Staro 21.10.2012., 19:06   #1171
Wolverine
Wolverine's Avatar
Postovi: 12,425
Budi bez brige, moći ćeš.
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 21.10.2012., 19:08   #1172
zuiko
Postovi: 456
Hvala!
zuiko je offline   Reply With Quote
Staro 21.10.2012., 19:08   #1173
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
gts 250 je sasvim dosta za Skyrim
takodjer i A4 ce moci gurati ali g630 ima ocjenu više
usporedba
tvoj sadašnji ocjena 3
A4 ocjena 5
g630 ocjena 6
Eto
Staro 21.10.2012., 19:12   #1174
zuiko
Postovi: 456
a onda ne brinem
Ocjene me ne zanimaju, bitno mi je da može lijepo gurat Skyrim. Zahtjevnije igre me ne zanimaju jer i za Skyrim tražim vrijeme pa mi baš ne ide
Zar bi gts250 mogla vrtit Skyrim uz ovo navedeno na više od 35fps uz dobre grafičke postavke na 1680x1050?
Ak to ide
Staro 21.10.2012., 21:30   #1175
zuiko
Postovi: 456
Sad sam našao neke prepiske na netu i:
It wont matter because skyrim only uses dual cores anyways,
So if u have a quad core or hexa core,
they will not preform much better then any other dual core because skyrim is based of a older engine that use dual core.
That's assuming if nothing else is running on his computer at all for the duration that he is playing. I did several tests over the weekend to gauge performance on Dual, Tri, and Quad cores. I turned off cores on my computer for each test to get frame rates in the same areas I tested. Having more than two cores certainly helps your computer avoid frequent lags whenever your OS needs to process something other than Skyrim on your processor. My average FPS with 2 cores active was between 45-50. 3 cores 50-55. 4 cores 55-57. Having more than 2 cores isn't going to increase your FPS, but it definitely smoothens it out and keeps the Min FPS closer to your average.
i još:
The 4890 is the recommended GPU and tom's showed a 5770 being able to handle skyrim on high at 1920x1080 quite well so im not sure if OCing your 4870 will help you out a ton.
http://www.tomshardware.com/review [...] 074-5.html
The CPU scaling however shows some of the slower PII being unable to give good FPS, it doesn't scale with cores much over two cores it would appear so the dual core isn't likely to be your issue but its clock speed may be.
http://www.tomshardware.com/review [...] 074-9.html
Izgleda da mi ne treba quad core nego dvije brze jezgre. Tak je bar ispalo.
EDIT:
Eto još jedan link. Izgleda da radi s četiri jezgre ali intenzivno koristi samo jednu pa mu je najvažnija brzina.
Četiri jezgre jesu bolje od dvije ali je arhitektura i brzina primarna:
http://www.techspot.com/review/467-s...nce/page7.html
Po svemu navedenom, AMD s dvije jezgre na 3,6 GHZ bi trebao zadovoljavajuće gurat Skyrim na 1680x1050. Quad bi bio bolji ali...eh, eh... po svemu što piše ne isplatimi se iznad ovog od AMD-a uzimat ništa od Phenoma ili Athlona nego ić na i3 2100 ili najslabiji A8.
HVALA SVIMA
Zadnje izmijenjeno od: zuiko. 21.10.2012. u 22:43.
Staro 22.10.2012., 07:06   #1176
darkijas
darkijas's Avatar
Postovi: 1,806
ako je istina da intelov socket 1155 uskoro ide u penziju onda ce vrlo brzo iz ducana nestati i procesori za tu platformu. Odnosno vlasnici kvalitetnih ploca sa slabijim procesorima ce za cpu upgrade morati kopati po oglasnicima u potrazi za jacim polovnjacima koji su sudeci prema dosadasnjim iskustvima najcesce precjenjeni od samih vlasnika (jer znaju da imaju rijedak primjerak) te neisplativi na kraju.
Uzmimo na primjer intelov socket 1156 neko je sigurno kupio kvalitetnu plocu i slabiji proc pa rekao-kupit cu si neki jaci za 2-3 godine. Sada umjesto u ducan po novi cpu moze otici samo do kioska po rupčiće za plakanje
darkijas je online   Reply With Quote
Staro 22.10.2012., 07:49   #1177
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Ma nece jos ici...naopako dosli ivy...prvo ce sada sb nestati i onda ce jedno vrijeme samo ib biti...ne vijerujem da ce brzo 1155 u penziju ;=)
Staro 22.10.2012., 08:49   #1178
zuiko
Postovi: 456
Bolje da nisam išao kopati
SAd me brine količina cache mamorije. A4 ima samo 1MB po jezgri.
Čini se da Skyrim voli memoriju proca.
