Staro 07.05.2012., 00:30   #31
MAGARAC
MAGARAC's Avatar
Postovi: 5,986
Ova ce grafa unistit Radeonke ako su ovi rezultati blizu istini. Za 400$ ce bit 50$ jeftinija i u najmanju ruku isto brza ko 7970. Bit ce rezova, opet i jos malo pa ce 7970 kosta kako je trebala kostat u startu.
Btw. cekam da se konacno rasprodaju sadasnje zalihe referentnih 680tki i da pocnu dolazit posteni modeli s njima valjda i koja 670. Vec ih je gro vani a nit osim fantomke nema kod nas..
Staro 07.05.2012., 00:32   #32
syss
syss's Avatar
Postovi: 10,805
kao i svaki inferioran hardver što mora biti jeftiniji :troll:
Staro 07.05.2012., 11:31   #33
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
NVIDIA's GeForce GTX 670 Short PCB Pictured Up Close
Thanks to the impressive power-draw and temperature figures its GeForce GTX 680 could come up with, NVIDIA's newest SKU based on the 28 nm GK104 silicon, the GeForce GTX 670, will feature a compact PCB. The reverse side of this PCB was first pictured on a Colorful-branded graphics card. A picture of its obverse side was posted earlier today. In comparison to the GTX 680, the GTX 670 PCB is quite short. The eight GDDR5 memory chips are distributed between both the sides, these chips are wired to the GPU over a 256-bit wide memory interface. The VRM area is pushed towards the front-end of the PCB. It consists of a 4+2 phase design. The card draws power from two 6-pin PCIe power connectors. Display outputs include two dual-link DVI, and one each of HDMI and DisplayPort. There are two SLI bridge connectors, giving it 4-way SLI capability.
http://www.techpowerup.com/165537/NV...-Up-Close.html
C L O W N I N G A R O U N D
Staro 07.05.2012., 15:03   #34
Brlja
Postovi: 874
Od podne gledam ovaj PCB i ne mogu se načuditi. Samo gore fali onaj elipsasti hladnjak s 9600 serije.
Brlja je offline   Reply With Quote
Staro 07.05.2012., 15:47   #35
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
Autor Brlja Pregled postova
Mozda ide gore onaj old skul "zalman-nesto-Cu"
Bez potpisa.
RaneZ je online   Reply With Quote
Staro 07.05.2012., 16:19   #36
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,722
i to koristi 2x6 pin?
Ivo_Strojnica je online   Reply With Quote
Staro 07.05.2012., 16:41   #37
ThePornstar
ThePornstar's Avatar
Postovi: 4,402
Hebate, zamisli bulk verziju pakovanja. Komotno s high-end grafičkom u džepu izađeš van iz dućana
Staro 07.05.2012., 17:49   #38
ante2
ante2's Avatar
Postovi: 1,313
Ahoj ekipa sta mislite oce jedna GTX 670 bit jaca od dvije GTX 560 Ti iz moje kante na rezi 1920x1080 + PhyX npr zadnji Batman: Arkham City.
Malo sam gledao rivjue koji su do sad izasli i nekako mi se cini da su tu negdje li-la mislim 560 Ti SLI vs 670 solo.
MSI Z77 MPower
Intel i5 3570K @4,2GHz, NOCTUA NH-U12S
Gigabyte GTX 1070
DDR3 16GB (4x4GB) 1600Hz Corsair Vengeance
Carbide Series Air 540, Corsair RM750i
CREATIVE LABS X-Fi Titanium-Kingston HyperX Cloud
DELL U2515H
Synology DS413
ante2 je offline   Reply With Quote
Staro 07.05.2012., 18:03   #39
MAGARAC
MAGARAC's Avatar
Postovi: 5,986
GTX 560 SLi je u rangu sa gtx 680 ali solo grafa slicne snage sa 2gb vrama je uvijek bolje za ugodno igranja.
Staro 07.05.2012., 18:18   #40
ante2
ante2's Avatar
Postovi: 1,313
Autor MAGARAC Pregled postova
Pod ugodno igranje mislis manje fps-a ali i manje musicav sistem tj driveri ili SLI profili koji ne rade kako treba i slicna veselja koja dobijes kad imas dvije grafe (o grijanju ne cu ni pocimat aj sad je stanje ok ali sam morao dodat 120 mm fen da puse po njima)
MSI Z77 MPower
Gigabyte GTX 1070
DELL U2515H
Synology DS413
Staro 07.05.2012., 18:41   #41
MAGARAC
MAGARAC's Avatar
Postovi: 5,986
Yes manje musicav, gladi fps, manje potencijalnih problema sa driverima...
Staro 10.05.2012., 15:22   #42
Wozniak jR.
humanware
Wozniak jR.'s Avatar
Datum registracije: Mar 2009
Lokacija: zGb
Postovi: 456
Wozniak jR. je offline   Reply With Quote
Staro 10.05.2012., 16:21   #43
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
hm, reviewi su vani, kak mi se cinilo kartica je mrak, al ogranicena bandwidthom memorije kao i 680... Bas su ga zeznuli s tom 256 bitnom sabirnicom i drasticnim povecanjem procesorske snage.
jedan gtx 660 sa 1024sp chipom i istom memorijskom konfiguracijom za 1500kn molim
Msi x79a GD65
Intel i7 3930k @ 4.7 1.4V
4x 4GB Kingston 1866 9-11-9
Gigabyte gtx 460 1gb
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Coolermaster Stacker 831
HP LP2065 / LG IPS231P
Windows 7 Enterprise
Trenutno nepostojeci
Staro 10.05.2012., 16:49   #44
Dramamine
Dramamine's Avatar
Lokacija: Bjelovar
Postovi: 42
Još uvijek se ne zna kad će biti na policama?
