Staro 09.04.2012., 17:59   #1
pci_e3x
Premium spammer
pci_e3x's Avatar
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
Nvidia Forceware v301.24 Beta driveri
Release Highlights
This is the first unified driver from the R300 family of drivers (versions 300.00 to 301.99).
GeForce R300 drivers are packed with new industry-leading, GeForce-exclusive features as well as some really nice performance increases in top games.
New in R300 Drivers:
New GPU Support – Adds support for the new GeForce GTX 680, the fastest, most efficient GPU ever built. Explore GeForce GTX 680 and its new SMX architecture on GeForce.com.
Performance Boost – Increases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. GeForce 296.10 WHQL-certified drivers. Results will vary depending on your GPU and system configuration:
GeForce GTX 570/580:
Up to 23% in Just Cause 2 with SLI
Up to 21% in The Elder Scrolls V: Skyrim
Up to 17% in StarCraft II with SLI
Up to 14% in Far Cry 2 with SLI
Up to 9% in Bulletstorm
Up to 7% in Civilization V
Up to 6% in Deus Ex: Human Revolution with SLI
Up to 6% in Dragon Age 2 with SLI
Up to 5% in Metro 2033 with SLI
Up to 5% in Total War: Shogun 2
GeForce GTX 560/560 Ti:
Up to 20% in The Elder Scrolls V: Skyrim
Up to 15% in Just Cause 2 with SLI
Up to 13% in Far Cry 2 with SLI
Up to 12% in Bulletstorm
Up to 11% in Civilization V
Up to 10% in StarCraft II with SLI
Up to 9% in Batman: Arkham City
Up to 4% in Deus Ex: Human Revolution with SLI
Up to 4% in Dragon Age 2 with SLI
Up to 4% in Metro 2033 with SLI
Up to 4% in Total War: Shogun 2
NVIDIA FXAA Technology – shader-based anti-aliasing technology available from the NVIDIA Control Panel that enables ultra-fast anti-aliasing in hundreds of PC games. FXAA delivers similar quality to 4x multi-sample antialiasing (MSAA) but is up to 60% faster, enabling substantially higher performance in games. FXAA is supported on all GeForce 8-series and later GPUs. Note: This feature is disabled for games that already have built-in support for FXAA. Visit GeForce.com to learn more.
NVIDIA Adaptive Vertical Sync – dynamically enables vertical sync based on your current frame rates for the smoothest gaming experience. Adaptive VSync is supported on all GeForce 8-series and later GPUs. Visit GeForce.com to learn more.
NVIDIA Frame Rate Target – dynamically adjusts frame rate to a user specified target. Support for this feature is enabled via third party applications via NVAPI. Visit GeForce.com to learn more.
NVIDIA Surround Technology – Adds the following new Surround capabilities. Visit GeForce.com to learn more.
Add in a fourth accessory display to get access to your email, web, or other applications while you game.
Maximize an application to a single physical display when in Surround mode (enabled by default).
Confine the Windows Taskbar to the center display (enabled by default).
Enable bezel peeking – a feature which enables users to temporarily ‘peak’ behind the monitor bezels using a hotkey (Ctrl + Alt + B). This feature is designed to be used in conjunction with bezel corrected resolutions.
Add or remove resolutions from the list of Surround resolutions (only those selected will be available to applications).
Full center display acceleration for single wide display modes (center display must be connected to the master GPU).
NVIDIA SLI Technology – Adds or updates the following SLI profiles:
Alan Wake
Call of Juarez: The Cartel
Counter-Strike: Global Offensive
Deus Ex: Human Revolution - The Missing Link
Left 4 Dead
Orcs Must Die!
Portal 2
Risen 2: Dark Waters
The Darkness II
NVIDIA 3D Vision – Adds or updates the following 3D Vision profiles:
All Zombies Must Die! – rated Fair
Ghosts 'n Goblins Online – rated Good
Oil Rush – rated 3D Vision Ready
Postal III – rated Good
Rayman Origins – rated Good
SevenCore – rated Fair
Stacking – rated Good
Unigine Heaven Benchmark v3.0 – rated 3D Vision Ready
Wargame: European Escalation – rated Good
Warp – rated Good
Wings of Prey – rated Fair
Krater – rated Poor
Other Details
Installs PhysX System Software v9.12.0213.
Installs HD Audio v1.3.12.0.
Supports OpenGL 4.2
Supports DisplayPort 1.2 for GeForce GTX 680.
Supports multiple languages and APIs for GPU computing: CUDA C, CUDA C++, CUDA Fortran, OpenCL, DirectCompute, and Microsoft C++ AMP.
Supports single GPU and NVIDIA SLI technology on DirectX 9, DirectX 10, DirectX 11, and OpenGL, including 3-way SLI, Quad SLI, and SLI support on SLI-certified Intel and AMD motherboards.
