Datum registracije: Mar 2009
Lokacija: Garešnica
Postovi: 49
mali broj FPS u igrama
pozz.evo,imam problem premalog(bar ja mislim premalog) FPS u igrama. Točnije u RIFT-u 5-15 (low postavke,max rezolucija 1920x1080),WoT 20-30fps,CoD4 110(smoke).Najviše me zanima rift,jer jednostavno nije moguće raditi raidove zbog tako malog fpsa. konf Win 7 64bit Napajanje 550W Chieftec GPS-550AB-A CPU Type QuadCore AMD Phenom II X4 Black Edition 940, 3000 MHz (15 x 200) Motherboard Name Gigabyte GA-MA770-US3 v2.0 (2 PCI, 4 PCI-E x1, 1 PCI-E x16, 4 DDR2 DIMM, Audio, Gigabit LAN, IEEE-1394) Disk Drive SAMSUNG HD103SJ ATA Device (1000 GB, 7200 RPM, SATA-II) Disk Drive ST3250824A ATA Device (250 GB, 7200 RPM, Ultra-ATA/100) Optical Drive Optiarc DVD RW AD-7200A ATA Device (DVD+R9:8x, DVD-R9:12x, DVD+RW:20x/8x, DVD-RW:20x/6x, DVD-RAM:12x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW/DVD-RAM) Monitor AOC 2436 [24" LCD] (V5399HA003433) Sapphire Radeon 6950 1GB DRR5 temp: Field Value Sensor Properties Sensor Type ITE IT8720F (ISA 228h) Motherboard Name Gigabyte MA770 / MA790FX / MA790GP / MA790X Series Chassis Intrusion Detected Yes Temperatures Motherboard 45 °C (113 °F) CPU 64 °C (147 °F) CPU #1 / Core #1 61 °C (142 °F) CPU #1 / Core #2 61 °C (142 °F) CPU #1 / Core #3 61 °C (142 °F) CPU #1 / Core #4 61 °C (142 °F) SAMSUNG HD103SJ 46 °C (115 °F) Seagate ST3250824A 48 °C (118 °F) Cooling Fans CPU 3000 RPM Chassis #2 1180 RPM Voltage Values CPU Core 1.33 V +3.3 V 3.34 V +12 V 12.45 V VBAT Battery 3.14 V DIMM 2.05 V probao sam s brisanjem,te ona reinstaliranjem drivera za grafičku,ali ništa.
M2N-E Green/AMD Athlon 64 3500+@2,24GHz/Ati Radeon x1600 512 MB DDR2/2x1GB Kingmax@667MHz/Seagate Barracuda 250 GB/Western Digital 80 GB/NoName PowerSupply 400W/MX518/MS Keyboard/17.1" Monitor/Integrated Digital HD Audio/Sennheiser HD 202/WinXP SP3 |
Lokacija: Sinj
Postovi: 3,538
Prosekeniraj sistem sa malwarebytes/hitman pro/trojan remover/antivirusom pa javi rezultate |
Postovi: 12,613
To su idle temperature?
Lokacija: Garešnica
Postovi: 49
Postovi: 12,613
Previsoke, moguce da ti throtla. Skini OCCT pa mu daj pola sata testa i grafove temperatura nam pokazi.
Lokacija: Remetinec
Postovi: 925
Ako je to idle onda je to previše u svakom slučaju. Provrti prime95 i gledaj temperature onda... Ili OCCT kako nino kaže, još bolje jer možeš pokazat grafove. Baci oko i u kućište u kakvom stanju je hladnjak na CPU, da nije pun prašine... |
Lokacija: Garešnica
Postovi: 49
ma nije hladnjak pun prasine,bas sam ga jučer očistio,sve povadio van,ispuhao.imam paste na procu i na hladnjaku.
Lokacija: Remetinec
Postovi: 925
U svakom slučaju provrti neki test i gledaj temperature. Može bit da hladnjak dobro ne leži, ili da senzor laže. Ja sam imao problem s temperaturama na X2 5000+ BE, i na kraju sam skinuo IHS i vidio da je ispod očito prošlom vlasniku pobjeglo paste, a moguće da je bila neka vodljiva. Kad sam sve očistio i vratio IHS temp su bile OK... Al nebi ti preporučo da to radiš s ovim procom, kod mene je ipak bilo riječ o vijednosti 150kn (pošto mi je lik vratio neke novce jer je proc bio poluispravan)... |
Lokacija: Garešnica
Postovi: 49
Lokacija: Remetinec
Postovi: 925
Po ovome ispada da je max temp za tvoj proc 62°C, znači da je ovih 80 previše. I čini se da ti throtla proc, po ovim padovima Vcore-a, al nek ti netko još kaže ko se bolje razumije u taj proc. Znači vrlo vjerojatno je problem u pregrijavanju proca ili laganju senzora. Probaj dok vrtiš test prstom hladnjak što bliže procesoru, ako nije vrel onda ili senzor laže ili hladnjak ne sjedi dobro... |
Postovi: 18,907
Prozrači kućište i promijeni napajanje pa javi kakva je onda situacija.
Postovi: 12,613
I meni nesto vuce na napajanje, kad vidim one ekg grafove. ![]()
Lokacija: Garešnica
Postovi: 49
evo power supply testa(samo 10ak minuta),nažalost morat ćete skinuti fail: http://www.2shared.com/file/MIVUwJC1/22-18.html i da,nemam drugo napajanje,tako da bih morao ići kupiti drugo ![]()
#17 |
Lokacija: Garešnica
Postovi: 49
nažalost morat ću kupiti,jer nemam od koga posuditi.(a i pare mi nisu problem).tako da nabacite neko napajanje koje će gurat to konfu još podosta dugo ![]()
#19 |
Lokacija: Garešnica
Postovi: 49
ok,nisam nabavio napajanje,no nasao sam stari proc Amd athlon 64 x2 dual core 5200+ te sam snjime napravio 6minutno OCCT testanje proca( DL link http://www.2shared.com/file/4pajmkZI/22-20.html
#21 |
Lokacija: Remetinec
Postovi: 925
Napravi Clear CMOS (izvadi bateriju na minutu dve, naravno, komp mora bit iskopčan iz struje). Također popipaj prstom hladnjak. Ovo sve sad zvuči da se proc pregrijava a može bit da je napajanje u k, ili da hladnjak ne sjedi dobro :S Pregledaj za svaki slučaj sve kondenzatore po ploči, da nije koji napuhnut... |
#22 |
Lokacija: Garešnica
Postovi: 49
evo,jučer sam napravio clear CMOS,te sam jos nanesao novu pastu na hladnjak.hladnjak je vruc,nakon sto ga OCCTam (dakle mogao bi reci da je tih 75°C).evo sada sam imao 3 ta testa,2po 1.5minutu (error code),i jedna po 4minute (isto error code on core#0) mislio sam promjenit matičnu i proc,a vidim dali bi imalo kakve promjene.
