Staro 10.04.2012., 19:58   #1
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Nvidia GeForce GTX 690
More GeForce GTX 690 Details Surface
We know from older reports that NVIDIA is working on GeForce GTX 690, a dual-GPU graphics card based on the 28 nm GK104 silicon, we also know that its launch will be strategically timed to follow that of AMD Radeon HD 7990. Expreview scored a few juicy details about this card. To begin with, it is reported that GeForce GTX 690 will draw power from two 8-pin PCIe power connectors.
The GeForce GTX 690 will use a PCI-Express 3.0-compliant bridge chip. Its display outputs will include three DVI and one DisplayPort. PSU with at least 650W capacity will be made a system requirement. The entire feature-set of GeForce GTX 680 will be carried over. The exact specifications, core configuration, and memory amount, remain at large.
http://www.techpowerup.com/163901/Mo...s-Surface.html
Bogami ako je istina ovo za snagu napajanja zvjerka će pošteno cuclati.
C L O W N I N G A R O U N D
Staro 10.04.2012., 21:33   #2
syss
syss's Avatar
Postovi: 10,805
pa moraju biti u sejfmodu i napisati neku veliku cifru... em što uzimaju u obzir veliku potrošnju ostatka sistema, em što moraju biti u sejfmodu
Staro 19.04.2012., 17:02   #3
nexusone
Datum registracije: Apr 2008
Postovi: 139
nexusone je offline   Reply With Quote
Staro 19.04.2012., 17:28   #4
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,540
To ispod 5k kuna nece biti
Staro 19.04.2012., 17:37   #5
MAGARAC
MAGARAC's Avatar
Postovi: 5,983
To je sala neka?
Obicno su takve dvoglave kostale kao dvije jednoglave ekvivalentne, cesto i vise. Pa racunaj. Nadam se da ce u paketu sa njom doci i puno vise "down to earth" gtx 670 koja bi mogla imat zanimljivu cijenu s obzirom na velik rez 7950 i 7970. Mozda 690 bude 2 x gtx 670, ne zna se jos nista ali moguce. U svakom sl. bi bilo bolje od 2 x 680 je bi to kostalo abnormalno.
Naslov ove recenzije gtx 680 Phantom je ono sto ja hocu i ocekujem..
Zadnje izmijenjeno od: MAGARAC. 19.04.2012. u 17:43.
Staro 20.04.2012., 11:28   #6
Postovi: 33,915
Zauzima samo 3 slota. Pih, jadno! Prava grafa mora zauzimati bar cijelu doljnju polovicu ploče.
Staro 20.04.2012., 11:56   #7
sapunko_HR
Datum registracije: Oct 2011
Lokacija: _
Postovi: 277
Autor MAGARAC Pregled postova
To je sala neka?
To nije ništa,ova je pravi fantom
sapunko_HR je offline   Reply With Quote
Staro 20.04.2012., 12:44   #8
Postovi: 8,192
Autor coconut Pregled postova
Hebiga, kad se priča o Phantomu onda su ta 3 slota bug, a kad se priča o DCII onda je to feature...
Staro 20.04.2012., 13:15   #9
MAGARAC
MAGARAC's Avatar
Postovi: 5,983
Nebi nikad uzeo ni jednu ni drugu. Ako nebi bilo TwinFrozra onda bi trazio Gigabyte i njihove WindForce hladnjAke. Ostalo me ne zanima.
LInko sam taj review samo zbog naslova koji je,
"Review: Fingers crossed for Nvidia's response to AMD's price cuts"
Htio bi ja iduci mj piknut jednu ali me srce boli kad vidim koliko kosta. 500kn manja cijena i neki bolji model bi me vec manje bolilo..
Ovak nesto ili naravno Light. koja ce prije ili kasnije doc.
Staro 20.04.2012., 13:34   #10
Doink the Clown
Postovi: 6,214
Autor Pupo Pregled postova
A to što Fantomka 10 puta bolje izgleda od DCII to nema veza, ipak Asus je Asus
Staro 20.04.2012., 14:20   #11
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,540
Kako kome, o ukusima se ne raspravlja ja bi uvjek uzeo prije asus ili GB nego gainwarda (govorim i za izgled a i za ostalo) , pogotovo prijasnji GBov model SOC sa 3 venta. Gledam sad ovu gb 680ku s 5 fanova od GB, cista glupost i nadam se da nece to sranje stavit na grafu nego provjereni 3x fan cooler.U kompu imam samo zvucnu tako da me cist zaboli jel 3 ili 6 slotova grafa , bitno je da kad vec toliko zauzima onda da posteno i 'ladi a asusica izgleda stvarno mocno.
Staro 20.04.2012., 18:14   #12
sapunko_HR
Lokacija: _
Postovi: 277
Ova još bolje izgleda i ima kvalitetne komponente,6GB memorije,8+3 faza VRM i još ima LED
Staro 20.04.2012., 19:11   #13
MAGARAC
MAGARAC's Avatar
Postovi: 5,983
Autor sapunko_HR Pregled postova
Fulo si temu.
Jos malo pa ce svi vikat da treba 6gb za igranje i da je LED jako bitna svar na grafi a izgled ce postat najbitnija stavka. Ko da nosite grafe sa sobom po bircevima i lovite zenske sa njima..