Ima li koji proc s 1MB po jezgri da dobro gura Skyrim?
Staro 22.10.2012., 10:14   #1179
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
intel
kako ti vec jakooo dugo govorim, okani se amda i uzmi jednostavno najeftiniji G555 ili jos bolje g630 i miran si. kompliciraš bezveze, sve što trebas imas na intelu g630 koji ce gurati odlično sve igre kamo li skyrim
a ja sam mislio da si ti vec u petak narucio komp...a ponedeljak vec i ti još ni ne znaš što hoces....grrr
Staro 22.10.2012., 10:33   #1180
zuiko
Postovi: 456
Naručio sam i platio A4 FM2 na Asroc A75 s 8GB RAM-a na 1333 ali mogu još danas izmjenit proc i memoriju ako želim skuplje.
Imam još pročitat par testova pa onda odlučujem dal će ić A4 ili A8
SAd me kopka i memorija. 1600 MHz ili 1860 MHz
Staro 22.10.2012., 12:03   #1181
tiki66
tiki
tiki66's Avatar
Postovi: 2,729
Oćeš koristiti integrirani gpu na FM2? Ne? Onda ti ne treba i uzmi Intel kako su ti preporučili.
G5** i b75 ploču i uživaj.
Staro 22.10.2012., 12:09   #1182
zuiko
Postovi: 456
Razmišljam da koristim integrirani GPU dok ne nađem vremena za igranje.
Do tad bi cijene grafa mogle malo past pa...
ZAto i gledam A8.
Staro 22.10.2012., 12:42   #1183
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
sa grafickom koju imas ili integriranom na chipu sigurno dvojezgreni amd na 3.4ghz nece bit usko grlo pa ni u skajrimu iz kojeg god razloga ga stavljao kao referencu.
S tim da snaga integrirane graficke osjetno raste sa skoro svakim modelom (a ni najjaca nije bas neka sreca osim ako se igras na niskim rezolucijama), usporedno sa cijenom...
s druge strane, 5600k za 800kn i nije tako los izbor, al kad vec idemo toliko vise i vise po cjenovnom rangu, mogao si uzet i nekog postenog intela
Msi x79a GD65
Intel i7 3930k @ 4.7 1.4V
4x 4GB Kingston 1866 9-11-9
Gigabyte gtx 460 1gb
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Coolermaster Stacker 831
HP LP2065 / LG IPS231P
Windows 7 Enterprise
Trenutno nepostojeci
Staro 22.10.2012., 14:15   #1184
zuiko
Postovi: 456
Ide A8 5600, A75 MBo i 8GB RAM-a na 1600 MHz.
Vidjet ćemo što to može
Skyrim mi je referenca jer jedino to planiram igrati u idućih godinu dana.
Možda uleti još nešto ali...
HVALA svima!
Staro 22.10.2012., 15:01   #1185
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
OT: baci oko radije na dishonored, za pocetak ima utjecaja sto radis na igru, a onda jos postoje vrlo raznoliki nacini za rjesavanje odredenih problema, sto u skyrimu nije bas tako No, svakom njegovo
Msi x79a GD65
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Staro 22.10.2012., 16:15   #1186
zuiko
Postovi: 456
Pogledat ću.
Hvala!
Staro 03.11.2012., 19:32   #1187
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Što mislite koliko će dugo još biti AM3 procesora na tržištu i hoće li im još padati cjena dok ne nestanu (pritom mislim na quadove tipa phenom, a ne one basic semperone)
Staro 03.11.2012., 19:35   #1188
lolofuxy
lolofuxy's Avatar
Datum registracije: Jun 2010
Postovi: 3,319
Phenomima će teško padat cijena prema dolje, sa 900 su pali na 600 kn (ovisno o dučanu), a kolko su već na tržištu mislim da će do kraja godine nestat iz dučana.
lolofuxy je offline   Reply With Quote
Staro 12.11.2012., 00:20   #1189
klem
Postovi: 591
hm hm mislim da ti je ovo kraj phenoma. Lako moguće da su ovo zadnje zalihe. Fx će ih zamjenit....nažalost . 600 kn za procesorčić kao što je phenom je malo. Fx mu nije ni do koljena .
klem je offline   Reply With Quote
Staro 12.11.2012., 12:58   #1190
tiki66
tiki
tiki66's Avatar
Postovi: 2,729
Za oko 600kn imamo u ponudi Athlon II X4 740 koji se čini kao sasvim pristojan procesor koji malo troši:
http://www.nabava.net/trazilica.php?...hlon+ii+x4+740
Staro 12.11.2012., 15:17   #1191
rodriguez
rodriguez's Avatar
Postovi: 2,057
Baš gledam na netu i ne vidim nešto reviewova?
