Staro 23.06.2012., 19:51   #301
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,741
Ako ti pise S-OFF u hbootu,onda te revolutionry vise ne zanima. Napravis ext particiju preko recoveryja ,i probas fleshati rom. Ako ne ide,odaberi neki drugi rom i probaj drugi.
Da. Piše S-OFF.
AKo napravim novu EXT particiju iz Recovery-a; što će biti sa starom koju sam već napravio u gpartedlive?
A ako bi išao na neki drugi custom ROM, što mi preporučate uz sl. uvjete:
1. stabilno
2. brzo
3. štedljivo (baterija)
4. sense...
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
Zadnje izmijenjeno od: estugarda. 23.06.2012. u 20:00.
estugarda je offline   Reply With Quote
Staro 23.06.2012., 20:05   #302
Autor estugarda Pregled postova
1. stabilno
2. brzo
4. sense...
ja sam koristio Aurora v4.1. bio je odličan ROM i sve karakteristike koje si naveo je imao. sad koliko vidim već su na v6.
http://forum.xda-developers.com/show...ghlight=aurora
Staro 23.06.2012., 21:15   #303
Postovi: 10,047
A ako bi išao na neki drugi custom ROM...
Ovo nije preporuka već samo test rom da utvrdiš ispravnost vlastitih koraka (da li je mob ok, ext na mjestu itd). Uđi u recovery, napravi full wipe i flešaj ovo:
http://download.oxygen.im/roms/updat...avo-signed.zip
Nikakav RIL, nikakav naknadni wipe, samo ta tri koraka. Pričekaj 5min da se boota. Ako se ne buta nešto nije ok i morat ćeš proći korak po korak dijagnozu ili vratiti stock rom i krenuti ispočetka.
Staro 24.06.2012., 10:45   #304
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Krenuo sam od početka. Rootao i stavio S-OFF preko Revolutionary-a. Nakon 20min, FCova i reseta je proradilo. Sad radi. Nije loše, ali ne čini mi se ništa brže od stocka. Možda se malo "slegne" s vremenom.
Ali definitivno je prekomplicirano za instalaciju...
Ovo je najkompliciraniji i najzbrčkanije dokumentiran (iako ima brdo materijala i uputa, odnosno baš zato) proces flashanja s kojim sam se do sada sreo, a flashao sam zbilja svašta; WM2003, Symbiane svih vrsta, WM6, WP7, Android na Prestigio i HD2, iOS...
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 24.06.2012., 11:15   #305
Postovi: 10,047
Gle, svaka tebi čast što si sve to pohvatao u jedan dan Mnogi bi se predali nakon utvrđivanja verzije bootloadera.
Drugo, rom koji si izabrao je možda prevelik zalogaj za početak, a i smrdi mi na kravu muzaru za donacije jer ovaj tip koji ga "developa" izgleda kao klinjo željan eura. Developer koji se kuži u tematiku ti nikada neće reći, citiram, da su preduvjeti za ovaj rom "Latest radio and RIL" kada se zna da rom overwritea bilo koji prethodno flešani RIL. Uostalom, cijela ta fama oko RIL-a je jako labava i pored činjenice da njegov rom već dolazi s nekim RIL-om, ništa nećeš postići flešanjem neke druge verzije. "OLD USERS RUNNING Runny ROM v1.0 and above Wipe Dalvik Cache" - strašno da jedan developer roma još uvijek savjetuje ovo.
Staro 24.06.2012., 11:26   #306
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Da. "Strašno" je feeling koji konstantno prati flashanje ovog ROMa. Iznenadilo me da je flashanje Android-native Desire-a (generalno, ne samo ovaj ROM) kompliciranije od flashanja Androida na HD2 (1h max, bez iskustva flashanja Androida na HD2).
I CM7 ROM (konkretno Typhoon) na HD2 definitivno radi brže nego Runny na Desire. Možda je do Sensa...
Općenito mi se Desire sekcija na xda čini jako zbrčkanom. Na HD2 je sve nekako logično. I na SE Xperia 1 je bilo isto tako.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 24.06.2012., 13:41   #307
Postovi: 10,047
Meni realno nijedan Sense, a pogotovo neki malo teži rom koji jedan dio sistema kopira na ext, nije radio jednako glatko kao CM7, Oxygen i ostali derivati iz AOSP-a. Zadnjih godinu dana sam proveo na Oxygenu i uz konstantno isprobavanje MIUI i CM7 romova uvijek sam se vraćao njemu jer svaki mi se ponašao lošije. Uvijek neki problemi, sitni lagovi itd... Ako ti Sense ne znači previše, probaj nešto od AOSP ponude ali budi spreman na odricanje.
I ja sad kad sam prešao na Samsunga kužim kako je HTC za nekoliko koraka kompliciraniji za shvatiti
Zadnje izmijenjeno od: spawn. 24.06.2012. u 16:13.
Staro 25.06.2012., 12:38   #308
E dečki moji, pogotovo ti xlr, si me totalno sada bacio u očaj a čuj, stvar je odabira, vidiš da neka ekipa trpa portane ICS ROM-ove na kojima pola toga ne radi.
aj sad jedno ovako banalno pitanje. Što to ima, tj. nema ROM koji nema Sense? koja je fama oko tog Sensota anivej?
