#481 |
Love Generation
Lokacija: Belišće
Postovi: 57
Extract primary loader [ OK ]
--> Validate secondary loader (FLASH) [ OK ]
-- Danube Secondary loader --
Version : 4.1.28.52.12
Build Profile : sx76x_danube_a
Build Date : Jun 10 2009 - 17:11:52
--> Extract secondary loader [ OK ]
--> Press enter to activate cli [ 00 ]
sx76x >
RIJEŠENO.Problem je bio u tome sto sam krivi file stavio na tftp server na kompu i onda kad ga je ruter prilikom bootanja automatski povukao nije mogaou updatati. Također je bitno da se file zove runtime.img ![]() Nakon otključvanja rutera htio sam ga prebaciti na Annex A i nakon dowloadanja
download firm http://sx763.co.cc/bootcode_a.img noreboot ruter se rebootao, i time nisam uspio izvrsiti download firm http://sx763.co.cc/runtime_a.img Sada na ruteru trepere voip i wlan, te se ne uspije bootat njegov frimware. Uspio sam povezat ruter preko serijskog porta i usao sam u consolu: Te sam uspio i prebaciti runtime.img preko tftpa i on ga je pokušao učitat ali ništa se nije dogodilo.. (rename-ao sam runtime_a.img u runtime.img da li je bitno ime?) Kako mogu oživit ruter? Bilo da stavim openwrt ili originalni sw... Code:
ROM VER: 1.0.3 CFG 01 Read EEPROMX X SHC Danube-External-Flash-Boot - Version V1.1 Mem-config: Flash: 8MB- 8MBx1 Ram: 32MB-32MBx1 Low level dbg is active... CPU0 MEMS ROM VER: 1.0.3 CFG 01 Read EEPROMX X SHC Danube-External-Flash-Boot - Version V1.1 Mem-config: Flash: 8MB- 8MBx1 Ram: 32MB-32MBx1 Low level dbg is active... CPU0 MEMS -- Danube Primary loader -- Version : 4.1.24.52.12 Build Profile : sx76x_danube_b Build Date : Sep 9 2009 - 17:53:25 --> Extract primary loader [ OK ] --> Validate secondary loader (FLASH) [ OK ] -- Danube Secondary loader -- Version : 4.1.28.52.12 Build Profile : sx76x_danube_a Build Date : Jun 10 2009 - 17:11:52 --> Extract secondary loader [ OK ] --> Press enter to activate cli [ 00 ] sx76x > Problem je bio u tome sto sam krivi file stavio na tftp server na kompu i onda kad ga je ruter prilikom bootanja automatski povukao nije mogaou updatati. Također je bitno da se file zove runtime.img ![]() Zadnje izmijenjeno od: Maki1908. 22.08.2012. u 16:27. Razlog: nasao rijesenje |
#482 | ||
jedan i jedini :D
Lokacija: novi zagreb
Postovi: 5,249
Nista se ne mora lemiti. Samo treba otvoriti ruter i odstekati postojeci konektor te pristekati novi sa RPSMA ili N konektorom. Konektora ima kupiti u esysu/H2shop, elma kurtalj, itd. Tako sam bar ja napravio. |
#483 |
Rasvjetno tijelo
Postovi: 374
trebala bi mi pomoć, stavija sam gore open wrt, malo se izmučija dok nisam skužija da preko chromea ne radi, nego da trebam firefox, al sad imam problem sa pppoe konekcijom, naime neće nikako da se spoji ![]() isp je h1, iša sam na open wrt jer sam vidija da bi se preko njega dalo sredit i iptv tu je sys log nakon boota, ima neko ideju šta radim krivo i kako to srediti? Code:
Aug 22 21:14:07 OpenWrt kern.info kernel: [ 0.228000] gptu: succeeded to request irq 127 Aug 22 21:14:07 OpenWrt kern.info kernel: [ 0.232000] gptu: succeeded to request irq 128 Aug 22 21:14:07 OpenWrt kern.info kernel: [ 0.236000] gptu: succeeded to request irq 129 Aug 22 21:14:07 OpenWrt kern.info kernel: [ 0.240000] gptu: succeeded to request irq 130 Aug 22 21:14:07 OpenWrt kern.info kernel: [ 0.244000] gptu: succeeded to request irq 131 Aug 22 21:14:07 OpenWrt kern.info kernel: [ 0.252000] squashfs: version 4.0 (2009/01/31) Phillip Lougher Aug 22 21:14:07 OpenWrt kern.info kernel: [ 0.260000] JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc. Aug 22 21:14:07 OpenWrt kern.info kernel: [ 0.268000] msgmni has been set to 57 Aug 22 21:14:07 OpenWrt kern.info kernel: [ 0.272000] io scheduler noop registered Aug 22 21:14:07 OpenWrt kern.info kernel: [ 0.276000] io scheduler deadline registered (default) Aug 22 21:14:07 OpenWrt kern.info kernel: [ 0.284000] ltq_asc.1: ttyLTQ1 at MMIO 0x1e100c00 (irq = 112) is a ltq_asc Aug 22 21:14:07 OpenWrt kern.info kernel: [ 0.292000] console [ttyLTQ1] enabled, bootconsole disabled Aug 22 21:14:07 OpenWrt kern.info kernel: [ 0.304000] ltq_nor: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000001 Chip ID 0x001000 Aug 22 21:14:07 OpenWrt kern.debug kernel: [ 0.312000] ltq_nor: Found an alias at 0x800000 for the chip at 0x0 Aug 22 21:14:07 OpenWrt kern.info kernel: [ 0.312000] Amd/Fujitsu Extended Query Table at 0x0040 Aug 22 21:14:07 OpenWrt kern.info kernel: [ 0.320000] Amd/Fujitsu Extended Query version 1.3. Aug 22 21:14:07 OpenWrt kern.notice kernel: [ 0.324000] number of CFI chips: 1 Aug 22 21:14:07 OpenWrt kern.notice kernel: [ 0.328000] Creating 4 MTD partitions on "ltq_nor": Aug 22 21:14:07 OpenWrt kern.notice kernel: [ 0.332000] 0x000000000000-0x00000000e000 : "primary" Aug 22 21:14:07 OpenWrt kern.notice kernel: [ 0.340000] 0x00000000e000-0x000000010000 : "secondary_env" Aug 22 21:14:07 OpenWrt kern.notice kernel: [ 0.348000] 0x000000010000-0x000000020000 : "secondary" Aug 22 21:14:07 OpenWrt kern.notice kernel: [ 0.352000] 0x000000020000-0x000000800000 : "linux" Aug 22 21:14:07 OpenWrt kern.info kernel: [ 0.360000] found squashfs behind kernel Aug 22 21:14:07 OpenWrt kern.notice kernel: [ 0.364000] Creating 2 MTD partitions on "ltq_nor": Aug 22 21:14:07 OpenWrt kern.notice kernel: [ 0.368000] 0x000000020000-0x0000001094dd : "kernel" Aug 22 21:14:07 OpenWrt kern.warn kernel: [ 0.372000] mtd: partition "kernel" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only Aug 22 21:14:07 OpenWrt kern.notice kernel: [ 0.388000] 0x0000001094dd-0x000000800000 : "rootfs" Aug 22 21:14:07 OpenWrt kern.warn kernel: [ 0.392000] mtd: partition "rootfs" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only Aug 22 21:14:07 OpenWrt kern.notice kernel: [ 0.408000] mtd: partition "rootfs" set to be root filesystem Aug 22 21:14:07 OpenWrt kern.info kernel: [ 0.412000] mtd: partition "rootfs_data" created automatically, ofs=410000, len=3F0000 Aug 22 21:14:07 OpenWrt kern.notice kernel: [ 0.420000] 0x000000410000-0x000000800000 : "rootfs_data" Aug 22 21:14:07 OpenWrt kern.info kernel: [ 0.480000] ltq_mii: probed Aug 22 21:14:07 OpenWrt kern.info kernel: [ 0.480000] eth0: ADM6996M model PHY found. Aug 22 21:14:07 OpenWrt kern.info kernel: [ 0.488000] eth0: attached PHY [Infineon ADM6996] (phy_addr=0:00, irq=-1) Aug 22 21:14:07 OpenWrt kern.debug kernel: [ 0.496000] Registered led device: soc:green:voip Aug 22 21:14:07 OpenWrt kern.debug kernel: [ 0.496000] Registered led device: soc:green:adsl Aug 22 21:14:07 OpenWrt kern.debug kernel: [ 0.496000] Registered