Datum registracije: Sep 2011
Postovi: 42
Xperia BL unlock(x8/x10/x10mini/x10mini_pro)
Pozdrav, Upozorenje! ako nemate bar malo iskustva sa adb i sa semc platformom nemojte se igrati! Pricekajte kroz par mjeseci alat sa velikom tipkom Unlock Bootloader xD! Evo u ovom tutorialu cu Vam pokazati kako unlockati bootloader kako bi mogli flashati CM7/kernele/nove drivere/sve sto prije niste mogli. Na xperia 2011 serije bootloaderi su otkljucani od starne sony ericssona, ali na 2010 seriji su zakljucani. Zahvaljujuci the_laseru (inace kreatoru setoo2 box-a), uspio je probiti qualcom mcu boot i unlockati bootloadere ![]() Za pocetak downloadat ovo (http://www.mediafire.com/?y261ezyy9gozyu9) s1tool: program za identificiranje koji sim lock certifikat imate! Upalite program, pritisnite do job i spojite mobitel u flash modu( iskljucen mobitel drzeci tipku back) Nakon sto ocita mobitel treba li bi imati SLICNO ovome: Code:
10.9.2011. 18:24:01 Welcome to S1 identify tool 10.9.2011. 18:24:02 10.9.2011. 18:24:02 TO CONNECT NEXT PHONES 10.9.2011. 18:24:02 X10 Xperia,E10 Xperia Mini,E15 Xperia X8,U20 Xperia Mini Pro 10.9.2011. 18:24:02 LT15 Xperia ARC,MT15 Xperia NEO,R800 Xperia PLAY 10.9.2011. 18:24:02 PRESS AND HOLD "BACK" BUTTON... 10.9.2011. 18:24:02 10.9.2011. 18:24:02 PLEASE ATTACH TURNED OFF PHONE NOW 10.9.2011. 18:24:02 10.9.2011. 18:24:08 10.9.2011. 18:24:08 RUNNING S1_EROM VER "r8A033" 10.9.2011. 18:24:08 SOFTWARE AID: 0001 10.9.2011. 18:24:08 LOADER AID: 0001 10.9.2011. 18:24:12 FLASH ID: "002C/00B3" 10.9.2011. 18:24:12 LOADER VERSION: "R4A024" 10.9.2011. 18:24:12 10.9.2011. 18:24:12 MODEL (from GDFS): X10i 10.9.2011. 18:24:12 SOFTWARE VERSION: 1227-4612_3.0.1.G.0.75 10.9.2011. 18:24:12 CUSTOM VERSION: 1241-1846_R1C 10.9.2011. 18:24:12 FILESYSTEM VERSION: WORLD-1-4-8_3.0.1.G.0.75 10.9.2011. 18:24:12 SERIAL NO: CB511G6SC9 10.9.2011. 18:24:12 10.9.2011. 18:24:12 SEMC SIMLOCK CERTIFICATE 10.9.2011. 18:24:12 Elapsed:10 secs. Code:
9.9.2011. 16:57:41 Welcome to S1 identify tool 9.9.2011. 16:57:52 9.9.2011. 16:57:52 TO CONNECT NEXT PHONES 9.9.2011. 16:57:52 X10 Xperia,E10 Xperia Mini,E15 Xperia X8,U20 Xperia Mini Pro 9.9.2011. 16:57:52 LT15 Xperia ARC,MT15 Xperia NEO,R800 Xperia PLAY 9.9.2011. 16:57:52 PRESS AND HOLD "BACK" BUTTON... 9.9.2011. 16:57:52 9.9.2011. 16:57:52 PLEASE ATTACH TURNED OFF PHONE NOW 9.9.2011. 16:57:52 9.9.2011. 16:58:17 9.9.2011. 16:58:17 RUNNING S1_EROM VER "R8A029" 9.9.2011. 16:58:17 SOFTWARE AID: 0001 9.9.2011. 16:58:17 LOADER AID: 0001 9.9.2011. 16:58:19 FLASH ID: "0020/00BC" 9.9.2011. 16:58:19 LOADER VERSION: "R4A045" 9.9.2011. 16:58:19 9.9.2011. 16:58:19 MODEL (from GDFS): E15i 9.9.2011. 16:58:19 SOFTWARE VERSION: 1236-9291_2.1.1.A.0.6 9.9.2011. 16:58:19 CUSTOM VERSION: 1241-4048_R1B 9.9.2011. 16:58:19 FILESYSTEM VERSION: VFE-1-8_2.1.1.A.0.6 9.9.2011. 16:58:19 SERIAL NO: BX902BUCMJ 9.9.2011. 16:58:19 9.9.2011. 16:58:19 SETOOL2 SIMLOCK CERTIFICATE 9.9.2011. 