Staro 25.06.2012., 15:42   #309
Postovi: 10,047
Neka me nitko krivo ne shvati, ne blatim Sense romove niti želim bacati ljude u očaj jer je sve to stvar ukusa i osobnog odabira. Davno sam prestao ljudima davati preporuke za (meni osobno) dobre romove jer to nema smisla. To je kao da ljudima daješ preporuku koji auto da kupe i onda ti kažu "a jebemu, nema držač za čaše"
Portanje romova je jedno, pogotovo ako je ICS u pitanju jer isti nikada neće doći i službeno, ali cherry picking raznih hackova i kompajliranje builda sa svojim imenom na njemu je nižerazredni developing. Barem ja to tako vidim... I onda takav developer skuplja donacije na svoj account, a napravio je što točno? Povukao repose i par sati kuhao rom. I takvo mišljenje imam kako za Sense, tako i za AOSP romove, bez iznimki. Onda isti taj u changelogu piše gluposti kao "improved battery life, camera fix, wifi boost" i sl. Daj mi link na github/gerrit code review/biloštadrugo ti mućki provokatoru
Teško za reći i VRLO je individualno. Meni AOSP rom ima sve što mi treba, a nema Sense Tebi će osjećaj možda biti kao da ti je netko odrezao ekstremitet. Mislim da bi trebao probati oba da bi shvatio prvo koliko toga gubiš, a nakon toga da li ti je to stvarno bilo potrebno ili postoji li zamjena za stvari koje ti nedostaju sa Sensea. Moj je prelazak bio težak jer u ono vrijeme nije bilo tako dobrog AOSP Froyo roma i svi su bili s istim bugovima. Gingerbread je još više pogoršao stvar, ali danas je to već druga priča.
Probao sam nekoliko popularnih Sense 3/3.5 romova... Jbga, nije mi to to kada su u pitanju performanse. Mob moram vrtiti na 1GHz, lag se pojavljuje, a ja tu ne mogu ništa. Usporedbe radi, Oxygen najnormalnije radi na 768MHz. Da baš moram, bazirao bih se na Sense 3 romovima.
Da me ne krenete sada razapinjati, sve ovo je moje mišljenje koje je razvijeno unazad 2 godine. Nije isključeno ni da su mi isprali mozak.
Staro 25.06.2012., 18:24   #310
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Ako se mene pita, Sense je nepotreban na Androidu, za razliku od WM6, gdje je spasio stvar. Ali to je druga priča.
Nepotreban je zato što usporava sučelje, a sve što on može, mogu i custom widgeti i aplikacije. Ako se koristi Sense u cjelosti, onda ima smisla, jer bi custom widgeti tih količina vjerojatno usporili stvar i više. Ako se koristi samo jedan dio, recimo samo HOME i lock, onda je od njega više štete nego koristi.
Ja sam ovaj put išao na ROM sa Sensom zato jer se radilo o mobu moje cure koja je već dugo na Sensu, i nije htjela promjenu u tom smislu. Ja osobno tjeram čisti CM7 na HTC HD2 i mogu reći da djeluje dosta brže...
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 27.06.2012., 09:31   #311
martantoni
Datum registracije: Aug 2009
Postovi: 59
Huawei U8160
dobio sam taj telefon na poklon iz CH, zelio bih mu staviti android 2.3, mislim da nema oficijelnu podrsku za 2.3, tako da treba custom rom, koji je najbolji, dakle treba ga rootati i clock work mod recoveri...
ima li neko dobre linkove za to...
i za kraj, kako ga najlakse otkljucati....
thanks
martantoni je offline   Reply With Quote
Staro 27.06.2012., 10:40   #312
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Dok ti se ne javi netko sa iskustvom s tim modelom i rootanjem, ja bih na tvojem mjestu počeo čitati ovo:
http://forum.xda-developers.com/show....php?t=1259739
Iako, ne vjerujem da ćeš nešto bitno postići flashanjem na GB, s obzirom na hardverska ograničenja. Ako se dobro sjećam te faze prelaska sa 2.2 na 2.3 na slabom hardveru, froyo je bolji za slabiji hardver. Mislim da bi na tom modelu imao više koristi od rootanog i oćišćenog Froya.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 27.06.2012., 15:47   #313
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,535
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 27.06.2012., 16:27   #314
bronsky
Datum registracije: Jun 2012
Lokacija: karlovac
Postovi: 1
trebam pomoć oko htc hd2, stavio bih android 4 ali mi guglanje nije jača strana, tek sam ga nabavio a ovaj njegov operativni je katastrofa s obzirom da sam na galaxyju 3 imao android kojeg sam bio rootao i updetao ali zaboravih kako se to radi...neki link mi okačite ako ga znate... Hvala
bronsky je offline   Reply With Quote
Staro 29.06.2012., 12:44   #315
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,535
Najveća zamjerka Andoidu, glatkoća GUI-a, sada je valjda ispravljena.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 01.07.2012., 13:55   #316
Banx
Banx's Avatar
Lokacija: Čepin
Postovi: 258
ima li kakva odlicna apk za provjeru data prometa,sto i koliko trosi...???
