#631 |
Lokacija: hr
Postovi: 755
Bug je do dsl fw-a, pokreni u konzoli: /sbin/dsl_cpe_control -f /lib/firmware/ltq-dsl-fw-b-danube.bin |
#632 | |
Datum registracije: May 2012
Postovi: 11
Device /dev/dsl_cpe_api open failed! Probao i br2684ctl_2.5.2-4_lantiq.ipk, isto se ponaša- ne diže dsl. U programs i startu ima br2684. Očigledno ću morati pričekati neku novu verziju softa (ovo više iziskuje previše vremena). |
#633 |
Datum registracije: Mar 2010
Postovi: 8
Kopam vec dva dana po original fw routera, i nisam nasao password za voip. firebug-om dodjem do voip password linije, u code upisem "text" umjesto "password" i pokaze mi postpass slova. Kak doci do pass-a za voip. |
#634 |
Postovi: 23,526
Pogledaj drugu temu o SX - u, odvrti decrypt konfiga i vidi šta si dobio. |
#635 | |
Lokacija: hr
Postovi: 755
Code:
/sbin/dsl_cpe_control -i00_00_00_00_00_04_00_00 -n /sbin/dsl_notify.sh -f /lib/firmware/ltq-dsl-fw-b-danube.bin |
#636 | |
Postovi: 11
![]() root@OpenWrt:~# /sbin/dsl_cpe_control -i00_00_00_00_00_04_00_00 -n /sbin/dsl_not ify.sh -f /lib/firmware/ltq-dsl-fw-b-danube.bin DSL_CPE: using script notification file - /sbin/dsl_notify.sh DSL_CPE: using 1st firmware file - /lib/firmware/ltq-dsl-fw-b-danube.bin DSL_CPE: Device /dev/dsl_cpe_api opened successfully DSL_CPE: Could not unmask event(18) for device 0 (0)! DSL_CPE: Already initialized - ignoring '-i' option! ^CDSL_CPE: terminated EventHandler: exit(0) DSL_CPE: User Thread Shutdown DSL_CPE: User Thread Shutdown DSL_CPE: CLI interface of DSL CPE API terminated. DSL_CPE: Goodbye from DSL CPE API CLI interface Sep 8 16:00:27 OpenWrt daemon.info pppd[6069]: Plugin rp-pppoe.so loaded. Sep 8 16:00:27 OpenWrt daemon.info pppd[6069]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.5 Sep 8 16:00:27 OpenWrt daemon.notice pppd[6069]: pppd 2.4.5 started by root, uid 0 Sep 8 16:00:42 OpenWrt daemon.warn pppd[6069]: Timeout waiting for PADO packets Sep 8 16:00:42 OpenWrt daemon.err pppd[6069]: Unable to complete PPPoE Discovery Sep 8 16:00:42 OpenWrt daemon.info pppd[6069]: Exit. |
#637 | |
Lokacija: Bjelovar
Postovi: 672
![]() ali kasnim par dana i eto nevolje... jučer je izgleda izašla nova verzija sa kernelom 3.3.8-1, novi svi paketi, ne da instalirati ![]() Code:
Collected errors: * satisfy_dependencies_for: Cannot satisfy the following dependencies for mpd-full: * kernel (= 3.3.8-1-60e53801fe89514f7dfb2e227ef0784b) * * opkg_install_cmd: Cannot install package mpd. |
#638 | |
Lokacija: hr
Postovi: 755
/sbin/dsl_cpe_control -i00_00_00_00_00_04_00_00 -n /sbin/dsl_notify.sh -f /lib/firmware/ltq-dsl-fw-b-danube.bin & |
#639 |
Postovi: 11
#640 |
Lokacija: Bjelovar
Postovi: 672
http://downloads.openwrt.org/attitud...lantiq/danube/ Nema USB patch, i dalje ima segmentation faultove ![]() |
#641 |
Lokacija: hr
Postovi: 755
Buidlati ću ja img za tu verziju, a seg. fault je jer vuče pakete iz trunk umjesto iz rc1 |
#643 |
Datum registracije: Jun 2012
Lokacija: Virka
Postovi: 8
može pomoć, netko? imao sam owrt ver. 3.2.nešt i sve je radilo ok dok danas nisam stavio rc1 http://downloads.openwrt.org/attitud...squashfs.image sad mi više ništa ne radi, web server, neće se spojit na net, ali mogu se logirat preko puttya sa ssh protokolom.. kako da mu stavim staru verziju ili bilo šta drugo samo da proradi? |
#644 |
Lokacija: Bjelovar
Postovi: 672