Win7 x64 (64bit)
http://www.geforce.com/drivers/results/43560
Win7 x86 (32bit)
http://www.geforce.com/drivers/results/43559
Staro 10.04.2012., 09:36   #2
gnomisa
gnomisa's Avatar
Datum registracije: Feb 2003
Postovi: 1,556
da da konačno, FXAA i adaptive sync, idem probat večeras jihaa
gnomisa je offline   Reply With Quote
Staro 16.04.2012., 20:41   #3
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,391
i, jel koristite adaptive vsync u igrama?
Staro 17.04.2012., 15:52   #4
Brlja
Postovi: 874
Evo ja sam enablao. Niš...drži mi fps na 60. Nego imam pitanje za ovaj FXAA. Sad kad njega enableam da li da Antialiasing - Mode ostavim Application Controled ili da stavim Override?
Edit: Evo malo sam se igrao s FXAA. Između ostaloga savjet je (našao na WoW forumima) da se enabla po aplikacijama, znači ne globalno. Navodno radi sranja s tekstom. I sad...jednu stvar sam primjetio kad smo već kod toga. Zapelo mi je za oko čudna slova u igrama za koje sam enablao, slova u meniju u WoW-u i slova u konzoli u Doti 2. Aj pogledajte ako ćete ispobavat. Postao bi screenshot ali me trolla igra, kad napravim screenshot onda su, kad gledam sliku, slova normalna i s FXAA enablenim.
Edit2: Evo uspio sam normalni SS uzet s snipping toolom. Primjetite razliku u slovima u konzoli. Inače samo u konzoli sam to i primjetio u Doti 2.
Evo ga s FXAA enable
OVDJE
I ovdje je s disable:
OVDJE
Edit4: Evo i WoW. Primjetite razliku u slovima pod options bez FXAA
OVDJE
i sa FXAA
OVDJE
Nije samo ovdje, taj blur u slovima se vidi i na addonovima, Grid, Prat...itd. što god ima neka slova. Za sad, u WoW-u bez FXAA. Čitam i na forumima da je i drugima "text a blurry mess" tako da mi se za sad FXAA baš i ne sviđa. Također...navodno to tako treba biti.
Zadnje izmijenjeno od: Brlja. 17.04.2012. u 21:23. Razlog: 2.5 megi slika sa direktnim učitavanjem, ne koristi thumbnails...
Brlja je offline   Reply With Quote
Staro 17.04.2012., 21:06   #5
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
Probaj. Meni je to za sad otkrice godine i ne pada mi na pamet gasit ga..
MAGARAC je online   Reply With Quote
Staro 17.04.2012., 21:25   #6
Brlja
Postovi: 874
Također, kako čitam, s enabled Adaptive vsync kartica ima manju potrošnju nego normalni vsync u igrama, sad koliko je tome za vjerovat.
Staro 17.04.2012., 22:34   #7
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,391
ja isto koristim, ali fali mi da ponekad vidim da imam preko 100fpsa u nekoj igri
Staro 17.04.2012., 22:49   #8
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
Lagano sam se odviknuo od toga. Sada mi je glade slade. Svida mi se taj adaptive vsync jako i koristit cu ga svugdje. Najbolje od vsync i off i on u jednom bez tearinga ili neugodnih iznenadenja.
Staro 17.04.2012., 23:18   #9
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,391
u diablu mi je puno fluidnije s adaptive vsyncom
kak sam se stilto danas, neš sam testirao i vrtim 3dčmark06 i slabi bodovi, poslije sam skužio da je zbog adaptive vsynca
Staro 18.04.2012., 12:39   #10
Full Throttle
Full Throttle's Avatar
Datum registracije: Dec 2009
Lokacija: Zagorje
Postovi: 872
jel onda treba možda isključiti vsync u samoj igri, ako se postavi u profil adaptive vsync?
Full Throttle je offline   Reply With Quote
Staro 18.04.2012., 12:46   #11
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,558
I trebas iskljuciti vsync u igri da bi ti adaptive sljakao
Staro 18.04.2012., 17:29   #12
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,391
samo me nešto zanima u vezi vsynca općenito
recimo igram igru (vsync off), imam 110 frejmova, i dođem do djela di framerate padne na 60 recimo
kako bi sa vsyncom se to ponašalo, pošto je lockano na 60 dal bi ostalo na 60? ili bi palo na neznam, 40?
valjda kužite
Staro 18.04.2012., 18:05   #13
Brlja
Postovi: 874
Pa vjerovatno bi ostalo na 60. Nego samo o Vsyncu pričate, jeste isprobavali ovaj FXAA šta? Što o njemu mislite?