led device: soc:green:usb Aug 22 21:14:07 OpenWrt kern.debug kernel: [ 0.500000] Registered led device: soc:green:wifi Aug 22 21:14:07 OpenWrt kern.info kernel: [ 0.500000] TCP westwood registered Aug 22 21:14:07 OpenWrt kern.info kernel: [ 0.504000] NET: Registered protocol family 17 Aug 22 21:14:07 OpenWrt kern.info kernel: [ 0.508000] 8021q: 802.1Q VLAN Support v1.8 Aug 22 21:14:07 OpenWrt kern.info kernel: [ 0.524000] VFS: Mounted root (squashfs filesystem) readonly on device 31:5. Aug 22 21:14:07 OpenWrt kern.info kernel: [ 0.532000] Freeing unused kernel memory: 168k freed Aug 22 21:14:07 OpenWrt kern.notice kernel: [ 7.080000] JFFS2 notice: (437) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (0 unchecked, 0 orphan) and 16 of xref (0 dead, 8 orphan) found. Aug 22 21:14:07 OpenWrt kern.info kernel: [ 10.080000] Compat-wireless backport release: compat-wireless-2012-02-27-1-r31118 Aug 22 21:14:07 OpenWrt kern.info kernel: [ 10.084000] Backport based on wireless-testing.git master-2012-02-27 Aug 22 21:14:07 OpenWrt kern.info kernel: [ 10.380000] cfg80211: Calling CRDA to update world regulatory domain Aug 22 21:14:07 OpenWrt kern.info kernel: [ 11.488000] cfg80211: World regulatory domain updated: Aug 22 21:14:07 OpenWrt kern.info kernel: [ 11.492000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) Aug 22 21:14:07 OpenWrt kern.info kernel: [ 11.500000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) Aug 22 21:14:07 OpenWrt kern.info kernel: [ 11.508000] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm) Aug 22 21:14:07 OpenWrt kern.info kernel: [ 11.512000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm) Aug 22 21:14:07 OpenWrt kern.info kernel: [ 11.520000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) Aug 22 21:14:07 OpenWrt kern.info kernel: [ 11.528000] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) Aug 22 21:14:07 OpenWrt kern.info kernel: [ 11.736000] usbcore: registered new interface driver usbfs Aug 22 21:14:07 OpenWrt kern.info kernel: [ 11.740000] usbcore: registered new interface driver hub Aug 22 21:14:07 OpenWrt kern.info kernel: [ 11.748000] usbcore: registered new device driver usb Aug 22 21:14:07 OpenWrt kern.warn kernel: [ 12.348000] PCI: Enabling device 0000:00:0e.0 (0000 -> 0002) Aug 22 21:14:07 OpenWrt kern.info kernel: [ 12.352000] ath5k 0000:00:0e.0: registered as 'phy0' Aug 22 21:14:07 OpenWrt kern.debug kernel: [ 12.364000] ath: EEPROM regdomain: 0x37 Aug 22 21:14:07 OpenWrt kern.debug kernel: [ 12.364000] ath: EEPROM indicates we should expect a direct regpair map Aug 22 21:14:07 OpenWrt kern.debug kernel: [ 12.364000] ath: Country alpha2 being used: AW Aug 22 21:14:07 OpenWrt kern.debug kernel: [ 12.364000] ath: Regpair used: 0x37 Aug 22 21:14:07 OpenWrt kern.debug kernel: [ 12.364000] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht' Aug 22 21:14:07 OpenWrt kern.info kernel: [ 12.364000] ath5k phy0: Atheros AR2414 chip found (MAC: 0x79, PHY: 0x45) Aug 22 21:14:07 OpenWrt kern.info kernel: [ 12.608000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (N/A, 2000 mBm) Aug 22 21:14:07 OpenWrt kern.info kernel: [ 12.616000] cfg80211: (5250000 KHz - 5330000 KHz @ 40000 KHz), (N/A, 2000 mBm) Aug 22 21:14:07 OpenWrt kern.info kernel: [ 