#3241 |
Datum registracije: Jan 2012
Lokacija: Žabnik
Postovi: 120
Al meni bas smeta to.. ne da sam picajzla al bas mi smeta.. iz vise razloga |
#3245 | |
Postovi: 19
i ja sam imao problem sa wifi na stock i na cyanu i nije bio problem u telefonu nego na routeru mora biti enkripcija namještena na tkip, ne na aes (ili automatic)... to je meni riješilo problem doma kad sam na wifi, ali na nekim mrežama vani se nemogu nikaj otvoriti iako je spojen... |
#3248 |
Lokacija: osijek
Postovi: 165
#3249 |
Lokacija: KR
Postovi: 14
testiram malo ovu skriptu za bateriju...ovo je trenutni status ![]() |
#3250 |
Datum registracije: May 2012
Lokacija: čepin
Postovi: 7
pozdrav svima, jel može netko stavit link za cm7 novi od benru-a |
#3251 |
Datum registracije: Nov 2011
Postovi: 185
ova aplikacija je puno bolja od DSP manager za zvuk, na marketu se plača ali na stranici developera je besplatna http://androidaudiohacks.com/?page_id=16 evo i na marketu free verzija, napominje da je preporučeno koristit custom rom cm7 itd jer na njima sigurno radi, na stock moze da nema ucinka https://play.google.com/store/apps/d...HJvaWQubHZoIl0. obavezno pazite s pojačavanjem zvuka jer ako pretjera mozete spalit zvucnik.. inace top ocjena VOLUME+ Volume+ is an application for Android Devices running Gingerbread (2.3) or higher which allows you to boost the maximum volume for Ringtones, Alarms, Message tones, etc. It is essentially a heavily modified DSP Manager which has been completely rewritten from scratch. Because of this it is strongly recommended that you remove one of them to install the other. It does this by exploiting the EQ settings (AudioEffect.api) included in Gingerbread, and because of this, it may be unstable on some devices. Please note that this application will not work to its full potential on phones running Stock (unmodified) software. I strongly suggest that if you are going to ‘root’ your phone that you flash CyanogenMod7 or higher and remove the built-in DSP Manager. I also will not be held responsible for anything that may happen to your device as a result of running this app. Please see my disclaimer for more information.
![]() ![]() Zadnje izmijenjeno od: goranszd. 14.05.2012. u 17:05. |
#3252 |
Registrirana Smrt
Lokacija: Croatia/Rijeka
Postovi: 33
jel zna netko koji je tocan density ekrana, nes sam dirao a nisam zapamtio broj koji je pisao... |
#3254 |
Registrirana Smrt
Postovi: 33
to si vidio na gsm areni ili preko neke aplikacije? mislim da mi je pisalo nes manje od 165, ali nema veze bubnut cu ga na 165 i bok ![]() |
#3255 | |
Postovi: 419
Proba sam i CyanogenMod7.2 RC2.01 By Joseph96, međutim nece da se pokrene nakon flasha sa zadnjim update-om (bez update-a radi ok, ali nista posebno). Portani squadzone rom mi je najbolji, ali ima dosta bug-ova. Ako ga se uspije sredit moga bi bit odlican. |
#3256 |
Postovi: 10,083
#3257 |
Registrirana Smrt
Postovi: 33
#3258 |
Postovi: 906
Jedno pitanje. Ne dobivam porike tipa od watsapp-a dok god ne otključam mob Znači, testirano, netko mi pošalje poruku ili nekaj, dok god ja imam tipa mob u đepu, na stolu i sl. neće doći poruka. Kada otključam mob onda stigne. Kolko kužim push baš i ne funkcionira najbolje, kako to rješiti? Iako mi se i spaja na wifi samo kad otključam mob. Hvala |
#3259 |
Postovi: 33
