Staro 25.04.2005., 21:58   #1
Juan46
Postovi: 2
Mišljenja, molim!
Periferne jedinice:
Miš Logitech B58, optički, crni - 92,09 KN, 86,21 KN
Tipkovnica Logitech UltraX Flat Desktop - 200,63 KN, 187,83 KN
Monitor 19" Samsung 959NF, 110 kHz, 0.25mm, NaturalFlat - 2.140,77 KN, 2.004,13 KN
Komponente:
DVD±RW PIONEER DVR-109, 16x, black, Dual layer ± recording, bulk - 489,19 KN, 457,97 KN
Napajanje TAGAN 420W, Super Silent, TG420-U01, aut.reg.brzine, S-ATA power cable - 665,13 KN, 622,68 KN
VGA PCI-E LEADTEK PX6600GT Extreme, GeForce PCX 6600GT, 128MB, DVI, TV - 1.907,92 KN, 1.786,14 KN
Kućište THERMALROCK Dragon, MIDI, black, Metal, bez PS - 754,09 KN, 705,95 KN
RAM PC-3200, 1024MB, DDR, Corsair C2, KIT, TwinX, DDR 400 MHz, 2 x 512MB - 1.450,61 KN, 1.358,02 KN
MBO DFI LAN PARTY UT nF4 Ultra-D, DDR, zvuk, S-ATA, FW, 2xG-LAN, PCI-E, s. 939 - 1.311,62 KN, 1.227,90 KN
CPU AMD Athlon64 3200+ BOX, socket 939, Winchester,2000MHz, 512kb c., FSB 800MHz - 1.554,26 KN, 1.455,05 KN
HDD 80.0 GB SEAGATE, NCQ, 8MB cache, Serial ATA Plus - 470,39 KN, 440,36 KN
Ukupno: 11.036,70 KN, 10.332,23 KN
...Sve iz Linksa!...
Juan46 je offline   Reply With Quote
Staro 26.04.2005., 00:19   #2
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,508
Čemu će služiti taj komp. Mislim da bi se mogli iskombinirati drugi hard i memorija...
Možda LG monitor...I DVD-Rom za On The Fly...
Staro 26.04.2005., 14:32   #3
Anthrax a.k.a. Priest
Postovi: 621
periferiju nisam gledao..ali bi mogao drugi hard i mozda malo jaca graficka..nravno ako ima dosta love u budgetu
Anthrax a.k.a. Priest je offline   Reply With Quote
Staro 28.04.2005., 10:28   #4
NITROS
NITROS's Avatar
Lokacija: Varaždin - Zagreb
Postovi: 874
Ja sam za te novce slozio bolji komp, ali u njemu nisam imao periferije.
Ako clockas uzmi 3200 ako ne onda 3000
NITROS je offline   Reply With Quote
Staro 30.04.2005., 00:15   #5
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
neki veči disk 120-160GB
Staro 29.05.2005., 20:08   #6
Stana B< 108 VK
Datum registracije: May 2005
Lokacija: Vinkovci
Postovi: 11
asa
Uzmi barem 160 GB HD
jer manje nije fora znam iz iskustva .
i napajanje od oko 600W .
TO bi ti bilo super :::
File Type: txt za mobitele.txt‎ (509 byte, 292 views)
AMD Athlon XP-A 2600+, 1913 MHz - max. 3000 MHz(11.5*166), 1.6V
ASUS A7N8X-E Deluxe ACPI BIOS Rev 1012
AMD ASUS A7N8X-E DELUXE Socket A,nVidia nForce2 Ultra400+MCP-
T, DDRAM, AGP8X, APU Audio/Dolby, Marvel Gb+NVIDIA 10/100LAN, Post
Reporter, IEEE1394, S/PDIF Out interface, Serial ATA , WI-FI Slot, WinDWD, CPU AMD 2600 ATHLON, COOLER FOR CPU, RAM DDR 256MBx2 PC3200
400, VGA AGP ATI RADEON 9600, WDC WD1200JB 120GB 7200 8MB (IDE), CASE MIDI TOWER ATX PRO, OPT DVD ROM, OPT CD-RW 52X, WinXP SP2 CRO
Stana.blog.hr
Stana B< 108 VK je offline   Reply With Quote
Staro 29.05.2005., 21:09   #7
Fleks
JDM
Fleks's Avatar
Datum registracije: Sep 2004
Postovi: 6,137
Re: asa
A zašto napajanje od 600w? I zašto 160gb disk?