Dramamine je offline   Reply With Quote
Staro 10.05.2012., 17:05   #45
pci_e3x
Premium spammer
pci_e3x's Avatar
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
s guru3d:
Yes the GeForce GTX 670 is here, the little brother of the GTX 680 which comes well how to put it mildly... slightly castrated. NVIDIA disabled one out of eight shader processor clusters and designed a more cost effective (and much smaller) PCB.
jel ovo znaci, da se mozda moze aktivirat ovaj SP flashanjem biosa?
(naravno, ako je disable, kao kod npr.: 6850)
Staro 10.05.2012., 17:06   #46
nino
nino's Avatar
Postovi: 12,612
Autor Dramamine Pregled postova
Stigle Point of View kod nas.
Staro 10.05.2012., 17:07   #47
musso
Unregistered User
musso's Avatar
Datum registracije: Jun 2002
Lokacija: Beč
Postovi: 722
Vidim ima MSAN, zanimaju me samo cijene. Tam ne mogu vidjeti.
musso je offline   Reply With Quote
Staro 10.05.2012., 17:09   #48
nino
nino's Avatar
Postovi: 12,612
Oko 3380,00 sa pdv-om.
Staro 10.05.2012., 17:12   #49
MAGARAC
MAGARAC's Avatar
Postovi: 5,986
Autor nino Pregled postova
Gdje?
Ok, vidim sad..
http://www.hardocp.com/article/2012/...eo_card_review
Cijena bi trebala bit u rangu sa 7950 a perf. su u rangu sa 7970..
Staro 10.05.2012., 17:14   #50
nino
nino's Avatar
Postovi: 12,612
Doslo mi u firmu na mail danas popodne, pa eto, najfriskija vijest.
Staro 10.05.2012., 17:14   #51
musso
Unregistered User
musso's Avatar
Lokacija: Beč
Postovi: 722
A jbt ako ce takva cijena bit bolje cu kupit MSI 680 za 400kn vise, u MagazinRSu.
To mora past na oko 3000.
Staro 10.05.2012., 17:15   #52
mr Rockwell
mr Rockwell's Avatar
Datum registracije: Mar 2008
Postovi: 354
REDEFINE
SLEEVING HOW TO
mr Rockwell je offline   Reply With Quote
Staro 10.05.2012., 17:17   #53
MAGARAC
MAGARAC's Avatar
Postovi: 5,986
Da tebalo bi bit oko 3000 do 3200 max ali su nase trgovine bezobrazne. Grafa je jako dobra i moze doc do perf. gtx 680 vise, manje svugdje tak da mislim da je to, to..
Kepleri su brutalni u BF3 to me najvise impresionira kod njih. GTX 670 prakticki razvaljuje 7970 u toj igri..
Staro 10.05.2012., 17:19   #54
tole_
Casual Racist
tole_'s Avatar
Lokacija: Sneed's feed and seed (formerly Chuck's)
Postovi: 422
ASUS DCU2
Za 2 godine si moja !!
tole_ je offline   Reply With Quote
Staro 10.05.2012., 17:23   #55
mr Rockwell
Postovi: 354
Za samo to mi i treba. Sve mi se cini da cu zhvaliti svojoj hd6970 i reci dobro došla 670
REDEFINE
SLEEVING HOW TO
Staro 10.05.2012., 17:32   #56
izi
izi's Avatar
Lokacija: Vinkovci - Slavonski Brod
Postovi: 139
http://www.youtube.com/watch?v=Tq2BO...&feature=g-u-u
Duplo jaca u skoro svakoj igri od gtx570, a u rangu sa gtx680 i 7970, strava kartica.
izi je offline   Reply With Quote
Staro 10.05.2012., 17:43   #57
MAGARAC
MAGARAC's Avatar
Postovi: 5,986
Ne pretjeruj. Brza je al ne bas toliko..
23% u 1080p 4xaa brza od 580, znaci jos nekih 20tak % brza od 570 = ispod 50%.
DC2 je jos i dual slot i kloknuta je kao gtx 680 i nekim cudom ima gotovo iste perf., vjerojatno noviji driveri na testu!!
http://www.guru3d.com/article/asus-g...-top-review/19
Zadnje izmijenjeno od: MAGARAC. 10.05.2012. u 21:15.
Staro 10.05.2012., 20:54   #58
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,533
Staro 10.05.2012., 21:09   #59
mr Rockwell
Postovi: 354
Hmm za tu lovu bolje kupiti HD 7970!?
REDEFINE
SLEEVING HOW TO
Staro 10.05.2012., 21:13   #60
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,533
Autor mr Rockwell Pregled postova
Ne, GTX 670 je na def. brza od 7970 a kad se clocka dolazi na razinu GTX 680 ( stock )