16:58:19 Elapsed:27 secs. za x8/mini/mini_pro koristite msm7227_semc.cmd 2. SETOOL2 SIMLOCK CERTIFICATEkoristite qsd8250_setool2.cmd ZA X10!!!!!!!!!! za x8/mini/mini_pro koristite msm7227_setool2.cmd 3. "NOT RECOGNIZED SIMLOCK CERTIFICATE" nazalost mobitel treba biti unlockan setool2 softwareom. Kada ste vidjeli koju vrstu simlock statusa imate idete unlockati BL: NE KORISTITI RAZLICITI CMD OD ONOG KOJI JE IZNAD NAPISAN Prvo skidate software za unlock BL, tj cmd fajl: -ZA X10: (http://www.mediafire.com/?zl2gcs6kvr4cbgc) - ZA x8/mini/mini_pro: (http://www.mediafire.com/?q1kku4qaw19jxeu) Raspakirajte arhivu!!! Kada ste skinuli mobite upalite i omogucite usb debugging (ispravljanje usb pogresaka) Nakon sto ste to ukljucili, mobite spajate na usb. Ako ste dobili SEMC SIMLOCK CERTIFICATE pokrecete: qsd8250_semc.cmd/msm7227_semc.cmd Ako ste dobili SETOOL2 SIMLOCK CERTIFICATE pokrecete qsd8250_setool2.cmd/msm7227_setool2.cmd (pokrecete ovisno koji model imate!!!!!) Nakon sto je mobitel ustekan na usb, usb debugging upaljen, .cmd fajl otvoren pise da stisnete enter. Pritisnite enter i nakon nekolko vremena dobivate SLICAN LOG: LOG od X10! Code:
process requires standard 2.x android firmware. Press any key to continue . . . Getting ROOT rights. 1464 KB/s (585731 bytes in 0.390s) error: protocol fault (no status) Waiting ... Removing NAND MPU restrictions via SEMC backdoor. Permanent. Require ROOT rights. 192 KB/s (3087 bytes in 0.015s) success Waiting ... Getting ROOT rights. Waiting ... Writing patched semcboot. Two step process First, we need get access to semcboot area 504 KB/s (8064 bytes in 0.015s) Second, we need to write semcboot ;) 1531 KB/s (588236 bytes in 0.375s) successfully wrote 0001ff80 Press any key to continue . . . Code:
process requires standard 2.x android firmware. Press any key to continue . . . Getting ROOT rights. 1743 KB/s (585731 bytes in 0.328s) error: protocol fault (no status) Waiting ... Removing NAND MPU restrictions via SEMC backdoor. Permanent. Require ROOT rights. 192 KB/s (3087 bytes in 0.015s) success Waiting ... Getting ROOT rights. Waiting ... Writing patched semcboot. Two step process First, we need get access to semcboot area 504 KB/s (8064 bytes in 0.015s) Second, we need to write semcboot ;) 1130 KB/s (596916 bytes in 0.515s) successfully wrote 0003ff00 Press any key to continue . . . BINGO, mobitel ima unlockan BOOTLOADER!!!!!!!!!!!! NAPOMENA: ako je mobitel unlocka bilo kojim alatom osim setool2 (jedino zasada "Omnius") nemojte unlockati BOOTLOADER jer ce se mobitel ponovo zakljucati i gubi se radio capability TRAJNO! Ako imate kakvih pitanja ili nesto, slobodno napistie Ako se ocitali mobitel i imate log njegov postati stavljajte ga ovako: Code:
tu log Svi TVORNICKI OTKLJUCANI MODELI SU PODRZANI. p.s. trebate imati adb drivere ![]() Za sva ostala pitanje/nejasoce post ovdje!! Bez krade tutorijala, LP Suradnik SETOOL2 Tima ![]() Zadnje izmijenjeno od: dekoder. 10.09.2011. u 19:18. |
Lokacija: Republica Crikvenica
Postovi: 1,194
imam x8 i idem to otključati m vrag neda mira dal može bez obzira koji je ROM gore da se to uradi ? nešto sam čuo da ima problema ako nije orginalni Sony ROM ? !!? x8 ima: SEMC SIMLOCK CERTIFICATE dakle trebam pokrenuti (jel to onaj Win Command Script fajl ?) u folderu msm7227_semc.cmd ? jel to to ? Treba li poslje i zaključati loader ? ili može da ostane kakav je ?..to mi nije jasno ? |
Postovi: 1,194
probao otključati, pojavi se početak kako treba , a onda cant find directories ..i slično i ne napravi ništa... imam ADB.exe uključen i isključen ista stvar, PC Com. , isto tako u čemu je fora, dal smeta što nije na c particiji ? komunikacija postoji dakle nekaj oko pronalaženja mjesta ga mući heljp , heljp log __________ process requires standard 2.x android firmware. Press any key to continue . . . Getting ROOT rights. * daemon not running. starting it now * * daemon started successfully * 780 KB/s (585731 bytes in 0.733s) - exec '/system/bin/sh' failed: No such file or directory (2) - - exec '/system/bin/sh' failed: No such file or directory (2) - Waiting ... Removing NAND MPU restrictions via SEMC backdoor. Permanent. Require ROOT rights . 