Staro 03.04.2012., 21:45   #331
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,538
Sto nisu rekli da izlazi krajem godine? Ili sam ja nesto krivo procitao...?
Staro 03.04.2012., 21:48   #332
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,493
pa piše Q3, znači tako rujan/listopad
Staro 03.04.2012., 23:15   #333
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Predaleko je to. Do tad ce se vec fino nagustat sa nekom bijesnom gtx 680. Onda i kad dode cu htjet neki bolji model pa cekat i to.
Evo i navodne spec. i cijena gtx 670Ti.
4 Graphics Processing Cores (GPCs), 7 Streaming Multiprocessors (SMX)
1344 CUDA cores
112 Texture Memory Units (TMUs), 32 Raster Operation Processors (ROPs)
256-bit wide GDDR5 memory interface
Around 900 MHz base core clock, boost clock and feature availability not known
Around 1250 MHz (5.00 GHz GDDR5 effective) memory clock, around 160 GB/s memory bandwidth
Estimated price US $349-399
Zadnje izmijenjeno od: MAGARAC. 05.04.2012. u 23:21.
Staro 10.04.2012., 00:28   #334
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Neznam jel dobro mjesto za pitati ali me buni ovaj FXAA. : shader-based anti-aliasing technology available from the NVIDIA Control Panel that enables ultra-fast anti-aliasing in hundreds of PC games. FXAA delivers similar quality to 4x multi-sample antialiasing (MSAA) but is up to 60% faster, enabling substantially higher performance in games.
To znaci da se to u CP mora paliti a u igrama gasiti klasicni AA ili ?
Staro 10.04.2012., 01:52   #335
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Ne moras gasit, trebali bi radit zajedno iako u nekim igrama FXAA gasi MSAA. Mnoge igre ga vec imaju u sebi a najbolje dode kad igra nema nikakav AA.
http://www.guru3d.com/article/gigaby...dition-review/
Zadnje izmijenjeno od: MAGARAC. 10.04.2012. u 02:02.
Staro 10.04.2012., 09:47   #336
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
NVIDIA GK106 GPU Detailed
Following the launch of a couple of more GK104-based SKUs, namely GeForce GTX 670 Ti, and GeForce GTX 670, some time in May; NVIDIA will launch its third (after GK104 and GK107) Kepler architecture-based silicon, codenamed GK106. GK106 will make up sub-$200 SKUs, and succeeds the GF116, on which SKUs such as the GeForce GTX 550 Ti, are based. The GK106 will make up at least one known desktop SKU, called GeForce GTX 660.
Its specifications are listed below.
  • 28 nm, around 210 mm² die-area, Kepler architecture
  • Two Graphics Processing Clusters (GPCs), four Streaming Multiprocessors (SMXs)
  • 768 CUDA cores
  • 64 TMUs, 24 ROPs
  • 192-bit wide GDDR5 memory interface, holding 1.5 GB or 2 GB memory
  • PCI-Express 3.0 bus interface
  • Around 130W TDP
  • Speculated performance comparable to GTX 560 Ti and HD 6950, competitive to Radeon HD 7800 series
http://www.techpowerup.com/163889/NV...-Detailed.html
C L O W N I N G A R O U N D
Staro 10.04.2012., 10:52   #337
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,858
Autor MAGARAC Pregled postova
U Control Panelu pod 3d Settings moraš upaliti FXAA (default je OFF), i onda će ti mijenjati MSAA.
Staro 10.04.2012., 11:27   #338
gnomisa
gnomisa's Avatar
Datum registracije: Feb 2003
Postovi: 1,556
Pa kaj se ne može u većini igara ugasit AA u igri i onda upališ FXAA u nvidia CP-u?
gnomisa je offline   Reply With Quote
Staro 10.04.2012., 21:41   #339
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Autor gnomisa Pregled postova
to i mene zanima ? Dali u igri gasiti njen AA i ostavit samo FXAA ili ?
Staro 10.04.2012., 22:45   #340
Ivo_Strojnica
PRO
Postovi: 4,858
pa pretpostavljam da se gasi njen AA i ostavlja se samo FXAA...
Staro 11.04.2012., 00:10   #341
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Nema veze FXAA sa MSAA u igri i uglavnom rade skupa, bar u novijim igrama. Nije to isto kao ranije kad se trebao ukljucit aa u opcijama da bi se mogao forsat preko drivera, u nekim igrama nego je odvojena stvar koja funkcionira zajedno sa vecinom vrsti aa. Nebi trebao radit zajedno sa supersampelingom.