thanks
Banx je offline   Reply With Quote
Staro 01.07.2012., 21:20   #317
dinos3
Dino Saur
dinos3's Avatar
Datum registracije: Jan 2012
Postovi: 940
ako imas ICS onda idi u postavke -> mobilna mreza (tako nesto)
dinos3 je offline   Reply With Quote
Staro 01.07.2012., 22:57   #318
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Autor Beelzeboss Pregled postova
thanks
Meni su preporučili 3GWatchdog i mogu reći da mi je točan skoro u KB. Za Tele2 je važno samo staviti da je blok po kojemu računaju promet 10KB (imaš u postavkama).
Staro 05.07.2012., 11:45   #319
OuttaControl
OuttaControl's Avatar
Lokacija: Dalmacija
Postovi: 5,797
gotovo, odustajem, 3 sata izgubljena na rootanje desirea, a unrevoked uporno neželi prepoznati uređaj , odnosno windowsi mi napisu u other devices ADB sa usklicnikom i da si bog nemos mu instalirat drivere,
a u hboot menuu ga normalno instalira...
Staro 05.07.2012., 12:25   #320
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,535
U prvom posu je opisano kako sam davnih dana instalirao problematične drivere. Ako baš ne ide, bootaj live Ubuntu i rootaj.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 05.07.2012., 13:06   #321
Postovi: 10,047
Dobro si rekao, 3h izgubljena na rootanje, umjesto da ih uložiš na otkrivanje alternative. I još ti ostanu 2h za večeru s curom
Mislim da bi Unrevoked trebao potpuno ukinuti podršku za rootanje iz Windowsa Bootaj Slax i rootaj mob. Slax iz razloga što odmah imaš aktivan root, mislim da na Ubuntu moraš prvo zatražiti root kroz terminal...Nisam neki Linuxaš, ali da ne bi bilo opet 3 sata u vjetar.
Staro 10.07.2012., 12:44   #322
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,535
Ako nekog zanima, Jelly Bean source je dostupan a i CM10 je u planu. Svi koji ispunjavaju preduvjete za CM9 trebali bi vrlo brzo dobiti i CM10.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 10.07.2012., 12:52   #323
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
vidio baš neki dan na xda, CM vrlo brzo ide na JB, iako već i sad ima polovičnih portova po romovima s nekim detaljima iz JB-a
Staro 10.07.2012., 23:39   #324
sti
Lokacija: Lawl
Postovi: 1,375
Evo trebam neke savjete. Imam Arc S i stavio sam na njega ICS 4.0.4.
Sad sam ga mislio flashat sa nekih custom ROM-om i rootati. Prije ovog mobitela sam imao Huawei U8650 i na njega sam stavio debrandirani ROM (originalni), te ga nakon toga rootao.
Sad me zanima kako da to napravim sa ovim mobitelom. Može li mi netko ukratko predložiti neki custom ROM i kako ga flashati, te rootati telefon (s kojim programom)? Hvala.
Staro 10.07.2012., 23:57   #325
Banx
Banx's Avatar
Lokacija: Čepin
Postovi: 258
"There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die."
Staro 15.07.2012., 14:11   #326
ECHO
Lokacija: CROATIA-Vukovar
Postovi: 2,354
Postoji li opcija da se preko Team viewera roota uređaj(HTC Desire gore je Frojo 2.2) za mene je to špansko selo i preveliki zalogaj pa bi ako je to moguće probao naći nekoga tko bi to napravio uz neku naknadu naravno ili netko ko je u OS ili VU.
Nadopuna upita podatkom koji sam trebao navesti sorry.
Zadnje izmijenjeno od: ECHO. 15.07.2012. u 21:00.
Staro 15.07.2012., 16:52   #327
Postovi: 10,047
Koji uređaj? Neke je lakše rootati nego što misliš.
Nvm, vidim u drugoj temi da je Desire u pitanju... I'm out
Staro 18.07.2012., 19:50   #328
stef_zg
stef_zg's Avatar
Postovi: 19
provjera data prometa
thanks
3G Watchdog je izvrstan,barem meni
stef_zg je offline   Reply With Quote
Staro 18.07.2012., 22:35   #329
Vuco
Vuco's Avatar
Postovi: 9,505
Autor stef_zg Pregled postova
+1
Meni ga preporučili i od tada gađa skoro u KB točno promet. Samo sam kod TELE2 stavio da računa u blokovima od 10KB (tako i ide u mreži).
Staro 19.07.2012., 13:21   #330
Take
bliss_zg - take, muljanje na tržnici
Datum registracije: Oct 2011
Postovi: 181
Pozdrav, koji je zadnji sluzbeni soft za Xperiu Arc S? Na njemu je gore dosao 2.3.5. i kada odem na updeat softwera na njemu pise da je zadnji soft gore, a na kutiji pise "Upgreadable to 4.0", pa ako moze pomoc oko toga, kako da stavi najnoviji sluzbeni?
Take je offline   Reply With Quote