Thinkpad T430 running
Staro 12.11.2012., 15:24   #1192
lolofuxy
lolofuxy's Avatar
Postovi: 3,319
To je nasljednik X4 641 koji je isto bio odličan proc, smanjena potrošnja, dobra paleta procesora u slučaju nadogradnje, oc potencijal bi trebao biti isti kao i na starom X4 641 (dobar, ako ne i bolji), novija arhitektura i cca 10-15% poboljšane sveukupne performanse.
Staro 12.11.2012., 15:27   #1193
rodriguez
rodriguez's Avatar
Postovi: 2,057
Samo što bi trebao mijenjat i ploču ako uzmem taj proc? A to je onda već neisplativo....
Staro 12.11.2012., 15:46   #1194
Guls
Guls's Avatar
Lokacija: Sveta Nedelja
Postovi: 2,938
Sorry na neupućenosti, ali koja je budućnost FM2 platforme? Da li je u planu izdavanje jačih procesora od postojećih ili se prelazi na neki drugi socket?
Intel i7 9700F
32GB Hyper-X DDR4-2666
2TB 970Pro PCIe NVMe M.2
Windows 11 Professional
Periferija
2 x 27" Dell P2723D
Corsair SP2500 2.1
Logitech MK270
17,3 FHD IPS 144Hz
AMD Ryzen 7 5800H
16GB DDR4-3200 RAM
1TB PCIe NVMe SSD
Sony Playstation 5
Staro 12.11.2012., 15:58   #1195
lolofuxy
lolofuxy's Avatar
Postovi: 3,319
U postu od kolege ćeš dosta toga saznat.
Staro 15.11.2012., 18:41   #1196
Zvonimir_s
Zvonimir_s's Avatar
Postovi: 406
kad FX-8350 - Vishera stiže u naše trgovine ?
Zvonimir_s je offline   Reply With Quote
Staro 16.11.2012., 14:06   #1197
BrainDamage
Datum registracije: Nov 2011
Lokacija: ST
Postovi: 259
Autor Zvonimir_s Pregled postova
Sutra stize u ASBIS FX8320, cijena u Asbisu je 1069.90 + PDV ilitiga 1337,37kn.
BrainDamage je offline   Reply With Quote
Staro 16.11.2012., 14:42   #1198
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Staro 17.11.2012., 07:24   #1199
Zvonimir_s
Zvonimir_s's Avatar
Postovi: 406
Nije ig bilo do neki dan...
Hmm preporucena cijena 190 $ ..bas me zanima nabavna...no tu je uracunt teansport i dobit trgovca... Po ovome imaju lijepu maržu..
S obzirom da troši dosta više struje...upitna isplativost u odnosu na i5
Edit:
S obirom da je u ADM otkljucani I5 za 300 kn jeftiniji od Linksa...i jeftiniji cca 100 kn od AMD ovog losijeg procesora...onda je stvarno smjesno kupovati AMD
Kod nas ce AMD unistiti trgovci..)
Zadnje izmijenjeno od: Zvonimir_s. 17.11.2012. u 07:30.
Staro 17.11.2012., 20:23   #1200
PURSUIT
PURSUIT's Avatar
Datum registracije: Sep 2012
Lokacija: POŽEGA
Postovi: 271
Autor Vlada011 Pregled postova
Moj predlog sto se tice AMDa ko hoce da kupi je nova serija procesora zvana Ivyshera 3770k a ako je to skupo onda 3570k, e taj umesto AMD.
Salim se ja to gledam ovako a ovo je prvenstveno savet za ljude koji bi da uzmu 8350 i jake i skupe ROG ploce ili GIGABYTE konkurentne kao i najskuplje modele ASRocka...
Moj savet je da se ne daje 200-220e za 8530k, Formula 5 Z i ostale...
Lepo dodas jos 40e i uzmes 2600k i Maximus 4 Gene Z ili tako nesto. Nece izaci mnogo skuplje. Ili can neku ASRock jeftiniju plocu za...
Sobzirom da ako izaberete Intel za 2 godine cete imati novi i7 ustede samo u struji.
Vlada@ Protjeran si sa jednog drugog foruma ,gdje si falio samo EVGA i NVIDIA grafe.Vidim da ovdje isto nastavljaš maltretirati ljude i nametati im svoja mišljenja.Iz priloženog se vidi da vuk dlaku mijenja ali čud ne.Nije uopće potrebno davati više od 1000 KN za neku ploču koja će držati FX 8350 i kloknutog a kamoli na stocku.Nemoj molim te komentirati ono što ne možeš da smisliš,jer nisi objektivan.
PURSUIT je offline   Reply With Quote