Kaj se mene tice moze imat i 10 ventova ako dobro hladi i nije bucna i moze bit drek smeda za zutim flekama. Najbolji hladnjaci su dvoslotni, TwinFrozr i Windforce a ovo sa 3 slota je ili nesposobnost ili karta na izgled..
Zadnje izmijenjeno od: MAGARAC. 20.04.2012. u 19:23.
Staro 20.04.2012., 19:39   #14
sapunko_HR
Lokacija: _
Postovi: 277
Fulo si temu.
Ram je bitna marketing stavka a o tome da li će profitirat igre saznat ćemo kad izađe crysis 3. Za sada je nepotrebno i 3GB.
Led ovdje nije samo izgled:
"Sapphire implemented LEDs for each of the 8 vGPU phases, that gives you a real-time indication of their individual loading. These LEDs can be seen through a window on the top of the card"
Staro 20.04.2012., 23:11   #15
pci_e3x
Premium spammer
pci_e3x's Avatar
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
led-ove ima i twinfrozr (barem je imala gtx 460 tf), tako da to nije nista novo i spektakularno
Staro 20.04.2012., 23:17   #16
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,540
Led je imala svaka 4870 za kontrolu 4 komponente na grafi ,al dosta off topica i safirkama...
Staro 21.04.2012., 04:28   #17
Chiron
Chiron's Avatar
Postovi: 371
Autor xulos Pregled postova
kako se točno zove ova i gdje se može nabavit ... pretpostavljam kod nas ne
Destiny isn't already Forged!!!
Chiron je offline   Reply With Quote
Staro 21.04.2012., 09:28   #18
Doink the Clown
Postovi: 6,214
Autor Chiron Pregled postova
To je DCUII TOP, moći će se nabaviti zašto ne?
http://www.techpowerup.com/164526/AS...CU-II-TOP.html
Staro 23.04.2012., 16:30   #19
pci_e3x
Premium spammer
pci_e3x's Avatar
Lokacija: D.Zagora
Postovi: 776
Staro 23.04.2012., 20:49   #20
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,187
NVIDIA GeForce GTX 690 Pictured
Here is the very first picture of NVIDIA GeForce GTX 690, a monstrous dual-GPU graphics card, slated for an April 28 unveiling at GeForce LAN, Shanghai. The picture reveals quite a bit about the card's design, especially that of its cooling assembly. To begin with, it bears more resemblance with that of the Radeon HD 6900, than its predecessor, the GeForce GTX 590; in that it features a lateral-flow blower instead of a larger lateral-flow fan that's found on cards such as the GTX 590 and GTX 295 (single-PCB).
The essential structure of the cooler remains the same as its predecessor. The card has just the one PCB, both GPU systems are located on it, with their own memory and VRM zones. the GPU systems are located at the two ends of the PCB, while the central portion probably holds components such as VRM and PCIe bridge chip. One can predict each GPU system to have a large, copper-rich channel heatsink, through which the blower in the center guides air through. Unfortunately, there's not much more that we describe the picture, owing to its angle. You can find a dual-DVI cluster at the end. In all likelihood, the card has enough connectivity for four displays.
Staro 23.04.2012., 20:52   #21
Doink the Clown
Postovi: 6,214
Staro 23.04.2012., 22:58   #22
mislav_os
freak
Postovi: 2,688
Treba čekati taj Crysis 3 pa da vidimo čija je jača
Staro 29.04.2012., 10:05   #23
pci_e3x
Premium spammer
pci_e3x's Avatar
Lokacija: D.Zagora
Postovi: 776
Staro 29.04.2012., 11:51   #24
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,679
Kako dobro izgleda!!! Koliko ce to para biti, 7k?
Staro 29.04.2012., 11:53   #25
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,533
Prije 9k
Staro 29.04.2012., 18:10   #26
mislav_os
freak
Postovi: 2,688
KOliko vidim, Ameri su stavili 999$, znači kod nas cca 8k (trebaju ti skoro dvije prosječne hrv. plaće za grafu, hahaha )
Staro 29.04.2012., 18:34   #27
MAGARAC
MAGARAC's Avatar
Postovi: 5,983
Sva sreca pa prosjecnom HR gameru takva grafa ne treba..
Puno bolje to djeluje od dosadasnjih Nvidijinih dvoglavih. Gotovo isto kao i 2 x gtx 680 sa istim brojem CUDA jezgri i ne puno nizim taktom. Regulacije isto nisu kresali tako da tu nebi trebalo bit problema. Ak bude i tiha kak se najavljuje bit ce to zvijer...
Cijena ce bit zanimljiva, pogotovo Asusu u Linksu. Mene puno vise zanima gtx 670. Ta bi vec mogla bit puno bliza HR dzepu iako ne i prihvatljiva..
Staro 29.04.2012., 21:01   #28
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,540
krasna stvar, malo je rec divna A cijena, ma tko to jos uopce gleda
Staro 30.04.2012., 18:57   #29
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,540
Staro 02.05.2012., 16:36   #30
Doink the Clown
Postovi: 6,214
