Staro 18.07.2012., 22:31   #1
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Nvidia GeForce GTX 660 / GTX 660 Ti
NVIDIA's newest product designed to strike the price-performance "sweetspot," the GeForce GTX 660, is set for a mid-August market launch, according to a SweClockers report. The new chip could roll out some time between August 13 and 19. Given that other Kepler-based SKUs have been launched on Tuesdays or Thursdays, it's likely that the launch date could be either the 14th, or the 16th. The GTX 660 will be based on the 28 nm "GK104" GPU. It will feature 1,344 or 1,152 CUDA cores, and a 192-bit wide GDDR5 memory interface, holding 1.5 GB of memory, according to the report. The new GPU could capture a crucial sub-$300 price-point.
http://www.techpowerup.com/169113/Ge...st-Report.html
C L O W N I N G A R O U N D
Zadnje izmijenjeno od: Doink the Clown. 16.08.2012. u 11:35.
Staro 19.07.2012., 08:50   #2
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
joj vidjet cemo... nekako se bojim da ce karticu pokopat ovoliko rezanje memorijske sabirnice..
Bas nikako da dodu na zelenu granu sa balansom, sad imaju previse performansi chipa uz premalo memorijske propusnosti (cini mi se da primarno boost performansi 670 i 680 dobivaju od povecanja takta memorije), za razliku od ranije kad je situacija bila obrnuta.
goguse, gle mene sta ga s****, ionako su se te kartice trebale zvat sa jednim brojem nize u startu. Jedva cekam vidjet potrosnju, samo 1 pci-e power konektor?
Msi x79a GD65
Intel i7 3930k @ 4.7 1.4V
4x 4GB Kingston 1866 9-11-9
Gigabyte gtx 460 1gb
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Coolermaster Stacker 831
HP LP2065 / LG IPS231P
Windows 7 Enterprise
Trenutno nepostojeci
Staro 19.07.2012., 17:20   #3
MAGARAC
MAGARAC's Avatar
Postovi: 5,986
Nece bit problema sa preuskom sabirnicom jer su taktovi vrama izuzetno visoki i Nvidija ja na tom podrucju napravila ogroman napredak u odnosu na Fermi. Jedna 256bit gtx 680 ima i istu propusnost kao i 384 bit 580 pa racunajte sto more 192 bit u odn na reicmo 256 na fermijima. Perf jos uvijek najvise rastu zbog takta GPU. Imam gtx 670 i sve je tu ostalo isto sem sto memorija ide nusporedivo bolje i razlike se vidi prevenstveno u benchevima.
Bit ce to dobra grafa vjerojatno i bit ce zanimljivo vidit na kojim ce to taktovima radit i kak ce ic.
MAGARAC je online   Reply With Quote
Staro 26.07.2012., 20:29   #4
nexusone
Datum registracije: Apr 2008
Postovi: 139
According to the latest set of specifications scored by SweClockers, NVIDIA's upcoming performance-segment GPU, the GeForce GTX 660 Ti, is not much different from the GTX 670. The GTX 660 Ti is based on the 28 nm GK104 GPU, with 1,344 CUDA cores enabled - the same number as that on the GTX 670. What's more, the clock speeds don't differ between the two, either - 915 MHz core, 980 MHz GPU Boost, and 6.00 GHz GDDR5-effective memory.
The memory amount stays 2 GB, as well. It's just that the memory bus width is reduced from 256-bit to 192-bit, resulting in 25% lower memory bandwidth. The 2 GB of memory is spread across the 192-bit memory bus, probably with four chips using 32-bit wide paths each, with four other chips sharing two 32-bit wide paths. NVIDIA is known for pulling off such memory configurations, like it did with the GeForce GTX 550 Ti.