U pravilu bi trebali iskuljcit MSAA u igri i ukljucit FXAA u driveru koji bi trebao radit u vecini slucajeva. Moze radit zajedno i s MLAA kod AMDa, recimo ako ga igra vec ima a u catalystu se ukljuci MLAA (npr. Mass Efect 3). Sve ovisi o samoj igri u nekima ce FXAA u driveru i iskuljucit MSAA u opijama u drugima nece itd..
Trebat ce uskoro napravit neki vodic za koristenje AA jer ih vec ima malo previse vrsta. MSAA, CSAA, q CSAA, MLAA, TRSSA i ADAA (multisampeling), FXAA, SSAA i jos taj Nvidjin kaj treba doc...
Zadnje izmijenjeno od: MAGARAC. 11.04.2012. u 00:51.
Staro 11.04.2012., 15:17   #342
Full Throttle
Full Throttle's Avatar
Datum registracije: Dec 2009
Lokacija: Zagorje
Postovi: 873
ja sam u bf3 ostavio 4 x msaa i 16 x fxaa, a u nvidia cp sam namjestio sljedeće:
to mi zasad izgleda najbolje i nema pada fps-a. sad dal je to dobro namješteno, neznam
Full Throttle je offline   Reply With Quote
Staro 11.04.2012., 16:50   #343
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Nisi nista namjestio samo si sve stavio na max a nista od toga ne radi u BF3. Da i radi nebi ti ni gtx 680 pomogla da imas igriv fps a sa svojom bi mozda imao 5,6 fps u prosjeku..
Ne radi to u svim igrama i to pitanje gdje, sto i kako je dosta relativno jer ovisi od igre do igre. Ja recimo volim tak sve ukljucit ak igram neku staru igru, GTR 2 ili sl. i onda mi supersamle i aa malo osjvjeze grafiku a u novim igram je ionak vec skoro sve ugradeno i nema potrebe, osim ak se radi o losijim portovima. Dosta igri vec ima po defaultu FXAA, BF3, Crysis 2, Mass Effect 3, DeusX, Skyrim, SS3 i tu nema potebe nista forsat kad se sve moze porihtat iz opcija u igri. Serious Sam recimo ima cuda od aa u opcijama za porihtat po svacijem ukusu, mogucnostima.
Zadnje izmijenjeno od: MAGARAC. 11.04.2012. u 19:01.
Staro 11.04.2012., 18:08   #344
Full Throttle
Lokacija: Zagorje
Postovi: 873
iskreno, to sam si i mislil
stvarno ne kužim na koji način ovo radi
Staro 11.04.2012., 19:47   #345
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,538
1344 CUDA cores
Kad bi mogli ocekivat ovu grafu u nasim ducanima?
Staro 12.04.2012., 12:19   #346
nexusone
Datum registracije: Apr 2008
Postovi: 139
Autor QuidZz Pregled postova
prema nekim informacijama, valjda u 5. mjesecu
nexusone je offline   Reply With Quote
Staro 12.04.2012., 12:27   #347
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,538
Ty
EDIT: Koliko sam ja skuzio GTX 670 Ti bi trebala biti u rangu između HD 7950 i HD 7970?
Zadnje izmijenjeno od: QuidZz. 12.04.2012. u 15:09.
Staro 13.04.2012., 00:14   #348
KorisNick
Datum registracije: Aug 2010
Lokacija: daleko, daleko iza 9 sela, daleko sam ja...
Postovi: 260
Tako je, nešto jača od 7950, te nešto slabija od 7970, ali i jeftinija.
KorisNick je offline   Reply With Quote
Staro 16.04.2012., 17:53   #349
nexusone
Postovi: 139
evo, stigli su driveri u kojima je podržana Geforce 670 kartica:
The driver is intended for:
GeForce GTX 680
GeForce GTX 670
DriverVer = 04/04/2012, 8.17.13.0125
link sa driverima
Valjda se onda približava i izlazaka iste..
EDIT:
NVIDIA Teases Upcoming Product
pitanje je jedino što je to...
Zadnje izmijenjeno od: nexusone. 18.04.2012. u 19:28.