17 KB/s (3087 bytes in 0.171s) - exec '/system/bin/sh' failed: No such file or directory (2) - - exec '/system/bin/sh' failed: No such file or directory (2) - - exec '/system/bin/sh' failed: No such file or directory (2) - Waiting ... Getting ROOT rights. - exec '/system/bin/sh' failed: No such file or directory (2) - Waiting ... Writing patched semcboot. Two step process First, we need get access to semcboot area 72 KB/s (8064 bytes in 0.109s) - exec '/system/bin/sh' failed: No such file or directory (2) - - exec '/system/bin/sh' failed: No such file or directory (2) - Second, we need to write semcboot ![]() 795 KB/s (596916 bytes in 0.733s) - exec '/system/bin/sh' failed: No such file or directory (2) - - exec '/system/bin/sh' failed: No such file or directory (2) - Press any key to continue . . . Zadnje izmijenjeno od: tigman. 27.09.2011. u 14:11. |
Postovi: 42
Flashaj 2.1 official firmware. Samo na njega ide. |
Postovi: 1,194
yu,, we did it ... sada san mirniji |
Postovi: 1,194
dakako nemože u mene da nema problema..., prestal mi je ujutro raditi WI-FI i nemogu čitati mobitelom SD lartivu ?!?!?!.., jučer je sve šljakalo , nisam niš dirao.. Uglavnom JOVO NANOVO sistem popravka je rezultirao trenutno da radi bez problema.., nadam se da nije puni mjesec i da preko noći ne mjenja oblike ! Dakako radi i na Tmobile i na svim drugim našim mrežama, ali i dalje me pita za onaj jebeni UNlock broj kada rebootam ..kaj se to nemre uzbaciti van ? |
Postovi: 42
MOZE IZGUBIO SI RADIO CAPABILITY. Trebas ponovo unlockat mob SETool-om i drzati offical firmware. Imas PM |
Postovi: 1,194
dakako to mi je palo na pamet.. i sada sam se opet vratio i sve radi... pitanje je Dokle ? nadam se višer od 24 sata ,,,joj |
Postovi: 42
neznam, ako zelis biti siguran odgovori na PM. |
Datum registracije: Mar 2011
Lokacija: Gotham City
Postovi: 519
stavljal sam 2.3 android na x10 mini i sad sam zaboravil krenal ... i lijepo u recovery reboota mobitel i sad mi neće se više upaliti tj. upali se i samo bjela slova sony ericsson. ne mogu uć u recovery ni neće se podići mobitel. ne mogu stavit android 2.1 ni ništa .... HELPPP |
Whatever :)
Datum registracije: Nov 2002
Lokacija: Rijeka,Bulevard
Postovi: 1,753
Pretpostavljam da imas najnoviji PC companion. Potreban ti je radi drivera. Flashaj sa Flashtoolom firmware i trebalo bi proci. Uglavnom procitaj malo ovaj topic sa xda,tu ces naci sve sto ti treba. http://forum.xda-developers.com/showthread.php?t=936733 Nadam se da sam ti pomogao.
#12 | |
Postovi: 519
nisam neki stručnjak za mobitele. dakle skinem Flashtool samo, il trebam i neke drajvere uz to jer na linku kaj si mi dal ima brdo toga?? EDIT: uspel sam i stavil sam gore Androdid 2.2 Fyoro il tak nekak .... i kak da ja sad dojdem do brojeva telefona koje sam imal na ANDROID 2.1?? .. imam backup na SD kartici al to je .sbf fajl i ne mogu ga otvoriti ... kopiral sam taj fajl na komp i jel moguće ikak doći do brojeva unutar tog fajla? Zadnje izmijenjeno od: beli14. 06.04.2012. u 20:17. |
Lokacija: hrvatska
Postovi: 3
![]() kao što rekoh ne mogu ga više upaliti. napravio sam sve kako je napisano. sve je bilo odrađeno kao na slikama. odjednom se mobitel ugasio i ne da se više upaliti. |
