 219
Autor Pupo Pregled postova
nece
Optika: TSST DVD-RW
Hard: Hitachi 500gb
Optika: Benq DVD-RW
Kućište: HP
Monitor: LG L1919S
Hard: Hitachi 500gb
Ploca: Epox 5EGMI
Optika: LG DVD-RW
Monitor: HP 1740
Hard: WD blue 320gb
Optika: TSST DVD-RW
Ekran: 15.4''
Grafa: Intel HD4000
Hard: Hitachi 500gb
SSD: San disk 32gb
Ekran: 14''
Staro 25.11.2012., 17:32   #748
Roboter
Postovi: 13
Go Vettel woot
Roboter je offline   Reply With Quote
Staro 25.11.2012., 17:32   #749
nino
nino's Avatar
Postovi: 12,612
Ok je sve to, ali nemogu vjerovat kako im se bolidi micu sa trkace putanje.
Staro 25.11.2012., 18:21   #750
Nacki
Faktor nesreće
Nacki's Avatar
Postovi: 219
Kimi istrazuje prostor oko staze
Optika: TSST DVD-RW
Hard: Hitachi 500gb
Optika: Benq DVD-RW
Kućište: HP
Monitor: LG L1919S
Hard: Hitachi 500gb
Ploca: Epox 5EGMI
Optika: LG DVD-RW
Monitor: HP 1740
Hard: WD blue 320gb
Optika: TSST DVD-RW
Ekran: 15.4''
Grafa: Intel HD4000
Hard: Hitachi 500gb
SSD: San disk 32gb
Ekran: 14''
