Staro 16.09.2012., 18:08   #121
Omerta
Omerta's Avatar
Lokacija: Grobnik - Rijeka
Postovi: 3,254
Jučer - 08:00-13:00 i nešto još popodne i navečer cca 2-3 sata. I danas 08:00 do 11h i nešto. cca 11 sati. Na Medium težini, nisam išao na Hard.
Oho, pa odlično, 11h je i više nego odlično s obzirom na neke današnje isprdke od igara..
Autor trouble Pregled postova
Opala,link,dobio sam erekciju i skidam
Staro 16.09.2012., 19:19   #122
ONeill
ONeill's Avatar
Datum registracije: Mar 2008
Postovi: 347
Autor d0magoj_OS Pregled postova
.jedino me ubija skakanje na stvari i penjanje strašno je bugovito i milion puta poginem zato što se doktor zaglavi padne ili nešto treće
Tako i meni, imam osjećaj kao da stalno zapinjem za nešto kad treba skočiti
ONeill je offline   Reply With Quote
Staro 16.09.2012., 22:10   #123
kian
kian's Avatar
Datum registracije: Oct 2001
Lokacija: Velika Gorica
Postovi: 600
Tko nema igre u Libraryu treba:
HOW TO LAUNCH BLACK MESA INSTALLED IN OTHER FOLDER THEN STEAM:
Assume you have Steam installed in: D:\Games\Steam
Assume your Steam user name is: Your_Steam_Username
Assume you have game installed in: D:\Games\Black Mesa
To lauch the game in command line you should type:
"D:\Games\Steam\steamapps\Your_Steam_Username\source sdk base 2007\hl2.exe" -game sourcetest -steam -game "D:\Games\Black Mesa"
If you are not familiar with command line you can create shortcut on desktop to hl2.exe by finding the file in your system (path can be different depends on when you got Steam installed) and then right click on it, chose sub-menu Sent to then chose Desktop (create shortcut). After you done that, right click on newly created shortcut, chose Properties (properties windows will appear) and then change Target field with launch command from above.
Of course you have to change paths if you got them installed in other folders.
forums.blackmesasource.com
Staro 17.09.2012., 00:13   #124
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,800
Postoji li opcija za instalacijom ove igre tj. igranja bez instalacije steama?
Staro 17.09.2012., 03:22   #125
tallsaint
tallsaint's Avatar
Datum registracije: Sep 2010
Postovi: 63
Ne, s obzirom da je mod, treba ti source sdk, preko steama.
Marantz PM6003/Pro-ject Debut III/Wharfedale Diamond 10.1
tallsaint je offline   Reply With Quote
Staro 17.09.2012., 05:16   #126
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,824
Postoji, velicina 4gb, instaliral bez steam-a. i popratnih gluposti.
Staro 17.09.2012., 14:37   #127
tallsaint
tallsaint's Avatar
Postovi: 63
Autor zvonac Pregled postova
Ipak postoji, ispričavam se na dezinformacijama Upravo sam sad provjerio po torrentima. Dovrsio sam igru jučer, odličan mod, mnogo sam se zabavio! Malo su me jedino ljestve razočarale koje su napravljene nekako više sticky nego u HL2, tesko je sići. Ostalo je čista petica! Sad se čeka Xen.
Staro 17.09.2012., 15:18   #128
Dobro je, živ je, i zdrav nije mu ništa
Staro 17.09.2012., 15:23   #129
domina
domina's Avatar
Lokacija: KC (HR)
Postovi: 917
To mora da su vitamini za konje .
Staro 17.09.2012., 15:25   #130
Ivo_Strojnica
PRO
Postovi: 4,800
Bit će on dobro.
Znači igra je odlična i vrijedna svake kune?
Staro 17.09.2012., 15:46   #131
veve
woot!!!
veve's Avatar
Postovi: 2,496
Pa besplatna je
Skupil jucer ekipu, ovaj security s magnumom cisti sve pred sobom. Nazalost morao sam ih ostaviti kod prepreka.
I kad naletis na ovakav arsenal znas da ti se lose sprema.
veve je offline   Reply With Quote
Staro 17.09.2012., 16:42   #132
Deathwish
overpowered
Deathwish's Avatar
Postovi: 915
Uf al me ova igra na hardu guzi, i oduševljen time, dođe marinac i papa micek di su ti helti nestali. A ti bi tankao helikopter, budes budes XD
A ona mjuza kad se pojavi (khm 30 specijalaca kroz strop khm)
btw ko je radio algoritme za kretanje assasinki, prelude su
@Work HP Zbook15
@Home Acer 5020
Deathwish je offline   Reply With Quote
Staro 18.09.2012., 23:00   #133
Elder
Lokacija: Krapina
Postovi: 169
Napkon da sam i ja nasel vremena i skinul i instaliral , zanimljivo je da ja nisam trebal dodavati nis na steamu samo mi je bacilo igru gore nakon instalacije
Elder je offline   Reply With Quote
Staro 19.09.2012., 20:35   #134
d0magoj_OS
Datum registracije: Nov 2011
Lokacija: Internet
Postovi: 782
prešao igru upravo....same pohvale osim skakutanja koje je toliko bugovito i jako kida živce....napravili su predobar remake i opet me podsjetili koliko je HL zapravo dobar natjerala me da igram cijeli serijal opet....što reći osim jedva čekam episode 3 Nevjerovatno kako niti jedna igra koju su izbacili nije ni blizu smeću sve sama remek dijela...