Sad moraš instalirati, ima samo osnove. Ako radi SSH znači da si prošao ovo http://wiki.openwrt.org/doc/howto/firstlogin ? Web sučelje je luci, ne znam što ti još treba http://wiki.openwrt.org/doc/techref/opkg Mrežne postavke koje si imao zaboravi, moraš ponovo sve konfigurirati |
#645 |
Lokacija: negdje
Postovi: 1,792
Imam jedan sx763... FW je 4.3.52.11.310 Što je bolje staviti u njega openwrt ili dd-wrt. Koje mogučnosti nudi jedan, a koje drugi? |
#646 |
Datum registracije: Dec 2012
Postovi: 29
Evo da pozdravim sve ovde prisutne na forumu i pošto sam ovde novi i imam također ovaj ruter siemensov gigaset sx 763 i ubacija san u njega DD-WRT soft ,i sve je ok,ali naišao san na noviju verziju Dd-a i pokušao sam ubaciti ali mi više neće nikako da fleša tj da mi ubaci niti jedan firmware....u čemu je kvaka??Nadam se da će mi netko pomoći dati koji link i pobliže pojasniti kako da to srihtam.... Unaprid se zahvaljujem na svakoj pomoći!!! |
#647 |
Lokacija: tu
Postovi: 2
Može li se na openwrt ili dd-wrt modificirani Siemens SX763 instalirati oscam ili cccam? |
#648 | |
Lokacija: Virka
Postovi: 8
nisam prošao firstlogin, password je ostao od stare verzije.. nemam pojma kak, sad nije ni bitno.. ne mogu instalirat luci jer mi je kriva adresa repozitorija.. kako da promijenim adresu repoa u opkg.conf? |
#649 |
Lokacija: hr
Postovi: 755
#650 | ||
Lokacija: negdje
Postovi: 1,792
Moram li napraviti ovo ispod ili ne? Citiraj:
#651 |
Postovi: 3,775
ima li novi DD-WRT s kojim radi wireless na novijim uređajima? vidim da je openwrt izašao s funkcionalnim wirelessom, no nisam vidio nigdje za DD-WRT. Thnx! ![]() EDIT: @Friday: noviji uređaji imaju problema s WLAN-om, ima vec opisan taj problem na temi, potrazi malo. Zato je i gore postavljen link sa Open-WRT-om koji podržava te novije uređaje. Zadnje izmijenjeno od: alengrosevic. 07.12.2012. u 23:57. |
#653 | |
Postovi: 2
#654 |
Lokacija: negdje
Postovi: 1,792
Stavio sam na ruter DD-WRT... Jel se može preko njega raditi torrent, neki server... Uglavnom, nemam pojma što takav ruter sad sve može. |
#655 |
Lokacija: os
Postovi: 39
Evo vam zadnji revision OpenWrt-a(r34578): http://vrsho.com/openwrt/sx763/openw...squashfs.image Napravljen i repository da mozete instalirat sve pakete: http://vrsho.com/openwrt/sx763/packages Nakon flashanja bi morao bit ovaj moj repo u /etc/opkg.conf no ako nije, stavite. Nadam se da sam kompajlo sve kernel module. EDIT: zaboravio ubacit gspca video support u pakete, bit ce uskoro. Zadnje izmijenjeno od: vr5h0. 08.12.2012. u 23:58. |
#657 |
Lokacija: Bjelovar
Postovi: 672
@vr5h0 - :top: Ali nešto ne valja: Code:
root@OpenWrt:~# opkg install kmod-usb-ohci Installing kmod-usb-ohci (3.3.8-1) to root... Downloading http://vrsho.com/openwrt/sx763/packages/kmod-usb-ohci_3.3.8-1_lantiq.ipk. Collected errors: * opkg_install_pkg: Package kmod-usb-ohci md5sum mismatch. Either the opkg or the package index are corrupt. Try 'opkg update'. * opkg_install_cmd: Cannot install package kmod-usb-ohci ![]() Tebi nije ništa javljao? |
#658 | |
Lokacija: os
Postovi: 39
Al evo, sređeno. Samo ponovno skini firmware i flashaj ruter. Reci ako nesto nece radit. |
#659 | |
Lokacija: Virka
Postovi: 8
uspio sam ga spojit na inet preko drugog routera, instalirao luci, postavio sve šta treba i neće se ulogirat.. adsl je syncan, annex a je postavljen.. šta još treba postavit i dali treba još nešto instalirat od paketa? |
#660 | |
Lokacija: Virka
Postovi: 8
šta si sve stavio od modula i paketa? |