12.624000] cfg80211: (5490000 KHz - 5710000 KHz @ 40000 KHz), (N/A, 2700 mBm) Aug 22 21:14:07 OpenWrt kern.info kernel: [ 12.636000] NET: Registered protocol family 8 Aug 22 21:14:07 OpenWrt kern.info kernel: [ 12.636000] NET: Registered protocol family 20 Aug 22 21:14:07 OpenWrt kern.info kernel: [ 12.696000] Button Hotplug driver version 0.4.1 Aug 22 21:14:07 OpenWrt kern.info kernel: [ 12.880000] PPP generic driver version 2.4.2 Aug 22 21:14:07 OpenWrt kern.info kernel: [ 13.072000] tun: Universal TUN/TAP device driver, 1.6 Aug 22 21:14:07 OpenWrt kern.info kernel: [ 13.076000] tun: (C) 1999-2004 Max Krasnyansky |
#484 | |
Datum registracije: Feb 2010
Lokacija: tu
Postovi: 36
Sad kombiniram s SX763 s dd-wrt-om kao glavnim routerom i na njega prikačenim TG782i na kojem koristim samo wireless. Vidim da više manje svi koriste obrnutu konfiguraciju tko ima TG782i, ali evo kad SX763 ostane bez WL adaptera i ovako je dobro. Također me zanimaju iskustva da li netko koristi neki oblik VPN servera (ne klijenta) - PPTP ili OpenVPN na dd-wrt. Zadnje izmijenjeno od: allidea. 23.08.2012. u 12:11. |
#485 |
Lokacija: hr
Postovi: 755
Vratio sam nazad na staru verziju dd-wrt. |
#486 |
Postovi: 683
#487 |
Lokacija: tu
Postovi: 36
Nakon par dana intenzivnog re-flashanja SX763 routera, evo još mojih par sugestija (@.Delboy - nije da se nudim, ali možda neke od njih ne bi bilo loše pridodati u prvi post) 1) IE se pokazao kao najbolji izbor za flashanje i uvijek radi bez greške. Chrome ne radi kako treba, a Firefox može raditi probleme ovisno o instaliranim add-onovima. 2) Prije flashanja obavezno (privremeno) isključite Firewall, a nije na odmet isključiti ni programe koji blokiraju IP adrese kao što je to npr. PeerBlock (načelno ovakvi programi ne bi smjeli raditi probleme, ali sigurno je sigurno i štedi vrijeme) 3) Kada započenete proces fashanja, nakon 15-ak sekundi će se pokazati poruka kako je router počeo flash fw-a i da će se po završetku isti rebootati. S obzirom da se ta stranica ne refresha automatski nakon završetka flasha i reboota u GUI novog firmwarea, postoji jednostavan način da otkrijete da li se router rebootao ili ne (ovo pogotovo vrijedi za dd-wrt jer prije i nakon flasha svijetle iste LEDice i po njima se ne može zaključiti da li je se router rebootao ili ne, za openwrt ne znam jer nisam pratio LEDice nakon flasha i općenito sam više naklonjen dd-wrtu). Kada se SX763 gasi i pali (reboota) čuje se specifičan zvuk (iliti "klik"). Po tome možete znati da se router rebootao. Kod flashanja dd-wrta ovaj zvuk bi trebali čuti tijekom prvih 5 minuta nakon što se pokazala poruka da je fash započeo. Nakon što čujete "klik" pričekajte još 30 sekundi i napravite refresh browsera. Nakon toga ukoliko je sve prošlo u redu bi trebali vidjeti GUI novog firmwarea. 4) Nadam se da ovo nećete čuti, ali ako tijekom flashanja čujete više od jednog "klika" znači da je nešto krenulo krivo i da se router stalno resetira. Meni je ovo resetiranje izgleda naškodilo wireless adapteru na SX763, pa vam savjetujem da isto prekinete što prije gašenjem routera i resetiranjem istog kako bi došli u failsafe boot. 5) Možda ne bi bilo loše staviti link na repozitorij web updateova za dd-wrt na ftp://ftp.dd-wrt.com/others/eko/Brai...gigaset_sx763/ odnosno na ftp://ftp.dd-wrt.com/others/eko/BrainSlayer-V24-preSP2/ |