d0magoj_OS je offline   Reply With Quote
Staro 19.09.2012., 23:35   #135
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
For the love of god,instaliral sam igru(setup) i dobio hrpu fajlova i nigdje exea....jel to način koji sam tako žarko htio izbjeći? (instalacija steama)
Staro 20.09.2012., 06:13   #136
postoji ti Steam i non-Steam verzija igre. Ako si skinuo Steam verziju (najvjerojatnije jesi), onda bez steama ništa. Skini non-steam, malo je "teža" ali ti ne treba aplikacija i account za steam.
Staro 20.09.2012., 12:27   #137
d0magoj_OS
Lokacija: Internet
Postovi: 782
instaliraj steam
instaliraj igru
instaliraj SDK preko steam
pokreni igru
Staro 20.09.2012., 12:39   #138
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
Thnx chaps!
Staro 20.09.2012., 15:20   #139
Remixer
Remixer's Avatar
Lokacija: Irska
Postovi: 1,171
instaliraj steam
instaliraj igru
pokreni igru
-ja sam bio inst. igru pa steam, pa SDK preko steam-a, i opet mi ne radi, WHY? :-(
http://img845.imageshack.us/img845/7167/croatia240animatedflagg.gif
Remixer je offline   Reply With Quote
Staro 20.09.2012., 15:27   #140
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
Autor Remixer Pregled postova
Imaš Half-Life 2 instaliran?
Staro 20.09.2012., 15:46   #141
veve
woot!!!
veve's Avatar
Postovi: 2,496
Ne treba mu Half life 2 ili bilo koja source igra, dovoljan mu je SDK.
Znaci postupak:
1. Istaliras Steam
2. Skines SDK
3. Instaliras Black Mesa: Source, vec ce biti ponudena odgovarajuca putanja, npr X:\Steam\SteamApps\sourcemods
Staro 20.09.2012., 16:12   #142
Remixer
Remixer's Avatar
Lokacija: Irska
Postovi: 1,171
Autor veve Pregled postova
Znaci postupak:
1. Istaliras Steam
2. Skines SDK
Nemam HL2... -na toj putanji mi je igra i instalirana, jedino da probam opet inst. sada kad imam steam & SDK ? -no ne mogu je ni deinstalirat jer ju ni jedan program za deinstalaciju ne vidi, WTF? -u steam-u nema koristi od 'add game' jer me traži .exe, a toga nema u black mesa... ili samo ja nemam?
Staro 20.09.2012., 17:56   #143
veve
woot!!!
veve's Avatar
Postovi: 2,496
Nemam je ni ja u add/remove, ocito nisu dodali tu opciju, ali neka te to ne brine, jer ako je bas zelis maknuti i ponovno probati instalaciju moras ici u Steam\SteamApps\sourcemods i izbrisati folder bms.
E sad jedino ne znam, jer se to nigdje ne spominje da li bas moras imati bilo kakvu igru kupljenu na steamu da bi ti uopce to radilo.
Staro 20.09.2012., 19:10   #144
ThePornstar
Postovi: 4,403
Ma ne treba, nemam ni ja. Imam posebno instaliran Half Life 2, skinul SDK sa Steama i instaliral BMS i to je to. Sve super
Staro 20.09.2012., 20:22   #145
Remixer
Remixer's Avatar
Lokacija: Irska
Postovi: 1,171
Ovdje mi je instalirana igra, onaj BMS folder sam eliminirao, ali i dalje STEAM ne vidi igru...
Staro 20.09.2012., 20:31   #146
s7ank0
s7ank0's Avatar
Postovi: 117
u BMS folderu ti je igra ak igras preko steama,ponovo instaliraj igru...
s7ank0 je offline   Reply With Quote
Staro 20.09.2012., 21:26   #147
Remixer
Remixer's Avatar
Lokacija: Irska
Postovi: 1,171
Autor s7ank0 Pregled postova
Sad radi, thx
UH, kad se sjetim ove igre na 15'' CRT monitoru onda... (davno prije heh)
Staro 21.09.2012., 14:25   #148
d0magoj_OS
Lokacija: Internet
Postovi: 782
igra--->sdk...nije ni meni radilo kad sam prvo instalirao igru pa onda steam...
zato što si prvo instalirao igru pa onda steam..mora bit obrnuto..steam--->igra--->sdk...nije ni meni radilo kad sam prvo instalirao igru pa onda steam...
Staro 21.09.2012., 21:59   #149
Remixer
Remixer's Avatar
Lokacija: Irska
Postovi: 1,171
Jučer sam navečer igrao nekoliko sati, sad sam mislio nastaviti ali ne znam kak, u steam-u nema ni traga od igre, a u folderu di je igra instalirana nema .exe, WTF?
Staro 22.09.2012., 15:29   #150
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,393
hvala na obavijesti, vrlo konstruktivan i nadasve bitan post za korisnike ovog foruma.