Dali mi neko moze rec di ima za skinut Miui-ov rom al da je na engleskom? Vec sam ih 2 probo kad god promjenim jezim ono kineska slova posvuda. http://www.htcmania.com/showthread.php?t=363161 Tu sam s linka skinuo al to je spanjolska verzija pa ako moz epomoc fala |
#3260 | |
Lokacija: Banja Luka
Postovi: 1
POMOĆ
Sad te pitam da li ćeš imati vremena i volje pa ću ti onda izraziti želje tj, šta bi želio. Pitam tebe pošto vidim da vladaš materijom ![]() Zadnje izmijenjeno od: tor. 16.05.2012. u 07:52. |
#3261 |
bycod
Lokacija: Zagreb / Dubrava
Postovi: 6,699
zlaja imas u ovom topicu apsolutno sve ![]() ja nemam vise taj mob tako da nisam bas u tome ![]()
#3262 |
Datum registracije: Mar 2012
Lokacija: Beograd
Postovi: 19
Ako moze mala pomoc, Odradio sam sve sa prve strane sto se tice rutovanja telefona, ali kada pokrenem SuperOneClick..on dodje do 7.stavke i tu program pukne tj "program is not responding". Pokusao sam da odradim i drugim nacinom, tj preko RecoveyClockmode-a i zip fajla. Sve protekne apsolutno bez problema ali kada odem na proveru da li je tel rutovan izbacuje da nije. Ako moze bilo kakva pomoc bio bih jako zahvalan. Pozdrav EDIT: Sad vidim da moram da stavim originalni rom da bih mogao da rutujem uredjaj..a to mi ne odgovara jer sam ja zeleo preko Clockwork recovery da bekapujem originalni (provajderov rom)..cisto ako mi zatreba. Zadnje izmijenjeno od: ozziris. 16.05.2012. u 19:47. |
#3263 |
Datum registracije: Apr 2012
Postovi: 18
ja sam imao slican problem kao ti.. sa RecoveyClockmode sve prodje dobro ali medju aplikacijama nije bilo super user aplikacije. onda sam je instalirao rucno i sve sljaka ![]() tako da vjerovatno ti je fon rutovan samo ti fali aplikacija. je l` vadis bateriju prije nego pokusas uci u recovery mode sa tipkama? |
#3264 |
Lokacija: Beograd
Postovi: 19
Da..i to par puta sam je vadio. Skinuo sam par console programa koji treba da potvrde da imam root medjutim svaki put je umesto znaka # pokazivao $ sto znaci da nemam root. Kako da rucno instaliram tu aplikaciju? |
#3265 |
Postovi: 18
jesi ukucao SU kad si instalirao konzolu? imas u tom su.zip aplikaciju, samo raspakuj i pokreni pa vidi hoce li raditi.. koji je android? pretpostavljam da je isti kao i kod mene jer su sa iste mreze |
#3266 |
Lokacija: Žabnik
Postovi: 120
ljudi... uspio sam ove u tele2 nahebat da mi vrate tele2 rom.. i sad imam sve u redu.. sa onim tipkama u navigacijskom oknu.. dakle ko kad kupite mobitel.. e sad da ja vas pitam. jel se to moze spremiti(takav rom) da kad stavim custom pa ako pozelim nazad orginal tele2 da stavim nazad tele2 rom... i jos 2 linka bi molio official 2.3.6 i najbolji cyan EDIT: sad kad su mi stavili natrag tele2 orginal rom fixao mi se problem sa wifiem ![]() |
#3267 |
Lokacija: pozega
Postovi: 3
Odlican mob.... da na njemu pise neko drugo brendirano ime kosto bi preko 2k |
#3268 |
Lokacija: Beograd
Postovi: 19
Sve sam uradio..dosao sam do kraja, snimio Fundovsky 4.0, pisalo instalacija uspesna..i kad sam kliknuo na reebot samo stoji logo huawei i ne pomera se. izvadio sam bateriju, i opet upalio i nista se ne desava. i tako vec 15min! Pomagajte! |
#3269 |
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Uđi u recovery ponovno (ugasi mob tako da izvadiš bateriju i spoji ga na punjač i trebao bi ući u recovery) i flashaj ponovno, s time da očistiš sve potrebne particije i dalvik cache.
#3270 |
Lokacija: Beograd
Postovi: 19
RADI! Hvala ljudi puno na savetima! Usro sam se ![]() |
