to sam napisao u prvom postu da neki pišu o tome da preko DVI sve radi ali kao što sam napisao problem je onda što moj LCD ima samo D-SUB i HDMI. Imao sam HDMI<--->DVI i sad mi je HDMI<--->HDMI i problem je i dalje isti.Preko D-SUB nisam ni probao pošto mi grafička nema D-SUB
#272 |
Datum registracije: Jun 2012
Postovi: 133
probaj i ovo pritisni Ctrl+Alt+F11 i igra bi trebala ići u fullscreen |
#273 |
Datum registracije: Nov 2011
Lokacija: Internet
Postovi: 782
#274 |
Postovi: 133
Evo još savjeta:As some of you who may noticed (those who have widescreen panels and are into retro-gaming or play games at anything other than your desktop resolution), there's a bug in the ATI drivers for Windows 7 (maybe Vista, don't know) that disables scaling and doesn't let you pick any scaling options. Thus we're stuck into Flattenedville any time the resolution is not widescreen. Here's the fix: - Set your resolution to anything below your usual resolution. - Hit the CCC - Top left, click "Graphics", and "Desktops & Displays" on the pulldown menu. - For your desired display, click the little black triangle in the bottom part of the screen, on the LITTLE picture, not the BIG one, and click "Configure". - The scaling options will now be selectable, check the "Enable GPU scaling" box and select "Maintain aspect ratio". Hit Apply. - Set your old resolution back. Even though the forementioned scaling controls are greyed out and you can actually see "Scale image to full panel size" grey-selected, don't worry. - Go play your games! Tested under Windows 7 RTM and Catalyst 9.8 drivers. I još jedan bitan:hey people i got the solution for people who has ATI video card, but sorry Nvidia people cant help urs cause i have ATI and dont know about Nvidia. Now this method worked for me.i don't say that its foolproof solution but its worth trying & befor trying this method update your ATI driver to the latest version(one which is compatible with windows 7).So here we go: 1. set your screen resolution to 1024*768 (lower than highest).to do this simply right click on your desktop,choose screen resolution and change resolution in resolution box. 2.now go to ur ATI catalyst control centre.to do this,right click on desktop and the top most choice is ATI catalyst control centre. 3.choose advanced settings. 4.choose "desktop and display".click on "graphics" on top left corner. 5.now right click on laptop picture in lower bar(in my case there is only on laptop picture in lower bar having "1" in circle on its left top corner) 6. choose "configure..." 7. Now select "Full Screen" from three options. 8. Click "Apply" & then "Ok". 9. Now change back your Screen resolution to original. p.s:if you are unable to choose "Full Screen" in ATI catalyst control centre then change your screen resolution(first try with decreasing it,if it doesn't help try increasing it) and then try again with ATI catalyst control centre. Bingo ,we are done!!! Now try to run your game,it should run in full screen.atleat it did for me. Zadnje izmijenjeno od: Jelc. 26.06.2012. u 21:00. Razlog: dupli post... |
#275 | ||
Lokacija: Internet
Postovi: 782
![]() ![]() ![]() kad smanjim rezoluciju mogu stavit opciju na maintain aspect ratio: ![]() čim vratim na 1920x1080 vrati se na problem: ![]() Zadnje izmijenjeno od: d0magoj_OS. 26.06.2012. u 18:56. |
#276 |
Postovi: 133
koji imaš direct x? |
#278 |
Postovi: 133
Znao sam to shranje od 11-ice uvijek stvara probleme,ništa onda ovako uninstall tog istog pa restart pa na update da ti povuče novi kad završi probaj ponovo igre. |
#279 |
Lokacija: Internet
Postovi: 782
napravio sam to odmah na početku instalacije windowsa, ![]() nakraju jedini način je DVI-DVI a to mi znači mjenjati monitor ili mjenjati grafičku opet :S ili netko ima još ideja? Zadnje izmijenjeno od: d0magoj_OS. 26.06.2012. u 19:35. |