#488 |
Postovi: 993
Što je na kraju s T-comovim IMS? Danas sam dobio sx763, i bilo bi fora imat OpenWrt, ali sam prebačen i na voip pa dali radi sigurno? Hvala |
#490 |
tiki
Postovi: 2,744
Ima li koja dobra duša da mi objasni di i šta trebam utipkati da mi proradi iskon voip i internet na openwrt-u? Stavio sam ovaj testni voip img iz prvog posta, no nikako da dobijem konekciju na internet. |
#491 |
Datum registracije: May 2012
Postovi: 11
update openwrt
može kratki how to za update ako imam primary loader promijenjen i allparts.image unutra (baš se ne snalazim, što god stavim router se ne boota)? Thnx, |
#492 |
Postovi: 11
iptv 3,4
moze tko postat net config za openwrt sa zadnja dva iptv porta |
#493 | |
Love Generation
Lokacija: Belišće
Postovi: 57
postam uskoro sto dobijem preko serijske konzole... Jel imao netko problema s pucanjem veze? Imam tri SX-a na svima je openwrt i na dva rutera puca veza konstantno i kod mene i kod susjeda (tako da nije problem u liniji), ovaj treci radi normalno. Na jedan "neispravan" sam vratio nazad originalni gigaset fw i veza ne puca... Radi se o annexu a, optima. |
#494 |
Love Generation
Lokacija: Belišće
Postovi: 57
Za one koji uspiju ubit ruter, evo kako ga ponovo oživiti. 1. Prvo je potrebno spojiti ruter preko serijskog kabla te uci u UART mode. Detaljnije na http://wiki.openwrt.org/toh/gigaset/sx76x VAŽNO: U programu za serijsku komunikaciju nemojte zaboravit iskljucit Hardware flow control, a ukljuciti Software flow control jer nećete moci slati keypress ili file-ove ruteru. (Ako vrtite GNU/Linux preporucam cutecom) 2. Nakon ulaska u UART mode, poslati ruteru u-boot.asc Ja sam naišao na dvije verzije u-boot.asc [1] S wiki.openwrt http://downloads.openwrt.org/snapsho...ng166_ramboot/ [2] I google.code https://sx76x-openwrt-danube.googlec...unk/u-boot.asc Imao sam problem s prvom [1] httpd preko kojeg se kasnije ubacuje allparts.img je jednostavno odbijao primit file do kraja. S drugom [2] je bilo sve ok. Za transfer protocol ja sam koristio "Plain" jer xmodem, ymodem i zmodem nisu ni pocimali prebacivat file. 3. Kad se prebacivanje u-boot.asc završi httpd ce se automatski pokrenuti i server se nalazi na 192.168.0.119 Tu sad treba ubaciti openwrt-lantiq-danube-GIGASX76X-allparts.image [3] opet google.code https://sx76x-openwrt-danube.googlec...allparts.image 4. Nakon što se uspješno prebaci ...allparts.img (vidi se preko serijske konzole) ruter ce ponovno uci u UART mode. Sad opet treba poslati u-boot.asc kako bi se ubaceni ...allparts.img mogao bootati. Nakon sto u-boot.asc prebacite automatski ce se pocet bootat ...allparts.img. 5. Kad se wrt digne do kraja treba se preko telnet-a spojiti na 192.168.1.1 promjenit lozinku s passwd, da se omoguci ssh. Zatim prebaciti originalni primary[4] i secondary[5] bootloader s scp-om u /tmp/ [4] Originalni primary ftp://dl.solcon.nl/pub/fiber/siemens...imary_boot.img [5] Modificirani secondary s httpd za ubacivanje .imga https://sx76x-openwrt-danube.googlec...ndary_boot.img 6. Nakon toga se treba spojiti s ssh-om i dd-at bootlodere u flash. dd if=/tmp/primary_boot.img of=/dev/mtdblock0 pa, dd if=/tmp/secondary_boot.img of=/dev/mtdblock2 7. Sad treba ugasiti na prekidač ruter, a prije toga maknuti kratkospojnike da ne uđe u UART mode. Postavit statičku ip adresu i na 192.168.1.1 se nalazi gui za ubacivanje wrt imga, osnovni ili voip ili ddwrt ![]() Ja sam uspio u jednom trenutku ubiti oba bootloadera i flash memoriju... @Delboy sry na gnjavazi preko IRC-a i puno hvala na pomoći ![]() ![]() |
