Lokacija: Yautja Prime
Postovi: 1,218
Nvidia GeForce v301.42 WHQL driveri
NVIDIA GeForce 301.42 WinVista 7 64-bit NVIDIA GeForce 301.42 WinVista 7 32-bit NVIDIA GeForce 301.42 WinXP 64-bit NVIDIA GeForce 301.42 WinXP 32-bit This is the first WHQL-certified unified driver from the R300 family of drivers (versions 300.00 to 301.99). GeForce R300 drivers are packed with new industry-leading, GeForce-exclusive features as well as some really nice performance increases in top games. New in R300 Drivers: New GPU Support: GeForce GTX 690 GeForce GTX 680 GeForce GTX 670 GeForce GT 600-series GPUs Performance Boost – Increases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. GeForce 296.10 WHQL-certified drivers. Results will vary depending on your GPU and system configuration: GeForce GTX 570/580: Up to 23% in Just Cause 2 with SLI Up to 21% in The Elder Scrolls V: Skyrim Up to 17% in StarCraft II with SLI Up to 14% in Far Cry 2 with SLI Up to 9% in Bulletstorm Up to 7% in Civilization V Up to 6% in Deus Ex: Human Revolution with SLI Up to 6% in Dragon Age 2 with SLI Up to 5% in Metro 2033 with SLI Up to 5% in Total War: Shogun 2 GeForce GTX 560/560 Ti: Up to 20% in The Elder Scrolls V: Skyrim Up to 15% in Just Cause 2 with SLI Up to 13% in Far Cry 2 with SLI Up to 12% in Bulletstorm Up to 11% in Civilization V Up to 10% in StarCraft II with SLI Up to 9% in Batman: Arkham City Up to 4% in Deus Ex: Human Revolution with SLI Up to 4% in Dragon Age 2 with SLI Up to 4% in Metro 2033 with SLI Up to 4% in Total War: Shogun 2 NVIDIA FXAA Technology – shader-based anti-aliasing technology available from the NVIDIA Control Panel that enables ultra-fast anti-aliasing in hundreds of PC games. FXAA delivers similar quality to 4x multi-sample antialiasing (MSAA) but is up to 60% faster, enabling substantially higher performance in games. FXAA is supported on all GeForce 8-series and later GPUs. Note: This feature is disabled for games that already have built-in support for FXAA. Visit GeForce.com to learn more. NVIDIA Adaptive Vertical Sync – dynamically enables vertical sync based on your current frame rates for the smoothest gaming experience. Adaptive VSync is supported on all GeForce 8-series and later GPUs. Visit GeForce.com to learn more. NVIDIA Frame Rate Target – dynamically adjusts frame rate to a user specified target. Support for this feature is enabled via third party applications via NVAPI. Visit GeForce.com to learn more. NVIDIA Surround Technology – Adds the following new Surround capabilities.Visit GeForce.com to learn more. Add in a fourth accessory display with GeForce GTX 600-series to get access to your email, web, or other applications while you game. Maximize an application to a single physical display when in Surround mode (enabled by default). Confine the Windows Taskbar to the center display (enabled by default). Enable bezel peeking – a feature which enables users to temporarily peek behind the monitor bezels using a hotkey (Ctrl + Alt + B). This feature is designed to be used in conjunction with bezel corrected resolutions. Add or remove resolutions from the list of Surround resolutions (only those selected will be available to applications). Full center display acceleration for single wide display modes (center display must be connected to the master GPU). NVIDIA SLI Technology – Adds or updates the following SLI profiles: Alan Wake Call of Juarez: The Cartel Counter-Strike: Global Offensive Deus Ex: Human Revolution - The Missing Link Left 4 Dead Orcs Must Die! Portal 2 Resident Evil: Operation Raccoon City Risen 2: Dark Waters The Darkness II Battlefield: Bad Company 2 Crusader Kings II Max