Staro 19.04.2012., 16:17   #350
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,538
NVIDIA To Release GeForce GTX 690 by April 30th
GeForce GTX 690 is dual-core card with 3072 CUDA cores in total. Since it’s based on the same GPU that GTX 680 has it will have two 256-bit bus interface. It would feature 4GB of GDDR5 memory. Card will require 650W power supply through two 8-pin power connectors.
Izvor:
Staro 23.04.2012., 20:52   #351
pci_e3x
Premium spammer
pci_e3x's Avatar
Lokacija: D.Zagora
Postovi: 776
NVIDIA GK110: The True 7-Billion Transistor Kepler GPU
The new 7-billion transistor GPU is probably the full implementation of NVIDIA’s Kepler GK110, the true successor of the GF100 (GTX 480) / GF110 (GTX 580). The GeForce GTX 680 (based on GK104, with only 3.5 billion transistor) is actually the successor of GeForce GTX 460 / GTX 560 (GF104 / GF114). The GK110 will be a monster in GPU computing, which is the weakness of the current GK104 GPU.
What will be the name of the GK110 based graphics card? Maybe the GTX 685 or GTX 780. The GTX 690 is already reserved for the dual GK104 board that should be announced shortly.
http://www.geeks3d.com/20120423/nvid...or-kepler-gpu/
Staro 25.04.2012., 12:10   #352
nexusone
Postovi: 139
Nvidia might launch GTX 670 as well
Dakle, vele da bi GTX 670 kartica trebala stici sa GTX 690 karticom.
Staro 29.04.2012., 08:47   #353
Wozniak jR.
humanware
Wozniak jR.'s Avatar
Datum registracije: Mar 2009
Lokacija: zGb
Postovi: 456
NVIDIA unleashes GeForce GTX 690 graphics card, loads it with dual Kepler GPUs, charges $1k
http://www.engadget.com/2012/04/29/N...medium=twitter
Wozniak jR. je offline   Reply With Quote
Staro 05.05.2012., 10:15   #354
Starsylph
Datum registracije: Oct 2010
Lokacija: Sfera
Postovi: 408
Kada dolaze kod nas u dućane Kepler gtx 640/650/660 ?
Starsylph je offline   Reply With Quote
Staro 05.05.2012., 11:58   #355
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Čekaj malo, trebaju prvo i službeno izmigoljiti na svjetlo dana.
Koliko sam upućen u glasine, GTX 640 i 650 trebale bi se pojaviti idući tjedan. No glasine su ipak glasine, tako je po njima GTX 660 već trebala ugledati svjetlo dana a GTX 690 se trebala pojaviti u trećem kvartalu ove godine
No u svakom slučaju, valjda će doći ovaj mjesec ili idući, mora Nvidia popuniti ponudu i za ostale tržišne segmente.
Link 1
Link 2
Link 3
MBO: MSI 760GM-E51 FX
VGA: Nvidia Quadro K600
SSD: Crucial BX500 1TB
Staro 16.05.2012., 13:04   #356
nexusone
Postovi: 139
Evo i nešto detalja o velikome kepleru.
GK 110 -- "Big Kepler" Here's what we know:
7.1 Billion Transistors
2880 Shader processors
15 SMX (shader engines with 192 Shader-ALUs)
384-Bit wide GDDR5 memory bus
6-Pin & 8-Pin power connectors for Tesla K20-cards
3x higher double precision
Evo i linka.
Staro 17.05.2012., 14:17   #357
Vendetta
Vendetta's Avatar
Postovi: 919
Neloše
Vendetta je offline   Reply With Quote
Staro 17.05.2012., 17:32   #358
sapunko_HR
Datum registracije: Oct 2011
Lokacija: _
Postovi: 277
sapunko_HR je offline   Reply With Quote
Staro 17.05.2012., 18:32   #359
ethan
Lokacija: Zagreb (centar)
Postovi: 190
Dal Nvidia namjerava taj GK110 stavit u obicne kartice ili je to samo za Teslu i Quadro?
ethan je offline   Reply With Quote
Staro 17.05.2012., 18:42   #360
nexusone
Postovi: 139
Autor ethan Pregled postova
pa vjerojatno hoce, ali kada se za tim ukaze potreba. najvjerojatnije ce to biti kad AMD najavi nesto tipa Radeon HD8970, pa ce taj cip staviti valjda u karticu imena GTX780