The other major component of the SweClockers report is the launch date. According to the source, NVIDIA will launch the GeForce GTX 660 Ti on August 16. We predict that the GamesCom event held in Cologne, Germany, which opens to the public on the same day, could serve as a launch-pad.
izvor
nexusone je offline   Reply With Quote
Staro 31.07.2012., 22:16   #5
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
danij3l je offline   Reply With Quote
Staro 31.07.2012., 23:08   #6
syss
syss's Avatar
Postovi: 10,805
samo za magarca - zvao je best buy i traži tvoju preporuku natrag
Staro 09.08.2012., 09:44   #7
Starsylph
Datum registracije: Oct 2010
Lokacija: Sfera
Postovi: 408
Kolika ce biti cijena kad dode kod nas?
Kojoj Ati GPU je ta GPu ekvivalentna po performansama ?
Starsylph je offline   Reply With Quote
Staro 09.08.2012., 10:17   #8
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
2. post iznad ti je review, pa malo prolistaj... Doduse cini se da stranica nije dostupna, imas na overclock.net forumu review...
Staro 09.08.2012., 10:30   #9
Full Throttle
Full Throttle's Avatar
Datum registracije: Dec 2009
Lokacija: Zagorje
Postovi: 872
kolko se sjećam pisalo je da bi u SAD-u koštala 200$. bilo kako bilo imam neki osjećaj da budu tu napumpali cijenu i do 2500 kn...
a ekvivalentna je 7950
Full Throttle je offline   Reply With Quote
Staro 09.08.2012., 10:43   #10
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Da, cijena kod nas sigurno nece biti usporediva s onom iz Us-a, to bi znacilo da nesto nije u redu s nasim trgovinama.. Performansama bi grafa tribala biti izmedju 7950 i 7970, tako se da naslutiti iz dostupnih reviewa..
Staro 09.08.2012., 11:06   #11
Starsylph
Lokacija: Sfera
Postovi: 408
Pa jel bude neka gtx kartica nove generacije ekvivalentna onome izmedu HD 7770 i 7850? 640 je dosta slaba, a valjda ce 660 biti preskupa kako kazete.
Da li ce Nvidia popuniti taj gap izmedju performanse i cijene?
I da li bude izasla HD 7780 ?
Staro 09.08.2012., 21:21   #12
gnomisa
gnomisa's Avatar
Datum registracije: Feb 2003
Postovi: 1,556
Mislim da bi 660ti mogla biti bestseller u HR......kad se cijene stabliziraju mislim da neće biti više od 2 soma kuna....za karticu koja puše za vratom 7970....
gnomisa je offline   Reply With Quote
Staro 09.08.2012., 21:44   #13
s7ank0
s7ank0's Avatar
Postovi: 117
Autor gnomisa Pregled postova
toplo se nadam posto si ju planiram nabavit...
s7ank0 je offline   Reply With Quote
Staro 09.08.2012., 22:40   #14
tole_
Casual Racist
tole_'s Avatar
Lokacija: Sneed's feed and seed (formerly Chuck's)
Postovi: 422
Sumnjam, pogotovo ako cijena zbilja bude $300. Naime toliko je vani hd7870 koja je u nasim ducanima oko 2300kn. Sad na tih 2300 dodas cjenovni premium koji, iz ne znam kojeg razloga, kod nas imaju nvidia kartice dodjes do cijene od bar 2500kn. Tu je vec hd7950 po meni daleko bolji izbor jer s upaljenim MSAA je bar za klasu bolja. No ajd, zivi bili, pa vidjeli
@Magarac
Iz onog TT reviewa. Jest da je rivju koma prvenstveno zbog odabira igara, ali recimo u AVP i Metrou se vidi da pri ukljucivanju MSAA performanse solidno opadaju. Bez AA je tu negdje sa 7950, s MSAA je u rangu 7850. Moguce da ju ogranicava skresana kolicina ROPa, gubi cak i od gtx580... No kazem, rivju nije nesto, pa je bolje pricekati nesto vjerodostojnije.
Zadnje izmijenjeno od: tole_. 10.08.2012. u 00:18.
tole_ je offline   Reply With Quote
Staro 09.08.2012., 22:54   #15
MAGARAC
MAGARAC's Avatar
Postovi: 5,986
Od kud ti to sa MSAA?
