Staro 02.07.2012., 18:37   #1
Multivitamin
Datum registracije: Mar 2009
Lokacija: Garešnica
Postovi: 49
mali broj FPS u igrama
pozz.evo,imam problem premalog(bar ja mislim premalog) FPS u igrama. Točnije u RIFT-u 5-15 (low postavke,max rezolucija 1920x1080),WoT 20-30fps,CoD4 110(smoke).Najviše me zanima rift,jer jednostavno nije moguće raditi raidove zbog tako malog fpsa.
konf
Win 7 64bit
Napajanje 550W Chieftec GPS-550AB-A
CPU Type QuadCore AMD Phenom II X4 Black Edition 940, 3000 MHz (15 x 200)
Motherboard Name Gigabyte GA-MA770-US3 v2.0 (2 PCI, 4 PCI-E x1, 1 PCI-E x16, 4 DDR2 DIMM, Audio, Gigabit LAN, IEEE-1394)
Disk Drive SAMSUNG HD103SJ ATA Device (1000 GB, 7200 RPM, SATA-II)
Disk Drive ST3250824A ATA Device (250 GB, 7200 RPM, Ultra-ATA/100)
Optical Drive Optiarc DVD RW AD-7200A ATA Device (DVD+R9:8x, DVD-R9:12x, DVD+RW:20x/8x, DVD-RW:20x/6x, DVD-RAM:12x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW/DVD-RAM)
Monitor AOC 2436 [24" LCD] (V5399HA003433)
Sapphire Radeon 6950 1GB DRR5
temp:
Field Value
Sensor Properties
Sensor Type ITE IT8720F (ISA 228h)
Motherboard Name Gigabyte MA770 / MA790FX / MA790GP / MA790X Series
Chassis Intrusion Detected Yes
Temperatures
Motherboard 45 °C (113 °F)
CPU 64 °C (147 °F)
CPU #1 / Core #1 61 °C (142 °F)
CPU #1 / Core #2 61 °C (142 °F)
CPU #1 / Core #3 61 °C (142 °F)
CPU #1 / Core #4 61 °C (142 °F)
SAMSUNG HD103SJ 46 °C (115 °F)
Seagate ST3250824A 48 °C (118 °F)
Cooling Fans
CPU 3000 RPM
Chassis #2 1180 RPM
Voltage Values
CPU Core 1.33 V
+3.3 V 3.34 V
+12 V 12.45 V
VBAT Battery 3.14 V
DIMM 2.05 V
probao sam s brisanjem,te ona reinstaliranjem drivera za grafičku,ali ništa.
M2N-E Green/AMD Athlon 64 3500+@2,24GHz/Ati Radeon x1600 512 MB DDR2/2x1GB Kingmax@667MHz/Seagate Barracuda 250 GB/Western Digital 80 GB/NoName PowerSupply 400W/MX518/MS Keyboard/17.1" Monitor/Integrated Digital HD Audio/Sennheiser HD 202/WinXP SP3
Multivitamin je offline   Reply With Quote
Staro 02.07.2012., 19:13   #2
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,533
Prosekeniraj sistem sa malwarebytes/hitman pro/trojan remover/antivirusom pa javi rezultate
Staro 02.07.2012., 19:15   #3
nino
nino's Avatar
Postovi: 12,607
To su idle temperature?
Staro 02.07.2012., 19:41   #4
Jooj
Jooj's Avatar
Lokacija: De
Postovi: 165
vjerojatno se pregrijava nešto (cpu - gpu) pa throttla
Jooj je offline   Reply With Quote
Staro 02.07.2012., 19:48   #5
Multivitamin
Lokacija: Garešnica
Postovi: 49
Autor QuidZz Pregled postova
probat cu,no nevjerujem daje problem virus,jer i nakon friske instalacije win7,opet sam imao malo fpsa.
@nino
da,idle.
Staro 02.07.2012., 19:53   #6
nino
nino's Avatar
Postovi: 12,607
Previsoke, moguce da ti throtla. Skini OCCT pa mu daj pola sata testa i grafove temperatura nam pokazi.
Staro 02.07.2012., 19:55   #7
njuskalo
njuskalo's Avatar
Lokacija: Remetinec
Postovi: 925
Ako je to idle onda je to previše u svakom slučaju. Provrti prime95 i gledaj temperature onda...
Ili OCCT kako nino kaže, još bolje jer možeš pokazat grafove. Baci oko i u kućište u kakvom stanju je hladnjak na CPU, da nije pun prašine...
njuskalo je offline   Reply With Quote
Staro 02.07.2012., 19:59   #8
Multivitamin
Lokacija: Garešnica
Postovi: 49
ma nije hladnjak pun prasine,bas sam ga jučer očistio,sve povadio van,ispuhao.imam paste na procu i na hladnjaku.
Staro 02.07.2012., 20:16   #9
njuskalo
njuskalo's Avatar
Lokacija: Remetinec
Postovi: 925
U svakom slučaju provrti neki test i gledaj temperature. Može bit da hladnjak dobro ne leži, ili da senzor laže. Ja sam imao problem s temperaturama na X2 5000+ BE, i na kraju sam skinuo IHS i vidio da je ispod očito prošlom vlasniku pobjeglo paste, a moguće da je bila neka vodljiva. Kad sam sve očistio i vratio IHS temp su bile OK... Al nebi ti preporučo da to radiš s ovim procom, kod mene je ipak bilo riječ o vijednosti 150kn (pošto mi je lik vratio neke novce jer je proc bio poluispravan)...