#495 | |
Postovi: 3,490
DD i OpenWRT u je trebalo 5 puta dulje da se spoji na liniju (već sam pomislio da ne radi), a nakon toga veza stalno puca. Isto kao i kod tebe, origgi annex A fw radi bez problema. |
#496 |
Love Generation
Lokacija: Belišće
Postovi: 57
Stvarno mi nije jasno zašto puca, do sada sam radio s 7 rutera i na 3 mi je pucala a uvijek ista verzija sw. Imam sad trenutno 3 rutera kod sebe, jedan s originalnim fw na annex a, koji radi odlicno i dva s openwrt-om na kojima puca veza. Probat cu jos jednom stavit openwrt i ddwrt pa provjeriti, te stavit originalni ako ne bude islo, pa postam rezultate. |
#497 |
Postovi: 13
Kako podesiti sx763 DD-WRT da se spaja putem PPPoE na drugi adsl modem? Ako adsl modem spojim na line ili dsl port na siemensu ne može se spojiti. probao sam naći neki način da se postavi WAN port na neki od LAN portova ali bez uspjeha. |
#498 |
Datum registracije: Apr 2009
Lokacija: Trenutno: ZD
Postovi: 91
Do sad sam bez problema flashao 2 rutera ali sa trećim imam problem. Nakon flashanja secondary_boota otvori mi se normalno failsafe UI te idem dodati uImage ali nakon odabira fajla javi grešku IE cannot display the webpage. U čemu je problem?? |
#499 |
Love Generation
Lokacija: Belišće
Postovi: 57
Dogodi se to da pukne veza izmedu http servera na ruteru i tvog browsera probaj s Firefox ili Chrome, meni se isto dogadalo i na kraju je uspilo s prastarom verzijom Firefoxa. Cini se da netko ne prati http standarde... |
#501 |
Proktolog
Lokacija: Dublin
Postovi: 287
Ako nekoga zanima graf prometa IPTV-a (a radio je po uputi/skripti za maxtv) neka si pogleda ovdje: http://192.168.1.1/graph_if.svg?nas1 Naravno, promjenite adresu ako vam je router na drugoj adresi. Ako sam nešto fulao ispravite me...
Freak Show Inc. |
#502 | |
Datum registracije: Sep 2012
Postovi: 1
wan
#505 |
Postovi: 469
Evo ja ću ti pomoći kad već nitko drugi neće, originalni firmware vraćaš tako da pročitaš tutorial u prvom postu ovog threada pa onda ako nešto zapne objasniš gdje si zapeo i u čemu je problem pa će ti netko od kolega forumaša sigurno pomoći... |
#506 |
Datum registracije: Aug 2012
Lokacija: CCNA
Postovi: 20
Jedno pitanje u vezi vraćanja originalnog fw.Na kojem annex-u je ruter kada se vrati original fw koji je u prvom postu? |
#507 | |
Datum registracije: Oct 2010
Lokacija: Kaštela
Postovi: 37
Pokusao sam uci priko web-a ali mi izbaci http://upload.slike.com/slike/JkSdQ.png E sad sta tocno dalje napravit |
#508 | |
Lokacija: CCNA
Postovi: 20
#509 |
Lokacija: Kaštela
Postovi: 37
Zahvaljujem kolega @dreamhack Je zadnji je na njemu bio openwrt. Rijesio sam problem, nego me sad zanima jel ima koji noviji primary i bootcode code sad je u ovom ver. primary 4.1.24.52.12 a secondary 4.1.28.52.12 Zadnje izmijenjeno od: Nikky. 26.09.2012. u 19:57. |
#510 |
Lokacija: CCNA
Postovi: 20
Na kojem si annex-u? Meni treba annex A. Zadnje izmijenjeno od: Nikky. 26.09.2012. u 19:57. |