#281 | |
Lokacija: Internet
Postovi: 782
obrisao sve drivere i resetirao,instalirao 12.4 i resetirao, Citiraj:
#283 |
Lokacija: Internet
Postovi: 782
u početku nije zato što sam to napravio i nije radilo,...ovaj put kad sam napraivo sam isto ušao u igru i problem je bio isti i nakon 2,3 minute slika je postala preko cijelog ekrana,...nemogu reć ni 100% da je to riješenje pošto sam opet i brisao directx i instalirao,updateao više ni sam neznam,s tune up radio svašta...iskreno ako hoćeš neznam šta je točno popravilo ovo ali zadnje što sam radio je bilo to što je domy napisa,uostalom googlaj malo vidjeti ćeš da hrpa ljudi ima ovaj problem i svatko je riješio problem na drugačiji način. |
#285 |
Postovi: 47
Bog svima,može jedna molba,neznam da li je prava tema za to,ali da ne otvaram novu. Možete li mi reći kolike su vam temperature na vašim 6870 po mogućnosti xfx ali one prve s referetnim coolerom što gura zrak kroz cijelu grafičku. Konkretno me zanimaju temp gpu-a i meme u furmarku sad u ljetnom razdoblju. Hvala unaprijed na odogovrima. |
#289 |
Postovi: 1,398
Jel može mišljenje o ovoj kartici- http://www.zagria.hr/38689-sapp-hd-6...5-hdmi-dvi-mdp Dakle, prodao sam svoju GTX 470 i tražim nešto sličnih performansi. Cijena je po meni odlična, jel ima kakva "caka"?! Probao sam naći 560Ti, al nema ništa na tržištu rabljenih..nova mi preskupa. Zadnje izmijenjeno od: BojanZD. 06.07.2012. u 12:16. |
#290 |
Datum registracije: Jun 2010
Postovi: 3,319
Nema nikakvih caka osim što je tvoja GTX 470 jača bila. |
#291 |
Torrent freek
Postovi: 3,946
? Pa HD6870 se kreće u tom rasponu, cijena je li-la kao i drugdje. Inače taj hladnjak lipše figura, nešto šta je nešto pretjerano efikasan, al obavit će svoj posao ![]()
#292 | |
Lokacija: Sinj
Postovi: 3,533
#293 |
Postovi: 1,398
Znam ja da je bila jača, al tih 10-15% mi ništa ne znači. Ja u biti tražim rabljenu 560Ti, al nema ih nigdje pa ako ne nađem, treba mi alternativa. ![]() To te pitam, thanx!! Da se svi ne pitate zašto sam prodao 470 pa sad tražim nešto "isto" il slabije-lud nisam,samo prelamam garancije.Tražim grafu sa novom garom ili barem preko godinu dana-tak uvijek radim s grafama! |
#294 |
gadget freak
Lokacija: Jasenovac
Postovi: 2,224
Ne pričaj gluparije. Pogotovo u bc2 i bf3 koje kolega najviše igra su sasvim ujednačene. Još dodatni + za 6870 je manje zagrijavanje i manja potrošnja struje. No ako baš moraš kupovat odmah, uzmi tu 6870, ako se možeš strpit, čekaj na tržnici 6950, zna ih počesto bit. ![]()
#295 | |
Lokacija: Sinj
Postovi: 3,533
#296 |
gadget freak
Lokacija: Jasenovac
Postovi: 2,224
#297 |
Lokacija: Sinj
Postovi: 3,533
#298 | |
Postovi: 1,398
Ustvari sam fokusiran najviše na 560Ti, ali sad ih ko za vraga, uopće nema po oglasnicima, tak da i ATI dolazi u obzir. Nije bitno dal je to 6870 nova ili 6950 rabljena, samo da je gara barem godinu dana i da nije više od 1300kn. Strpit se mogu neko vrijeme,al nekako nema baš grafi za birat? Rado bi da je dual fan..samo neznam koliko mogu birat za te pare... |
#299 |
Postovi: 3,319
@jopis Otkud ja znam koje igrice on igra ... GTX 470 je sveukupno jača, a što se tiče potrošnje i zagrijavanja to je druga priča i oni su naravno strani HD 6870. A što se tiče nabavke druge grafe, strpi se malo sigurno će se pojaviti koja GTX 560 Ti. |
#300 | |
gadget freak
Lokacija: Jasenovac
Postovi: 2,224
Imao sam dilemu kad sam slagao frendu komp prije 18mj, između 6870 i 470, i uspoređivao ih na svim relevantnim i nerelevantim stranicama i testovima. Na kraju smo uzeli msi 6870 tf2 i prezadovoljan je s grafom i performansama. Ako ne vjeruješ, odi na anandtech gpu 2011, pa na gpu 2012 i provjeri ![]() ![]()