Staro 02.07.2012., 20:57   #10
Multivitamin
Lokacija: Garešnica
Postovi: 49
Staro 02.07.2012., 21:14   #11
njuskalo
njuskalo's Avatar
Lokacija: Remetinec
Postovi: 925
Po ovome ispada da je max temp za tvoj proc 62°C, znači da je ovih 80 previše. I čini se da ti throtla proc, po ovim padovima Vcore-a, al nek ti netko još kaže ko se bolje razumije u taj proc. Znači vrlo vjerojatno je problem u pregrijavanju proca ili laganju senzora. Probaj dok vrtiš test prstom hladnjak što bliže procesoru, ako nije vrel onda ili senzor laže ili hladnjak ne sjedi dobro...
Staro 02.07.2012., 21:33   #12
Nick7
Lokacija: Velika Gorica
Postovi: 1,515
Po slikama, CPU ti throttla jer se pregrijava.
Da li ti je hladnjak vruci na dodir dok se vrti OCCT?
Nesto ti definitivno ne stima.... jer su ovo ipak drasticno previsoke temperature.
Staro 02.07.2012., 21:39   #13
domy_os
domy_os's Avatar
Postovi: 18,836
Prozrači kućište i promijeni napajanje pa javi kakva je onda situacija.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 02.07.2012., 21:42   #14
nino
nino's Avatar
Postovi: 12,607
I meni nesto vuce na napajanje, kad vidim one ekg grafove.
Staro 02.07.2012., 22:25   #15
Multivitamin
Lokacija: Garešnica
Postovi: 49
evo power supply testa(samo 10ak minuta),nažalost morat ćete skinuti fail: http://www.2shared.com/file/MIVUwJC1/22-18.html
i da,nemam drugo napajanje,tako da bih morao ići kupiti drugo
Staro 02.07.2012., 22:42   #16
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,533
ako mozes posudi od nekoga pa testiraj..
Staro 03.07.2012., 13:59   #17
Multivitamin
Lokacija: Garešnica
Postovi: 49
nažalost morat ću kupiti,jer nemam od koga posuditi.(a i pare mi nisu problem).tako da nabacite neko napajanje koje će gurat to konfu još podosta dugo
Staro 03.07.2012., 14:28   #18
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,533
Staro 03.07.2012., 22:24   #19
Multivitamin
Lokacija: Garešnica
Postovi: 49
ok,nisam nabavio napajanje,no nasao sam stari proc
Amd athlon 64 x2 dual core 5200+
te sam snjime napravio 6minutno OCCT testanje proca( DL link http://www.2shared.com/file/4pajmkZI/22-20.html
Staro 04.07.2012., 08:02   #20
Multivitamin
Lokacija: Garešnica
Postovi: 49
mali update:sada mi nakon 8,15,3minute svako mali izbaci Error detected on Core #3.
slike:
http://www.easilysharing.com/images/...0662103827.png
http://www.easilysharing.com/images/...3290380413.png
http://www.easilysharing.com/images/...0606401585.png
http://www.easilysharing.com/images/...8384914382.png
http://www.easilysharing.com/images/...4137145696.png
http://www.easilysharing.com/images/...7927012028.png
http://www.easilysharing.com/images/...0072110496.png
http://www.easilysharing.com/images/...9809291953.png
http://www.easilysharing.com/images/...1921953919.png
http://www.easilysharing.com/images/...8224448355.png
http://www.easilysharing.com/images/...0193665016.png
http://www.easilysharing.com/images/...8135647563.png
http://www.easilysharing.com/images/...4498679964.png
http://www.easilysharing.com/images/...2162538623.png
http://www.easilysharing.com/images/...5456328253.png
http://www.easilysharing.com/images/...2872392574.png
http://www.easilysharing.com/images/...6233834653.png
http://www.easilysharing.com/images/...3678546761.png
http://www.easilysharing.com/images/...8692391718.png
Zadnje izmijenjeno od: Multivitamin. 04.07.2012. u 08:13.
Staro 04.07.2012., 11:50   #21
njuskalo
njuskalo's Avatar
Lokacija: Remetinec
Postovi: 925
Napravi Clear CMOS (izvadi bateriju na minutu dve, naravno, komp mora bit iskopčan iz struje). Također popipaj prstom hladnjak. Ovo sve sad zvuči da se proc pregrijava a može bit da je napajanje u k, ili da hladnjak ne sjedi dobro :S
Pregledaj za svaki slučaj sve kondenzatore po ploči, da nije koji napuhnut...
Staro 04.07.2012., 14:11   #22
Multivitamin
Lokacija: Garešnica
Postovi: 49
evo,jučer sam napravio clear CMOS,te sam jos nanesao novu pastu na hladnjak.hladnjak je vruc,nakon sto ga OCCTam (dakle mogao bi reci da je tih 75°C).evo sada sam imao 3 ta testa,2po 1.5minutu (error code),i jedna po 4minute (isto error code on core#0)
mislio sam promjenit matičnu i proc,a vidim dali bi imalo kakve promjene.