Payne 3 Sniper Elite V2 Street Fighter X Tekken NVIDIA 3D Vision – Adds or updates the following 3D Vision profiles: All Zombies Must Die! – rated Fair Ghosts 'n Goblins Online – rated Good Oil Rush – rated 3D Vision Ready Postal III – rated Good Rayman Origins – rated Good SevenCore – rated Fair Stacking – rated Good Unigine Heaven Benchmark v3.0 – rated 3D Vision Ready Wargame: European Escalation – rated Good Warp – rated Good Wings of Prey – rated Fair Krater – rated Poor Adam's Venture Episode 1- rated Poor Blacklight: Retribution – rated Poor The Darkness II – updated in-game recommended settings Depth Hunter – updated profile Dirt: Showdown – rated Good Passion Leads Army Benchmark – rated 3D Vision Ready Resident Evil: Operating Raccoon City – Rated Fair rFactor 2 – changed rating to 3D Vision Ready Trackmania 2: Canyon – rated Fair Unigine 3.0 Heaven Benchmark – updated profile World of Tanks – changed rating to Excellent. Other Details Installs PhysX System Software v9.12.0213. Installs HD Audio v1.3.16.0. Supports OpenGL 4.2 Supports DisplayPort 1.2 for GeForce GTX 600-series. Supports multiple languages and APIs for GPU computing: CUDA C, CUDA C++, CUDA Fortran, OpenCL, DirectCompute, and Microsoft C++ AMP. Supports single GPU and NVIDIA SLI technology on DirectX 9, DirectX 10, DirectX 11, and OpenGL, including 3-way SLI, Quad SLI, and SLI support on SLI-certified Intel and AMD motherboards. GeForce 600 series: GTX 690, GTX 680, GTX 670, GT 645, GT 640, GT 630, GT 620, GT 610, 605 GeForce 500 series: GTX 590, GTX 580, GTX 570, GTX 560 Ti, GTX 560 SE, GTX 560, GTX 555, GTX 550 Ti, GT 545, GT 530, GT 520, 510 GeForce 400 series: GTX 480, GTX 470, GTX 465, GTX 460 v2, GTX 460 SE v2, GTX 460 SE, GTX 460, GTS 450, GT 440, GT 430, GT 420, 405 GeForce 300 series: GT 340, GT 330, GT 320, 315, 310 GeForce 200 series: GTX 295, GTX 285, GTX 280, GTX 275, GTX 260, GTS 250, GTS 240, GT 240, GT 230, GT 220, G210, 210, 205 GeForce 100 series: GT 140, GT 130, GT 120, G 100 GeForce 9 series: 9800 GX2, 9800 GTX/GTX+, 9800 GT, 9600 GT, 9600 GSO, 9600 GS, 9500 GT, 9500 GS, 9400 GT, 9400, 9300 GS, 9300 GE, 9300, 9200, 9100 GeForce 8 series: 8800 Ultra, 8800 GTX, 8800 GTS 512, 8800 GTS, 8800 GT, 8800 GS, 8600 GTS, 8600 GT, 8600 GS, 8500 GT, 8400 SE, 8400 GS, 8400, 8300 GS, 8300, 8200 / nForce 730a, 8200, 8100 / nForce 720a GeForce 7 series: 7950 GX2, 7950 GT, 7900 GTX, 7900 GT/GTO, 7900 GS, 7800 SLI, 7800 GTX, 7800 GT, 7800 GS, 7650 GS, 7600 LE, 7600 GT, 7600 GS, 7550 LE, 7500 LE, 7350 LE, 7300 SE / 7200 GS, 7300 LE, 7300 GT, 7300 GS, 7150 / NVIDIA nForce 630i, 7100 GS, 7100 / NVIDIA nForce 630i, 7100 / NVIDIA nForce 620i, 7050 PV / NVIDIA nForce 630a, 7050 / NVIDIA nForce 630i, 7050 / NVIDIA nForce 610i, 7025 / NVIDIA nForce 630a GeForce 6 series: 6800 XT, 6800 XE, 6800 Ultra, 6800 Series GPU, 6800 LE, 6800 GT, 6800 GS/XT, 6800 GS, 6800, 6700 XL, 6610 XL, 6600 VE, 6600 LE, 6600 GT, 6600, 6500, 6250, 6200 TurboCache, 6200SE TurboCache, 6200 LE, 6200 A-LE, 6200, 6150SE nForce 430, 6150LE / Quadro NVS 210S, 6150 LE, 6150, 6100 nForce 420, 6100 nForce 405, 6100 nForce 400, 6100 ION series: ION LE, ION |
Xulos :)
Postovi: 7,541
Rade kao zmaj ![]()
LateralusX
Postovi: 1,788
Datum registracije: Dec 2009
Lokacija: Zagorje
Postovi: 872
hmm, ja sam jučer stavio ove drivere i prvi puta mi se dogodilo na bf3 (sharqi peninsula mapa) da imam poskakivanje s 60 fps na 30 fps. iritantnije nego da je cijelo vrijeme bilo 30 fps. uglavnom vratio sam na stare 301.24 drivere i sad opet radi normalno. |
Datum registracije: Feb 2010
Lokacija: underground
Postovi: 71
Moram i ja pohvalit drivere, odlično rade, stabilni su. Bravo Nvidia. |