SPAMERU
Staro 29.05.2005., 21:40   #8
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,190
Re: asa
A?
Koj je tebi vrag?
Aj se vrati spamat na blogove, tamo moš kolko oš'.
Tagan 420 W je idealno napajanje za ovu konfu.
Staro 29.05.2005., 22:24   #9
LuXor
Datum registracije: Jul 2004
Lokacija: Bjelovar
Postovi: 752
Imaš i diskontu24 HIS-ovu Radeonku X800 (256mb, 256bit, 12pix/6vert) po malo manje od 1700 krznatih. Puno bolji izbor za manje pare.
LuXor je offline   Reply With Quote
Staro 29.05.2005., 22:42   #10
E.T.
E.T.'s Avatar
Postovi: 2,458
Uzmi jos jedan DVD citac za 170-200Kn, vjeruj mi kad pocnes snimati cd/dvd bit ce ti puno komotnije od samo jednog optickog uredaja...
Ovako mi djeluje kao konfiguracija za oc cija je najslabija karika graficka kartica i u tom pogledu mislim da nije dovoljno izbalansirana konfiguracija... Takva snaga ti ocito treba za sto ugodnije igranje (inace bi trazio drugacije rjesenje) i onda stedis na najvaznijem elementu GPU-u...
U ovako poslozenoj konfiguraciji ces nakon oc-a imati nekih 10% bolje perfomanse od slicne (nakon oc iste naravno) slozene za kakvih 6500Kn... Jednostavno smatram (IMO) da konfiguraciju od >10k Kn mora pogoniti napredniji graficki sustav (6800GT)...
www.rabbits-clan.com
E.T. je offline   Reply With Quote
Staro 29.05.2005., 23:44   #11
atha
atha's Avatar
Postovi: 9,067
Re: asa
moronu, odi spavati. pa sutra ponovno doji. mozda nesto pametnije smislis.
uzmi 160 jer manje nije fora...kakav je to razlog za kupiti disk? jer nije fora... a i jebalo te iskustvo i hdd od 160gb. i jedna mala centrala za pogoniti 9 grafickih u sli modu i 4 procesora? 600w? cak i da se zajebevash, nisi nimalo humoristican.
___________
Just atha
x
Staro 30.05.2005., 23:37   #12
Darth Vader
Dark side Moderator
Darth Vader's Avatar
Postovi: 1,633
Re: Re: asa
:clap: :clap: :clap: :clap: :clap:
Sto jest jest mali je uporan al uci, stavio je link za blog u sig, sad jos samo da NESPEMA S GLUPIM ATTACHIMA bilo bi ok!
Jak ko rakija!
Darth Vader je offline   Reply With Quote
Staro 30.05.2005., 23:54   #13
E.T.
E.T.'s Avatar
Postovi: 2,458
Re: Re: Re: asa
Jos i da malo smanji taj sig. Koga zanima njegova revizija BIOSA, bas svaki opticki disk...Dobro da nam je napisao sve feature MBO-a i CPU-a tako da znamo da Asusica ima 10/100LAN... Steta sto nije napisao i boju pojedinih komponenti, sto sve misli kupiti u buducnosti, citate iz svog bloga, kratak zivotopis....
Sorry zbog OT no morao sam!
Staro 31.05.2005., 00:01   #14
Darth Vader
Dark side Moderator
Postovi: 1,633
@Stana B< 108 VK
Image Hosted by ImageShack.us
@Juan46
Sorry brate morao sam!
Jak ko rakija!
Staro 31.05.2005., 06:31   #15
atha
atha's Avatar
Postovi: 9,067
he is banned....wooo!!!
___________
Just atha
x
Staro 31.05.2005., 19:40   #16
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
@Stana B< 108 VK
@Juan46
ljubim te...dokraja zivota sam ti zahvalan
tip mi je polako(ali sigurno) isao na zivac koji nije bas najjaci
blup
mc_fish je offline   Reply With Quote
Staro 31.05.2005., 20:02   #17
Darth Vader
Dark side Moderator
Postovi: 1,633
Originally posted by mc_fish
ljubim te...:
..oh ribice...!
Jak ko rakija!