Staro 10.08.2012., 10:06   #16
Full Throttle
Lokacija: Zagorje
Postovi: 872
iz gornjeg reviewa pretpostavljam
Staro 10.08.2012., 10:35   #17
MAGARAC
MAGARAC's Avatar
Postovi: 5,986
Vidim..
Btw jako los izbor igri ko i obicno. Ne znaci to puno bez BF3, Skyrim itd,, Jedino je u AvP neka razlika ali ne znam ko to jos igra. Bit ce 660ti jeftinija od 7950 i perf. tu negdje. Prerano je rec da je jedna brza od druge jer jos nije ni izasla.
Evo I Hawk sa 3gb memorije..
http://www.techpowerup.com/170017/MS...ed-Tested.html
Zadnje izmijenjeno od: MAGARAC. 10.08.2012. u 10:46.
Staro 10.08.2012., 16:16   #18
gnomisa
gnomisa's Avatar
Postovi: 1,556
Autor MAGARAC Pregled postova
Vidim..
Ispada da će 660Ti imati 1.5 GB meme....
Staro 10.08.2012., 16:38   #19
s7ank0
s7ank0's Avatar
Postovi: 117
kolko sam skuzio 660 a ne 660ti ce imat 1.5gb...
Staro 10.08.2012., 18:26   #20
kripton
Cars & Tunning
kripton's Avatar
Lokacija: Vukovar - Rijeka
Postovi: 536
wtf, gtx 660 u svakom testu tuce gtx 580?!
to zbog 2gb naspram 1.5gb?
NovA Squadron
kripton je offline   Reply With Quote
Staro 11.08.2012., 10:36   #21
gnomisa
gnomisa's Avatar
Postovi: 1,556
Autor kripton Pregled postova
bit će da je stvar u novom chipu...haha
Staro 11.08.2012., 16:35   #22
vedranzeman
Lokacija: Kloštar Podravski
Postovi: 1,019
Stigla GTX 660 TI na cjenik(e) u HR, tko zna kad će na police.
Cijena "popularna" - 2639,49 kn za Gigabyte 660 TI OC verziju.
vedranzeman je offline   Reply With Quote
Staro 11.08.2012., 16:36   #23
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
EPIC
Staro 11.08.2012., 16:43   #24
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,144
Autor vedranzeman Pregled postova
kakav joke
sad mi je drago da sam uboo 570tku i da nisam cekao.
Staro 11.08.2012., 16:58   #25
s7ank0
s7ank0's Avatar
Postovi: 117
a u pm...nista od kupovine...
Staro 11.08.2012., 17:32   #26
MAGARAC
MAGARAC's Avatar
Postovi: 5,986
Jbg pa zna se koliko je 300$ kod nas. 300 eura + 10%. To je vec stari recept.
Staro 11.08.2012., 18:26   #27
s7ank0
s7ank0's Avatar
Postovi: 117
Zadnje izmijenjeno od: s7ank0. 11.08.2012. u 18:38.
Staro 11.08.2012., 18:31   #28
Full Throttle
Lokacija: Zagorje
Postovi: 872
haha, pa naravno. gamad uvoznička.
al nije ovo niš čudno, realna cijena s obzirom po kolko idu gtx 670.
Staro 11.08.2012., 19:40   #29
MAGARAC
MAGARAC's Avatar
Postovi: 5,986
S obzirom da se dobije grafa koja je mrvicu sporija od 7970 ili gtx 670 nije to uopce tak lose.
Jos je i WindForce OC model. Treba jos sacekat prave recenzije da se tocno vide perf..
Nerealno je ockivat dobit takve perf. po cijeni neke 7850 ili sl..
Mislim da ce 660 bit jos bolji izbor. AK joj ne skresu previse CUDA jezgri bit ce to zmaj od grafe i ta bi mogla bit nova 560ti..
Staro 11.08.2012., 19:50   #30
NeooS
NeooS's Avatar
Datum registracije: Apr 2009
Lokacija: na Zemlji
Postovi: 527
HD 7950 je bolja grafa svakako od GTX 660Ti a di tek HD 7970 !!
NeooS je offline   Reply With Quote
