Postovi: 7,703
msi k8n neo2 platinum
ima li tko iskustava s MSI K8N Neo2 platinium s socketom 939 i kakva je? ploča ima nForce 3 Ultra a evo opis: CPU • Supports Socket 939 for AMD® Athlon™ 64 FX / Athlon™ 64 processor • Supports up to 3500+, 3800+ Athlon 64 FX 53, or higher CPU • nVIDIA® nForce3 Ultra Chipset - HyperTransport link to the AMD Athlon 64/Athlon 64 FX CPU - HyperTransport supporting speed up to 1GHz (2000MT/s) - AGP3.0 8X interface at 533 MT/s (million transfers per second) - Two independent SATA controllers, for four drives - IEEE 802.3 NVIDIA MAC for 1000BASE-T - Dual Fast ATA-133 IDE controllers Main Memory • Supports dual channel DDR 266/333/400, using four 184-pin DDR DIMMs . • Supports a maximum memory size up to 4GB without ECC. • Supports 2.5v DDR SDRAM DIMM. Slots • One AGP (Accelerated Graphics Port) 1.5V 4X/8X slot • Five 32-bit v2.3 Master PCI bus slots (support 3.3v/5v PCI bus interface). On-Board IDE/SATA • An IDE controller on the nVIDIA nForce3 Ultra chipset provides IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA133/100/66 operation modes. - Can connect up to 4 IDE devices • Supports 4 SATA ports. Transfer rate is up to 150MB/s. • NV RAID (Software) • Supports up to 4 SATA & 2 ATA133 Hard drives - RAID O or 1, 0+1, JBOD is supported - RAID function work w/ATA133 + SATA H/D or 2 SATA H/D Audio • 7.1 channel audio codec RealTek ALC850. - Compliance with AC97 v2.3 Spec. - Meet PC2001 audio performance requirement. LAN • Supports dual LAN jacks - 1 LAN supports 10/100/1000 Fast Ethernet by Marvell 88E1111 PHY - 1 LAN supports 10/100/1000 Fast Ethernet by Realtek 8110S (1000Mbps) IEEE1394 • VIA 6306 chipset - Supports up to 3 x 1394 ports. - Transfer rate is up to 400Mbps On-Board Peripherals On-Board Peripherals include: - 1 floppy port supports 2 FDD with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes - 1 serial port - 1 parallel port supports SPP/EPP/ECP mode - 1 Audio jack(5-in-1), coaxial/fiber SPDIF out - 8 USB 2.0 ports (Rear x 4 / Front x 4) - 2 RJ45 LAN jack - 3 IEEE 1394 connectors (Rear x 1/ Front x 2) BIOS • The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and expansion cards of the board automatically. • The mainboard provides a Desktop Management Interface(DMI) function which records your mainboard specifications. Dimension • 30.5cm(L) x 24.5cm(W) ATX Form Factor Mounting • 6 mounting holes. |
Lokacija: Ispred kompa
Postovi: 2,004
sig govori sve .to ti je najbolja AGP ploca za 939. ima najmane bugova i relativno dobra za ocing (s obzirom na mogucnosti 64-cetvorki kaj dolaze kod nas). ak trebas AGP plocu najbolji izbor ali ak mislis ici na neke novije dakle PCI-E radje zemi DFI NF4 plocu.