Staro 18.04.2012., 20:00   #14
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
valjda kužite
O tome se i radi. Klasicni vsync ima takvih iznenadenja a ovaj adaptive radi na nekoj "zlatnoj sredini" i za sad nema takvih iznenadenja. Kad nestane snage onda jbg. ali zbog drugih razloga nema nikakvih dropova.
Staro 18.04.2012., 20:34   #15
Ivica121
Ivica121's Avatar
Datum registracije: Feb 2010
Lokacija: underground
Postovi: 71
Ruše mi se ovi driveri isto kao i 296 verzija. Jedino mi radi s 295 verzijom dobro i bez rušenja.
Pa koji qurac Nvidia radi s driverima?
Ivica121 je offline   Reply With Quote
Staro 18.04.2012., 22:59   #16
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,391
jesi sweeperom očistio iz safe moda?
Staro 19.04.2012., 12:30   #17
Ivica121
Ivica121's Avatar
Postovi: 71
Pa Nvidia kaže da se netrebaju brisat stari driveri, samo stavit nove na stare. Evo ti link pa pročitaj: http://www.nvidia.com/object/drivers_faq.html
Staro 19.04.2012., 12:40   #18
tiki66
tiki
tiki66's Avatar
Postovi: 2,741
Probaj kod instalacije novih drivera kliknuti 'Perform clean install'
Staro 19.04.2012., 12:54   #19
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,391
Autor Ivica121 Pregled postova
je ali ako imaš probleme, to prvo treba napraviti, totalno clean install, probaj, meni pomogne uvijek
Staro 19.04.2012., 13:04   #20
Ivica121
Ivica121's Avatar
Postovi: 71
Kak se briše s tim Sweeperom?
Staro 19.04.2012., 13:06   #21
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,391
prvo ga instaliraš (3.2.0 verzija), pa odeš u safe mode, onda ga pokreneš i staviš kvačicu na nvidia physx i nvidia display, stisneš clean, restartaš komp normalno i instaliraš drivere koje hoćeš
Staro 19.04.2012., 13:07   #22
Ivica121
Ivica121's Avatar
Postovi: 71
Hvala. Znači odem u safe mode i kad pokrenem driver Sweeper samo odaberem nvidia phsyx i nvidia display i clean
Idem probat pa javim.
Staro 19.04.2012., 13:37   #23
Ivica121
Ivica121's Avatar
Postovi: 71
Neće mi zać u safe mode, ja stišćem f8 ali ništa, uopće mi ne nudi safe mode nego se normalno pali?
Staro 19.04.2012., 13:42   #24
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,558
prvo uninstall drivera iz control panela, restart a ond sweeper pa restart i onda instalacija novih.I nemoras ici u safe mod, ja nikad nisam.
Staro 19.04.2012., 13:43   #25
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,391
How to use ?
There are two methods to use Driver Sweeper.
Both methods achieve the same results. This method is always able to clean all files.
This method will delete remaining files upon reboot (if deleting failed). You can clean your drivers this way:
Use the official uninstaller(s) of the driver(s) you want to uninstall.
Reboot your PC in Safe Mode.
Run Driver Sweeper and select what to clean.
Analyse lists all the entries possible to remove, cleaning removes the entries selected.
More drivers can be selected for the same cleaning process.
Staro 19.04.2012., 13:47   #26
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,558
Neznam, nisam nikad isao sejf mod i nije bilo problema.
Staro 19.04.2012., 13:49   #27
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,391
preporučljivo je, pogotovo ako baš imaš problema sa driverima otić u safe mode i tamo clean napravit.
a sad ivica to što nemožeš u safe mode je dodatan problem
Staro 19.04.2012., 13:55   #28
Ivica121
Ivica121's Avatar
Postovi: 71
E ušo sam u Safe mode, probao sam s USB tipkovnicom i sad ulazi bez problema. Stara Tipkovnica nije radila dobro. Evo napravio sam kak si rekao i zasad sve radi super. Sad ćemo vidjet kak će radit. So far so good.
Hvala puno!
EDIT: Ako nekome neće zaći pomoću tipke f8 neka napravi ovo i radi 100%.
http://www.howtogeek.com/howto/windo...ng-the-f8-key/
Zadnje izmijenjeno od: Ivica121. 19.04.2012. u 14:21.
Staro 19.04.2012., 16:37   #29
Ivica121
Ivica121's Avatar
Postovi: 71
Zasad Driveri rade bez rušenja. Ak se ova metoda pokaže dobra, odasd ću svake drivere prvo maket iz safe moda s sweeperom pa onda stavljat nove.
Staro 19.04.2012., 16:51   #30
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,558
Nemoras, ako ti sad ovi rade dobro, radit ce ti i presnimljeni preko njih.Problem je ako te prvi snimljeni zayebavaju 99% ce te i presnimljeni zayebavat.