#3 | |
Datum registracije: Jun 2004
Lokacija: Xindi weapon
Postovi: 441
Datum registracije: Sep 2002
Postovi: 278
I moj glas za K8N Neo2 Platinum! Izasao novi BIOS 1.5: http://www.msi.com.tw/program/suppor...UID=607&kind=1 - Update NVPXE version to 2.03.0469. - Update CBROM version to 1.47. - Update NVRAID version to 4.81. Zadnje izmijenjeno od: N!NO. 11.03.2005. u 12:23. |
Postovi: 2
Kakva su vasa razmisljanja u svezi MSI K8N Neo4 Platinum ploce?Ima li itko iskustva s njom? |
#6 | |
Postovi: 2,004
#7 | |
Postovi: 2,560
![]() šteta kaj još skupljam lipe po stanu za Mbo ![]() |
Postovi: 1,313
hmh
:confused: jel neko zna sta im dojdu one skracenice u opisu ispravki novog biosa za MSI K8N Neo 2 Platinum odnosi se na zanji BIOS 1.5 - Update NVPXE version to 2.03.0469. - Update CBROM version to 1.47. - Update NVRAID version to 4.81. ![]() |
Postovi: 278
Eto da malo pohvalim plocu... Jucer sam je malo isprobavao i dobio stabilan rad na 300 x 7 na 1,5V i memorija 300 8-4-4-2,5 2T na 2,75V. Procesor na zalost nece stabilno raditi na 300x8, ali na 300x7 radi super. Polovicne mnozitelje ne koristim iz vjerskih razloga Eto i mene u klubu 600 No stroj vozim na 290x8 s memorijom na 241 6-3-3-2,5 1T jer je tako dosta brzi u svim testovima. |
Datum registracije: Jul 2003
Lokacija: Croatia/Zagreb
Postovi: 43
Ploca je fenomenalna,toplo je preporucam nemam nikakvih zamjerki. |
Postovi: 278
Novi BIOS 1.6: http://tinyurl.com/5xa6q - Fix when CPU Temperature over 40.C and then to restar system the CPU Temperature still show 40.C - Make the CPU FAN Starup Voltage over 6V - Fix LAN BOOT function fail after update NVPXE 2.03.0469 |
Ancient
Lokacija: Đakovo
Postovi: 894
Stigla i moja--NAPOKON- pa da odmah pitam;jel to normalno da neda memoriji u 3 slota(isprobano-definitivno-kada imam u 2 slota sve ok ali kada probam i u treći,neće)bilo koji od ova 3 izvadim i radi-znači svi su ispravni. |
#16 |
Postovi: 278
#21 |
Ancient
Lokacija: Đakovo
Postovi: 894
Pa sad više ne kužim.Nešta opet dobro neradim-neće recimo 240 dignuta voltaža čak probao i to a memorija onako na 166 pa je ukupno cca 390---- a radi evo sad na 11x225 sinkrono i sve ok znači 2475 MHz momentalno i mema 450 i sve to na 1.55V.....probao sam i na 235 sinhro ide a ako ne neide;zaključak:negdje hebem. Ajde molim neka netko posta svoje postavke iz biosa(bez latencija meme) pa da skužim gdje griješim--neke 240-50 npr a memorija asinhrono 166-znači 210-tak:confused:
#24 |
Postovi: 278
Novi BETA BIOS 1.8 normal i modded: http://www.zen15326.zen.co.uk/MSI_K8N_NEO2_BIOS/ |
#27 |
Ancient
Lokacija: Đakovo
Postovi: 894
Aha,ok-a mene i dalje nabrijavanje hebe. korumpira mi hard,već sam 2x win ponovo radio.popizdiću neznam gdje griješim;ajd daj mi navedi-nabroj svoje postavke N!NO. Dali može biti problem što je sata disk - imam ionako za njega dole ono --- Safely Remove Hardware:confused:
#28 |
Postovi: 278
Ma ovo safely remove hw te ne mora brinuti, a sto se tice korupcije, moras disk zastekati na konektor SATA 3. Znaci ne na 1 nego na 3. Ako imas drugi disk na 2, njega ustekaj na 4 i rijesio si sve probleme. |
#30 |
Postovi: 278
Nije problem sa SATA samo kod ove ploce. nFroce3 i 4 imaju s tim problema. Cipset ima podrsku za 4 SATA kanala s time da samo za dva ima u chipsetu PHY, a dva su vanjska. Tako da za dva imas zalockani takt skupa s PCIom, a za dva takt raste kako se dize HTT. Bolje je jedino kod ploca koje imaju posebni vanjski SATA kontroler on board. |
